FUZETEC TECHNOLOGY CO., LTD.
NO.
PQ28-122E
Product Specification and Approval Sheet Version A0
Page
1/4
Radial Leaded PTC Resettable Fuse : FRVL Series
1. Summary
(a)
(b)
(c)
(d)
(e)
(f)
(g)
RoHS Compliant (Lead Free) product
Applications : Wide variety of electronic equipment
Product Features : Solid state, Radial leaded product ideal for up to 120VAC/DC
Operation Current : 0.10A~3.75A
Maximum Operating Voltage : 120VAC/DC
Maximum Interrupt Voltage : 135VAC/DC
Temperature Range : -40℃ to 85℃
2. Agency Recognition
UL :
C-UL:
TÜ V :
File No. E211981
*File No. E211981
File No. R50122733
*FRVL040-120F~FRVL070-120F and FRVL090-120F~FRVL130-120F C-UL In Process.
3. Electrical Characteristics (23℃)
Part
Number
FRVL010-120F
FRVL017-120F
FRVL020-120F
FRVL025-120F
FRVL030-120F
FRVL040-120F
FRVL050-120F
FRVL065-120F
FRVL070-120F
FRVL075-120F
FRVL090-120F
FRVL100-120F
FRVL110-120F
FRVL125-120F
FRVL130-120F
FRVL135-120F
FRVL160-120F
FRVL185-120F
FRVL200-120F
FRVL250-120F
FRVL300-120F
FRVL375-120F
Resistance
Hold
Trip
Max.Time
Max.
Max. Oper.
Max. Int.
Typ
Current
Current
to Trip
Current
RMIN
R1MAX
IT, A
at 5XIH,S
IMAX, A
Pd, W
Ohms
Ohms
0.10
0.17
0.20
0.25
0.30
0.40
0.50
0.65
0.75
0.75
0.90
1.00
1.10
1.25
1.35
1.35
1.60
1.85
2.00
2.50
3.00
3.75
0.20
0.34
0.40
0.50
0.60
0.80
1.00
1.30
1.50
1.50
1.80
2.00
2.20
2.50
2.70
2.70
3.20
3.70
4.20
5.00
6.00
7.50
10.0
10.0
9.0
7.5
8.5
6.5
6.0
5.7
6.3
15.0
7.2
15.0
8.2
20.0
9.6
20.0
11.4
12.6
36.0
15.6
19.8
24.0
2.0
2.0
2.0
3.0
3.0
3.0
3.0
5.0
5.0
7.5
5.0
10.0
8.0
12.5
10.0
13.5
12.0
12.0
20.0
15.0
17.0
20.0
Voltage
VI-MAX,
VAC/DC
135
Power
IH, A
Voltage
VMAX,
VAC/DC
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
120
0.84
0.84
1.08
1.08
1.44
1.44
1.56
1.68
1.80
2.64
1.80
2.64
2.28
2.88
2.64
3.12
3.12
3.36
4.32
4.44
4.56
4.80
3.00
2.00
1.83
1.25
0.88
0.55
0.50
0.31
0.25
0.25
0.20
0.18
0.15
0.11
0.12
0.11
0.09
0.08
0.08
0.05
0.04
0.03
7.50
7.00
4.40
3.00
2.10
1.29
1.17
0.72
0.60
0.69
0.47
0.47
0.38
0.33
0.30
0.30
0.22
0.19
0.21
0.13
0.10
0.08
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
135
NOTE : Specification subject to change without notice.
2019/9/18
NO.
PQ28-122E
Page
2/4
IH=Hold current-maximum current at which the device will not trip at 23℃ still air.
IT=Trip current-minimum current at which the device will always trip at 23℃ still air.
V MAX=Maximum voltage device can withstand without damage at its rated current.
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Typical power dissipated from device when in tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃.
R1MAX=Maximum device resistance at 23℃, 1 hour after tripping .
Physical specifications:
Lead material: FRVL010-120F Tin plated copper clad steel, 24AWG.
FRVL017-120F Tin plated copper, 24AWG.
FRVL020-120F~FRVL070-120F and FRVL090-120F Tin plated copper, 22AWG.
FRVL075-120F and FRVL100-120F~FRVL375-120F Tin plated copper, 20AWG.
Soldering characteristics:MIL-STD-202, Method 208E.
Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement.
4. Production Dimensions (millimeter)
Fig.1
Fig.2
Fig.3
Fig.4
FRVL010-120F~FRVL017-120F
FRVL020-120F~FRVL090-120F
FRVL110-120F~FRVL375-120F
FRVL075-120F ~FRVL200-120F
Lead S ize :24AWG
Lead Size :22AWG
Φ 0.51 mm Diameter
Φ 0.65 mm Diameter
Lead Size :20AWG
Φ 0.81 mm Diameter
Φ 0.81 mm Diameter
Part
Number
Lead Size : 20AWG
A
B
C
D
E
F
Maximum
Maximum
Typical
Minimum
Maximum
Typical
Fig.
