H1692CE-A
H1692CE-A
    MNC(铭普光磁)
    SMD
    百兆网络变压器 传输速率: 10/100 BASE-T 封装类型: SMT 端口数: SINGLE PORT Pin脚个数: 16 是否支持POE:YES POE电流:700mA 工作温度范围:工业级...
H1692CE-A 数据手册
10/100 BASE-T SINGLE PORT SURFACE MOUNT MAGNETICS Meets IEEE 802.3u Standards. RoHS Compliant. 700mA Current Capability Per POE Port / Two-pair. 10/100 Base-T,Surface mount Type,Open Header . Operating temperature range: -40℃ to +85℃ Electrical Specifications @25°C Return Loss OCL(uH Min) CMRR Insertion Loss Cross talk Part (dB Min) @100KHz,0.2V Turns Ratio (dB Min) (dB Max) (dB Min) (±5%) Number With 15mA DC Bias 0.5-100MHz 0.5-100MHz 0.5-30MHz 30.1-60MHz 60.1-80MHz 0.5-40MHz 40.1-100MHz -18+20*log(f/30) H1692CE-A 1CT:1CT -18 -12 350 -1.1 -35 -30 -33+20*log(f/50) HI-POT (Vrms) 1500 MECHANICAL 12.7 7.10 H1692CE-A YYWWX 1.27 0.76 9.45 2.03 10.65 0.46 1.27 8.89 SUGGESTED PAD LAYOUT 6.40max 0.3 0°-8° 16 SURFACES Unless otherwise specified all tolerances are:±0.25 in mm SCHEMATICS 1CT:1CT TD1+ 1 16 MX1- 14 MX1+ 15 MCT1 TCT1 2 TD1- 3 Chip side Line side 1CT:1CT TD2+ 6 11 MX2+ TCT2 7 TD2- 8 9 MX2- 10 MCT2 Headquarters +86 769 86921000··Shenzhen R&D +86 755 36899993··USA +1 512 3433613··Korea +82 70 46394572··Taiwan +886 2 26984868··Hongkong +852 21211269 www.mnc-tek.com
H1692CE-A 价格&库存
很抱歉,暂时无法提供与“H1692CE-A”相匹配的价格&库存,您可以联系我们找货
