FUZETEC TECHNOLOGY CO., LTD.
NO.
PQ33-101E
Product Specification and Approval Sheet Version A5
Page
1/4
Radial Leaded PTC Resettable Fuse : FRHV Series
1. Summary
(a) RoHS Compliant (Lead Free) Product
(b) Applications : Wide variety of electronic equipment
(c) Product Features : Low hold current Solid state, Radial leaded product ideal for up
to 60V/100V/250V/600V
(d) Operation Current : 0.08A~0.40A
(e) Maximum Operation Voltage : 60V/100V/250VDC
(f) Maximum Interrupt Voltage : 250V/600VAC
(g) Temperature Range : -40℃ to 85℃
2. Agency Recognition
UL :
C-UL:
TÜ V:
File No. E211981
File No. E211981
*File No. R50138901
*FRH160-600MF and FRH200-600VF~FRH400-600F TÜ V In Process.
3. Electrical Characteristics (23℃)
Part
Number
FRH080-250VF
FRH110-250VF
FRH120-250VF
FRH145-250VF
FRH180-250XF
FRH150-600MF
FRH160-600MF
FRH160-600VF
FRH200-600VF
FRH250-600VF
FRH400-600F
Hold
Current
Trip
Current
IH, A
0.08
0.11
0.12
0.15
0.18
0.15
0.16
0.16
0.20
0.25
0.40
IT, A
0.16
0.22
0.24
0.29
0.65
0.30
0.32
0.32
0.40
0.85
1.00
Max. Time
To Trip
Current Time
A
0.35
1.00
1.00
1.00
3.00
1.00
1.00
1.00
1.00
3.00
3.00
Sec
4.0
2.0
2.0
2.5
2.0
4.0
7.0
7.0
12.0
1.0
4.0
Resistance
Max.
Current
Max. Oper.
Voltage
Max. Int.
Voltage
Typ.
Power
RMIN
R1MAX
IMAX, A
3.0
3.0
3.0
3.0
10.0
3.0
3.0
3.0
3.0
3.0
3.0
VMAX, VDC
100
100
100
100
100
250
250
250
250
250
60
VI-MAX,VAC
250
250
250
250
250
600
600
600
600
600
600
Pd, W
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
Ohms
14.00
5.00
4.00
3.00
0.80
6.00
4.00
4.00
4.00
1.00
0.95
Ohms
33.00
16.00
16.00
12.00
4.00
17.00
16.00
18.00
13.50
7.00
1.90
IH=Hold current-maximum current at which the device will not trip at 23℃ still air.
IT=Trip current-maximum current at which the device will always trip at 23℃ still air.
V MAX=Maximum operating voltage at which the device can withstand without damage at its rated current.
VI -MAX = Maximum interrupt voltage device can withstand for short period of time. (Not for long term.)
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Typical power dissipated from device when in the tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃.
R1MAX=Maximum device resistance at 23℃ 1 hour after tripping .
Physical specifications:
Lead material: Tin plated copper, 22 AWG.
Soldering characteristics:MIL-STD-202, Method 208E.
Insulating coating:Flame retardant epoxy ,meet UL-94V-0 requirement.
*NOTE : All FRHV products are designed to assist equipment to pass ITU, UL60950 or GR1089 specification.
*FRH150-600MF, FRH160-600VF meet UL497A Overvoltage and Endurance Conditioning requirements for Thermistor type
component.
CAUTION : FRHV devices are not intended for continous use of Line Voltage such as 120VAC ~ 600VAC and above.
NOTE : Specification subject to change without notice.
2019/11/13
NO.
PQ33-101E
Page
2/4
4. Production Dimensions (millimeter)
Fig.1
Lead Size :22AWG,
Φ 0.65 mm Diameter
Part
Number
Fig
FRH080-250VF
FRH110-250VF
FRH120-250VF
FRH145-250VF
FRH180-250XF
FRH150-600MF
FRH160-600MF
FRH160-600VF
FRH200-600VF
FRH250-600VF
FRH400-600F
1
1
2
2
1
2
2
2
2
2
2
Fig.2
Lead Size : 22AWG,
Φ 0.65 mm Diameter
A
B
C
D
E
Maximum
Maximum
Typical
Minimum
Maximum
5.8
6.8
6.5
6.5
9.0
9.0
9.0
16.0
12.0
12.0
15.0
9.6
9.9
11.0
11.0
12.0
12.5
12.5
12.6
14.0
15.0
14.5
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.7
4.6
4.6
4.6
4.6
3.8
4.6
4.6
6.0
6.0
6.0
6.0
2019/11/13
NO.
PQ33-101E
Page
3/4
5. Thermal Derating Curve
FRHV Series
Percent of Rated Hold and Trip Current
200%
B
150%
A
100%
A
B
50%
A= FRH180-250XF
B= All other FRHV devices
0%
-40
-20
60
80
Ambient Temperature (℃)
6. Typical Time-To-Trip at 23℃
1000
A= FRH080-250VF
B= FRH110-250VF
C= FRH120-250VF
D= FRH145-250VF
E= FRH180-250XF
Time-to-trip (S)
100
10
1
E
D
C
0.1
B
A
0.01
1
1.5
2
2.5
3
Fault current (A)
2019/11/13
NO.
PQ33-101E
4/4
1000
100
Time-to-trip (S)
F = FRH150-600MF
G = FRH160-600MF
H = FRH160-600VF
I = FRH200-600VF
J = FRH250-600VF
K = FRH400-600F
Page
10
K
J
I
H
G
F
1
0.1
0.01
0.00
0.50
1.00
1.50
2.00
2.50
3.00
Fault current (A)
7. Material Specification
Lead material:Tin plated copper, 22 AWG.
Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement
8. Part Numbering and Marking System
Part Numbering System
Part Marking System
FRH □ □ □ ─ □ □ □ VF
RoHS Compliant / Lead Free
V: High Operating Voltage Device
X: Round Type
M: Special Type
Maximum Interrupt
Voltage Rating
Current Rating
F
RH □ □ □ F
Fuzetec Logo
Part Identification
Product Family
F
RH110F
51AB
Example
Date Code/Lot Number
* FRH150-600MF Marking : RH6150F, FRH160-600MF Marking : RH6160F , FRH160-600VF Marking : RH6160F
* FRH200-600VF Marking : RH6200F , FRH250-600VF Marking : RH6250F , FRH400-600F Marking : RH6400F
Note: Font on Marking may look slightly different due to fine turnings of each Marking printer.
2019/11/13
很抱歉,暂时无法提供与“FRH120-250VF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.23671
- 50+0.97535
- 300+0.86325
