GCNR5040-100MC
GCNR5040-100MC
    GLE(格莱尔)
    功率电感 SMD
GCNR5040-100MC 数据手册
P. 1/ 7 客户 Customer: GCNR5040 系列 GLE 部品型号 GLE Part NO. 接受 Accepted by Customer's Part No. 客户部品型号 Physical dimensions 外形寸法 GCNR5040 名 Type 型 承认书 Specifications Ref.No. 单位 Unit: RoHS Comp. mm A B C D E F 5.0±0.2 5.0±0.2 4.0+0.2/-0.3 4.0±0.2 1.25±0.2 2.5±0.2 备注:黑色印字 NO. 构成部品 Components 材质 Materials 原产国 Country of origin 1 磁性材料 Magnetic powder 镍锌铁氧体磁粉 Nickel zinc ferrite magnetic powder 中国 China 2 铜线 Wire 改良聚胺脂涂布铜线 Polyurethane-system coated copper wire 德国 Germany 3 磁胶 Magnetic epoxy resin 镍锌铁氧体磁粉+环氧树脂 Nickel zinc ferrite magnetic powder+ epoxy 中国 China 4 电极 Welding surface 锡 Sn 中国 China Issued 2019.06.25 记 号 Symbol 日 期 Date 页 Page 变 更 内 容 Contents of revision 深圳市格莱尔电子有限公司 Shenzhen Glorious Electronic Co.,Ltd. TEL: 0755-27815501-5503 / 29305001-5003 FAX: 0755-27815500 / 29305500 确 认 Check 承认者 Approved by 审查者 Checked by 担当者 Made by 张立华 张顺钧 刘子善 P. 2/ 7 GCNR5040 Type 项目 Item 电极强度 1 Terminal Strength 2 回流焊耐热试验 Reflow test 耐振性 3 Vibration 4 跌落实验 Free fall test 高温高湿试验 5 High temperature and high humidity test 一般规格 General Specifications (1/3) 规格 Specification 条件 Condition 电感的电极焊在基板上,在 X.Z 方向用 5.0N 的静荷重加压 10±2 No electrode detachment 秒。 When the device is pushed in two directions of X and Z with the should be found force of 5N for 10±2seconds after soldering between copper plate and the electrodes Change from an initial value L : within±20% 峰值温度 Peak temp 240±5℃ 30±10s 试验板的厚度 0.8mm 以上,按上面条件通过两次热风炉。 The specimen shall be subjected to the reflow process under the above condition 2 times.Test board shall be 0.8mm thick. Base material shall be glass epoxy resin. 测定 Measurement 常温常湿中放置于 1 小时以上测试。 The specimen shall be stored at standard atmospheric conditions for 1 h in prior to the measurement. Change from an initial value L : within±20% 振动频率 10~55~10Hz, 振幅 1.5mm, 振动 1 小时。 The specimen shall be subjected to a vibration of 1.5mm amplitude, sweep frequency 10~55~10Hz after vibration for 1 hours Change from an initial value L : within±20% 试件安装在基板上,由 1 米高自由落体,连续 10 次。 The specimen must be fixed on test board. Then it shall be fallen freely from 1m height. 10 consecutive times。 Change from an initial value L : within±20% 深圳市格莱尔电子有限公司 在温度 40±2℃,湿度 90〜95%中放置 96±4 小时后,常温常湿 中放置 1 小时以上 2 小时以内测试。 The specimen shall be stored at a temperature of 40 ± 2 ℃ with relative humidity of 90 ~ 95% for 96 ± 4h. Then it shall be stabilized under standard atmospheric conditions for 1 h before measurement. Measurement shall be made within 1h~ 2h. Shenzhen Glorious Electronic Co.Ltd. P. 3/ 7 GCNR5040 Type 项目 Item 高温保存试验 6 High temperature preservation test 低温保存试验 7 8 9 Low temperature preservation test 可焊性试验 Solder ability test Specification 条件 Condition 在温度 125±2℃中放置 96±1 小时后,常温常湿中放置 1 小时以 上 2 小时以内测试。 Change from an initial The specimen shall be stored at a temperature of 125±2℃ for value 96± 1h. Then it shall be stabilized under standard atmospheric L : within±20% conditions for 1 h before measurement. Measurement shall be made within 1h~ 2h. 在温度-40±3℃中放置 96±1 小时后,常温常湿中放置 1 小时以 Change from an initial 上 2 小时以内测试。 value After stored at a temperature of -40 ± 3 ℃ for 96 ±1h. The L : within±20% specimen should be measured,then it should be measured under normal temperature and humidity in 1h~ 2h hours. 95%以上的面积要被 覆盖。 New solder shall cover 95% minimum of the surface immersed. 试验品的电极深布松香后,焊锡槽温度 260±5℃,时间:3±0.5 秒。 Terminals shall be immersed in flux at room temperature. Dip sample into solder bath containing molten solder at 260±5℃ for 3±0.5 seconds. 以温度-40±3℃中放置 30 分钟,在 125℃±2℃放置 30 分钟,中 间转换时间不超过 1 分钟为一个循环。