FUSB110F
FUSB110F
    FUZETEC(富致)
    插件
FUSB110F 数据手册
FUZETEC TECHNOLOGY CO., LTD. NO. Product Specification and Approval Sheet Version PQ05-101E 9 Page 1/4 Radial Leaded PTC Resettable Fuse: FUSB Series 1. Summary (a) (b) (c) (d) (e) (f) RoHS Compliant (Lead Free) Product Applications: Low voltage USB equipment and Computers & peripherals Product Features: Low resistance, Fast trip time, Low trip-to-hold ratio Operation Current: 0.75A~2.50A Maximum Voltage: 16V/30VDC Temperature Range : -40℃ to 85℃ 2. Agency Recognition UL: File No. E211981 C-UL: File No. E211981 TÜ V: File No. R50004084 3. Electrical Characteristics (23℃) Max.Time Part Hold Trip Current Current Number FUSB075F FUSB090F FUSB110F FUSB120F FUSB135F FUSB155F FUSB160F FUSB185F FUSB250F to Trip Current Time Max. Rated Typ. Current Voltage Power Resistance RMIN R1MAX IH, A IT, A A Sec IMAX, A VMAX, VDC Pd, W Ohms Ohms 0.75 0.90 1.10 1.20 1.35 1.55 1.60 1.85 2.50 1.30 1.80 2.20 2.00 2.70 2.70 3.20 3.70 5.00 8.0 8.0 8.0 8.0 8.0 7.8 8.0 8.0 8.0 0.4 1.2 2.3 0.7 4.5 2.2 9.0 10.0 40.0 40 40 40 40 40 40 40 40 40 16 16/30 16/30 16 16/30 16 16/30 16/30 16/30 0.3 0.6 0.7 0.6 0.8 0.7 0.9 1.0 1.2 0.08 0.07 0.05 0.04 0.04 0.03 0.03 0.03 0.02 0.23 0.18 0.14 0.14 0.12 0.12 0.11 0.09 0.07 IH=Hold current-maximum current at which the device will not trip at 23℃ still air. IT=Trip current-minimum current at which the device will always trip at 23℃ still air. V MAX=Maximum voltage device can withstand without damage at its rated current. I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX). Pd=Typical power dissipated from device when in tripped state in 23℃ still air environment. RMIN=Minimum device resistance at 23℃. R1MAX=Maximum device resistance at 23℃, 1 hour after tripping . Physical specifications: Lead material: Tin plated copper clad steel,24 AWG. Soldering characteristics: Solder ability per ANSI/J-STD 002 Solder heat withstand per IEC 68-2-20 Insulating coating:Flame retardant epoxy polymer, meets UL 94V-0 requirement. NOTE : Specification subject to change without notice. 2019/11/13 NO. FUZETEC TECHNOLOGY CO., LTD. Product Specification and Approval Sheet Version PQ05-101E 9 Page 2/4 4. Production Dimensions (millimeter) Fig.1 Fig.2 Lead Size: 24AWG Lead Size: 24AWG Φ 0.51 mm Diameter Part Φ 0.51 mm Diameter A B C D E F Maximum Maximum Typical Minimum Maximum Typical 6.9 7.4 7.4 6.9 8.9 6.9 8.9 10.2 11.4 11.4 12.2 14.2 11.7 13.5 11.7 15.2 15.7 18.3 5.1 5.1 5.1 5.1 5.1 5.1 5.1 5.1 5.1 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 Fig Number FUSB075F FUSB090F FUSB110F FUSB120F FUSB135F FUSB155F FUSB160F FUSB185F FUSB250F 2 1 1 2 1 2 1 1 1 5. Thermal Derating Curve Precent of Rated Hold and Trip Current FUSB Series 200% 150% 100% 50% 0% -40 -20 0 20 40 60 80 Ambient Temperature (C) NOTE : Specification subject to change without notice. 2019/11/13 NO. FUZETEC TECHNOLOGY CO., LTD. Product Specification and Approval Sheet Version PQ05-101E 9 Page 3/4 6. Typical Time-To-Trip at 23℃ A = FUSB075F B = FUSB120F C = FUSB155F FUSB Series A B C 100 Time-to-trip (S) 10 1 0.1 0.01 0.001 1 10 100 Fault current (A) D = FUSB090F E = FUSB110F F = FUSB135F G = FUSB160F H = FUSB185F I = FUSB250F D E F G H FUSB Series I 100 Time-to-trip (S) 10 1 0.1 0.01 0.001 1 10 100 Fault current (A) NOTE : Specification subject to change without notice. 2019/11/13 NO. FUZETEC TECHNOLOGY CO., LTD. Product Specification and Approval Sheet Version PQ05-101E 9 Page 4/4 7. Material Specification Lead material: Tin plated copper clad steel, 24 AWG Soldering characteristics: MIL-STD-202, Method 208E Insulating coating:Flame retardant epoxy ,meet UL-94V-0 requirement 8. Part Numbering and Marking System Part Numbering System Part Marking System FUSB □ □ □ F RoHS Compliant / Lead Free F UB155F 93AB F UB Fuzetec Logo □ □ □ F RoHS Compliant / Lead Free Part Identification Product Family Current Rating □ □ □ □ Example Date Code/Lot Number Note: Font on Marking may look slightly different due to fine turnings of each Marking printer. NOTE : Specification subject to change without notice. 2019/11/13
FUSB110F 价格&库存
很抱歉,暂时无法提供与“FUSB110F”相匹配的价格&库存,您可以联系我们找货
