GLS88BP960G3-I-CD302
    GREENLIANT(绿芯)
GLS88BP960G3-I-CD302 数据手册
GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 Features  Industry Standard PCIe Host Interface – PCIe Gen3x4 – PCI Express Base Revision 3.1 compliant – NVMe 1.3 compliant  Performance – Sequential data read: Up to 3,300 MB/s – Sequential data write: Up to 1,000 MB/s  Reliability – Mean Time Between Failures (MTBF): 2 million hours  Data Protection – End-to-end data path protection – Secure erase / Data sanitization – Supports TCG OPAL 2.0 – Crypto Erase (cryptographic key reset)  Built-in ECC – Uses advanced LDPC bit error detection and correction optimized for 3D NAND  Industrial 3D TLC NAND Flash  Endurance – Program/ Erase (P/E) cycles: 3K – TeraBytes Written (TBW): Up to 2,800  Operating Temperature Range – Industrial: -40°C to 85°C (measured using 128KB transfer size)  DRAM for Enhanced Performance  Power Management – 3.3V single power supply  Power Consumption – Active mode(typical): 1.92TB: < 5,900 mW 960GB: < 5,500 mW 480GB: < 5,000 mW 240GB: < 3,650 mW \ – Idle mode: < 2,000 mW  Integrated Current Detector – Protects from inrush current and generates reset during power-up and power-down to prevent inadvertent writes  32-bit / 64-bit Addressing Mode  512 Byte / 4 KB Sector Size Support  IO Queuing – 8 IO queues supported  Supports SMART and TRIM Commands (reported by SMART) – Thermal throttling when approaching maximum operating temperature (active cooling is recommended for high performance)  M.2 2280 Form Factor – 22mm x 80mm x 3.58mm (max) – Double-sided (DS), M key  All Devices are RoHS Compliant Notes: 1. User capacity: 1GB = 1 billion bytes, 1TB = 1 trillion bytes 2. PCIe = Peripheral Component Interconnect Express 3. NVMe = Non-Volatile Memory Express Product Description The GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temperature NVMe M.2 ArmourDrive™ PX Series (referred to as “M.2 ArmourDrive” in this factsheet) are high-performance, high-reliability solid state drives. They combine 240, 480 or 960 GBytes, or 1.92 TBytes of NAND flash memory with an advanced NVMe PCIe controller on a printed circuit board (PCB). NVMe is a highly scalable protocol optimized for efficient data transport over PCIe for storage on NAND flash. The NVMe PCIe SSD controller with built-in advanced NAND management firmware communicates with the host through the standard PCIe interface. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). The firmware effectively optimizes the use of NAND flash memory’s program/erase (P/E) cycles and minimizes write amplification. M.2 ArmourDrive’s advanced NAND management technology improves endurance, enhances data security and helps prevent data corruption during unexpected power failure events. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to improve data reliability and significantly extend the life of the product. M.2 ArmourDrive is ideal for applications that require removable form factor and more reliable data storage. NVMe M.2 solid state storage technology is used in industrial and cloud computing, datacenters, highperformance enterprise storage and networking systems, endpoint and thin clients, gaming machines and broadcasting equipment. These removable solid state drives (SSDs) provide low latency and fast sequential and random read/write speeds. These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 1 04/28/2023 S71472-01 GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 1.0 GENERAL DESCRIPTION Each M.2 ArmourDrive module integrates an NVMe PCIe SSD controller with up to four NAND flash multi-chip packages and DRAM. Refer to Figure 2-1 for the M.2 ArmourDrive block diagram. 1.1 1.1.5 Power Interrupt Data Protection Optimized M.2 ArmourDrive The MCU translates PCIe / NVMe commands into data and control signals required for flash media operation. Power Interrupt Data Protection is a mechanism to prevent data corruption during unexpected power failure events. Enhanced data integrity is supported by the controller’s advanced firmware during abnormal power loss. The controller proactively optimizes the amount and stay time of the “in-flight” data residing in the cache. To ensure there is no data loss risk caused by power cycling, the controller sends an acknowledgement to the host only when the incoming data is fully committed to the NAND flash. 1.1.2 Internal Direct Memory Access (DMA) 1.1.6 Error Checking and Correction (ECC) M.2 ArmourDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmware-based approach, thereby increasing the data transfer rate. The ECC technology uses advanced LDPC algorithms to detect and correct errors, ensuring data integrity and extending the SSD lifespan. The heart of M.2 ArmourDrive is the NVMe PCIe SSD controller, which translates standard PCIe signals into flash media data and control signals. The following components contribute to M.2 ArmourDrive’s operation. 