FP6146-12S5GTR
FP6146-12S5GTR
    FITIPOWER(天鈺科技)
    SOT23-5
    1.2V 300MA 5V
FP6146-12S5GTR 数据手册
FP6146 fitipower integrated technology lnc. 300mA Low Noise High PSRR 85T LDO with Shutdown Description Features The FP6146 is a low dropout, low noise, high PSRR, very low quiescent current positive linear regulator. The FP6146 can supply 200mA output current with low dropout voltage at about 300mV that optimized for battery-powered systems or portable wireless devices such as mobile phones. The shutdown function can provide remote control for the external signal to decide the on/off state of FP6146 that consumes less than 0.1µA during shutdown mode.     The FP6146 regulator is able to operate with output capacitors as small as 1µF for stability. Other than the current limit protection, FP6146 also offers the on chip thermal shutdown feature providing protection against overload or any condition when the ambient temperature exceeds the maximum junction temperature.          Low Dropout Voltage of 300mV at 200mA Low 30μVrms Output Noise Guaranteed 300mA Output Current High Power Supply Rejection Ratio of 70dB at 10kHz Very Low Quiescent Current at 35µA Max. 2% Output Voltage Accuracy Needs Only 1µF Capacitor for Stability Fast Response in Line/Load Transient Thermal Shutdown Protection Current Limit Protection Low-ESR Ceramic Capacitor for Output Stability Miniature Packages: SOT-23-3, SOT-23-5, TSOT-23-5, TDFN-6 (1.6mm×1.6mm), SC-82-4 and SC-70-5 RoHS Compliant The FP6146 offers high precision output voltage of 2%. It is housed in low-profile, space-saving SOT-23-3, SOT-23-5, TSOT-23-5, TDFN-6 (1.6mm×1.6mm), SC-82-4 and SC-70-5 packages. Applications Pin Assignments Ordering Information S5 Package (SOT-23-5) FP6146-□□□□ VOUT NC 5 4      Mobile Phones Notebook, Sub-Notebook and Tablet Computers DSC Portable Information Appliances Battery Power Systems TR: Tape/Reel G: Green 1 2 3 VIN GND SHDN S3 Package (SOT-23-3) VIN 3 FP6146-2.1-APR-2014 1 2 GND VOUT Package Type S3: SOT-23-3 S5: SOT-23-5 S8: TSOT-23-5 WD: TDFN-6 (1.6mm×1.6mm) C8: SC-82-4 C5: SC-70-5 Output Voltage 11: 1.1V 27: 2.7V 12: 1.2V 28: 2.8V 15: 1.5V 30: 3.0V 18: 1.8V 31: 3.1V 25: 2.5V 33: 3.3V 26: 2.6V 36: 3.6V Note 1: Please consult Fitipower sales office or authorized distributors for availability of special output voltages. 1 FP6146 fitipower integrated technology lnc. Part Number NC VOUT FP6146-12S3G 5 1 2 4 SOT-23-5 Marking 3 Part Number VIN GND SHDN WD Package TDFN-6 (1.6mm×1.6mm) VOUT 1 NC 2 GND 3 GND 6 VIN 5 NC 4 SHDN C8 Package (SC-82-4) VIN VOUT 4 3 1 2 GND SHDN C5 Package (SC-70-5) Product Code FB8 Part Number Product Code FP6146-11S5G Product Code FH9 FP6146-27S5G Product Code B6G FP6146-12S5G H2= FP6146-28S5G H6= FP6146-15S5G H3= FP6146-30S5G H7= FP6146-18S5G H4= FP6146-31S5G t3G FP6146-25S5G H5= FP6146-33S5G H8= FP6146-26S5G r5= FP6146-36S5G a2G Part Number TSOT-23-5 Marking FP6146-12S8G Product Code H9= FP6146-28S8G Product Code K3= FP6146-15S8G H0= FP6146-30S8G K4= FP6146-18S8G K1= FP6146-31S8G t4G FP6146-25S8G K2= FP6146-33S8G K5= FP6146-26S8G r6= FP6146-36S8G a3G Part Number Part Number TDFN-6 (1.6mm×1.6mm) Marking FP6146-12WDG Product Code f FP6146-28WDG Product Code m FP6146-15WDG h FP6146-30WDG n FP6146-18WDG i FP6146-31WDG g FP6146-25WDG k FP6146-33WDG r FP6146-26WDG B- FP6146-36WDG s Part Number Part Number SC-82-4 Marking VOUT NC 5 4 1 