G650-04474-01
G650-04474-01
    OTHER
    G650-04474-01
G650-04474-01 数据手册
    System-on-Module datasheet  Version 1.11      Features    ● ● ● ● ● ● ● ● ● ● ● ● NXP iMX 8M SoC  ○ Quad-core ARM Cortex-A53, plus Cortex-M4F  ○ 2D/3D Vivante GC7000 Lite GPU and VPU  Google Edge TPU ML accelerator  Cryptographic coprocessor  Wi-Fi 2x2 MIMO (802.11b/g/n/ac 2.4/5 GHz)  Bluetooth 4.2  8 or 16 GB eMMC  1, 2, or 4 GB LPDDR4  USB 3.0  Gigabit Ethernet  HDMI and MIPI-DSI  MIPI-CSI-2  Up to 95x GPIO (including SPI, I2C, PWM, UART, SAI, and SDIO)    Description    The Coral System-on-Module (SoM) is a fully-integrated system that helps you build embedded systems that demand fast  machine learning (ML) inferencing. It contains NXP's iMX 8M system-on-chip (SoC), eMMC memory, LPDDR4 RAM, Wi-Fi,  and Bluetooth, but its unique power comes from Google's Edge TPU coprocessor.    The Edge TPU is a small ASIC designed by Google that accelerates TensorFlow Lite models in a power efficient manner: it's  capable of performing 4 trillion operations per second (4 TOPS), using 2 watts of power—that's 2 TOPS per watt. For  example, the Edge TPU can execute state-of-the-art mobile vision models such as MobileNet v2 at almost 400 frames per  second. This on-device ML processing reduces latency, increases data privacy, and removes the need for a constant  internet connection.    Key benefits of the SoM:    ● High-speed and low-power ML inferencing (4 TOPS @2 W)  ● A complete Linux system (running Mendel, a Debian derivative)  ● Small footprint (40 x 48 mm)    The SoM is also included in the Coral Dev Board, which is a single-board computer that enables fast prototyping and  evaluation of the standalone SoM.         Coral.ai | Copyright 2019 Google LLC.      System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Ordering information    Part number  Description  G650-04474-01  Coral System-on-Module with 1 GB RAM (8 GB eMMC)  G650-05369-01  Coral System-on-Module with 2 GB RAM (8 GB eMMC)  G650-05370-01  Coral System-on-Module with 4 GB RAM (16 GB eMMC)             Coral.ai | Copyright 2019 Google LLC.      2    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Table of contents    Features 1  Description 1  Ordering information 2  Table of contents 3  1 System components 4  1.1 Block diagrams 7  2 Mechanical dimensions 9  3 System power 9  3.1 Power signals 3.2 Power consumption 3.3 Edge TPU power characteristics 10  11  12  4 Boot mode 13  5 Peripheral interfaces 13  5.1 MIPI camera (CSI) 5.2 MIPI display (DSI) 5.3 HDMI 5.4 Ethernet 5.5 PCIe 5.6 USB 5.7 Digital audio (SAI) 5.8 Sony/Philips audio (SPDIF) 5.9 Micro-SD card 5.10 JTAG debugging 5.11 I2C 5.12 UART 5.13 SPI 5.14 GPIO 5.15 PWM 14  14  15  15  16  16  17  19  20  20  21  21  22  22  23  6 Wi-Fi and Bluetooth 23  7 Baseboard developer guide 24  7.1 7.2 7.3 7.4 7.5 7.6 7.7 Reference design Baseboard connectors Connectors, keepouts, and component max heights Trace impedance recommendations MIPI trace length compensation Thermal management Other recommendations 24  24  24  25  26  27  27  8 Pinout schematic 28  9 Environmental reliability 28  10 Document revisions 29       Coral.ai | Copyright 2019 Google LLC.      3    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        1 System components    Table 1. Available SoM components and features  Feature  Details  Main system-on-chip (iMX 8M)  Arm Cortex-A53 MPCore platform  Quad symmetric Cortex-A53 processors:  ● 32 KB L1 Instruction Cache  ● 32 KB L1 Data Cache  ● Support L1 cache RAMs protection with parity/ECC    Support of 64-bit Armv8-A architecture:  ● 1 MB unified L2 cache  ● Support L2 cache RAMs protection with ECC  ● Frequency of 1.5 GHz  Arm Cortex-M4 core platform  ● ● ● 16 KB L1 Instruction Cache  16 KB L1 Data Cache  256 KB tightly coupled memory (TCM)  Graphic Processing Unit (GPU)  ● ● ● ● ● ● Vivante GC7000Lite  4 shaders  267 million triangles/sec  1.6 Gigapixel/sec  32 GFLOPs 32-bit or 64 GFLOPs 16-bit  Supports OpenGL ES 1.1, 2.0, 3.0, 3.1, Open CL 1.2, and Vulkan  Video Processing Unit (VPU)  ● ● 4Kp60 HEVC/H.265 main, and main 10 decoder  4Kp60 VP9 and 4Kp30 AVC/H.264 decoder (requires full system  resources)  1080p60 MPEG-2, MPEG-4p2, VC-1, VP8, RV9, AVS, MJPEG, H.263  decoder  ● I/O connectivity  ● ● ● ● ● ● ● ● ● 2x USB 3.0/2.0 controllers with integrated PHY interfaces  1x Ultra Secure Digital Host Controller (uSDHC) interfaces  1x Gigabit Ethernet controller with support for EEE, Ethernet AVB,  and IEEE 1588  2x UART modules  2x I2C modules  2x SPI modules  16x GPIO lines with interrupt capability  4x PWM lines  Input/output multiplexing controller (IOMUXC) to provide centralized  pad control    Note: The list above is the number of signals available to the baseboard  (after considering SoC signals used by the SoM).  