GLS86FP128G3-I-BZ001
    GREENLIANT(绿芯)
GLS86FP128G3-I-BZ001 数据手册
GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 Features • Industry Standard SATA Host Interface – SATA 1.5Gb/s, 3Gb/s and 6Gb/s – SATA Revision 3.2 – ATA/ATAPI-8 compliant – Supports 48-bit address feature set – Native Command Queuing (NCQ) up to 32 commands • Performance – Sequential data read: Up to 550 MB/s – Sequential data write: Up to 500 MB/s • Reliability – Mean Time Between Failures (MTBF): 2 million hours • Data Protection – Secure erase / Data sanitization • Integrated Current Detector – Protects from inrush current and generates reset during power-up and power-down to prevent inadvertent writes • Supports TRIM and SMART Commands • 20-Byte Serial Number – Factory pre-programmed unique ID • Built-in ECC – Uses advanced LDPC bit error detection and correction optimized for 3D NAND • NAND Configuration – 3 bits per cell (3D TLC) • Endurance – 3K P/E cycles (typical) • Operating Temperature Range – Industrial: -40°C to 85°C – Commercial: 0°C to 70°C (measured using 128KB transfer size) • Power Management – 3.3V power supply – Host initialized power management (HIPM) – Device initialized power management (DIPM) • Power Consumption – Active mode: 1TB: 1650mW (typical) 512GB: 1550mW (typical) 256GB: 1450mW (typical) 128GB: 1350mW (typical) 64GB: 1215mW (typical) 32GB: 1100mW (typical) – Idle mode: < 335 mW (typical) – Slumber mode: < 15 mW (typical) – DevSleep mode (optional): < 5 mW (typical) (SSD case temperature reported by SMART) • JEDEC standard MO-300 mSATA form factor – 29.85 mm x 50.80 mm x 4.85 mm • All Devices are RoHS Compliant Product Description The GLS86FP032G3 / 064G3 / 128G3 / 256G3 / 512G3 / 001T3 Industrial and Commercial Temperature miniSATA (mSATA) ArmourDrive™ PX Series modules (referred to as “mSATA ArmourDrive” in this datasheet) are high-performance, highreliability solid state drives. They combine 32, 64, 128, 256 or 512 GBytes, or 1 TByte of NAND flash memory with an advanced Serial ATA (SATA) controller on a printed circuit board (PCB). The SATA SSD controller with built-in advanced NAND management firmware communicates with the host through the standard SATA protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). The firmware effectively optimizes the use of NAND flash memory’s program/erase (P/E) cycles and minimizes write amplification. mSATA ArmourDrive’s advanced NAND management technology improves endurance, enhances data security and helps prevent data loss during unexpected power failure events. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to improve data reliability and significantly extend the life of the product. mSATA ArmourDrive is ideal for applications that require removable form factor and more reliable data storage. mSATA solid state storage technology is widely used in industrial computers, set-top boxes, test and measurement instrumentation, multifunctional printers, medical equipment, security and surveillance systems, network servers and digital signage. These removable solid state drives (SSDs) surpass traditional hard disk drives (HDDs) in their small size, security, reliability, ruggedness and low power consumption. These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 mSATA ArmourDrive is available in a standard JEDEC 52-pin PCB module form factor. 1 04/29/2020 S71466-01 GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 1.0 GENERAL DESCRIPTION Each mSATA ArmourDrive module integrates a SATA SSD controller with up to four NAND flash multi-chip packages. Refer to Figure 2-1 for the mSATA ArmourDrive block diagram. 1.1 1.1.5 Optimized mSATA ArmourDrive Power Interrupt Data Protection is a mechanism to prevent data loss during unexpected power failure events. Enhanced data integrity is supported by the controller’s advanced firmware during abnormal power loss. The controller proactively optimizes the amount and stay time of the “in-flight” data residing in the cache. To ensure there is no data loss risk caused by power cycling, the controller sends an acknowledgement to the host only when the incoming data is fully committed to the NAND flash. The heart of mSATA ArmourDrive is the SATA SSD controller, which translates standard SATA signals into flash media data and control signals. The following components contribute to mSATA ArmourDrive’s operation. 1.1.1 Microcontroller Unit (MCU) The MCU translates SATA commands into data and control signals required for flash media operation. 1.1.2 Internal Direct Memory Access (DMA) 1.1.6 mSATA ArmourDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmwarebased approach, thereby increasing the data transfer rate. 1.1.3 Error Correction Code (ECC) The ECC technology uses advanced Low Density Parity Check (LDPC) algorithms to detect and correct errors, ensuring data integrity and extending the SSD lifespan. 