85T SOT-23-3 Marking S8 Package (TSOT-23-5) 2 3 FP6146-12C8G Product Code T1= FP6146-28C8G Product Code T5= FP6146-15C8G T2= FP6146-30C8G T6= FP6146-18C8G T3= FP6146-31C8G t5G FP6146-25C8G T4= FP6146-33C8G T7= FP6146-26C8G r4= FP6146-36C8G a1G Part Number Part Number VIN GND SHDN SC-70-5 Marking Figure 1. Pin Assignment of FP6146 FP6146-2.1-APR-2014 FP6146-12C5G Product Code a5G FP6146-28C5G Product Code A1G FP6146-15C5G a6G FP6146-30C5G A2G FP6146-18C5G a7G FP6146-31C5G A3G FP6146-25C5G a8G FP6146-33C5G A4G FP6146-26C5G a9G FP6146-36C5G A5G Part Number Part Number 2 FP6146 fitipower integrated technology lnc. 85T Typical Application Circuit VIN VIN CIN 1µF GND VSHDN SHDN VOUT VOUT COUT 1µF FP6146 NC Figure 2. Typical Application Circuit of FP6146 Note 2: To prevent oscillation, it is recommended to use minimum 1µF X7R or X5R dielectric capacitors if ceramics are used as input/output capacitors. Functional Pin Description Pin Name VIN VOUT NC GND Pin Function Power is supplied to this device from this pin which is required an input filter capacitor. In general, the input capacitor in the range of 1µF to 10µF is sufficient. The output supplies power to loads. The output capacitor is required to prevent output voltage from oscillation. The FP6146 is stable with an output capacitor 1µF or greater. The larger output capacitor will be required for application with larger load transients. The large output capacitor could reduce output noise, improve stability and PSRR. No connection Common ground pin Pull this pin high to enable IC, Pull this pin low to shutdown IC. Floating this pin will be shutdown due to the built-in pull-low resistor. FP6146-2.1-APR-2014 3 FP6146 fitipower integrated technology lnc. 85T Block Diagram RSEN PMOS VIN VOUT Current Limit SHDN Power Shutdown _ Error Amp R1 + 5MΩ Thermal Shutdown Vref R2 GND Figure 3. Block Diagram of FP6146 FP6146-2.1-APR-2014 4 fitipower integrated technology lnc. FP6146 Absolute Maximum Ratings ● VIN, 85T to GND --------------------------------------------------------------------------------------------- +6V ● Power Dissipation @TA =25ºC, (PD) SOT-23-3 ------------------------------------------------------------------------------------------------- +0.4W SOT-23-5 ------------------------------------------------------------------------------------------------- +0.4W TSOT-23-5 ----------------------------------------------------------------------------------------------- +0.4W TDFN-6 (1.6mm×1.6mm) ---------------------------------------------------------------------------- +0.63W SC-82-4 -------------------------------------------------------------------------------------------------- +0.2W SC-70-5 -------------------------------------------------------------------------------------------------- +0.3W ● Package Thermal Resistance, (θJA) SOT-23-3 ------------------------------------------------------------------------------------------------- +250ºC/W SOT-23-5 ------------------------------------------------------------------------------------------------- +250ºC/W TSOT-23-5 ----------------------------------------------------------------------------------------------- +250ºC/W TDFN-6 (1.6mm×1.6mm) ---------------------------------------------------------------------------- +160ºC/W SC-82-4 -------------------------------------------------------------------------------------------------- +500ºC/W