GH211A
GH211A
    GOCHIP(鑫雁)
    TO-94
    带 FG 输出的霍尔驱动 IC
GH211A 数据手册
Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  General Description The GH211A is an integrated Hall sensor with output driver and frequency generation (FG) designed for electronic commutation of brush-less DC motor and DC fan applications. The device includes an on-chip Hall sensor for magnetic sensing, an amplifier that amplifies the Hall voltage, a Schmitt trigger to provide switching hysteresis for noise rejection, a temperature compensation circuit to compensate the temperature drift of Hall sensitivity, two complementary open-drain drivers for sinking large load current. It also includes an internal voltage regulator which is used to provide bias voltage for internal circuits. Place the device in a variable magnetic field, while the magnetic flux density is larger than threshold BOP, OUT1 will be turned on (low) and OUT2 (and FG) will be turned off (high). This output state is held till the magnetic flux density reversal falls below BRP causing OUT1 to be turned off (high) and OUT2 (and FG) turned on (low). GH211A is available in TO-94 (SIP-4L) package.  Features • z • z On Chip Hall Effect Sensor • z 3.5~18V Power Supply Voltage Drivers Allow 400mA Without Overheating FG singnal Output Zener Diodes Protection for Output Driver Embedded Over-Temperature Protection Precise Magnetic Switching Thresholds  Applications • z z Dual-coil Brushless DC Fan • z • z • z • z Dual-coil Brushless DC Motor TO-94(SIP-4L) Figure 1. Package Type of GH211A  Ordering Information Package TO-94(SIP-4L) Temperature Range -40 to 105 ℃ Part Number GH211AHUB Sep 05. 2017 Rev. 2. 1 Marking ID GH211A Packing Type Bulk GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 1 Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  Pin Configuration UB Package (TO-94/SIP-4L) 1 23 4 4 GND 3 OUT2 2 OUT1 1 FG Figure 2. Pin Configuration of GH211A (Front View)  Pin Description Pin Number Pin Name Function 1 FG 2 OUT1 Output Pin 1 (Open-Drain) 3 OUT2 Output Pin 2 (Open-Drain) 4 GND FG signal Output Pin (Open-Drain) Ground Pin Sep 05. 2017 Rev. 2. 1 GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 2 Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  Functinal Block Diagram FG 1 VDD Over-Temperature Protection Recovery Internal Regulator OUT1 2 Digital Hall Sensor Amplifier Control Logics Schmitt OUT2 23 4 GND Figure 3. Functional Block Diagram of GH211A Sep 05. 2017 Rev. 2. 1 GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 3 Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  Absolute Maximum Ratings TA =25°C (Note 1) Parameter Symbol Condition Value Unit 22 V 33 V Supply Voltage (Continuous) VDD(CONT) Supply Voltage (Peak) VDD(PEAK) Supply currentt (Fault) IDD(FAULT) 3.5 mA Continuous current I OUT(HOLD) 400 mA Hold current I OUT(HOLD) 600 mA Peak current I OUT(PEAK) 800 mA FG pin sink current IFG 15 mA Power dissipation PD TO-94(SIP-4L) 550 mW Thermal Resistance (Junction to Ambient) θJA TO-94(SIP-4L) 227 ℃/W Thermal Resistance (Junction to Case) θJC TO-94(SIP-4L) 49 ℃/W Operating Junction temperature TJ -40 to 150 ℃ Storage temperature TSTG -55 to 160 ℃ Output Clamp Voltage of Zener Diode VZ 33 V Magnetic Flux Density B Unlimited Gauss 260 ℃ IR-Reflow Lead Temperature  ≤100s ≤200µ s 10s TP Recommended Operating Conditions Parameter Symbol Min Max Unit Power Supply Voltage VDD 3.5 18 V Operation Temperature TA -40 105 ℃ Note 1: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated above “Recommended Operating Conditions” is not implied. Exposure to “Absolute Maximum Ratings” for extended periods may affect device reliability. Sep 05. 