FP6185-28S5
FP6185-28S5
    FITIPOWER(天鈺科技)
    SOT23-5
    停产 300MA 5.5V
FP6185-28S5 数据手册
FP6185 85T 300mA, Low Noise High PSRR LDO Regulator Description Features The FP6185 is a low dropout, low noise, high PSRR, very low quiescent current positive linear regulator. The FP6185 can supply 300mA output current with low dropout voltage at about 400mV that optimized for battery-powered systems or portable wireless devices such as mobile phones. The shutdown function can provide remote control for the external signal to decide the on/off state of FP6185 that consumes less than 0.1µA during shutdown mode. The FP6185 regulator is able to operate with output capacitors as small as 1µF for stability. Other than the current limit protection, FP6185 also offers the on chip thermal shutdown feature providing protection against overload or any condition when the ambient temperature exceeds the maximum junction temperature.              Low VIN and Wide VIN Range: 2V to 5.5V Guarantee Output Current 300mA 2% Output Voltage Accuracy Output Noise 65μVrms from 10Hz to 100kHz VOUT Fixed 1.1V to 3.3V Low Dropout Voltage of 400mV at 300mA Ripple Rejection 70dB at 10kHz Very Low Quiescent Current at 35µA Needs Only 1µF Capacitor for Stability Thermal Shutdown Protection Current Limit Protection Miniature Packages: SOT-23-5, UTDFN-4L (1mm×1mm) RoHS Compliant Applications The FP6185 offers high precision output voltage of 2%.The FP6185 is available in SOT-23-5 and UTDFN – 4L (1mmx1mm) packages which features small size.   Pin Assignment Ordering Information   PDAs, Mobile phones, GPS, Smartphones Wireless Handsets, Wireless LAN, Bluetooth® , Zigbee® Portable Medical Equipment Other Battery Powered Applications FP6185-□□ S5 Package (SOT-23-5) VOUT Package Type S5: SOT-23-5 X6: UTDFN-4L NC 5 4 (Marking) 1 2 3 Output Voltage VIN GND SHDN X6 Package (UTDFN-4L)(1mmx1mm) (Top view) VIN SHDN 3 4 UTDFN-4L Marking Part Number Product Code FP6185- EP 1 VOUT 2 GND Figure 1. Pin Assignment of FP6185 FP6185-Preliminary-0.2-Jan-2017 1 FP6185 85T Typical Application Circuit VIN VIN CIN 1µF GND VSHDN VOUT VOUT COUT 1µF FP6185 SHDN NC Figure 2. Typical Application Circuit of FP6185 Note 2: To prevent oscillation, it is recommended to use minimum 1µF X7R or X5R dielectric capacitors if ceramics are used as input/output capacitors. Functional Pin Description PIN NUMBER PIN NAME SOT-23-5 UTDFN-4L 1 4 VIN 5 1 VOUT 4 - NC 2 2 GND 3 3 FUNCTIONS Power is supplied to this device from this pin which is required an input filter capacitor. In general, the input capacitor in the range of 1µ F to 10µ F is sufficient. The FP6185 is stable with an output capacitor 1µF or greater. The larger output capacitor will be required for application with larger load transients. The large output capacitor could reduce output noise, improve stability and PSRR. No connection Common ground pin Pull this pin high to enable IC, pull this pin low to shutdown IC. shutdown due to the built-in pull-low resistor. Floating this pin will be Block Diagram RSEN PMOS VIN VOUT Current Limit SHDN Power Shutdown _ Error Amp R1 + 5MΩ Thermal Shutdown Vref R2 GND Figure 3. Block Diagram of FP6185 FP6185-Preliminary-0.2-Jan-2017 2 FP6185 Absolute Maximum Ratings (Note 1) 85T ● Supply Voltage VIN ----------------------------------------------------------------------------------------- -0.3V to +6.5V ● EN Voltage VEN --------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V ● Power Dissipation @ TA=25°C & TJ=125°C (PD) SOT23-5 ----------------------------------------------------------------------------------------- 0.4W UTDFN-4L(1mmx1mm)----------------------------------------------------------------------- TBD ● Package Thermal Resistance (θJA) (Note 2) SOT23-5 ----------------------------------------------------------------------------------------- +250°C/W UTDFN-4L(1mmx1mm)----------------------------------------------------------------------- TBD ● Package Thermal Resistance (θJC) SOT23-5 ----------------------------------------------------------------------------------------- +130°C/W UTDFN-4L(1mmx1mm)----------------------------------------------------------------------- TBD ● Lead Temperature (Soldering, 10sec.) --------------------------------------------------------------- 260°C ● Junction Temperature (TJ) ------------------------------------------------------------------------------- -40°C to +150°C ● Storage Temperature (TSTG) ----------------------------------------------------------------------------- -65°C to +150°C Note 1:Stresses beyond this listed under “Absolute Maximum Ratings" may cause permanent damage to the device. Note 2:θJA is measured at 25°C ambient with the component mounted on a high effective thermal conductivity 4-layer board of JEDEC-51-7. The thermal resistance greatly varies with layout, copper thickness, number of layers and PCB size. Recommended Operating Conditions ● VIN Supply Voltage ---------------------------------------------------------------------------------------- +2V to +5.5V ● Output Current (IOUT) -------------------------------------------------------------------------------------- 0mA to 300mA ● Operating Temperature Range (TOPR) ---------------------------------------------------------------- -40°C to +85°C ● Operating Junction Temperature Range (TJ) -------------------------------------------------------- -40°C to +125°C FP6185-Preliminary-0.2-Jan-2017 3 FP6185 85T Electrical Characteristics (VIN=VOUT+1V, pin connected to VIN, CIN=1µF, COUT=1µF, TA=25ºC, unless otherwise specified) Parameter Symbol Input Voltage Range VIN Current Limit Quiescent Current Standby Current RLoad=1Ω IQ IOUT=0mA VOUT Dropout Voltage (Note 4) VDROP Dropout Voltage (Note 4) VDROP V mA 0.1 -2 µA 1 µA +2 % VOUT=1.2V 1950 2300 VOUT=1.5V 1600 1920 VOUT=1.8V 1450 1750 VOUT=2.5V 980 1170 VOUT=2.7V 630 760 VOUT=3.0V 510 610 VOUT=3.3V 400 480 VOUT=1.2V 650 767 VOUT=1.5V 533 640 VOUT=1.8V 483 583 VOUT=2.5V 327 390 VOUT=2.7V 210 253 VOUT=3.0V 170 203 VOUT=3.3V 133 160 mV mV 1 8 mV VLOAD IOUT=0mA to 150mA 6 30 mV PSRR (Note 6) VNOISE Temperature Coefficient TC (Note 6) VIN=VOUT+1V, fRIPPLE = 10kHz COUT=1μF, IOUT=0mA BW=10Hz ~ 100KHz IOUT=1mA, VIN=5V TSD Thermal Shutdown Threshold (Note 6) TSD Hysteresis Pin Current Pin Threshold 5.5 35 IOUT=1mA IOUT=100mA Unit 300 Pin Connected to GND IOUT=300mA Max IOUT=1mA, VIN=VOUT +1V to 5V Ripple Rejection (Note 6) Output Noise Voltage Typ VLINE Line Regulation (Note 5) Min 2 ILIMIT ISTBY Output Voltage Accuracy Load Regulation Conditions V ( Start-up V ( FF Shutdown 70 dB 65 μVRMS 100 ppm/ºC 145 ºC 25 ºC 0.3 uA 1.0 V 0.4 V Note 4: The dropout voltage is defined as VIN-VOUT, which is measured when VOUT drops 2% of its normal value with the specified output current. Note 5: Load regulation and dropout voltage are measured at a constant junction temperature by using a 40ms low duty cycle current pulse. Note 6: Guarantee by design. FP6185-Preliminary-0.2-Jan-2017 4 FP6185 85T Application Information The FP6185 is a low dropout linear regulator that could provide 300mA output current at dropout voltage about 400mV. Current limit and on chip thermal shutdown features provide protection against any combination of overload or ambient temperature that could exceed maximum junction temperature. 1. Output and Input Capacitor The FP6185 regulator is designed to be stable with a wide range of output capacitors. The ESR of the output capacitor affects stability. Larger value of the output capacitor decreases the peak deviations and improves transient response for larger current changes. The capacitor types (aluminum, ceramic, and tantalum) have different characterizations such as temperature and voltage coefficients. All ceramic capacitors are manufactured with a variety of dielectrics, each with different behavior across temperature and applications. Common dielectrics used are X5R, X7R and Y5V. It is recommended to use 1µF to 10µF X5R or X7R dielectric ceramic capacitors with 30m to 50m ESR range between device outputs and ground for stability. The FP6185 is designed to be stable with low ESR ceramic capacitors and higher values of capacitors and ESR could improve output stability. The ESR of output capacitor is very important because it generates a zero to provide phase lead for loop stability. 2. Protection Features In order to prevent overloading or thermal condition from damaging the device, FP6185 has internal thermal and current limiting functions designed to protect the device. It will rapidly shut off PMOS pass element during over-temperature condition. 3. Thermal Consideration The power handling capability of the device will be limited by allowable operation junction temperature (125ºC). The power dissipated by the device will be estimated by PD=IOUT(VIN-VOUT). The power dissipation should be lower than the maximum power dissipation listed in “Absolute Maximum Ratings” section. 4. Shutdown Operation The FP6185 is shutdown by pulling the input low, and turned on by driving the high. If pin floating, the FP6185 will shut down because pin has built-in a pull low resistor (refer to Block Diagram). There are no requirements for the ESR on the input capacitor, but its voltage and temperature coefficient have to be considered for device application environment. FP6185-Preliminary-0.2-Jan-2017 5 FP6185 85T Outline Information SOT-23-5 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Note:Followed From JEDEC MO-178-C. Carrier Dimensions FP6185-Preliminary-0.2-Jan-2017 6 FP6185 85T Outline Information (Continued) UTDFN- 4L 1.0mm x 1.0mm (pitch 0.65 mm) Package (Unit: mm) SYMBOLS UNIT A A1 DIMENSION IN MILLIMETER MIN MAX 0.340 0.400 0.00 A3 0.050 0.102REF D 0.950 1.050 E 0.950 1.050 D1 0.430 0.530 E1 0.430 k b 0.180 e L 0.530 0.211REF 0.280 0.650TYP 0.200 0.300 Note:Followed From JEDEC 664-1 Carrier Dimensions Life Support Policy Fitipower’s products are not authorized for use as critical components in life support devices or other medical systems. FP6185-Preliminary-0.2-Jan-2017 7
FP6185-28S5 价格&库存
很抱歉,暂时无法提供与“FP6185-28S5”相匹配的价格&库存,您可以联系我们找货