SC-70-5 -------------------------------------------------------------------------------------------------- +330ºC/W ● Maximum Junction Temperature (TJ) ------------------------------------------------------------------------ +150ºC ● Storage Temperature Range (TSTG) -------------------------------------------------------------------------- -65ºC to +150ºC ● Lead Temperature (Soldering, 10 sec.) (TLEAD) ------------------------------------------------------------ +260ºC Note 3: tresses beyond those listed under “Absolute Maximum Ratings" may cause permanent damage to the device. Recommended Operating Conditions ● Input Voltage (VIN) ------------------------------------------------------------------------------------------------ +2.0V to +5.5V ● Operating Temperature Range (TOPR) ----------------------------------------------------------------------- -40ºC to +85ºC FP6146-2.1-APR-2014 5 FP6146 fitipower integrated technology lnc. 85T Electrical Characteristics (VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified) Parameter Symbol Current Limit ILIMIT RLoad=1Ω IQ IOUT=0mA Quiescent Current Standby Current ISTBY VOUT Output Voltage Accuracy Conditions Min Typ Max 300 Pin Connected to GND IOUT=1mA Unit mA 35 60 µA 0.1 1 µA +2 % -2 VOUT=1.2V 1100 1300 VOUT=1.5V 910 1100 VOUT=1.8V 750 900 VOUT=2.5V 500 600 VOUT=3.0V 270 330 VOUT=3.3V 230 270 VOUT=1.2V 1950 2300 VOUT=1.5V 1600 1920 VOUT=1.8V 1450 1750 VOUT=2.5V 980 1170 VOUT=3.0V 510 610 VOUT=3.3V 400 480 IOUT=150mA Dropout Voltage (Note4) VDROP mV IOUT=300mA Line Regulation VLINE IOUT=1mA, VIN=VOUT +1V to 5V 1 8 mV Load Regulation (Note5) VLOAD IOUT=0mA to 150mA 6 30 mV Ripple Rejection (Note6) PSRR VIN=VOUT+1V, fRIPPLE = 10kHz 70 dB Output Noise Voltage (Note6) VNOISE COUT=1μF, IOUT=0mA 30 μVRMS IOUT=1mA, VIN=5V 100 ppm/ºC 145 ºC 25 ºC 5 MΩ Temperature Coefficient (Note6) TC TSD Thermal Shutdown Threshold (Note6) Pull-Low Resistance Pin Threshold TSD Hysteresis R V ( Start-up V ( FF Shutdown 1.0 V 0.4 V Note 4: The dropout voltage is defined as VIN-VOUT, which is measured when VOUT drops 2% of its normal value with the specified output current. Note 5: Load regulation and dropout voltage are measured at a constant junction temperature by using a 40ms low duty cycle current pulse. Note 6: Guarantee by design. FP6146-2.1-APR-2014 6 FP6146 fitipower integrated technology lnc. 85T Typical Performance Curves 50 50 VOUT=2.8V CIN=1uF COUT=1uF VOUT=1.8V CIN=1uF COUT=1uF 45 Quiescent Current (uA) Quiescent Current (uA) 45 40 35 30 40 35 30 3.0 3.5 4.0 4.5 5.0 5.5 6.0 3.0 3.5 4.0 Figure 4. Quiescent Current vs. Input Voltage 5.5 6.0 750 VIN=4V VOUT=2.5V CIN=COUT=1uF 700 Current Limit (mA) Current Limit (mA) 5.0 Figure 5. Quiescent Current vs. Input Voltage 750 700 4.5 Input Voltage (V) Input Voltage (V) 650 600 550 VIN=4V VOUT=1.8V CIN=COUT=1uF 650 600 550 500 500 450 450 -25 0 25 50 75 100 125 -25 Figure 6. Current Limit vs. Temperature VIN=2.8V, VOUT=1.8V, IOUT=1mA to 100mA 50 75 100 125 Figure 7. Current Limit vs. Temperature VIN=3.8V, VOUT=2.8V, IOUT=1mA to 100mA VOUT IOUT IOUT FP6146-2.1-APR-2014 25 Temperature ( C) VOUT Figure 8. Load Transition Response 0 0 0 Temperature ( C) Figure 9. Load Transition Response 7 FP6146 fitipower integrated technology lnc. 85T Typical Performance Curves (Continued) VIN=4.3V, VOUT=3.3V, IOUT=1mA to 100mA VOUT