On-chip memory  ● ● Boot ROM (128 KB)  On-chip RAM (128 KB + 32 KB)       Coral.ai | Copyright 2019 Google LLC.      4    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Display  Audio  HDMI Display Interface:  ● HDMI 2.0a supporting one display up to 1080p  ● Upscale and downscale between 4K and HD video (requires full  system resources)  ● 20+ Audio interfaces 32-bit @ 384 kHz fs, with Time Division  Multiplexing (TDM) support  ● SPDIF input and output  ● Audio Return Channel (ARC) on HDMI    MIPI-DSI Display Interface:  ● MIPI-DSI 4 channels supporting one display, resolution up to   1920 x 1080 at 60 Hz  ● LCDIF display controller  ● Output can be LCDIF output or DC display controller output  ● ● 1x SPDIF input and output  2x synchronous audio interface (SAI) modules supporting I2S, AC97,  TDM, and codec/DSP interfaces  1x SAI for 8 Tx channels for HDMI output audio  1x SPDIF input for HDMI ARC input  Camera  ● 2x MIPI-CSI2 camera inputs (4-lane each)  Security  ● Resource Domain Controller (RDC) supports four domains and up to  eight regions  Arm TrustZone (TZ) architecture  On-chip RAM (OCRAM) secure region protection using OCRAM  controller  High Assurance Boot (HAB)  Cryptographic acceleration and assurance (CAAM) module  Secure non-volatile storage (SNVS): Secure real-time clock (RTC)  Secure JTAG controller (SJC)  ● ● ● ● ● ● ● ● ML accelerator  Edge TPU coprocessor  ● ● ● ASIC designed by Google that provides high performance ML  inferencing for TensorFlow Lite models  Uses PCIe Gen2 x1 and I2C/GPIO to interface with the iMX 8M SoC  4 trillion operations per second (TOPS)  2 TOPS per watt  Random access memory (SDRAM)  ● ● ● 1, 2, or 4 GB LPDDR4 SDRAM (4-channel, 32-bit bus width)  1600 MHz maximum DDR clock  Interfaces directly to the iMX 8M build-in DDR controller  Flash memory (eMMC)  ● 8 GB eMMC (KLMBG4GEND-B031) for the 1 and 2 GB RAM models  or 16 GB eMMC (EMMC16G-TB29-PZ90) for the 4 GB RAM model  8-bits MMC mode  Conforms to JEDEC version 5.0 and 5.1  ● Memory and storage  ● ● Expandable flash support  ● ● ● Meets SD/SDIO 3.0 standard  Runs at 4-bits SDIO mode  Supports system boot from SD card         Coral.ai | Copyright 2019 Google LLC.      5    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Network & wireless  Ethernet  ● ● 10/100/1000 Mbps Ethernet/IEEE 802.3 networks  Reduced gigabit media-independent interface (RGMII)  Wi-Fi  Murata LBEE5U91CQ module:  ● Wi-Fi 2x2 MIMO (802.11a/b/g/n/ac 2.4/5 GHz)  ● Supports PCIe host interface for W-LAN  Bluetooth  Murata LBEE5U91CQ module:  ● Bluetooth 4.2 (supports Bluetooth low-energy)  ● Supports UART interface  Security  Cryptographic coprocessor  Microchip ATECC608A cryptographic coprocessor:  ● Asymmetric (public/private) key cryptographic signature solution  based on Elliptic Curve Cryptography and ECDSA signature  protocols  Hardware interface  Baseboard connectors  3x 100-pin connectors (Hirose DF40C-100DP-0.4V)                 Coral.ai | Copyright 2019 Google LLC.      6    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        1.1 Block diagrams    Figures 1 and 2 illustrate the core components on the SoM and SoC.      Figure 1. Block diagram of the SoM components         Coral.ai | Copyright 2019 Google LLC.      7    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01          Figure 2. Block diagram of iMX 8M SoC components, provided by NXP (some I/O signals on the SoC are consumed on the  SoM, so refer to table 1 for availability)           Coral.ai | Copyright 2019 Google LLC.      8    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        2 Mechanical dimensions    Table 2. SoM mechanical dimensions  Measurement  Value  Size  48 x 40 x 5.11 mm  Weight  13 g    Figure 3 illustrates all of the SoM's dimensions. For a top-down view of the baseboard connector locations and component  height restrictions, see the Baseboard developer guide.      Figure 3. SoM dimensions (in millimeters)    3 System power    The SoM requires 5 V as power input (at VSYS_5V). The SoM then generates the local voltage rails for all SoM components  through on-board PMICs.    Table 3. SoM power requirements  Power input  Voltage  Main power supply (VSYS_5V)  5 V ± 5%    Caution: Do not connect the 1.8/3.3 V power output pins to any high current devices or you might brownout the system.  These power lines are shared with internal SoM circuits, so there is no safe limit for a high current device, but you can  safely use them for low current tasks such as for a level shifter or pull-up/down.    Caution: Do not connect any of the 3.3 V I/O pins to a device that draws more than ~82 mA of power or you will  brownout the system.         Coral.ai | Copyright 2019 Google LLC.      9    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        3.1 Power signals    Even though there are multiple power signals defined in the board-to-board connectors, only the VSYS_5V and ground  connections are required. All others are optional.    Note: Make sure to route all the VSYS_5V and GND pins, and add decoupling (bypass) capacitors between VSYS_5V  and GND near the mating connector pins.     Table 4. Power and reset pin signals  Name  Type  Connector  Pins  Voltage  Description  VSYS_5V  Power  J1312  93, 94, 95, 96, 97, 98, 99, 100  5 V  Main 5 V power input to SoM.  Must be connected.  GND  Power  J1312  9, 10, 65, 66, 71, 72, 77, 78, 83,  84    Common ground.  Must be connected.  GND  Power  J1311  1, 2, 7, 8, 13, 14, 19, 20, 25, 26,  31, 32, 37, 38, 43, 44, 49, 50,  55, 56, 61, 62, 67, 68, 73, 74,  79, 80, 86, 89, 90, 94, 99, 100    Common ground.  Must be connected.  GND  Power  J1310  1, 2, 7, 25, 39, 40, 42, 44, 45,  46, 50, 51, 56, 57, 62, 63, 64,  65, 66, 67, 68, 69, 70, 71, 72,  73, 74, 75, 76, 77, 78, 80    Common ground.  