GLS85VM1004G-S-I-LFWE-ND217
    GREENLIANT(绿芯)
    LBGA
GLS85VM1004G-S-I-LFWE-ND217 数据手册
GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 Features  Industry Standard Embedded MultiMediaCard (eMMC) Host Interface – JEDEC/MMC Standard Version 5.1 JESD84-B51 compliant – Backward compatible with previous eMMC standards  Performance – eMMC clock speed: Up to 200MHz – eMMC data bus width: x1/x4/x8 – Supports Dual Data Rate mode – Supports HS200 / HS400 modes – Sequential data read: Up to 160 MByte/sec* – Sequential data write: Up to 57 MByte/sec*  Integrated Voltage Detector – Detects supply voltage fluctuations and generates reset during power-up and powerdown to prevent inadvertent writes  Expanded Data Protection – Hardware Write Protection pin – Data sanitization  Latency Management – Reduces latency due to background tasks during time critical read/write operations  Supports SMART and TRIM Commands  Robust Built-in ECC  NAND Configuration – 1 bit per cell (SLC) – Designed with Greenliant’s advanced EnduroSLC™ Technology  High Endurance – GLS85VM1004G: 75K P/E cycles – GLS85VM1004Q: 150K P/E cycles  Operating Temperature Range – Industrial: -40°C to 85°C  100-ball LBGA Package – 14.0 mm x 18.0 mm x 1.40 mm, 1.0 mm ball pitch, LFWE  All Devices are RoHS Compliant * measured in HS400 enhanced mode using 1 MByte transfer size  Power Management – 3.3V power supply (VCC) – 3.3V or 1.8V eMMC IO voltage (VCCQ) – Immediate disabling of unused circuitry without host intervention  Power Consumption – Active mode: 471 mW (typical) – Sleep mode: 0.5mW (typical) Product Description The GLS85VM1004G / 1004Q eMMC NANDrive™ EX Series devices (referred to as “eMMC NANDrive” in this factsheet) are fully integrated solid state drives. They combine an advanced Greenliant NAND controller and 4 GBytes of NAND flash memory in a multi-chip package. These products are ideal for embedded and portable applications that require small form factor, high endurance and reliable data storage. The integrated NAND flash controller with built-in advanced NAND management firmware communicates with the host through the standard eMMC protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). eMMC NANDrive’s advanced NAND management technology enhances data security, improves endurance and accurately tracks the usage of the NAND flash. This innovative technology combines robust error correction capabilities with advanced wear-leveling algorithms and bad block management to extend the life of the product. eMMC solid state drives are widely used in GPS and telematics, in-vehicle infotainment, portable and industrial computers, handheld data collection scanners, point-of-sale terminals, networking and telecommunications equipment, robotics, audio and video recorders, monitoring devices and set-top boxes. eMMC NANDrive supports Single Data Rate (SDR) and Dual Data Rate (DDR) modes, HS200 mode, HS400 mode, boot, multiple partitions, permanent and partial write protect, Replay Protected Memory Block (RPMB) access, Sanitize and TRIM, hardware reset and other features detailed in the eMMC 5.1 standard specification. It is backward compatible with previous eMMC standards eMMC NANDrive provides complete eMMC solid state drive (SSD) functionality and compatibility in a 14mm x 18mm BGA package for easy, space saving mounting to a system motherboard. With its small size, low power consumption, strong security, reliability and ruggedness, eMMC NANDrive surpasses removable storage and discrete NAND-based products. These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 1 11/20/2023 S71460-01 GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 1.0 GENERAL DESCRIPTION Each eMMC NANDrive contains an integrated eMMC NAND flash memory controller and NAND flash die in a BGA package. Refer to Figure 2-1 for the eMMC NANDrive block diagram. 1.1 Optimized eMMC NANDrive The heart of the eMMC NANDrive is the eMMC NAND flash memory controller, which translates standard eMMC signals into flash media data and control signals. The following components contribute to the eMMC NANDrive’s operation. 1.1.6 Serial Communication Interface (SCI) The Serial Communication Interface (SCI) is designed for error reporting. During the product development stage, it is recommended to provide the SCI port on the PCB to aid in design validation. 1.1.1 Microcontroller Unit (MCU) The MCU transfers the eMMC commands into data and control signals required for flash media operation. 1.1.7 Multi-tasking Interface The multi-tasking interface enables fast, sequential write performance by allowing concurrent Read, Program and Erase operations to multiple flash media. 1.1.2 Internal Direct Memory Access (DMA) The eMMC NANDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmwarebased approach, thereby increasing the data transfer rate. 1.2 EnduroSLC™ is a proprietary 3D NAND management technology developed by Greenliant for high reliability applications requiring ultra-high endurance and superior data retention. Using 1-bit-per-cell (SLC) NAND configuration, EnduroSLC enabled SSDs are ideal for write-intensive applications used in extreme temperature, high stress environments. EnduroSLC enabled solid state drives offer a high reliability flash storage solution with ultra-high write endurance that exceeds capabilities of legacy, planar SLC NAND based products. 1.1.3 Power Management Unit (PMU) The PMU controls the power consumption of the eMMC NANDrive. The PMU dramatically reduces the power consumption of the eMMC NANDrive by putting the part of the circuitry that is not in operation into Sleep mode. The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure the eMMC NANDrive’s data integrity. 