FP6185-18S5
FP6185-18S5
    FITIPOWER(天鈺科技)
    SOT23-5
    1.8V 300MA 5.5V
FP6185-18S5 数据手册
FP6185 85T 300mA, Low Noise High PSRR LDO Regulator Description The FP6185 is a low dropout, low noise, high PSRR, very low quiescent current positive linear regulator. The FP6185 can supply 300mA output current with low dropout voltage at about 400mV that optimized for battery-powered systems or portable wireless devices such as mobile phones. The shutdown function can provide remote control for the external signal to decide the on/off state of FP6185 that consumes less than 0.1µA during shutdown mode. The FP6185 regulator is able to operate with output capacitors as small as 1µF for stability. Other than the current limit protection, FP6185 also offers the on chip thermal shutdown feature providing protection against overload or any condition when the ambient temperature exceeds the maximum junction temperature. The FP6185 offers high precision output voltage of 2%.The FP6185 is available in SOT-23-5 package which features small size. Features              * 1. Attention should be paid to the power dissipation of the package when the output current is large. Applications     FP6185-Preliminary 0.3-JUN-2017 Low VIN and Wide VIN Range: 2V to 5.5V Output Current 300mA*1 2% Output Voltage Accuracy Output Noise 65μVrms from 10Hz to 100kHz VOUT Fixed 1.0V to 3.3V Low Dropout Voltage of 400mV at 300mA Ripple Rejection 75dB at 1KHz Very Low Quiescent Current at 35µA Needs Only 1µF Capacitor for Stability Thermal Shutdown Protection Current Limit Protection SOT-23-5 Package RoHS Compliant PDAs, Mobile phones, GPS, Smartphones Wireless Handsets, Wireless LAN, Bluetooth® , Zigbee® Portable Medical Equipment Other Battery Powered Applications 1 FP6185 85T Pin Assignment Ordering Information FP6185-□□ S5 Package (SOT-23-5) VOUT Package Type S5: SOT-23-5 NC Output Voltage 11: 1.1V 12: 1.2V 15: 1.5V 18: 1.8V 25: 2.5V 27: 2.7V 28: 2.8V 29: 2.9V 30: 3.0V 33: 3.3V 5 4 (Marking) 1 2 3 VIN GND SHDN Figure 1. Pin Assignment of FP6185 Marking Information Part Number Product Code FP6185-11S5 FU4 FP6185-12S5 FD8 FP6185-15S5 FD9 FP6185-18S5 FE1 FP6185-25S5 FU5 FP6185-27S5 FU6 FP6185-28S5 FE3 FP6185-29S5 FE2 FP6185-30S5 FU7 FP6185-33S5 FE4 Note: Please consult Fitipower sales office or authorized distributors for availability of special output voltages. FP6185-Preliminary 0.3-JUN-2017 2 FP6185 85T Typical Application Circuit VIN VIN CIN 1µF GND VSHDN VOUT VOUT COUT 1µF FP6185 SHDN NC Figure 2. Typical Application Circuit of FP6185 Note: To prevent oscillation, it is recommended to use minimum 1µF X7R or X5R dielectric capacitors if ceramics are used as input/output capacitors. Functional Pin Description Pin Name Pin No. Pin Function VIN 1 Power is supplied to this device from this pin which is required an input filter capacitor. In general, the input capacitor in the range of 1µF to 10µF is sufficient. GND 2 Common ground pin. 3 Pull this pin high to enable IC, pull this pin low to shutdown IC. Floating this pin will be shutdown due to the built-in pull-low resistor. NC 4 No connection. VOUT 5 The FP6185 is stable with an output capacitor 1µ F or greater. The larger output capacitor will be required for application with larger load transients. The large output capacitor could reduce output noise, improve stability and PSRR. Block Diagram RSEN PMOS VIN VOUT Current Limit SHDN Power Shutdown _ Error Amp R1 + 5MΩ Thermal Shutdown Vref R2 GND Figure 3. Block Diagram of FP6185 FP6185-Preliminary 0.3-JUN-2017 3 FP6185 Absolute Maximum Ratings (Note 1) 85T ● Supply Voltage VIN ---------------------------------------------------------------------------------------- -0.3V to +6.5V ● EN Voltage VEN -------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V ● Power Dissipation @ TA=25°C & TJ=125°C (PD) SOT-23-5 ---------------------------------------------------------------------------------------- 0.4W ● Package Thermal Resistance (θJA) (Note 2) SOT-23-5 ---------------------------------------------------------------------------------------- 250°C/W ● Package Thermal Resistance (θJC) SOT-23-5 ---------------------------------------------------------------------------------------- 130°C/W ● Lead Temperature (Soldering, 10sec.) -------------------------------------------------------------- +260°C ● Junction Temperature (TJ) ------------------------------------------------------------------------------ -40°C to +150°C ● Storage Temperature (TSTG) ---------------------------------------------------------------------------- -65°C to +150°C Note 1: Stresses beyond this listed under “Absolute Maximum Ratings" may cause permanent damage to the device. Note 2: θJA is measured at 25°C ambient with the component mounted on a high effective thermal conductivity 4-layer board of JEDEC-51-7. The thermal resistance greatly varies with layout, copper thickness, number of layers and PCB size. Recommended Operating Conditions ● VIN Supply Voltage --------------------------------------------------------------------------------------- +2V to +5.5V ● Output Current (IOUT) ------------------------------------------------------------------------------------- 0mA to 300mA ● Operating Temperature Range (TOPR) --------------------------------------------------------------- -40°C to +85°C ● Operating Junction Temperature Range (TJ) ------------------------------------------------------- -40°C to +125°C FP6185-Preliminary 0.3-JUN-2017 4 FP6185 85T Electrical Characteristics (VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified) Parameter Symbol Input Voltage Range Current Limit VIN RLoad=1Ω IQ IOUT=0mA ISTBY Output Voltage Accuracy Dropout Voltage Dropout Voltage (Note 3) (Note 3) VOUT VDROP VDROP Min Typ 2 ILIMIT Quiescent Current Standby Current Conditions 5.5 V mA 35 IOUT=1mA IOUT=300mA Unit 320 0.1 Pin Connected to GND IOUT=150mA Max -2 µA 1 µA +2 % VOUT=1.2V 800 1200 VOUT=1.5V 600 900 VOUT=1.8V 475 700 VOUT=2.5V 275 400 VOUT=2.7V 250 350 VOUT=3.0V 225 325 VOUT=3.3V 200 300 VOUT=1.2V 1550 2300 VOUT=1.5V 950 1400 VOUT=1.8V 750 1100 VOUT=2.5V 550 800 VOUT=2.7V 500 700 VOUT=3.0V 450 650 VOUT=3.3V 400 600 mV mV VLINE IOUT=1mA, VIN=VOUT +1V to 5V 1 8 mV Load Regulation (Note 4) VLOAD IOUT=0mA to 300mA 6 30 mV Ripple Rejection (Note 5) PSRR Line Regulation Output Noise Voltage (Note 5) VNOISE Temperature Coefficient TC (Note 5) Output Discharge Resistance Pin Current FP6185-Preliminary 0.3-JUN-2017 IOUT=1mA, VIN=5V TSD Thermal Shutdown Threshold (Note 5) VIN=VOUT+1VDC+0.2VP-P(AC), fRIPPLE=1KHz,VOUT≧1.8V, IOUT=30mA COUT=1μF, IOUT=0mA BW=10Hz ~ 100KHz 75 dB 65 μVRMS 100 ppm/ºC 145 ºC TSD Hysteresis 25 ºC RDIS V =0V 60 Ω I V =2.5V 0.3 uA 5 FP6185 85T Electrical Characteristics (Continued) (VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified) Parameter Pin Threshold Symbol Conditions V ( Start-up V ( FF Shutdown Min Typ Max 1.0 Unit V 0.4 V Note 3: The dropout voltage is defined as VIN-VOUT, which is measured when VOUT drops 2% of its normal value with the specified output current. Note 4: Load regulation and dropout voltage are measured at a constant junction temperature by using a 40ms low duty cycle current pulse. Note 5: Guarantee by design. FP6185-Preliminary 0.3-JUN-2017 6 FP6185 85T Typical Performance Curves VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified VOUT=3.3V, IOUT=0mA VOUT=3.3V, IOUT=0mA VSHDN 2V/div VSHDN 2V/div VOUT 2V/div VOUT 2V/div 20us/div 80us/div Figure 4. Turn ON Waveform Figure 5. Turn OFF Waveform VOUT=1.5V, IOUT=0mA VOUT=1.5V, IOUT=0mA VSHDN 2V/div VSHDN 2V/div VOUT 1V/div VOUT 1V/div 20us/div 80us/div Figure 6. Turn ON Waveform Figure 7. Turn OFF Waveform 3.3VOUT/IOUT=1mA300mA1mA 1.5VOUT/IOUT=1mA300mA1mA VOUT 100mV/div VOUT 100mV/div IOUT 100mA/div IOUT 100mA/div 40us/div 40us/div Figure 8. Load Transient Response Figure 9. Load Transient Response FP6185-Preliminary 0.3-JUN-2017 7 FP6185 85T Typical Performance Curves (Continued) VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified VOUT=3.3V/10mA, CIN=none