Must be connected.  DCDC_3V3  Power  J1310  84, 86, 88, 90  3.3 V  3.3 V output from SoM. Can be left  floating if not used. Not for  high-current usage; can be used to  pull-up GPIO.  VDD_3V3  Power  J1310  94, 96, 98 100  3.3 V  3.3 V output from SoM. Can be left  floating if not used. Not for  high-current usage; can be used to  pull-up GPIO.  VDDA_1V8  Power  J1310  91, 93, 95, 97, 99  1.8 V  1.8 V output from SoM. Can be left  floating if not used. Not for  high-current usage; can be used to  pull-up GPIO.  POR_B  Output  J1310  79  3.3 V  "Power_On_Reset" signal from iMX  8M PMIC to reset the SoC  (active-low open-drain output).  Available to enable sequencing.  PWRON_B  Input  J1312  86  3.3 V  "Power_On" (active-low input).  Triggers a reset of the iMX 8M  PMIC power cycle.  Pull-up in SoM.  SYS_nRST  Input  J1312  63  3.3 V  System reset (active-low input).  Recommended for reset button on  baseboard.  Pull-up in SoM.       Coral.ai | Copyright 2019 Google LLC.      10    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        3.2 Power consumption    Caution: You must provide a cooling solution to ensure the SoM surface maintains an operational temperature as  specified in the Environmental reliability section. Unlike the Coral Dev Board, the standalone SoM does not include a  cooling solution (the SoM components are covered only with an EMI shield).    The power consumption numbers listed in this section are based on a high performance test that includes the following:    ● GPU: 3D rendering  ● CPU: 2 of 4 cores 100% loaded  ● Active Wi-Fi download  ● 7" HDMI display on  ● DDR: 800 MHz  ● Edge TPU running MobileNet V1 at 500 MHz  ● Fan intermittently on    Table 5 lists the power draw measurements during different operational tests both for both the SoM, and for the Dev Board  baseboard and SoM working together.    Table 5. SoM power draw measurements  Operational test  SoM power  System power (SoM + Dev Board baseboard)*  Idle  2.6 W  4.0 W  Idle with HDMI display on  3.0 W  4.3 W  High performance  6.2 W  8.5 W  * Tested with Coral Dev Board—performance on your custom baseboard may vary.    During the high performance test, the top power-consuming components (top heat sources) are as indicated in figure 4.      Figure 4. Power draw and ordinate locations (in millimeters) of top power components during high performance test             Coral.ai | Copyright 2019 Google LLC.      11    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        3.3 Edge TPU power characteristics    The current drawn by the Edge TPU is highly variable and depends on the model being executed. Although the average  current drawn by the Edge TPU may be less than 500 mA, it can repeatedly and rapidly spike up to 3 A, depending on the  model you're running. These spikes also occur suddenly: even a simple model can generate current transients in excess of  1 A/μs, which can last several tens of microseconds.    The Edge TPU dissipates power roughly proportional to its computational load. The resulting heat in the Edge TPU die must  be safely and reliably conducted away to avoid excessive die temperatures that can affect performance and reliability.    The Edge TPU’s junction temperature Tj must stay below the maximum operating specification:    ● Maximum Edge TPU junction temperature Tj: 115 °C    Warning: Exceeding the maximum temperature can result in permanent damage to the Edge TPU and surrounding  components, and can possibly cause fire and serious damage, injury, or death.    For information about thermal management strategies for the Edge TPU, see section 7.6.           Coral.ai | Copyright 2019 Google LLC.      12    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        4 Boot mode    Use the BOOT_MODE[1:0] pins to configure the SoM boot mode setting as indicated in the following tables.    Table 6. Boot mode pin signals  Name  Type  Connector  Pins  Voltage  Description  BOOT_MODE0  Input  J1312  64  3.3 V  SoC BOOT_MODE0 signal (can be set by  switch or pin-strap on baseboard)  BOOT_MODE1  Input  J1312  62  3.3 V  SoC BOOT_MODE1 signal (can be set by  switch or pin-strap on baseboard)    Table 7. Boot mode pin settings  BOOT_MODE[1:0] bits  Boot type  00  Boot from fuses (default behavior)  01  Serial downloader  10  Internal boot  11  Reserved    The boot configuration is specified by the iMX 8M SoC, so for more details, refer to the iMX 8M SoC documentation.    Note: If BOOT_MODE[1:0] is "10" (internal boot), then GPIO pins SAI1_RX[7:0] and SAI1_TX[7:0] are used to enable boot  configuration overrides (such as whether to boot from eMMC or SD card) by latching them to the BOOT_CFG[15:0] bits in  the SoC. For further details, such as information about GPIO boot overrides and boot fuses, see the iMX 8M SoC  documentation.    5 Peripheral interfaces    The following interfaces are available from the SoM, through the three 100-pin board-to-board connectors.    This section is organized based on the default pin functions when running the Mendel operating system. For information  about alternative pin functions you may enable with your own device tree overlay, see the iMX 8M SoC documentation.    