VIN=3.5V, VOUT=2.5V, IOUT=1mA to 100mA VOUT IOUT IOUT Figure 10. Load Transition Response VIN=3.8V, VOUT=2.8V, IOUT=1mA to 150mA Figure 11. Load Transition Response VIN=3.8V, VOUT=2.8V, IOUT=0mA to 150mA VOUT VOUT IOUT IOUT Figure 12. Load Transition Response Figure 13. Load Transition Response VIN=4V, VOUT=2.8V, IOUT=100mA VIN=4V, VOUT=2.8V, IOUT=100mA VOUT VOUT Figure 14. Shutdown/Enable Test FP6146-2.1-APR-2014 Figure 15. Shutdown/Enable Test 8 FP6146 fitipower integrated technology lnc. 85T Typical Performance Curves (Continued) VIN=3V4V, VOUT=1.8V, IOUT=10mA VIN=4V5V, VOUT=2.8V, IOUT=10mA VIN VIN VOUT VOUT Figure 16. Line Transition Response Figure 17. Line Transition Response 3.0 2.2 VIN=2.8V VOUT=1.8V CIN=1uF COUT=1uF 2.8 Output Voltage (V) Output Voltage (V) 2.0 VIN=3.5V VOUT=2.5V CIN=1uF COUT=1uF 1.8 1.6 2.6 2.4 2.2 1.4 2.0 -40 -20 0 20 40 60 80 100 120 -40 -20 0 0 40 60 80 100 120 Temperature ( C) Figure 18. Output Voltage vs. Temperature Figure 19. Output Voltage vs. Temperature 55 60 VIN=2.8V CIN=1uF 50 Quiescent Current (uA) COUT=1uF 45 VIN=3.5V VOUT=2.5V CIN=1uF COUT=1uF 55 VOUT=1.8V 50 Quiescent Current(uA) 20 0 Temperature ( C) 40 35 30 25 45 40 35 30 25 20 20 -40 -20 0 20 40 60 80 100 120 0 Temperature( C) Figure 20. Quiescent Current vs. Temperature FP6146-2.1-APR-2014 -40 -20 0 20 40 60 80 100 120 0 Temperature ( C) Figure 21. Quiescent Current vs. Temperature 9 FP6146 fitipower integrated technology lnc. 85T Typical Performance Curves (Continued) 550 450 VOUT=3.3V 400 CIN=1uF 350 COUT=1uF 0 Tj=85 C Dropout Voltage(mV) Dropout Voltage(mV) 500 0 Tj=25 C 300 250 0 Tj=-40 C 200 150 100 500 VOUT=2.8V 450 CIN=1uF 400 COUT=1uF 0 Tj=85 C 0 Tj=25 C 350 300 0 Tj=-40 C 250 200 150 100 50 50 0 0 0 30 60 90 120 150 180 210 240 270 0 300 30 60 90 120 150 180 210 240 270 -80 -80 Power Supply Rejection Ratio(dB) Figure 23. VOUT=2.8V Dropout vs. Temperature Power Supply Rejection Ratio(dB) Figure 22. VOUT=3.3V Dropout vs. Temperature -60 VIN=4V,VOUT=2.8V COUT=2.2uF,No Load -40 -20 300 Loading Current(mA) Loading Current(mA) -60 VIN=4V,VOUT=1.8V COUT=2.2uF, No Load -40 -20 0 0 1 10 100 1000 10000 100000 1000000 Frequency(Hz) Figure 24. Power Supply Rejection Ratio vs. Frequency FP6146-2.1-APR-2014 1 10 100 1000 10000 100000 1000000 Frequency(Hz) Figure 25. Power Supply Rejection Ratio vs. Frequency 10 fitipower integrated technology lnc. 85T Application Information The FP6146 is a low dropout linear regulator that could provide 200mA output current at dropout voltage about 300mV. Current limit and on chip thermal shutdown features provide protection against any combination of overload or ambient temperature that could exceed maximum junction temperature. 1. Output and Input Capacitor The FP6146 regulator is designed to be stable with a wide range of output capacitors. The ESR of the output capacitor affects stability. Larger value of the output capacitor decreases the peak deviations and improves transient response for larger current changes. The capacitor types (aluminum, ceramic, and tantalum) have different characterizations such as temperature and voltage coefficients. All ceramic capacitors are manufactured with a variety of dielectrics, each with different behavior across temperature and applications. Common dielectrics used are X5R, X7R and Y5V. It is recommended to use 1µF to 10µF X5R or X7R dielectric ceramic capacitors with 