CC2012A-801
CC2012A-801
    MENTECH(铭普光磁)
    SMD,2x1.2mm
    2 800Ω@100MHZ
CC2012A-801 数据手册
CHIP COMMON MODE CHOKE High Common Mode Impedance at High Frequency. Excellent Noise Suppression Performance. Small Size and Low Profile,Surface Mount Type. Operating Temperature Range: -40℃ to +85℃. RoHS Compliant. Electrical Specifications @25°C Part Number Common Mode Impedance Insulation Resistance Rated Current DC Resistance Rated Voltage Withstand Volt CC2012A-801 Ω,@100MHz 800±25% MΩ Min mA Max Ω Max Vdc Max Vdc Max 10 300 0.88 50 125 MECHANICAL DIMENSIONS (unit:mm) Recommended PAD Layout Unless otherwise specified all tolerances are:±0.25mm SCHEMATIC Impedance-Frequency Characteristics (Typical) Headquarters +86 769 86921000··Shenzhen R&D +86 755 36899993··USA +1 512 3433613··Korea +82 70 46394572··Taiwan +886 2 26984868··Hongkong +852 21211269 www.mnc-tek.com
CC2012A-801 价格&库存
很抱歉,暂时无法提供与“CC2012A-801”相匹配的价格&库存,您可以联系我们找货
CC2012A-801
    • 20+0.13200
    • 100+0.12000
    • 500+0.11200
    • 1000+0.10400
    • 5000+0.09440
    • 10000+0.09040
    CC2012A-801
    • 50+0.36480
    • 500+0.27490
    • 1500+0.22630
    • 10000+0.19750
    • 20000+0.17240
    • 50000+0.15890
    库存:1873
