HK241-43010
HK241-43010
    KUM
    HK241-43010
HK241-43010 数据手册
CUSTOMER DRAWING - NOTE - CAV. NO. 2 1 1. BEFORE USING, CHECK THE HARMFUL CRACK, BURR, ETC. 02506HY 43M-W ASSY 2. GENERAL TOLERANCES - SEE BLOW. 3. MARKING & CAV No. BY AS GENERAL RULE OF KUM. 46.8 44.2 4. ASSY PART 1) TERMINAL APPLICATION WIRE(SQ) AVSS 0.3~0.5sq CHFUS 0.22sq ISO VIEW MARKING B AVSS 0.85~1.25sq AVSS 0.3~0.5sq MARKING MATERIALS A PART NAME TML MMC-M-S TML MMC-M-S-Au TML MMC-M-SS TML MMC-M-SS-Au TML NIC-M-M TML NIC-M-S PART NO. TK191-00100 TK191-00110 TK191-00400 TK191-00410 TK201-00200 TK201-00100 5. THIS PART IS NON-WATERPROOF CONNECTOR. POLE NO. 28.8 17.3 SECTION B-B(2/1) A 2 1 22.05 B 40.55 42 51.6 52.8 S/H 02506HY 43M-GN 4.15 SECTION A-A(2/1) ISO VIEW CAV. NO. 15.9 MARKING CJW 11.09.27 EO11-0130 33.6 34.3 4.95 GENERAL TOLERANCE A 10MAX 50MAX 100MAX 150MAX 200MAX 200VR ANGLE 0.2 0.3 0.5 0.8 1.0 1.4 30' APVD DATE NOTE No. SYM RELEASED BSH ALTERATION DWN ② S/H 02506HY 43M-GN HK251-43030 GREEN PBT DRAWING NAME 02506HY 43M-W ASSY ① 02506HY 43M-W HK241-43010 WHITE PBT DRAWING No. HK241-43011-C01 NO. PART NAME PART No. COLOR MATERIAL THIRD ANGLE PROJECTION A - BSH BSH KDK CJW TOLERANCE SCALE DESIGN DRAWN CHECKED APPROVED 케이유엠 Data_Server:d:/도면/.../02506HY/... A3.
HK241-43010 价格&库存
很抱歉,暂时无法提供与“HK241-43010”相匹配的价格&库存,您可以联系我们找货