Note: All I/O pins have a 90 k pull-down resistor in the SoC that are used by default during bootup, which you can  reconfigure with a device tree overlay after bootup. However, some pins (such as I2C, some SAI, and some SD2 pins)  also have pull-up resistors inside the SoM, as noted in the following tables, which you cannot reconfigure with a device  tree overlay.    Caution: Do not connect any of the 3.3 V I/O pins to a device that draws more than ~82 mA of power or you will  brownout the system.             Coral.ai | Copyright 2019 Google LLC.      13    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        5.1 MIPI camera (CSI)    There are two channels for MIPI camera serial interface (CSI-2), each with four lanes and a maximum bit rate of 1.5 Gbps.    Table 8. CSI channel 1 pins  Name  Type  Connector  Pins  Voltage  Description  MIPI_CSI1_CLK_P/N  Input  J1311  18/16  0.2-1.2 V  MIPI CSI1 clock (positive/negative)  MIPI_CSI1_D0_P/N  Input  J1311  12/10  0.2-1.2 V  MIPI CSI1 data (positive/negative)  MIPI_CSI1_D1_P/N  Input  J1311  23/21  0.2-1.2 V  MIPI CSI1 data (positive/negative)  MIPI_CSI1_D2_P/N  Input  J1311  6/4  0.2-1.2 V  MIPI CSI1 data (positive/negative)  MIPI_CSI1_D3_P/N  Input  J1311  29/27  0.2-1.2 V  MIPI CSI1 data (positive/negative)  Name  Type  Connector  Pins  Voltage  Description  MIPI_CSI2_CLK_P/N  Input  J1311  36/34  0.2-1.2 V  MIPI CSI2 clock (positive/negative)  MIPI_CSI2_D0_P/N  Input  J1311  35/33  0.2-1.2 V  MIPI CSI2 data (positive/negative)  MIPI_CSI2_D1_P/N  Input  J1311  30/28  0.2-1.2 V  MIPI CSI2 data (positive/negative)  MIPI_CSI2_D2_P/N  Input  J1311  24/22  0.2-1.2 V  MIPI CSI2 data (positive/negative)  MIPI_CSI2_D3_P/N  Input  J1311  41/39  0.2-1.2 V  MIPI CSI2 data (positive/negative)    Table 9. CSI channel 2 pins    5.2 MIPI display (DSI)    The four-lane MIPI display serial interface (DSI) offers the following features:    ● Resolution up to 1920 x 1080 at 60 Hz  ● LCDIF display controller  ● Maximum bit rate of 1.5 Gbps    Table 10. DSI pins  Name  Type  Connector  Pins  Voltage  Description  MIPI_DSI1_CLK_P/N  Output  J1311  59/57  0.2-1.2 V  MIPI DSI clock (positive/negative)  MIPI_DSI1_D0_P/N  Output  J1311  47/45  0.2-1.2 V  MIPI DSI data (positive/negative)  MIPI_DSI1_D1_P/N  Output  J1311  54/52  0.2-1.2 V  MIPI DSI data (positive/negative)  MIPI_DSI1_D2_P/N  Output  J1311  42/40  0.2-1.2 V  MIPI DSI data (positive/negative)  MIPI_DSI1_D3_P/N  Output  J1311  48/46  0.2-1.2 V  MIPI DSI data (positive/negative)             Coral.ai | Copyright 2019 Google LLC.      14    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        5.3 HDMI    The High-Definition Multimedia Interface (HDMI) connection provides the following features:    ● HDMI 2.0a supporting one display up to 1080p  ● Upscale and downscale between 4K and HD video (requires full system resources)  ● 20+ Audio interfaces 32-bit @ 384 kHz fs, with Time Division Multiplexing (TDM) support  ● SPDIF input and output  ● Audio Return Channel (ARC) on HDMI    Table 11. HDMI pins  Name  Type  Connector  Pins  Voltage  Description  HDMI_REFCLKP/N  Output  J1310  58/60  3.3 V  HDMI reference clock (27 MHz) (positive/negative).  Required for bootup, even if you don't use HDMI.  For detail, see the reference design schematic.  HDMI_CLKP/N  Output  J1312  68/70  3.3 V  HDMI clock (positive/negative)  HDMI_TX0_P/N  Output  J1312  75/73  3.3 V  HDMI transmit (positive/negative)  HDMI_TX1_P/N  Output  J1312  79/81  3.3 V  HDMI transmit (positive/negative)  HDMI_TX2_P/N  Output  J1312  76/74  3.3 V  HDMI transmit (positive/negative)  HDMI_AUX_P/N  Output  J1312  82/80  3.3 V  HDMI AUX (positive/negative)  HDMI_HPD  Output  J1312  89  3.3 V  HDMI Hot Plug Detect  HDMI_DDC_SDA  Output  J1312  85  3.3 V  HDMI Display Data Channel data  HDMI_DDC_SCL  Output  J1312  87  3.3 V  HDMI Display Data Channel clock  HDMI_CEC  Output  J1312  91  3.3 V  HDMI Consumer Electronic Control    5.4 Ethernet    The Ethernet Media Access Controller (MAC) supports 10/100/1000 Mbps Ethernet/IEEE 802.3 networks with reduced  gigabit media-independent interface (RGMII). Requires an Ethernet PHY on the baseboard.    Table 12. Ethernet pins  Name  Type  Connector  Pins  Voltage  Description  ENET_RD0  Input  J1310  33  1.8 V  RGMII receive from PHY  ENET_RD1  Input  J1310  35  1.8 V  RGMII receive from PHY  ENET_RD2  Input  J1310  31  1.8 V  RGMII receive from PHY  ENET_RD3  Input  J1310  37  1.8 V  RGMII receive from PHY  ENET_RX_CTL  Input  J1310  29  1.8 V  RGMII receive from PHY  ENET_RXC  Input  J1310  27  1.8 V  RGMII receive from PHY       Coral.ai | Copyright 2019 Google LLC.      15    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        ENET_TD0  Output  J1310  19  1.8 V  RGMII transmit to PHY  ENET_TD1  Output  J1310  21  1.8 V  RGMII transmit to PHY  ENET_TD2  Output  J1310  17  1.8 V  RGMII transmit to PHY  ENET_TD3  Output  J1310  15  1.8 V  RGMII transmit to PHY  ENET_TX_CTL  Output  J1310  13  1.8 V  RGMII transmit to PHY  ENET_TXC  Output  J1310  23  1.8 V  RGMII transmit to PHY  ENET_MDC  Output  J1310  11  1.8 V  RGMII clock for PHY  ENET_MDIO  Output  J1310  9  1.8 V  RGMII MDIO data for PHY  ENET_nRST  (GPIO1_IO09)  Output  J1312  43  3.3 V  PHY reset  ENET_nINT  (GPIO1_IO11)  Input  J1312  39  3.3 V  PHY interrupt  ENET_WoL  (GPIO1_IO10)  Input  J1312  41  3.3 V  PHY Wake-on-Lan  CLKO_25M  (GPIO1_IO15)  Output  J1310  54  3.3 V  Optional 25 Mhz clock to PHY    5.5 PCIe    The SoC includes PCIE1 and PCIE2 lines that are routed to the baseboard connectors, but you should not need to connect  these and you should not remap these with your own device tree because both are used on the SoM for Wi-Fi (PCIE1) and  the Edge TPU (PCIE2).    