G72T07DB
G72T07DB
    JASN(建旭电子)
    插件,34.6x19.1mm
    10/100/1000BASE-T 四端口磁性模块
G72T07DB 数据手册
10/100/1000 BASE-T QUAD PORT MAGNETICS MODULE P/N: G72T07DB DATA SHEET Rev:A/0 Feature Compliant with IEEE 802.3ab standard. Comply with RoHS requirements. Operating temperature range: 0℃ to +70℃. Storage temperature range: -20℃ to +125℃. Electrical Specifications @ 25℃ OCL: 350uH Min. @100KHz/0.1V with 8mA DC Bias Hi-POT : 1500VAC 1mA 2S Turn Ratio: 1:1±2% LK: 0.5uH Max @100KHz/0.2V Cw/w 120pF Max @100KHz/0.2V D.C.R: 1.4 ohm Max Insertion Loss: 1-100MHz: -1.0dB Max Cross Talk : 1-100MHz: -30dB Min 1-30MHz 40MHz 50MHz 60-80MHZ 80-100MHZ -18dB Min -14.4dB Min -13.1dB Min -12dB Min -10dB Min Return Loss: Schematic 1 Mechanical 72 19 54 2 71 20 53 3 70 21 52 4 69 22 51 5 68 23 50 6 67 24 49 7 66 25 48 8 65 26 47 9 64 27 46 10 63 28 45 11 62 29 44 12 61 30 43 13 60 31 42 14 59 32 41 15 58 33 40 16 57 34 39 17 56 35 38 18 55 36 37 1. Unit: mm[inch] 2. Unless otherwise specified, all tolerances are ±0.25[.01] Http://www.jansum.cn E-mail:sales@jansum.cn Tel:+86-769-86299641 Fax:+86-769-86299645
G72T07DB 价格&库存
很抱歉,暂时无法提供与“G72T07DB”相匹配的价格&库存,您可以联系我们找货