30m to 50m ESR range between device outputs and ground for stability. The FP6146 is designed to be stable with low ESR ceramic capacitors and higher values of capacitors and ESR could improve output stability. The ESR of output capacitor is very important because it generates a zero to provide phase lead for loop stability. FP6146 2. Protection Features In order to prevent overloading or thermal condition from damaging the device, FP6146 has internal thermal and current limiting functions designed to protect the device. It will rapidly shut off PMOS pass element during over-temperature condition. 3. Thermal Consideration The power handling capability of the device will be limited by allowable operation junction temperature (125ºC). The power dissipated by the device will be estimated by PD=IOUT(VIN-VOUT). The power dissipation should be lower than the maximum power dissipation listed in “Absolute Maximum Ratings” section. 4. Shutdown Operation The FP6146 is shutdown by pulling the input low, and turned on by driving the high. If pin floating, the FP6146 will shut down because pin has built-in a pull low resistor (refer to Block Diagram). There are no requirements for the ESR on the input capacitor, but its voltage and temperature coefficient have to be considered for device application environment. FP6146-2.1-APR-2014 11 FP6146 fitipower integrated technology lnc. 85T Outline Information SOT-23-3 Package (Unit: mm) SYMBOLS UNIT DIMENSION IN MILLIMETER MIN MAX A 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Carrier Dimensions FP6146-2.1-APR-2014 12 FP6146 fitipower integrated technology lnc. 85T Outline Information (Continued) SOT-23-5 Package (Unit: mm) SYMBOLS UNIT DIMENSION IN MILLIMETER MIN MAX A 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Note:Followed From JEDEC MO-178-C. Carrier Dimensions FP6146-2.1-APR-2014 13 FP6146 fitipower integrated technology lnc. 85T Outline Information (Continued) TSOT-23-5 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.70 0.90 A1 0.00 0.10 A2 0.70 1.00 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Carrier Dimensions FP6146-2.1-APR-2014 14 FP6146 fitipower integrated technology lnc. 85T Outline Information (Continued) TDFN-6 (1.6mm×1.6mm) Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.70 0.80 A1 0.00 0.05 A2 0.18 0.25 D 1.55 1.65 E 1.55 1.65 a 0.18 0.30 b 0.18 0.30 e 0.45 0.55 D1 0.95 1.05 E1 0.55 0.65 Carrier Dimensions FP6146-2.1-APR-2014 15 FP6146 fitipower integrated technology lnc. 85T Outline Information (Continued) SC-82-4 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.80 1.10 A1 0.00 0.10 A2 0.80 1.00 B 0.15 0.40 B1 0.35 0.55 D 1.80 2.20 E 1.15 1.35 E1 1.80 2.40 e 1.20 1.40 L 0.25 0.45 Carrier Dimensions FP6146-2.1-APR-2014 16 FP6146 fitipower integrated technology lnc. 85T Outline Information (Continued) SC-70-5 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.90 1.10 A1 0.00 0.10 A2 0.90 1.00 b 0.15 0.35 D 1.80 2.20 E1 1.80 2.40 E 1.15 1.35 e 0.55 0.75 L 0.26 0.46 Carrier Dimensions Life Support Policy Fitipower’s products are not authorized for use as critical components in life support devices or other medical systems. FP6146-2.1-APR-2014 17
FP6146-12S5GTR 价格&库存
很抱歉,暂时无法提供与“FP6146-12S5GTR”相匹配的价格&库存,您可以联系我们找货
FP6146-12S5GTR
    • 5+0.64628
    • 50+0.50631
    • 150+0.43632
    • 500+0.38384
    • 3000+0.34182
    • 6000+0.32076