5.6 USB    There are two USB controllers and corresponding PHYs on the SoM. Each USB instance contains USB 3.0 (USB 3.1 Gen 1)  core, which can operate in both USB 3.0 and 2.0 mode.    Table 13. USB channel 1 pins      Name  Type  Connector  Pins  Voltage  Description  USB1_DP/N  I/O  J1311  51/53  3.3 V  USB 2.0 (positive/negative)  USB1_TXP/N  Output  J1311  58/60  1.8 V  USB 3.0 transmit (positive/negative)  USB1_RXP/N  Input  J1311  64/66  1.8 V  USB 3.0 receive (positive/negative)  USB1_VBUS  Input  J1311  82/84  5 V  VBUS detect (same at both pins)  USB1_ID  Input  J1311  76  3.3 V  USB ID         Coral.ai | Copyright 2019 Google LLC.      16    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Table 14. USB channel 2 pins  Name  Type  Connector  Pins  Voltage  Description  USB2_DP/N  I/O  J1311  63/65  3.3 V  USB 2.0 (positive/negative)  USB2_TXP/N  Output  J1311  69/71  1.8 V  USB 3.0 transmit (positive/negative)  USB2_RXP/N  Input  J1311  70/72  1.8 V  USB 3.0 receive (positive/negative)  USB2_VBUS  Input  J1311  75/77  5 V  VBUS detect (same at both pins)  USB2_ID  Input  J1311  88  3.3 V  USB ID    5.7 Digital audio (SAI)    The SAI module provides a synchronous audio interface (SAI) that supports full duplex serial interfaces with frame  synchronization, such as I2S, AC97, TDM, and codec/DSP interfaces.    Note: If booting the SoM in eFUSE mode (default behavior), all SAI pins are available during boot. However, when using  the other boot modes, pins SAI1_RX[7:0] and SAI1_TX[7:0] are used to enable boot configuration overrides by latching  them to the BOOT_CFG[15:0] bits in the SoC—that is, only until boot completes. The SoM uses internal pin strap (pull-up  and pull-down) resistors to select the different boot configuration, so you should be careful if you add any pull-up/down  resistors for these pins on your baseboard. For details, see the iMX 8M SoC documentation.    Table 15. SAI 1 signals  Name  Type  Connector  Pins  Voltage  Description  SAI1_MCLK  I/O  J1312  26  3.3 V  Audio master clock  SAI1_RXC  Input  J1312  17  3.3 V  Receive bit clock  SAI1_RXFS  Input  J1312  19  3.3 V  Receive frame sync  SAI1_RXD0  Input  J1312  33  3.3 V  Receive channel.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_RXD1  Input  J1312  35  3.3 V  Receive channel.  Pull-up in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_RXD2  Input  J1312  27  3.3 V  Receive channel.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_RXD3  Input  J1312  31  3.3 V  Receive channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_RXD4  Input  J1312  29  3.3 V  Receive channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.       Coral.ai | Copyright 2019 Google LLC.      17    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        SAI1_RXD5  Input  J1312  21  3.3 V  Receive channel.  Pull-up in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_RXD6  Input  J1312  25  3.3 V  Receive channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_RXD7  Input  J1312  23  3.3 V  Receive channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXC  Output  J1312  40  3.3 V  Transmit bit clock.  SAI1_TXFS  Output  J1312  46  3.3 V  Transmit frame sync.  SAI1_TXD0  Output  J1312  44  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD1  Output  J1312  42  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD2  Output  J1312  30  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD3  Output  J1312  36  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD4  Output  J1312  38  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD5  Output  J1312  34  3.3 V  Transmit channel.  Pull-up in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD6  Output  J1312  28  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.  SAI1_TXD7  Output  J1312  32  3.3 V  Transmit channel.  Pull-down in SoM: 10k Ohm.  Reserved during boot, except in eFUSE mode. See note  above.         Coral.ai | Copyright 2019 Google LLC.      18    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Table 16. SAI 2 signals  Name  Type  Connector  Pins  Voltage  Description  SAI2_TXD  Output  J1312  14  3.3 V  Transmit channel  SAI2_RXD  Input  J1312  20  3.3 V  Receive channel  SAI2_TXC  Output  J1312  18  3.3 V  Transmit bit clock  SAI2_TXFS  Output  J1312  16  3.3 V  Transmit frame sync  SAI2_MCLK  I/O  J1312  12  3.3 V  Audio master clock  SAI2_RXFS  Input  J1312  24  3.3 V  Receive frame sync  SAI2_RXC  Input  J1312  23  3.3 V  Receive bit clock    Note: The SoC includes SAI3 lines, but most of these are used by the SoM for Wi-Fi, so you should not remap these with  your device tree. Only SAI3_RXC and SAI3_RXFS are provided by the SoM baseboard connectors and available for use  as GPIO.    