2017 Rev. 2. 1 GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 4 Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  Electrical Characteristics VDD =12V , TA =25°C, unless otherwise specified. Symbol Conditions Min Supply Voltage VDD Operating (Note 2) Supply Current IDD Output open Output Current I OUT Parameter Output Leakage Current I LEAKAGE FG Output Low Voltage VFG R DSON Output Driver ON-Reistance  1.3 Max Unit 18 V 2.5 mA 400 mA VOUT =18V 0.1 10 µA I FG =5mA 200 400 mV TA =25 ℃ 1.4 1.8 Ohm TA =105℃ 2.0 2.5 Ohm TSD Thermal Shutdown Threshold Typ ℃ 165 Magnetic Characteristics VDD =12V , TA =25°C, unless otherwise specified. Parameter Symbol Min Typ Max Unit Operating Point B OP 5 30 60 Gauss Releasing Point B RP -60 -30 -5 Gauss Hysteresis B HYS Gauss 60 VOUT1 VOUT2 B HYS Off-state B HYS Off-state High High Turn off N B RP 0 Turn on Turn on On-state On-state B OP Low S N Turn off B RP B OP 0 Conditions OUT1 North Pole B OP < B RP High Low Low South Pole B OP > B RP Low High High Magnetic Pole (Note 3) OUT2 FG Note 2: The minimal value of VDD should be determined using the following equation: VDD = 3.5V + RCOIL * IDD Note 3: The magnetic pole is applied facing the marked side of the package. Sep 05. 2017 Rev. 2. 1 GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 5 S Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  Typical Application D1 VDD Coil 1 Coil 2 GH211A FG OUT1 OUT2 GND R1 5.1K VFG R2 4.7 C1 2.2 F R3 4.7 C2 2.2 F C3 2.2 F Figure6. Typical Application of GH211A Note: 1. D1 is an ordinary diode used to filter the noise from VDD and It is optional. 2. C1=C2=C3=2.2µF typical, electrolytic capacitors are better. They should be fine tuned based on system design. 3. R1=5.1K Ω typical. It should be selected according to FG signal requirement. 4. R2=R3=4.7Ω typical. They can be cancelled according to system requirement.  Marking Information (TO-94/SIP-4L) GH211A GH211A: Part No. YWWX 1 2 3 Y: Year, 0~9, ex: "7"=2017 WW: Nth Week, 01~52 X: Internal Code 4 Sep 05. 2017 Rev. 2. 1 GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 6 Data Sheet GH211A HALL DRIVER IC WITH FG OUTPUT  Pacakge Information (UB: TO-94/SIP-4L) Unit: mm 0.63/0.84 0.27/0.48 1.75/1.95 1.15/1.35 Marking Side A D J 1 a 2 a E 2 b 1 L S F L c 1 b 1 e Size A b1 b2 c D e1 E F J L L1 S a1 a2 a3 a4 MIN. MAX. 1.45 1.65 0.38 0.44 0.35 0.45 5.12 5.32 1.24 1.30 3.55 3.75 0.00 0.20 4.10 4.30 14.00 14.60 1.32 1.52 0.63 0.83 5° 4° 7° 10° 12° 5° 7° TYP. 1.55 0.40 0.48 0.40 5.22 1.27 3.65 4.20 14.30 1.42 0.73 3° 5° 11° 6° Unit: mm 3 a ° 5 4 x 3 . 0 4 a Sep 05. 2017 Rev. 2. 1 GOCHIP ELECTRONICS TECHNOLOGY (SHANGHAI) CO., LTD. 7
GH211A
物料型号:GH211A
器件简介: - GH211A是一款集成霍尔传感器、输出驱动和频率生成(FG)的集成电路,设计用于电子换向的无刷直流电机和直流风扇应用。 - 该设备包括一个片上霍尔传感器用于磁感应,一个放大器用于放大霍尔电压,一个施密特触发器用于提供开关滞后以抑制噪声,一个温度补偿电路用于补偿霍尔灵敏度的温度漂移,两个互补的开漏驱动器用于吸收大负载电流。 - 还包括一个内部电压调节器,用于为内部电路提供偏置电压。
引脚分配: - 引脚1:FG,FG信号输出引脚(开漏) - 引脚2:OUT1,输出引脚1(开漏) - 引脚3:OUT2,输出引脚2(开漏) - 引脚4:GND,地引脚
参数特性: - 绝对最大额定值:包括供电电压、供电电流、持续电流、峰值电流、FG引脚吸收电流、功耗、热阻、工作结温、存储温度、稳压二极管的输出钳位电压、磁通密度、IR-回流引脚温度等。 - 推荐工作条件:包括电源电压和工作温度。 - 电气特性:包括供电电压、供电电流、输出电流、输出漏电流、FG输出低电压、输出驱动器导通电阻、热关断阈值等。 - 磁特性:包括工作点、释放点、滞后等。
功能详解: - 功能框图展示了FG、VDD、恢复、过温保护、OUT1、内部霍尔数字放大器、施密特控制、OUT2、GND等组件。
应用信息: - 适用于无刷直流电机、双线圈无刷直流风扇、双线圈无刷直流电机。
封装信息: - GH211A采用TO-94(SIP-4L)封装。 - 订购信息包括封装、温度范围、部件编号、标记ID和包装类型。
典型应用: - 展示了GH211A在典型应用中的电路连接,包括电源VDD、线圈1和2、FG输出、OUT1、OUT2和GND。
标记信息: - 包括部件编号、年份、周数和内部代码。
GH211A 价格&库存
很抱歉,暂时无法提供与“GH211A”相匹配的价格&库存,您可以联系我们找货
