FUZETEC TECHNOLOGY CO., LTD.
NO.
PQ07-107E
Product Specification and Approval Sheet Version
3
Page
1/3
Axial Leaded PTC Resettable Fuse: FLR450F
1. Summary
(a)
(b)
(c)
(d)
(e)
(f)
RoHS Compliant (Lead Free) Product
Applications: Rechargeable battery packs, Lithium cell and battery packs
Product Features: Low profile, Low resistance, High hold current, Solid state
Operation Current: 4.5A
Maximum Voltage: 20V
Temperature Range : -40℃ to 85℃
2. Agency Recognition
UL:
TÜ V:
File No. E211981
File No. R50004084
3. Electrical Characteristics (23℃)
Part
Resistance
Hold
Trip
Max.Time
Rated
Maximum
Typical
Current
Current
to Trip
Voltage
Current
Power
RMIN
RMAX
R1MAX
IH, A
IT, A
at 5XIH,S
VMAX, VDC
IMAX, A
Pd, W
Ohms
Ohms
Ohms
4.5
8.9
5.0
2.5
0.011
0.020
0.028
Number
FLR450F
IH=Hold current-maximum current at which the device will not trip at 23℃ still air.
IT=Trip current-minimum current at which the device will always trip at 23℃ still air.
V MAX=Maximum voltage device can withstand without damage at its rated current.
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Maximum power dissipated from device when in tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃.
R1MAX=Maximum device resistance at 23C, 1 hour after tripping.
Physical specifications:
Lead material:0.13mm nominal thickness, quarter-hard nickel.
Insulating material: Polyester tape.
4. Production Dimensions (millimeter)
A
Part
B
C
D
F
Number
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
FLR450F
24.0
26.0
9.9
10.5
0.6
1.0
5.3
6.7
5.9
6.1
NOTE : Specification subject to change without notice.
NO.
PQ07-107E
3
Page
5. Thermal Derating Curve
FLR450F
Precent of Rated Hold and Trip Current
200%
150%
100%
50%
0%
-40
-20
60
80
Ambient Temperature (C)
6. Typical Time-To-Trip at 23℃
FLR450F
100
Time-to-trip (S)
10
1
0.1
0.01
1
10
Fault Current (A)
100
2/3
NO.
PQ07-107E
3
Page
3/3
7. Material Specification
Lead material: 0.13 mm nominal thickness, quarter-hard nickel
Insulating material:Polyester tape
8. Part Numbering and Marking System
Part Numbering System
Part Marking System
FLR □ □ □ F
RoHS Compliant / Lead Free
FLR450F
33AB
F LR □ □ □ F
Current Rating
Example
Part Identification
Product Family
Fuzetec Logo
Date Code/Lot Number
Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible
electrical arcing and/or flame.
-PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent
condition and/or prolonged trip are not anticipated.
- Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device
performance.
很抱歉,暂时无法提供与“FLR450F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.13890
- 10+1.05130
- 100+0.96360
- 500+0.87610
- 国内价格
- 1+0.86400
- 10+0.83200
- 100+0.75520
- 500+0.71680
- 国内价格
- 1+1.61363
- 10+1.28078
- 30+1.13811
- 100+0.96002