1.1.7 Power Management Unit (PMU) Multi-tasking Interface The multi-tasking interface enables concurrent Read, Program and Erase operations to multiple NAND flash media. The PMU controls the power consumption of mSATA ArmourDrive. The PMU dramatically reduces the power consumption of mSATA ArmourDrive by putting the part of the circuitry that is not in operation into sleep mode. 1.2 Advanced NAND Management mSATA ArmourDrive’s controller uses advanced wear-leveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure mSATA ArmourDrive firmware integrity. For regular power management, the host must send an IDLE_IMMEDIATE command and wait for command ready before powering down mSATA ArmourDrive. 1.1.4 Power Interrupt Data Protection Embedded Flash File System The embedded flash file system is an integral part of mSATA ArmourDrive. It contains MCU firmware that performs the following tasks: 1. Translates host side signals into flash media writes and reads 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 2 04/29/2020 S71466-01 GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 2.0 FUNCTIONAL BLOCKS Figure 2-1: mSATA ArmourDrive Block Diagram These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 3 04/29/2020 S71466-01 GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 3.0 APPENDIX 3.1 Product Ordering Information GLS 86 FP XX XX xxx x3 - I - BZ0xx XXX XX - X - XXXXX Ordering Code BZ0xx = mSATA AmourDrive Revision Operating Temperature I = Industrial: -40°C to +85°C C = Commercial: 0°C to +70°C NAND Configuration 3 = 3 bits per cell GByte or TByte Designator G = GByte T = TByte Capacity 032 = 32 GByte 064 = 64 GByte 128 = 128 GByte 256 = 256 GByte 512 = 512 GByte 001 = 1 TByte Product Generation P = Generation Form Factor F = Full length (mSATA) Product Family 86 = mSATA ArmourDrive These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 4 04/29/2020 S71466-01 GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: Capacity Operating Temperature Part Number Form Factor 32GB Industrial (-40°C to 85°C) GLS86FP032G3-I-BZ000 JEDEC MO-300 (full length) 32GB Industrial (-40°C to 85°C) GLS86FP032G3-I-BZ001 JEDEC MO-300 (full length) 32GB Commercial (0°C to +70°C) GLS86FP032G3-C-BZ000 JEDEC MO-300 (full length) 64GB Industrial (-40°C to 85°C) GLS86FP064G3-I-BZ000 JEDEC MO-300 (full length) 64GB Industrial (-40°C to 85°C) GLS86FP064G3-I-BZ001 JEDEC MO-300 (full length) 64GB Commercial (0°C to +70°C) GLS86FP064G3-C-BZ000 JEDEC MO-300 (full length) 128GB Industrial (-40°C to 85°C) GLS86FP128G3-I-BZ000 JEDEC MO-300 (full length) 128GB Industrial (-40°C to 85°C) GLS86FP128G3-I-BZ001 JEDEC MO-300 (full length) 128GB Commercial (0°C to +70°C) GLS86FP128G3-C-BZ000 JEDEC MO-300 (full length) 256GB Industrial (-40°C to 85°C) GLS86FP256G3-I-BZ000 JEDEC MO-300 (full length) 256GB Industrial (-40°C to 85°C) GLS86FP256G3-I-BZ001 JEDEC MO-300 (full length) 256GB Commercial (0°C to +70°C) GLS86FP256G3-C-BZ000 JEDEC MO-300 (full length) 512GB Industrial (-40°C to 85°C) GLS86FP512G3-I-BZ000 JEDEC MO-300 (full length) 512GB Industrial (-40°C to 85°C) GLS86FP512G3-I-BZ001 JEDEC MO-300 (full length) 512GB Commercial (0°C to +70°C) GLS86FP512G3-C-BZ000 JEDEC MO-300 (full length) 1TB Industrial (-40°C to 85°C) GLS86FP001T3-I-BZ000 JEDEC MO-300 (full length) 1TB Industrial (-40°C to 85°C) GLS86FP001T3-I-BZ001 JEDEC MO-300 (full length) 1TB Commercial (0°C to +70°C) GLS86FP001T3-C-BZ000 JEDEC MO-300 (full length) These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 5 04/29/2020 S71466-01 GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 3.2 Board Diagrams SIDE VIEW TOP VIEW BOTTOM VIEW Note: All dimensions are in millimeters, unless otherwise specified. Tolerances on all dimensions are ± 0.15 mm, unless otherwise specified. Figure 3-1: mSATA ArmourDrive Dimensions These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 6 04/29/2020 S71466-01 GLS86FPxxxx3 PX Series Industrial / Commercial Temp mSATA ArmourDrive™ Factsheet 03.000 April 2020 Revision History Revision 01.000 02.000 03.000 Description Initial Release as Factsheet Added Commercial Temperature part numbers; Updated Features descriptions on page 1 Updated Features descriptions on page 1; Added BZ001 part numbers Date March 12, 2019 June 26, 2019 April 29, 2020 © 2020 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and ArmourDrive and NANDrive are trademarks of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2020 Greenliant GLS FS0019 Rev. 00 7 04/29/2020 S71466-01
GLS86FP128G3-I-BZ001 价格&库存
很抱歉,暂时无法提供与“GLS86FP128G3-I-BZ001”相匹配的价格&库存,您可以联系我们找货