1.1.1 Microcontroller Unit (MCU) 1.1.7 Multi-tasking Interface The multi-tasking interface enables concurrent Read, Program and Erase operations to multiple NAND flash media. 1.1.3 Power Management Unit (PMU) The PMU controls the power consumption of M.2 ArmourDrive. The PMU dramatically reduces the power consumption of M.2 ArmourDrive by putting the part of the circuitry that is not in operation into sleep mode. 1.2 M.2 ArmourDrive’s controller uses advanced wearleveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure M.2 ArmourDrive firmware integrity. 1.1.4 Embedded Flash File System The embedded flash file system is an integral part of M.2 ArmourDrive. It contains MCU firmware that performs the following tasks: 1.3 1. Translates host side signals into flash media writes and reads 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 Advanced NAND Management Advanced Data Security Advanced data security measures include end-to-end data path protection, data sanitization (Secure Erase) and cryptographic erase (Crypto Erase) support. Secure Erase is an effective method to quickly wipe all data from a PCIe-based SSD using the NVMe protocol (Format NVM). Cryptographic erase resets the cryptographic key of an OPAL-activated SSD making all encrypted user data useless. M.2 ArmourDrive’s controller supports industry standard AES-256 encryption to protect sensitive user data. 2 04/28/2023 S71472-01 GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 2.0 FUNCTIONAL BLOCKS Figure 2-1: M.2 ArmourDrive Block Diagram These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 3 04/28/2023 S71472-01 GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 3.0 APPENDIX 3.1 Product Ordering Information GLS 88 BP XX XX xxx x3 - I - CD3xx XXX XX - X - XXXXX Ordering Code CD3xx = NVMe M.2 AmourDrive Revision with encryption and on-board DRAM Operating Temperature I = Industrial: -40°C to +85°C NAND Configuration 3 = 3 bits per cell GByte Designator G = GByte Note: TByte Designator included in Capacity Capacity 240 = 240 GByte 480 = 480 GByte 960 = 960 GByte 1T92 = 1.92 TByte Product Generation P = Generation Form Factor B = M.2 2280 (DS) Product Family 88 = NVMe M.2 ArmourDrive These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 4 04/28/2023 S71472-01 GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: M.2 ArmourDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 240GB Industrial (-40°C to 85°C) GLS88BP240G3-I-CD300 2280 (DS), M key 240GB Industrial (-40°C to 85°C) GLS88BP240G3-I-CD313 2280 (DS), M key 480GB Industrial (-40°C to 85°C) GLS88BP480G3-I-CD300 2280 (DS), M key 480GB Industrial (-40°C to 85°C) GLS88BP480G3-I-CD302 2280 (DS), M key 480GB Industrial (-40°C to 85°C) GLS88BP480G3-I-CD313 2280 (DS), M key 960GB Industrial (-40°C to 85°C) GLS88BP960G3-I-CD300 2280 (DS), M key 960GB Industrial (-40°C to 85°C) GLS88BP960G3-I-CD302 2280 (DS), M key 960GB Industrial (-40°C to 85°C) GLS88BP960G3-I-CD313 2280 (DS), M key 1.92TB Industrial (-40°C to 85°C) GLS88BP1T923-I-CD300 2280 (DS), M key 1.92TB Industrial (-40°C to 85°C) GLS88BP1T923-I-CD313 2280 (DS), M key These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 5 04/28/2023 S71472-01 GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 3.2 Board Diagrams SIDE VIEW TOP VIEW BOTTOM VIEW Note: All dimensions are in millimeters, unless otherwise specified. Figure 3-1: M.2 2280 ArmourDrive Dimensions These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 6 04/28/2023 S71472-01 GLS88BP240G3 / 480G3 / 960G3 / 1T923 Industrial Temp NVMe M.2 2280 ArmourDrive™ PX Series Factsheet 04.000 April 2023 Revision History Number Description Date 01.000 Initial release as Factsheet December 13, 2019 02.000 Updated Features on page 1 August 07, 2020 03.000 Added part numbers with “CD302” suffix; Updated power consumption values September 14, 2021 04.000 Added part numbers with “CD313” suffix April 28, 2023 © 2023 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and ArmourDrive is a trademark of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 3Greenliant GLS FS0019 Rev. 01 7 04/28/2023 S71472-01
物料型号:GLS88BP240G3 / 480G3 / 960G3 / 1T923
器件简介: - 这些是高性能、高可靠性的固态硬盘,结合了NAND闪存存储和先进的NVMe PCIe控制器。
引脚分配: - M.2 2280接口,22mm x 80mm x 3.58mm尺寸,双面(DS),M键。
参数特性: - PCIe Gen3x4接口,兼容PCI Express Base Revision 3.1和NVMe 1.3。 - 顺序读取速度高达3300MB/s,顺序写入速度高达1000MB/s(128KB传输大小)。 - 支持3.3V单电源供电。 - 活动模式下功耗典型值:1.92TB < 5900mW,960GB < 5500mW,480GB < 5000mW,240GB < 3650mW。 - 空闲模式功耗:<2000mW。 - 内置电流检测器,保护免受过电流冲击,并在上电和下电期间生成复位以防止意外写入。
功能详解: - 支持S.M.A.R.T和TRIM命令。 - 平均无故障时间(MTBF):200万小时。 - 数据保护包括端到端数据路径保护、安全擦除/数据清理、支持TCG OPAL 2.0、密码擦除(密码密钥重置)。 - 内置ECC,使用针对3D NAND优化的先进LDPC位错误检测和校正。 - 工业级3D TLC NAND闪存。 - 耐久性:编程/擦除(P/E)周期:3000次,写入的TB数(TBW):最高2800TB。 - 工作温度范围:工业级:-40°C至85°C。
应用信息: - 适用于需要可移动外形尺寸和更可靠数据存储的应用。NVMe M.2固态存储技术用于工业和云计算、数据中心、高性能企业存储和网络系统、端点和瘦客户端、游戏机和广播设备。
封装信息: - 所有设备均符合RoHS标准。
GLS88BP960G3-I-CD302 价格&库存
很抱歉,暂时无法提供与“GLS88BP960G3-I-CD302”相匹配的价格&库存,您可以联系我们找货
