FRK400-60F
FRK400-60F
    FUZETEC(富致)
    插件
    60V 4A 插件自恢复
FRK400-60F 数据手册
NO. FUZETEC TECHNOLOGY CO., LTD. PQ34-113E Product Specification and Approval Sheet Version 3 Page 1/3 Radial Leaded PTC Resettable Fuse : FRK400-60F 1. Summary (a) (b) (c) (d) (e) (f) RoHS Compliant (Lead Free) product Applications : Wide variety of electronic equipment Product Features : Solid state, Radial leaded product ideal for up to 60VDC Operation Current : 4.00A Maximum Operation Voltage : 60VDC Temperature Range : -40℃ to 85℃ 2. Agency Recognition UL : C-UL: TÜ V: Pending Pending Pending 3. Electrical Characteristics (23℃) Part Hold Trip Current Current IH, A IT, A I, A 4.00 8.00 20.0 Rated Typ. Current Voltage Power RMIN R1MAX Time,S IMAX, A VMAX, VDC Pd, W Ohms Ohms 24.0 40 60 3.70 0.014 0.060 Number FRK400-60F Resistance Max. Max.Time to Trip IH=Hold current-maximum current at which the device will not trip at 23℃ still air. IT=Trip current-minimum current at which the device will always trip at 23℃ still air. V MAX=Maximum voltage device can withstand without damage at its rated current. I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX). Pd=Typical power dissipated from device when in tripped state in 23℃ still air environment. RMIN=Minimum device resistance at 23℃. R1MAX=Maximum device resistance at 23℃, 1 hour after tripping . Physical specifications: Lead material: Tin plated copper,20AWG. Soldering characteristics:MIL-STD-202, Method 208E. Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement. 4. Production Dimensions (millimeter) FRK400-60F Lead Size : 20AWG Φ 0.81 mm Diameter Part A B C D E F Number Maximum Maximum Typical Minimum Maximum Typical FRK400-60F 21.00 24.90 10.2 7.6 3.00 1.4 NOTE : Specification subject to change without notice. FUZETEC TECHNOLOGY CO., LTD. NO. Product Specification and Approval Sheet Version PQ34-113E 3 Page 5. Thermal Derating Curve FRK400-60F Percent of Rated Hold and Trip Current 200% 150% 100% 50% 0% -20 0 20 40 60 80 Ambient Temperature(℃) 6. Typical Time-To-Trip at 23℃ FRK400-60F 100 Time-to-Trip(s) 10 1 0.1 0.01 1 10 Fault Current(A) NOTE : Specification subject to change without notice. 100 2/3 NO. FUZETEC TECHNOLOGY CO., LTD. Product Specification and Approval Sheet Version PQ34-113E 3 Page 3/3 7. Material Specification Lead material:Tin plated copper, 20 AWG. Soldering characteristics:MIL-STD-202, Method 208E. Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement 8. Part Numbering and Marking System Part Numbering System FRK □ □ □ ─ □ □ Part Marking System F F RK400F RoHS Compliant / Lead Free F RK Fuzetec Logo □ □ □ F 31BD RoHS Compliant / Lead Free Part Identification Product Family Voltage Rating Current Rating Example □ □ □ □ Date Code/Lot Number Note: Font on Marking may look slightly different due to fine turnings of each Marking printer. Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. - Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance. NOTE : Specification subject to change without notice.
FRK400-60F 价格&库存
很抱歉,暂时无法提供与“FRK400-60F”相匹配的价格&库存,您可以联系我们找货
