FSTOF2002E0D
FSTOF2002E0D
    LYG(凌烟阁)
    TOF模组
FSTOF2002E0D 数据手册
FSTOF2002x0D ToF Module 单点 TOF 模块 FSTOF2002x0D 规 格 书 Preliminary Datasheet Rev 1.0 1 Copyright©2020-2021, Lingyange Semiconductor Inc. 珠海凌烟阁芯片科技有限公司 FSTOF2002x0D ToF Module 目 录 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. Features 特点............................................................................................. 3 Applications 应用........................................................................................ 3 Description 说明......................................................................................... 3 Specifications 规格..................................................................................... 4 System block diagram 系统框图................................................................ 4 Module pin definition 模块脚位定义............................................................ 5 Interface configuration 接口配置................................................................ 5 Communication protocol demonstration 通讯协议演示……………...…….. 6 Physical dimension 结构尺寸..................................................................... 7 3D concept model 示意图 / Module appearance 模块外观......................... 7 Recommended connector 推荐连接器....................................................... 8 Outer cover suggestion 外盖设计建议....................................................... 8 Multi module design 多模块设计................................................................ 8 Packaging Information 包装信息…………………....................................... 9 Ordering information 订购信息…...………………....................................... 9 Preliminary Datasheet Rev 1.0 2 Copyright©2020-2021, Lingyange Semiconductor Inc. 珠海凌烟阁芯片科技有限公司 FSTOF2002x0D ToF Module 1. Features 特点: • • • • • • • • • 940 nm 激光,符合 IEC 60825-1-2014 第 3 版规定的 Class 1 操作条件 超小型尺寸:16mm x 10mm x 7.5 mm 测量距离:100mm~2000mm (@88%反射率白卡) 测量精度:±5% (2000mm@88%反射率白卡) 通讯接口:UART / I2C 自动光学串扰补偿 高速测距响应 易于设置,不需要额外的光学校准要求 3.3V 单电源工作 2. Applications 应用: • • • • • • • • • 自动水龙头和冲洗阀 复印机和自动售货机、智能货架 ATM 和 Kiosks 的系统用户检测 无人机避障、扫地机器人 工厂自动化 车载导航等领域 人员经过、闯入检测 台灯 摄像头快速聚焦辅助 3. Description 说明: FSTOF2002x0D 是一款为方便客户使用而设计的高性能、低成本的中距的单点 TOF 测距模 块,采用 Sharp 特有的 SPAD(Single Photon Avalanche Diodes) 组件,通过测量一束 940nm 的红外光线在空中折返的时间来计算出被测物的距离,这种技术简称为 TOF (time of flight), 能够获得精确地测量结果和对环境光的抗干扰能力,广泛的适用于机器人、消费电子、 物联网等诸多应用场合。 此产品集成光、机、电、测距算法等功能,对外采用 6pin SH1.0 插座,经由主控端给模块提 供 3.3V,支持 UART 和 I2C 等访问接口。并于出厂时完成光学校正,方便客户简易完成组 装出货。为了满足多模块设计使用需求,主控芯片可以下拉模块选择脚位 (RXD) 信号并搭配 I2C 接口进行相应的 TOF 模块操作。 当前模块有三个子版本,根据选配的 MCU 不同,分配的型号分别是 FSTOF2002C0D / FSTOF2002D0D / FSTOF2002E0D. 其中 FSTOF2002D0D / FSTOF2002E0D 可以通过更 新软件,满足客户实现低功耗的要求。 Preliminary Datasheet Rev 1.0 3 Copyright©2020-2021, Lingyange Semiconductor Inc. 珠海凌烟阁芯片科技有限公司 FSTOF2002x0D ToF Module 4. Specifications 规格: 参数 规格 MCU 8051 量程 100-2000mm (@88%反射率白卡) 精度 ±5% (@2000mm,88%反射率白卡) 测量周期 36ms 光源 VCSEL 波长 935nm~955nm 视场角 15~25° 人眼安全 Class 1 (IEC 60825-1:2014-3rd edition) 供电电压 3.0~3.6V 平均电流
FSTOF2002E0D 价格&库存
很抱歉,暂时无法提供与“FSTOF2002E0D”相匹配的价格&库存,您可以联系我们找货
