GLS85LP1001P-S-I-LBTE-ND003
    GREENLIANT(绿芯)
    LBGA
GLS85LP1001P-S-I-LBTE-ND003 数据手册
PATA NANDrive™ Product Brief 85LP Series Product Description The award-winning PATA NANDrive™ family of embedded solid state drives (SSDs) integrate Greenliant’s advanced ATA controller with one or more NAND flash die in a multi-chip package. With its small form factor and widely adopted industry-standard ATA/IDE interface, PATA NANDrive has revolutionized how embedded system designers utilize NAND flash devices. Its built-in microcontroller and flash file management firmware replace the need for host-side Flash File System (FFS) and Memory Technology Driver (MTD) software. PATA NANDrive provides complete IDE hard disk drive (HDD) functionality and compatibility in a ball grid array (BGA) package for easy, space-saving and cost-effective mounting to a system motherboard. It can also be seamlessly integrated in systems that don’t have an ATA interface by connecting the device to a standard memory bus. PATA NANDrive is an ideal replacement for high-density parallel NOR flash and CompactFlash cards in embedded designs that require smaller, higher security and more reliable storage. www.NANDrive.com Key Features One of the Industry’s Smallest SSDs - 12mm x 24mm 91-ball LBGA package - 14mm x 24mm 91-ball BGA package Industry Standard ATA/IDE Interface - Host Interface: 8- or 16-bit access - Supports up to PIO Mode-6 - Supports up to Multi-Word DMA Mode-4 - Supports up to Ultra DMA Mode-6 Energy Efficient - Reduces power consumption by putting unused circuitry into sleep mode without host intervention Multitasking Technology Increases Performance - Sustained Read Performance up to 50 MB/sec - Sustained Write Performance up to 35 MB/sec Robust Pre-programmed Firmware - Advanced wear leveling maximizes product lifespan - Configurable algorithms support global and group wear leveling - Embedded flash file system for seamless capacity upgrade with no change to host software Power Interrupt Data Protection - Prevents data corruption when power is lost or unstable Bad Block Management - Replaces bad blocks with spare blocks in the NAND flash to prevent uncorrectable errors Built-in ECC - Uses advanced hardware engine to correct bit errors Expanded Data Protection - WP#/PD# pin configurable by firmware for prevention of data overwrites - Added data security through user-selectable protection zones and security erase/purge commands SSD Lifespan Monitoring - Enables SMART command-based alerts indicating the remaining useful product life - Estimates optimal SSD capacity based upon specific application usage models Multiple Capacities with Same Pin-out - 1 GB, 2 GB, 4 GB, 8 GB - 1mm ball spacing enables use of lower cost PCBs Industrial Temperature - Industrial operation: -40°C to +85°C Applications — — — — — — — — — — — — — — — — Set-top box / Net-top box GPS and telematics In-vehicle infotainment Video conferencing Tablet PC / Smartbook / Netbook Multi-function printer Point of Sale terminal VoIP system / PBX Wireless base station Router / Gateway / Switch Server / Network-attached storage Industrial PC / Single-board computer Ultrasound and medical imaging Industrial automation & control Test & measurement instrumentation Video surveillance / ID terminal Greenliant 3970 Freedom Circle, Suite 100 Santa Clara, CA 95054 USA Tel. 1-408-200-8000 Fax 1-408-200-8099 www.Greenliant.com PATA NANDrive Package Diagrams 91-ball BGA package LBT is 12mm x 24mm FT is is 14mm x 24mm Pb-freeis (RoHS compliant) Note: 1. All linear dimensions are in millimeters. 2. Untoleranced dimensions are nominal target values. 3. Coplanarity: 0.15 mm. 4. Ball opening size is 0.40 mm (± 0.05 mm). Product Lineup PATA NANDrive Block Diagram 85 Series PATA NANDrive Embedded Flash File System SRAM Buffer ECC Internal DMA Multitasking Interface ATA/IDE Host Interface or Memory Bus Capacity MCU Temperature Range 1 GB NAND Flash 2 GB 4 GB PMU NAND Configuration / Endurance Package 12 x 24 x 1.4mm LBGA 1-bit-per-cell SLC NAND / 60K P/E cycles Industrial -40°C to +85°C 14 x 24 x 1.9mm BGA SCI 8 GB twitter.com/Greenliant NANDrive FAQs: www.greenliant.com/nandrive-faqs linkedin.com/company/Greenliant Long-Term Availability: www.greenliant.com/support/#LTA-program facebook.com/Greenliant For more information, contact your Greenliant representative: www.greenliant.com/sales © 2023 Greenliant Greenliant, the Greenliant logo, and NANDrive are trademarks of Greenliant. These specifications are subject to change without notice. 10/2023
1. 物料型号:型号为MAX31855KASA+,是一款冷结温度补偿的热电偶模拟输出集成电路。
2. 器件简介:MAX31855KASA+能够以数字格式输出两种不同热电偶类型(K型或J型)的温度测量值,适用于工业和医疗领域。
3. 引脚分配:该器件共有8个引脚,分别对应VCC、GND、SO、CS、CLK、DOUT、DGND和CHB。
4. 参数特性:工作电压范围为2.0V至3.5V,具有±1°C的精度,支持两种热电偶类型(K型或J),转换速率为4次/秒。
5. 功能详解:器件通过SPI接口输出温度值,内置冷结补偿,能够提高测量精度。
6. 应用信息:适用于需要精确温度测量的工业过程控制和医疗设备。
GLS85LP1001P-S-I-LBTE-ND003 价格&库存
很抱歉,暂时无法提供与“GLS85LP1001P-S-I-LBTE-ND003”相匹配的价格&库存,您可以联系我们找货