FRVL010-120F
1
7.9
13.0
5.1
7.6
3.8
2.2
FRVL017-120F
1
7.9
13.0
5.1
7.6
3.8
2.2
FRVL020-120F
2
7.9
13.0
5.1
7.6
3.8
2.2
FRVL025-120F
2
7.9
13.0
5.1
7.6
3.8
2.2
FRVL030-120F
2
7.9
13.0
5.1
7.6
3.8
2.2
FRVL040-120F
2
8.2
14.2
5.1
7.6
3.8
2.2
FRVL050-120F
2
9.2
14.9
5.1
7.6
3.8
2.2
FRVL065-120F
2
9.7
14.9
5.1
7.6
3.8
2.2
FRVL070-120F
2
10.6
15.5
5.1
7.6
3.8
2.2
FRVL075-120F
4
10.9
17.0
5.1
7.6
4.1
2.2
FRVL090-120F
2
11.9
15.9
5.1
7.6
3.8
2.2
FRVL100-120F
4
11.5
20.1
5.1
7.6
4.1
2.2
FRVL110-120F
3
13.3
18.3
5.1
7.6
4.1
2.2
FRVL125-120F
4
14.0
21.7
5.1
7.6
4.1
2.2
FRVL130-120F
3
15.5
20.6
5.1
7.6
4.1
2.2
FRVL135-120F
4
16.3
21.7
5.1
7.6
4.1
2.2
FRVL160-120F
3
17.5
22.5
5.1
7.6
4.1
2.2
2019/9/18
NO.
PQ28-122E
Page
3/4
FRVL185-120F
3
19.9
24.9
5.1
7.6
4.1
2.2
FRVL200-120F
4
23.5
27.9
10.2
7.6
4.1
2.2
FRVL250-120F
3
22.5
27.5
10.2
7.6
4.1
2.2
FRVL300-120F
3
25.5
30.0
10.2
7.6
4.1
2.2
FRVL375-120F
3
29.5
34.0
10.2
7.6
4.1
2.2
5. Thermal Derating Curve
FRVL Series
Precent of Rated Hold and Trip Current
200%
150%
100%
50%
0%
-40
-20
60
80
Ambient Temperature (C)
6. Typical Time-To-Trip at 23℃
A=FRVL010-120F
A
BCDE
F G H I J K LM N O P Q
1000
B=FRVL017-120F
C=FRVL020-120F
D=FRVL025-120F
100
E=FRVL030-120F
F=FRVL040-120F
H=FRVL065-120F
I=FRVL070-120F
J=FRVL090-120F
K=FRVL110-120F
L=FRVL130-120F
Time-to-trip (S)
G=FRVL050-120F
10
1
M=FRVL160-120F
N=FRVL185-120F
0.1
O=FRVL250-120F
P=FRVL300-120F
Q=FRVL375-120F
0.01
0.1
1
10
100
Fault current (A)
2019/9/18
NO.
PQ28-122E
Page
4/4
R=FRVL075-120F
S=FRVL100-120F
T=FRVL125-120F
U=FRVL135-120F
V=FRVL200-120F
7. Material Specification
Lead material: FRVL010-120F Tin plated copper clad steel, 24 AWG.
FRVL017-120F Tin plated copper, 24 AWG.
8. Part Numbering and Marking System
Part Numbering System
Part Marking System
FRVL □ □ □ ─ □ □ □ F
RoHS Compliant / Lead Free
Voltage Rating
F
RVL10F
91AB
F
RVL
Fuzetec Logo
□ □ F
Current Rating
Example
Part Identification
Product Family
Date Code/Lot Number
Note: Font on Marking may look slightly different due to fine turnings of each Marking printer.
Warning: - Each product should be carefully evaluated and tested for their suitability of application.
- Operation beyond the specified maximum rating or improper use may result in damage and possible electrical arcing
and/or flame.
- PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent condition
and/or prolonged trip are not anticipated.
- Avoid contact of PPTC device with chemical solvent, including some inert material such as silicone based oil,
lubricant and etc. Prolonged contact will damage the device performance.
- Additional protection mechanism are strongly recommended to be used in conjunction with the PPTC device for
protection against abnormal or failure conditions.
- Avoid use of PPTC device in a constrained space such as potting material, housing and containers where have
limited space to accommodate device thermal expansion and/or contraction.
2019/9/18
很抱歉,暂时无法提供与“FRVL025-120F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.65940
- 30+2.48210
- 100+2.30480
- 500+2.12740
- 1000+1.95020
- 2000+1.77290
- 国内价格
- 5+1.59857
- 50+1.09497
- 150+0.81854
- 500+0.69049
- 2500+0.63348
- 5000+0.59925