The SoC also includes SAI5 lines that are all provided by the SoM connectors, but three of them are pin-strapped inside  the SoM (SAI5_RXD1, SAI5_RXD3, and SAI5_RXFS), and their level is latched by the U-Boot bootloader to determine the  SoM SKU (LPDDR4 memory size). We recommend that you do not use these three pins for any other purpose and do  not connect them. The remaining SAI5 pins (SAI5_MCLK, SAI5_RXC, SAI5_RXD0, and SAI5_RXD2) are available for use  as GPIO.    5.8 Sony/Philips audio (SPDIF)    Sony/Philips Digital Interface (SPDIF) is a standard audio file transfer format that supports Transmitter and Receiver  functionality. Refer to NXP iMX 8M documentation for additional details.    Table 17. SPDIF pin signals  Name  Type  Connector  Pins  Voltage  Description  SPDIF_EXT_CLK  Output  J1311  92  3.3 V  External clock signal  SPDIF_TX  Output  J1311  96  3.3 V  Transmit data channel  SPDIF_RX  Input  J1311  98  3.3 V  Receive data channel             Coral.ai | Copyright 2019 Google LLC.      19    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        5.9 Micro-SD card    An Ultra Secure Digital Host Controller (uSDHC) module provides the interface between the host and SD/SDIO/MMC cards,  with the following features:    ● SD/SDIO standard, up to version 3.0  ● MMC standard, up to version 5.0  ● 3.3 V operation only  ● 1- and 4-bit SD/SDIO/MMC modes    Table 18. SD/MMC pin signals  Name  Type  Connector  Pins  Voltage  Description  SD2_CLK  Output  J1310  48  3.3 V  Serial clock  SD2_CMD  Output  J1310  26  3.3 V  Command line  Pull-up in SoM: 10k Ohm  SD2_nCD  (SD2_CD_B)  Output  J1310  24  3.3 V  Card detect  SD2_DAT0  I/O  J1310  28  3.3 V  Data bit 0  Pull-up in SoM: 10k Ohm  SD2_DAT1  I/O  J1310  32  3.3 V  Data bit 1  SD2_DAT2  I/O  J1310  34  3.3 V  Data bit 2  SD2_DAT3  I/O  J1310  38  3.3 V  Data bit 3  SD2_nRST  (SD2_RESET_B)  Output  J1310  36  3.3 V  Card reset  SDIO_WAKE  (SD2_WP)  Output  J1310  30  3.3 V  Write protect or GPIO    5.10 JTAG debugging    5-pin JTAG debugging with a Secure JTAG Controller (SJC) for secure debugging.    Table 19. JTAG pin signals  Name  Type  Connector  Pins  Voltage  Description  JTAG_TMS  Output  J1312  59  3.3 V  Test mode select  JTAG_TDI  Input  J1312  61  3.3 V  Test data in  JTAG_TDO  Output  J1312  57  3.3 V  Test data out  JTAG_TCK  Output  J1312  53  3.3 V  Test clock  JTAG_nTRST  Input  J1312  55  3.3 V  Test reset             Coral.ai | Copyright 2019 Google LLC.      20    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        5.11 I2C    Two I2C bus interfaces are available.    Table 20. I2C pin signals  Name  Type  Connector  Pins  Voltage  Description  I2C2_SCL  Input  J1311  87  3.3 V  Serial clock  Pull-up in SoM: 4.7k Ohm  I2C2_SDA  Output  J1311  85  3.3 V  Serial data  Pull-up in SoM: 4.7k Ohm  I2C3_SCL  Input  J1311  83  3.3 V  Serial clock  Pull-up in SoM: 4.7k Ohm  I2C3_SDA  Output  J1311  81  3.3 V  Serial data  Pull-up in SoM: 4.7k Ohm    Note: The SoC also includes I2C1 and I2C4 lines, but these are used by the SoM for power management and wireless  controls, so you should not remap these with your own device tree.    5.12 UART    Two UART v2 modules are available with the following features:    ● 7- or 8-bit data words, 1 or 2 stop bits, programmable parity (even, odd, or none).  ● Programmable baud rates up to 4 Mbps.  ● 32-byte FIFO on Tx and 32 half-word FIFO on Rx supporting auto-baud.    Note: By default, the Mendel operating system configures UART1 for use with the the serial console.    The SoC also includes UART2 and UART4 lines, but these are used by the SoM for Bluetooth, so you should not remap  these with your own device tree.    Table 21. UART pin signals  Name  Type  Connector  Pins  Voltage  Description  UART1_TXD  Output  J1311  93  3.3 V  Transmit channel  UART1_RXD  Input  J1311  95  3.3 V  Receive channel  UART3_TXD  Output  J1311  91  3.3 V  Transmit chanel  UART3_RXD  Input  J1311  97  3.3 V  Receive channel             Coral.ai | Copyright 2019 Google LLC.      21    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        5.13 SPI    Two full-duplex eSPI interfaces are available, with data rates up to 52 Mbit/s and two chip select lines.    Table 22. SPI channel 1 pin signals  Name  Type  Connector  Pins  Voltage  Description  ECSPI1_MISO  Input  J1312  5  3.3 V  Master input  ECSPI1_MOSI  Output  J1312  7  3.3 V  Master output  ECSPI1_SCLK  Output  J1312  4  3.3 V  Serial clock  ECSPI1_SS0  Output  J1312  8  3.3 V  Chip select  ECSPI1_SS1  Output  J1310  6  3.3 V  Chip select    Table 23. SPI channel 2 pin signals  Name  Type  Connector  Pins  Voltage  Description  ECSPI2_MISO  Input  J1312  3  3.3 V  Master input  ECSPI2_MOSI  Output  J1312  6  3.3 V  Master output  ECSPI2_SCLK  Output  J1312  2  3.3 V  Serial clock  ECSPI2_SS0  Output  J1312  1  3.3 V  Chip select  ECSPI2_SS1  Output  J1310  4  3.3 V  Chip select    5.14 GPIO    The following pins are configured for general purpose input/output, by default. Additionally, you can reconfigure other pins  (SAI, SPDIF, SDIO, I2C, UART, SPI, and PWM) to behave as GPIO, using a device tree overlay.    