泰州福声电子科技有限公司-----电声产品专业制造商
FUSHENG ELECTRONICS------Acoustic Components Professional Manufacturer
SPECIFICATION OF PRODUCT
承 认 书
CUSTOMER:
DESCRIPTION:
Piezo Buzzer
FUSHENG P/N:
FUET-1760
CUSTOMER P/N:
DATE:
CUSTOMER
2019-8-28
APPROVER
CHECKER
Cui
泰州福声电子科技有限公司
地址:江苏省泰州市海陵区凤凰西路 98 号
电话:0086-523-86219066 传真:0086-523-81601108
邮箱: sales@electronic-tech.cn
网址:www.tzfsdz.com
FUET-1760
1.SPECIFICATION 规格
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
Hz
4000
square wave
2
Operating Voltage
Vp-p
1 ~ 25
3
Rated Voltage
Vp-p
3
4
Current Consumption
mA
MAX.12
at Rated Voltage
5
Sound Pressure Level
dB
MIN. 90
at 10cm at Rated Voltage
6
Electrostatic Capacity
pF
15000±30%
at 100Hz 1V
7
Operating Temperature
-30 ~ +85
8
Storage Temperature
-40 ~ +85
9
Dimension
mm
17 x H 6.0
10
Weight (MAX)
gram
1.0
11
Housing Material
12
Leading Pin
Tin Plated Brass(Sn)
13
Environmental
Protection Regulation
RoHS
2. APPEARANCE DRAWING
± 0.3
See appearance drawing
LCP( Black )
尺寸图
Unit: mm
FUET-1760
3.TESTING METHOD 测量方式
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments
shown below.
4. Typical Frequency Response Curve
FUET-1760
5.Surface mounting condition
5.1 Reflow soldering
Recommendable reflow soldering condition is as follows.
Note: (1) In automated mounting of the SMD sound transducers on PCB, any bending, expanding
and pulling forces or shocks against the SMD sound transducers shall be kept minimum
to prevent them from electrical failures and mechanical damages of the devices.
(2) In the reflow soldering, too high soldering temperatures and too large temperature
Gradient such as rapid heating or cooling may cause electrical failures and mechanical
5.2 Soldering pattern
FUET-1760
6. RELIABILITY TEST
NO.
ITEM
1
High Temperature
Test (Storage)
After being placed in a chamber with 80 2ºC for 96 hours and then
being placed in normal condition for 2 hours.
Allowable variation of SPL after test: 10dB.
2
Low Temperature
Test (Storage)
After being Placed in a chamber with -30 2ºC for 96 hours and then
Humidity Test
After being Placed in a chamber with 90-95% R.H. at 40 2ºC for 96
hours and then being placed in normal condition for 2 hours.
3
TEST CONDITION AND REQUIREMENT
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+70ºC
+25ºC
4
Temperature Cycle
Test
5
Drop Test
6
Vibration Test
7
Solderability
Test
8
Terminal Strength
Pulling Test
+25ºC
- 20ºC
Drop on a hard wood board of 4cm thick, any directions ,6 times,
at the height of 75cm .
After being applied vibration of amplitude of 1.5mm with 10 to 55 Hz
band of vibration frequency to each of 3 perpendicular directions for
2 hours .
Lead terminals are immersed in rosin for 5 seconds and then
immersed in solder bath of +300 5ºC for 3 1 seconds .
90% min. lead terminals shall be wet with solder
(Except the edge of terminals).
The force of 9.8N(1.0kg) is applied to each terminal in axial direction for
10 seconds.
No visible damage and cutting off.
TEST CONDITION.
Standard Test Condition
一般测试条件
Judgment Test Condition
争议时测试条件
a) Temperature : +5 ~ +35℃
a) 温度 : +5 ~ +35℃
a) Temperature : +25 ± 2℃
a) 温度 : +25 ± 2℃
b) Humidity : 45-85%
b) 湿度 : 45-85%
b) Humidity : 60-70%
b) 湿度 : 60-70%
c) Pressure : 860-1060mbar
c) 气压 : 860-1060mbar
FUET-1760
7. PACKING STANDARD
FUET-1760
很抱歉,暂时无法提供与“FUET-1760”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.24000
- 10+3.16440
- 30+3.11040
- 100+3.06720