1.3 1. Manages and optimizes the data access of flash media 2. Provides flash media wear leveling to spread flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of the data file structure 4. Manages system security for the selected protection zones 1.4 Advanced NAND Management eMMC NANDrive’s integrated controller uses advanced wear-leveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. 1.1.5 Error Checking and Correction (ECC) The ECC technology uses advanced algorithms to detect and correct errors, ensuring data integrity and extending the SSD lifespan. GLS FS0019 Rev. 01 SMT Reflow Consideration Preprogrammed NAND devices have temperature limits due to data retention. The EnduroSLC eMMC NANDrive family can withstand multiple passes of SMT high temperature process without losing data. Using Greenliant’s recommended reflow profile during production will help prevent damage to the device and ensure better retention of any preprogrammed data through the surface-mount soldering process. See the relevant datasheet section describing the recommended reflow temperature limits. 1.1.4 Embedded Flash File System The embedded flash file system is an integral part of the eMMC NANDrive. It is integrated in the controller’s firmware that performs the following tasks: These specifications are subject to change without notice. © 2023 Greenliant EnduroSLC™ Technology 2 11/20/2023 S71460-01 GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 2.0 FUNCTIONAL BLOCKS eMMC NANDrive NAND Controller Embedded Flash File System eMMC HOST I/F MCU SRAM Buffer Memory Channel I/F eMMC I/F NAND NAND NAND NAND NAND Chips Chips Chips Chips Flash ECC Internal DMA PMU Flash Media I/F NAND I/F SCI Figure 2-1: eMMC NANDrive Block Diagram These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 3 11/20/2023 S71460-01 GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 3.0 Product Ordering Information GLS 85 VM 1 0xx x - S - I - L F W E - NDxxx XX XX X XXX X - X - X - XXXX - XXXXX 1) Ordering Code NDxxx = NANDrive Revision EDxxx = Evaluation Board Revision Environmental Attribute E = non-Pb solder (RoHS Compliant) Package Modifier W = 100-ball positions Package Type LF = LBGA (max. package height 1.40mm) Operating Temperature I = Industrial: -40°C to +85°C NAND Configuration S = 1 bit per cell Product Generation G, Q = Generation Capacity 004 = 4 GByte GByte Designator 1 = GByte Interface M = eMMC Voltage V = 2.7V to 3.6V Product Family 85 = NANDrive 1) Note that the top side marking on the package typically does not include ordering codes (e.g. NDxxx), unless it is a special custom specification (C-SPEC) required by the end-customer to be marked on the device. These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 4 11/20/2023 S71460-01 GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 Valid Combinations Valid product combinations are those that are in mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: eMMC NANDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number Package 4GB Industrial (-40°C to 85°C) GLS85VM1004G-S-I-LFWE-ND217 LFWE, 14x18x1.40mm 4GB Industrial (-40°C to 85°C) GLS85VM1004G-S-I-LFWE-ND232 LFWE, 14x18x1.40mm 4GB Industrial (-40°C to 85°C) GLS85VM1004G-S-I-LFWE-ND242 LFWE, 14x18x1.40mm 4GB Industrial (-40°C to 85°C) GLS85VM1004Q-S-I-LFWE-ND218 LFWE, 14x18x1.40mm 4GB Industrial (-40°C to 85°C) GLS85VM1004Q-S-I-LFWE-ND234 LFWE, 14x18x1.40mm 4GB Industrial (-40°C to 85°C) GLS85VM1004Q-S-I-LFWE-ND244 LFWE, 14x18x1.40mm Table 3-2: eMMC Evaluation Board Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 2) 4GB Industrial (-40°C to 85°C) GLS85VM1004G-S-I-E2-ED242 JEDEC MO-277 4GB Industrial (-40°C to 85°C) GLS85VM1004Q-S-I-E2-ED244 JEDEC MO-277 2) The evaluation boards with the form factor MO-277 support up to 52MHz with x1/x4/x8 bus and Dual Data Rate mode. Use them for comprehensive functional testing. If the end-user’s system has support for 200MHz bus speed, it can be tested only with eMMC 5.1 NANDrive devices soldered down on the user’s board. These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 5 11/20/2023 S71460-01 GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 4.0 Package Diagram GLS85VM1004G / 1004Q-S-I-LFWE 0.10 Note: All linear dimensions are in millimeters. Untoleranced dimensions are nominal target values. Coplanarity: 0.10 mm Ball diameter is 0.45 mm (± 0.05 mm) Ball opening size is 0.38 mm (± 0.05 mm), SMD type Figure 4-1: eMMC NANDrive 100-Ball LBGA (Greenliant Package Code: LFWE) These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 6 11/20/2023 S71460-01 GLS85VM1004G / 1004Q (100-ball) Industrial Grade eMMC NANDrive™ EX Series Factsheet 03.100 November 2023 Revision History Number 01.000 01.001 01.100 01.200 02.000 03.000 03.100 Description Initial release as Factsheet Added Endurance on page 1 Updated Features on page 1 and section 1.1.5 Updated Features on page 1 Added EnduroSLC description (1.2); Updated Features on page 1, and tables 3-1 and 3-2 Added parts with ordering codes ND242, ND244 Increased endurance (P/E cycles); Updated Voltage in Section 4.0 Date January 28, 2019 April 30, 2019 October 14, 2019 March 12, 2020 February 22, 2021 December 30, 2022 November 20, 2023 © 2023 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and EnduroSLC and NANDrive are trademarks of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 7 11/20/2023 S71460-01
GLS85VM1004G-S-I-LFWE-ND217 价格&库存
很抱歉,暂时无法提供与“GLS85VM1004G-S-I-LFWE-ND217”相匹配的价格&库存,您可以联系我们找货