Table 24. GPIO pin signals  Name  Type  Connector  Pins  Voltage  Description  GPIO6  I/O  J1312  49  3.3 V  GPIO  GPIO7  I/O  J1312  45  3.3 V  GPIO  GPIO8  I/O  J1312  47  3.3 V  GPIO  GPIO12  I/O  J1312  51  3.3 V  GPIO  NAND_CLE  I/O  J1310  10  3.3 V  GPIO  NAND_DATA02  I/O  J1310  12  3.3 V  GPIO  NAND_ALE  I/O  J1310  16  3.3 V  GPIO  NAND_DATA07  I/O  J1310  18  3.3 V  GPIO       Coral.ai | Copyright 2019 Google LLC.      22    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        NAND_DATA06  I/O  J1310  20  3.3 V  GPIO  NAND_DATA03  I/O  J1310  22  3.3 V  GPIO  SAI3_RXC  I/O  J1312  13  3.3 V  GPIO  SAI3_RXFS  I/O  J1312  15  3.3 V  GPIO  SAI5_MCLK  I/O  J1312  50  3.3 V  GPIO  SAI5_RXC  I/O  J1312  56  3.3 V  GPIO  SAI5_RXD0  I/O  J1312  58  3.3 V  GPIO  SAI5_RXD2  I/O  J1312  54  3.3 V  GPIO  SAI5_RXD1  I/O  J1312  48  3.3 V  SAI5_RXD3  I/O  J1312  52  3.3 V  SAI5_RXFS  I/O  J1312  60  3.3 V  GPIO  Do not pin-strap.  Pin-strapped in SoM for latch from bootloader. We  recommend you do not connect.    5.15 PWM    There are four PWM output pins available with 16-bit resolution and 4x16 data FIFO.    Table 25. PWM pin signals  Name  Type  Connector  Pins  Voltage  Description  PWM1 (GPIO1_IO01)  Output  J1312  88  3.3 V  PWM or GPIO  PWM2 (GPIO1_IO013)  Output  J1312  90  3.3 V  PWM or GPIO  PWM3 (GPIO1_IO014)  Output  J1312  92  3.3 V  PWM or GPIO  PWM4 (SAI3_MCLK)  Output  J1312  11  3.3 V  PWM or GPIO    6 Wi-Fi and Bluetooth    The SoM includes the Murata LBEE5U91CQ module, which provides Wi-Fi (IEEE 802.11 a/b/g/n/ac WLAN, 2.4/5 GHz) and  Bluetooth 4.2 (with Bluetooth Low Energy support), using wireless antennas integrated into the board.             Coral.ai | Copyright 2019 Google LLC.      23    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        7 Baseboard developer guide    This section provides details to help you integrate the Coral SoM into your own baseboard (carrier board) hardware.    7.1 Reference design    If you'd like to see a reference baseboard design that uses the System-on-Module, download the following schematic and  layout files for the Coral Dev Board.    Table 26. Dev Board schematics, layout, and 3D files  File  Description  Coral-Dev-Board-baseboard-schematic.pdf  Baseboard schematic in PDF  Coral-Dev-Board-baseboard-schematic-Altium.zip  Baseboard schematic files in Altium format  Coral-Dev-Board-baseboard-layout-Allegro.brd  Baseboard CAD layout in BRD format  Coral-Dev-Board.STEP  Dev Board (baseboard and SoM) 3D CAD file in STEP format  Coral-SoM.STEP  SoM-only 3D CAD file in STEP format    7.2 Baseboard connectors    The SoM connects to the host baseboard with three 100-pin connectors.    Table 27. SoM and baseboard connectors  SoM  Baseboard  3x 100-position plug  Hirose Electric DF40C-100DP-0.4V(51)  3x 100-position receptacle  Hirose Electric DF40HC(3.0)-100DS-0.4V(51)    The location of each connector plug on the SoM is illustrated in figure 3, and the corresponding position for each  receptacle on your baseboard is illustrated in figure 5.    7.3 Connectors, keepouts, and component max heights    Figure 5 illustrates the area of your baseboard where the SoM connects. The measurements are relative to the standoff in  the bottom-left corner, indicating the position for the three board-to-board (B2B) connectors (Hirose DF40C-100DP-0.4V),  two standoffs, and the following component regions:    A. Antenna keepout: Place no components and no copper in this region. This area of your baseboard is directly below  the SoM's Wi-Fi and Bluetooth antennas, so it must be kept clear of any metals to ensure strong radio signals.  B. Max height of baseboard components in this region is 2.8mm.  C. Max height of baseboard components in this region is 1.5mm.    Additionally, figure 5 indicates the location of pin 1 on your baseboard connectors. To see all the pin assignments, refer to  the pinout schematic.       Coral.ai | Copyright 2019 Google LLC.      24    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01            Figure 5. Top view of baseboard connectors and component restrictions (measured in millimeters)    7.4 Trace impedance recommendations    The following table lists the recommended impedance for high-speed signals on the baseboard.    Table 28. Trace impedance recommendation  Signal group  Impedance  PCB manufacture tolerance (±)  All single-ended signal, unless specified  50 Ohm single-ended  10%  PCIe TX/RX data pair  85 Ohm differential  10%  USB differential signals  90 Ohm differential  10%  Differential signals: including Ethernet, PCIe clocks,  100 Ohm differential  HDMI, MIPI (CSI and DSI)  10%             Coral.ai | Copyright 2019 Google LLC.      25    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        7.5 MIPI trace length compensation    MIPI signals for the CSI/DSI interfaces are high-speed signals that require the total etched trace lengths for each line within  a group (the paired clock lanes and four data lanes) be equal to each other. Due to space constraints on the SoM, the MIPI  signal traces lengths currently are not equal (as indicated in the following tables). You must incorporate the length  difference on your baseboard traces such that the trace lengths for each MIPI group match each other.    