完成 20 个循环后,常温常 Change from an initial 湿中放置 1 小时以上 2 小时以内测试。 冷热冲击试验 The specimen shall be measured afcer to 20 continuous cycles Cold and hot value of temperature change of -40℃±3℃for 30 min and 125℃±2℃ L : within±20% cycle test for 30 min with the transit period of 2min or less. Then it shall be stabilized under standard atmospheric conditions for 1 h before measurement. Measurement shall be made within 1h~ 2h. 保存温湿度范围 10 规格 一般规格 General Specifications (2/3) Storage temperature and humidity range temperature range: 5℃〜35℃ humidity range: 在包装的状态下。 In packing state. 25%〜80% 标准状态 Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions in making measurements and test as follows; Ambient temperature : 5℃ to 35℃, Relative humidity: 45% to 85%, Air pressure: 86kPa to 106kPa If more strict measurement is required, measurement shall be made within following limits; Ambient temperature : 20±2℃, Relative humidity: 65±5%, Air pressure: 86kPa to 106kPa 深圳市格莱尔电子有限公司 Shenzhen Glorious Electronic Co.Ltd. P. 4/ 7 GCNR5040 Type 一般规格 条件 General Specifications (3/3) Reflow soldering condition  回数:2 回  Reflow times: 2times max  We recommend infrared ray as heat source of reflow bath.  However halogen lamp shall be used, side heat will be beyond range of resistance heat, so we can't recommend it. 推荐焊盘寸法 Recommended PCB pattern 单位 Unit: 深圳市格莱尔电子有限公司 mm Shenzhen Glorious Electronic Co.Ltd. P. 5/ 7 GCNR5040 个别规格 Part Specifications 客户部品型号 Customer`s Part No. Note: 许容公差 GLE 部品型号 GLE Part NO. 饱和电流 Isat (A) Max. △L/L≦-35% 温升电流 Irms (A) Max. △T≦40℃ GCNR5040-1R0M 1.0 100KHz/1v 12 7.35 4.90 GCNR5040-1R5M 1.5 100KHz/1v 15 6.30 4.30 GCNR5040-2R2M 2.2 100KHz/1v 19 4.90 3.80 GCNR5040-3R3M 3.3 100KHz/1v 24 3.95 3.40 GCNR5040-4R7M 4.7 100KHz/1v 30 3.50 3.00 GCNR5040-6R8M 6.8 100KHz/1v 43 2.75 2.50 GCNR5040-100M 10 100KHz/1v 64 2.35 2.10 GCNR5040-150M 15 100KHz/1v 86 2.00 1.95 GCNR5040-220M 22 100KHz/1v 129 1.60 1.50 GCNR5040-330M 33 100KHz/1v 188 1.30 1.20 GCNR5040-470M 47 100KHz/1v 272 1.10 1.00 GCNR5040-680M 68 100KHz/1v 400 0.90 0.80 GCNR5040-101M 100 100KHz/1v 560 0.75 0.70 Inductance Tolerance : □ J =±5% 直流阻抗 中心 测定频率 DC Resistance InductanceLo Test Frequency (uH) (Hz/v) (mΩ)±30% □ K =±10% 深圳市格莱尔电子有限公司 (特性以实物为准) □ L =±15% □ M =± 20% □ N=±30% Shenzhen Glorious Electronic Co.Ltd. P. 6/ 7 GCNR5040 捆包规格 Packing Specifications 1. 寸法 Unit :mm Tape Dimensions 2. 方法 Taping method 冷封 3. 卷盘寸法图 A 12.0 B 5.50 C 1.75 D 8.00 E 4.00 F 2.00 G Ø1.50 H 0.35 (The direction shall be seen from the top cover tape side.) Reel dimensions 4. 捆包箱 Packing A 330.0 B Ø13.0 C 21.0 D 16.4 E 100 F 12.4 box  捆包箱材质 Packing case material 纸 Kraft paper  收纳数 Real quantity per packing box 4reel / 1box  数量/ 卷 Quantity : 1500PCS / reel  表示 Marking 客户部品型号,数量,Lot No. Customer's part number, Quantity, Lot number. 深圳市格莱尔电子有限公司 Shenzhen Glorious Electronic Co.Ltd. P. 7/ 7 禁用物质 Prohibited Subtances 1. RoHS 规制的六种物质 1)铅及其化合物 Lead and its compounds 2)水银及其化合物 Mercury and its inorganic compounds 3)镉及其化合物 Cadmium and its compounds 4)六价铬化合物 Hexavalent chromium compounds 5)多溴联苯 PBB 6)多溴二苯醚 PBDE 2. 破坏臭氧层的化学物质使用限制 PROHIBITION TO USE OZONE DEPLETING SUBSTANCES (ODS) 限制性物质 Prohibited substances 1)氟氯化碳 CFCS 2)氟哌丁苯 Halon 3)四氯化碳 Carbon tetrachloride 4)三氯乙烯(三氯乙烷) Trichloroethane ( Methy1 chloroform) 我公司保证我司的产品和生产过程符合“RoHS 和 HF 规则”,所有产品中使用的材料均是化学物质生产 规则中登记的材料。 We confirm that our products and our production process accord with "rule of RoHS&HF". All materials used in this product are registered material under Regulation of Manufacture of Chemical Substances. 深圳市格莱尔电子有限公司 Shenzhen Glorious Electronic Co.Ltd.
GCNR5040-100MC 价格&库存
很抱歉,暂时无法提供与“GCNR5040-100MC”相匹配的价格&库存,您可以联系我们找货