VOUT=1.5V/10mA, CIN=none VIN 1V/div VIN 1V/div VOUT 50mV/div VOUT 50mV/div 40us/div 40us/div Figure 10. Line Transient Response Figure 11. Line Transient Response IOUT=1mA Figure 12. Output Voltage vs. Input Voltage VIN=5V IOUT=1mA Figure 13. Output Voltage vs. Input Voltage VIN=3.3V Figure 14. Output Voltage vs. Output Current FP6185-Preliminary 0.3-JUN-2017 Figure 15. Output Voltage vs. Output Current 8 FP6185 85T Typical Performance Curves (Continued) VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified VOUT=3.3V Figure 16. Dropout Voltage vs. Output Current IOUT=1mA Figure 18. Output Voltage vs. Temperature VIN=4.3V, VOUT=3.3V Figure 20. Quiescent Current vs. Temperature FP6185-Preliminary 0.3-JUN-2017 VOUT=1.5V Figure 17. Dropout Voltage vs. Output Current IOUT=1mA Figure 19. Output Voltage vs. Temperature VIN=2.5V, VOUT=1.5V Figure 21. Quiescent Current vs. Temperature 9 FP6185 85T Typical Performance Curves (Continued) VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified VOUT=3.3V, VSHDN=0V VOUT=1.5V, VSHDN=0V Figure 22. Shutdown Current vs. Temperature VOUT=3.3V, IOUT=0mA Figure 23. Shutdown Current vs. Temperature VOUT=1.5V, IOUT=0mA VOUT 50uV/div VOUT 50uV/div 10ms/div Figure 24. Output Noise Voltage FP6185-Preliminary 0.3-JUN-2017 10ms/div Figure 25. Output Noise Voltage 10 FP6185 85T Application Information The FP6185 is a low dropout linear regulator that could provide 300mA output current at dropout voltage about 400mV. Current limit and on chip thermal shutdown features provide protection against any combination of overload or ambient temperature that could exceed maximum junction temperature. 1. Output and Input Capacitor The FP6185 regulator is designed to be stable with a wide range of output capacitors. The ESR of the output capacitor affects stability. Larger value of the output capacitor decreases the peak deviations and improves transient response for larger current changes. The capacitor types (aluminum, ceramic, and tantalum) have different characterizations such as temperature and voltage coefficients. All ceramic capacitors are manufactured with a variety of dielectrics, each with different behavior across temperature and applications. Common dielectrics used are X5R, X7R and Y5V. It is recommended to use 1µF to 10µF X5R or X7R dielectric ceramic capacitors with 30m to 50m ESR range between device outputs and ground for stability. The FP6185 is designed to be stable with low ESR ceramic capacitors and higher values of capacitors and ESR could improve output stability. The ESR of output capacitor is very important because it generates a zero to provide phase lead for loop stability. 2. Protection Features In order to prevent overloading or thermal condition from damaging the device, FP6185 has internal thermal and current limiting functions designed to protect the device. It will rapidly shut off PMOS pass element during over-temperature condition. 3. Thermal Consideration The power handling capability of the device will be limited by allowable operation junction temperature (125ºC). The power dissipated by the device will be estimated by PD=IOUT(VIN-VOUT). The power dissipation should be lower than the maximum power dissipation listed in “Absolute Maximum Ratings” section. 4. Shutdown Operation The FP6185 is shutdown by pulling the input low, and turned on by driving the high. If pin floating, the FP6185 will shut down because pin has built-in a pull low resistor (refer to Block Diagram). There are no requirements for the ESR on the input capacitor, but its voltage and temperature coefficient have to be considered for device application environment. FP6185-Preliminary 0.3-JUN-2017 11 FP6185 85T Outline Information SOT-23-5 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Note: Followed From JEDEC MO-178-C. Carrier Dimensions Life Support Policy Fitipower’s products are not authorized for use as critical components in life support devices or other medical systems. FP6185-Preliminary 0.3-JUN-2017 12
