FL13NN
FL13NN
    EOZ
    EOZ - FL13NN - Industrial Pushbutton Switch, IP67, FL, 13.5 mm, SPST-NO, Momentary, Round Domed, Bla...
FL13NN 数据手册
the FL.series range, the first 12mm / 13mm push button in the world with a fully illuminated lens. Available in 12 mm and 13.5 mm standard mounting hole sizes, a unique high brightness full face illuminated switch and a non-illuminated version as a plug-in replacement for competitor products. Designed and manufactured in France with IP67 sealing and rugged PA6.6 polyamide construction the FL.series has superb tactile feedback and vibrant single or bi-colour multi-LED illumination. Mechanical Total travel Operating force Panel thickness Part numbers Non-illuminated 2 mm ±0.3mm 5 N ±30% 1 - 6 mm (max) Ø13.5 Terminal type Plug-in terminal 2.8 x 0.5 mm Switching action Momentary Torque 0.3 Nm Mechanical Life (CEI 60542-5 9b) 1,000,000 cycles (max) Electrical Dielectric strength Insulation resistance (CEI 60512-2 3a) Contact resistance (CEI 60512-2 2a) Travel contact 2500 VAC 1GΩ < 50mΩ (max) 1.2 mm ±0.3mm 125mA at 125 VAC resistive 300°C max. for 3 seconds Lighting Black Blue Green Orange Red White Yellow Ø13.5 Ø12 Cap FL13LB5 FL13LG5 FL13LO5 FL13LR5 FL13LW5 FL13LY5 FL12LB5 FL12LG5 FL12LO5 FL12LR5 FL12LW5 FL12LY5 Blue Green Orange Red White Yellow Dual-color illuminated Ø13.5 Ø12 Cap Illumination color FL13DGB5 FL13DRB5 FL13DRG5 FL12DGB5 FL12DRB5 FL12DRG5 Milky white Milky white Milky white Blue or Green* Blue or Red* Green or Red* *Inverted polarity Voltage 5V Materials It is possible to lower the voltage until 2.7V «min» to lower the luminous intensity. Current LED Cap FL12NN FL12NB FL12NG FL12NO FL12NR FL12NW FL12NY illuminated Electrical Life (CEI 60542-5 9a) 500,000 cycles Current rating (typical) (CEI 60542-5 10a) 400mA at 32 VAC resistive 100mA at 50 VDC resistive Weld at the soldering iron: Ø12 FL13NN FL13NB FL13NG FL13NO FL13NR FL13NW FL13NY 65 mA (max) Environmental IK impact resistance. (EN 50102) IK6 (front face) Ingress protection (DIN EN IEC60529) IP67 (front face) Operating temperature (CEI 60512-6) -40°C to +85°C Storage temperature (CEI 60512-6) -40°C to +105°C Saline mist 48 hours Cyclic temperature / humidity test «Z/AD» (CEI 6068-2-38) 240 hours (cycles of -10°C in 65°C / 93% humidity) Body PA 6.6 Button PC Contacts Gold plated nickel Contacts terminals Gold plated nickel LED terminals Silver plated nickel www.eozonline.com Ø13.5mm Product Drawings Panel Cut Out Ø12mm Product Drawings Panel Cut Out Terminal version: Terminal contact Terminal led 2016EOZ039 ind 2.2 Non-illuminated Diagram Illuminated 1 NO www.eozonline.com
FL13NN 价格&库存
很抱歉,暂时无法提供与“FL13NN”相匹配的价格&库存,您可以联系我们找货
FL13NN
    库存:14
