NO.
FUZETEC TECHNOLOGY CO., LTD.
PQ02-104E
Product Specification and Approval Sheet Version
5
Page
1/3
Radial Leaded PTC Resettable Fuse: FRU135-30F
1. Summary
(a) RoHs Compliant (Lead Free) Product
(b) Applications: Wide variety of electronic equipment
(c) Product Features: Low resistance, High hold current, Solid state, Radial leaded
product ideal for up to 30V
(d) Operation Current: 1.35A
(e) Maximum Voltage: 30V
(f) Temperature Range : -40℃ to 85℃
2. Agency Recognition
UL:
File No. E211981
C-UL: File No. E211981
TÜ V:
File No. R50004084
3. Electrical Characteristics (23℃)
Part
Resistance
Hold
Trip
Max.Time
Maximum
Rated
Typical
Current
Current
To Trip
Current
Voltage
Power
RMIN
R1MAX
IH, A
IT, A
at 5XIH,S
IMAX, A
VMAX, VDC
Pd, W
Ohms
Ohms
1.35
2.70
7.3
100
30
0.8
0.040
0.130
Number
FRU135-30F
IH=Hold current-maximum current at which the device will not trip at 23℃ still air.
IT=Trip current-minimum current at which the device will always trip at 23℃ still air.
V MAX=Maximum voltage device can withstand without damage at its rated current.
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Maximum power dissipated from device when in tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃.
R1MAX=Maximum device resistance at 23℃, 1 hour after tripping.
Physical specifications:
Lead material: Tin plated copper, 24 AWG.
Soldering characteristics: MIL-STD-202, Method 208E.
Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement.
4. Production Dimensions (millimeter)
FRU 135-30F
Lead Size: 24AWG
Φ 0.51 mm Diameter
Part
A
B
C
D
E
F
Number
Maximum
Maximum
Typical
Minimum
Maximum
Typical
FRU135-30F
8.9
13.5
5.1
7.6
3.0
0.9
NOTE : Specification subject to change without notice.
NO.
PQ02-104E
5
Page
5. Thermal Derating Curve
FRU135-30F
Precent of Rated Hold and Trip Current
200%
150%
100%
50%
0%
-40
-20
60
80
Ambient Temperature (C)
6. Typical Time-To-Trip at 23℃
FRU135-30F
100
Time-to-trip (S)
10
1
0.1
0.01
0.001
0.1
1
10
Fault current (A)
100
2/3
NO.
PQ02-104E
5
Page
3/3
7. Material Specification
8. Part Numbering and Marking System
Part Numbering System
Part Marking System
FRU □ □ □ ─ □ □ F
RoHS Compliant / Lead Free
Voltage Rating
Current Rating
F
RU135F
31AB
F
RU □ □ □ F
Example
Fuzetec Logo
Part Identification
Product Family
Date Code/Lot Number
Note: Font on Marking may look slightly different due to fine turnings of each Marking printer.
Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible
electrical arcing and/or flame.
-PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent
condition and/or prolonged trip are not anticipated.
- Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device
performance.
很抱歉,暂时无法提供与“FRU135-30F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.44612
- 50+1.18487
- 300+1.07288