Table 29. CSI channel 1 signal trace length on SoM  Name  Etch length (mils)  Manhattan length (mils)  MIPI_CSI1_CLKN  306.1  287.89  MIPI_CSI1_CLKP  309.4  297.73  MIPI_CSI1_D0N  310.97  309.53  MIPI_CSI1_D0P  315.24  319.38  MIPI_CSI1_D1N  242.48  209.15  MIPI_CSI1_D1P  241.23  250.5  MIPI_CSI1_D2N  354.22  356.78  MIPI_CSI1_D2P  351.84  392.21  MIPI_CSI1_D3N  246.25  230.81  MIPI_CSI1_D3P  250.2  272.16    Table 30. CSI channel 2 signal trace length on SoM      Name  Etch length (mils)  Manhattan length (mils)  MIPI_CSI2_CLKN  299.51  282.39  MIPI_CSI2_CLKP  301.92  323.73  MIPI_CSI2_D0N  258.48  252.46  MIPI_CSI2_D0P  258.58  293.81  MIPI_CSI2_D1N  289.71  260.74  MIPI_CSI2_D1P  292.95  302.08  MIPI_CSI2_D2N  293.48  266.24  MIPI_CSI2_D2P  298.18  280.42  MIPI_CSI2_D3N  265.86  274.12  MIPI_CSI2_D3P  268.14  315.46         Coral.ai | Copyright 2019 Google LLC.      26    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        Table 31. DSI signal trace length on SoM  Name  Etch length (mils)  Manhattan length (mils)  MIPI_DSI_CLKN  296.45  339.08  MIPI_DSI_CLKP  297.41  380.43  MIPI_DSI_D0N  212.5  219  MIPI_DSI_D0P  211.9  260.34  MIPI_DSI_D1N  322.16  347.35  MIPI_DSI_D1P  326.95  388.69  MIPI_DSI_D2N  305.05  304.05  MIPI_DSI_D2P  309.08  345.38  MIPI_DSI_D3N  297.15  274.52  MIPI_DSI_D3P  298.16  315.86    7.6 Thermal management    Caution: You must provide a cooling solution to ensure the SoM surface maintains an operational temperature as  specified in section 9.    You can use the SoM's threaded standoffs (indicated in figure 3) to mount a passive or active cooling solution.    The Edge TPU includes an internal temperature sensor and the Coral PCIe driver provides a programmable interface to  help you make power management decisions. Using the PCIe device interface, you can read the Edge TPU temperature  and make your own thermal-management decisions such as when to activate a fan. Additionally, you can configure some  Edge TPU parameters to specify the temperature at which the Edge TPU should shut down, and specify trip-points for  dynamic frequency scaling (DFS). For more information, read the app note, Manage the PCIe module temperature.    7.7 Other recommendations    ● ● ● Make sure to route all the VSYS_5V and GND pins, and add decoupling (bypass) capacitors between VSYS_5V and  GND near the mating connector pins.  When placing a pull-up or pull-down resistor on some of the SoM signals, such as I/O pins (especially SAI1_TXD[7:0]  and SAI1_RXD[7:0]), review the signal description for each peripheral interface, because some of them already have  pull-up/down resistor in the SoM for initialization purposes.  Make sure to connect the HDMI reference clock (HDMI_REFCLK) to a 27 MHz source. Even if you do not use HDMI,  this is required during bootup for a DRM-related software check. For detail, see the reference design schematic.              Coral.ai | Copyright 2019 Google LLC.      27    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        8 Pinout schematic    Caution: The signal directions in figure 6 are not all accurate. Instead refer to the "type" of each pin in the tables from the  Peripheral interfaces section.      Figure 6. SoM connector schematic (see large image)    9 Environmental reliability    Table 32. SoM environmental and mechanical limits  Measurement  Limits  Shock  50 G / 20 ms  Vibration  20 G / 0-600 Hz  MTTF  >200,000 hours  Operating temperature  -20 to +85 °C 1  Storage temperature  -40 to +85 °C  Relative humidity  10% to 90% (operation)  5% to 95% (storage)  The operating temperature range is for the SoM's ambient environment, and assumes that the Edge TPU junction  temperature (Tj) does not exceed its absolute maximum rating, as specified in section 3.3. It's your responsibility to provide  thermal solution that maintains the maximum junction temperature for all SoM components.    1          Coral.ai | Copyright 2019 Google LLC.      28    System-on-Module datasheet v1.11  G650-04474-01 / G650-05369-01 / G650-05370-01        10 Document revisions    Table 33. History of changes to this document  Version  Changes  1.11 (January 2021)  Changed the operating temperature to reflect the true SoM limits (previous limit of 0 to 50 °C  was incorrectly based on performance with the heatsink and fan on the Dev Board).  Added section 3.3 and section 7.6 to elaborate on the Edge TPU's power/thermal behaviors.  Added detail about 16 GB eMMC included with the 4 GB RAM model, and eMMC PNs.  Removed misleading "External memory" section about the SoC from table 1.  1.10 (October 2020)  Fixed MIPI_DSI1_D2_N pin position in table 10.  1.9 (August 2020)  Added detail about HDMI_REFCLK requirement.  Removed list of certifications (instead see website).  Updated document styles.  1.8 (July 2020)  Added part numbers for all SKU variants.  1.7 (June 2020)  Corrected J1311 list of grounds: changed pin 33 to 32.  1.6 (April 2020)  Added detail about SAI5 pins that are pin-strapped in the SoM.  1.5 (February 2020)  Clarified and enhanced documentation of SAI, power and reset pin signals.  Added information about PWRON_B pin.  1.4 (January 2020)  Fixed USB2_RXP/N pin position.  1.3 (December 2019)  Fixed HDMI_TX1 pin positions.  1.2 (August 2019)  Added PDF download of this datasheet and the Dev Board baseboard schematic.  1.1 (July 2019)  Removed wireless antenna connector details.  1.0 (June 2019)  Initial release.         Coral.ai | Copyright 2019 Google LLC.      29
G650-04474-01 价格&库存
很抱歉,暂时无法提供与“G650-04474-01”相匹配的价格&库存,您可以联系我们找货
