FX357CVBTH-01P2GB
FX357CVBTH-01P2GB
    LYG(凌烟阁)
    SOP-4
    DC输入 隔离电压(RMS):3.75KV
FX357CVBTH-01P2GB 数据手册
FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler SCHEMATIC Description The FX357 series combine an AlGaAs infrared emitting diode as the emitter which is optically 1 4 2 3 coupled to a silicon planar phototransistor detector in a plastic SOP4 package. With the robust coplanar double mold structure, FX357 series provide the most stable isolation feature. Features ⚫ High isolation 3750 VRMS ⚫ CTR flexibility available see order information ⚫ DC input with transistor output ⚫ Operating temperature range - 55 °C to 110 °C ⚫ REACH compliance ⚫ Halogen free ⚫ MSL class 1 ⚫ Regulatory Approvals ◼ VDE - EN60747-5-5(VDE0884-5) ◼ CQC - GB4943.1, GB8898 Applications • Switch mode power supplies • Programmable controllers • Household appliances • Office equipment Rev: A06 PIN DEFINITION 1. Anode 2. Cathode 3. Emitter 4. Collector PACKAGE OUTLINE FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT NOTE INPUT Forward Current IF 60 mA Peak Forward Current IFP 1 A Reverse Voltage VR 6 V Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 3750 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C 1 OUTPUT COMMON Note 1. 100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Rev: A06 2 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.24 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 10 - pF V=0, f=1kHz OUTPUT Collector Dark Current ICEO - - 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 - - V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BVECO 7 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS Current Transfer Ratio FX3570 50 - 600 FX357A 80 - 160 130 - 260 200 - 400 FX357D 300 - 600 FX357E 100 - 200 - 0.06 0.2 V IF=20mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. FX357B FX357C CTR % IF=5mA, VCE=5V Collector-Emitter Saturation Voltage VCE(sat) Isolation Resistance RISO Floating Capacitance CIO - 0.4 1 pF V=0, f=1MHz Response Time (Rise) tr - 3 18 μs Response Time (Fall) tf - 4 18 μs VCE=2V, IC=2mA RL=100Ω Cut-off Frequency fc - 80 - kHz Note 3. Fig.12&13 Note 4. Fig.14 Rev: A06 10^12 10^14 VCE=2V, IC=2mA RL=100Ω,-3dB 3 3 4 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler CHARACTERISTIC CURVES Rev: A06 Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs. Ambient Temperature Fig.5 Collector Current vs. Collector-emitter Voltage Fig.6 Collector Current vs. Collector-emitter Voltage FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler CHARACTERISTIC CURVES Fig.7 Normalized Current Transfer Ratio vs. Forward Current Fig.8 Normalized Current Transfer Ratio vs. Ambient Temperature Fig.9 Collector-emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs. Load Resistance Fig.11 Frequency Response Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13 Curves of Response Time Fig.14 Test Circuits of Frequency Response Rev: A06 www.lyg-semi.com FX357 Series SOP4, DC Input Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Packing Option 1 Packing Option 2 Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Reel Dimension Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler BOX SPECIFICATIONS (Reel Type) Inner Box ⚫ L x W x H = 36cm x 36cm x 6.9cm Outer Box ⚫ L x W x H = 45cm x 38cm x 38cm Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION FX357R VYAWW LYG FX357 R V Y : Company Abbr. : Part Number : CTR Rank : VDE Option : Fiscal Year A WW : Manufacturing Code : Work Week ORDERING INFORMATION LABEL INFORMATION FX357RVBTH-0ZP2GCM FX357 – Part Number R – Rank Option(0/A/B/C/D/E) V – VDE BTH – Fixed Character 0 – Fixed Character Z – Packing Option (1/3) P2 – Fixed Character G – Material Option (G: Green Material / None: None Green Material) C – Color Option(W: White / B: Black) M – Leadframe Option (F: Iron Leadframe / None: Copper Leadframe) PACKING QUANTITY Option Quantity Quantity – Inner box Quantity – Outer box 1 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units 2 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler TEMPERATURE PROFILE OF SOLDERING WAVE SOLDERING(JESD22-A111 COMPLIANT) HAND SOLDERING BY SOLDERING IRON Soldering Temperature Soldering Time 380+0/-5oC 3 sec max. ⚫ One time soldering is recommended for all soldering method. ⚫ Do not solder more than three times for IR reflow soldering. Rev: A06 FX357 Series www.lyg-semi.com SOP4, DC Input Photo Transistor Coupler DISCLAIMER ⚫ LYG is continually improving the quality, reliability, function and design. LYG reserves the right to make changes without further notices. ⚫ The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed. ⚫ LYG makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LYG disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular ⚫ The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability. ⚫ This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death. ⚫ Please contact LYG sales agent for special application request. ⚫ Immerge unit’s body in solder paste is not recommended. ⚫ Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LYG’s terms and conditions of purchase, including but not limited to the warranty expressed therein. ⚫ Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Rev: A06
FX357CVBTH-01P2GB 价格&库存
很抱歉,暂时无法提供与“FX357CVBTH-01P2GB”相匹配的价格&库存,您可以联系我们找货
