GLS85LS1004P-S-I-FZJE-TT095
    GREENLIANT(绿芯)
    4 GByte Industrial-Grade SLC SATA NANDrive™ SSD (Solid State Drive) - FBGA-145
GLS85LS1004P-S-I-FZJE-TT095 数据手册
GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 Features • Industry Standard Serial ATA (SATA) Host Interface 1) - SATA 1.5Gb/s - ATA/ATAPI-8 compliant - Supports 48-bit address feature set • Performance - Sequential data read: Up to 70 MByte/sec* - Sequential data write: Up to 60 MByte/sec* • Integrated Voltage Detector - Detects supply voltage fluctuations and generates reset during power-up and powerdown to prevent inadvertent writes • Supports SMART Commands • Expanded Data Protection - Added data security through user-selectable protection zones • 20-Byte Serial Number - Factory pre-programmed 10-Byte unique ID - User-programmable 10-Byte ID • Robust Built-in ECC • NAND Configuration - 1 bit per cell (SLC) • Industrial Temperature Range - -40°C to 85°C • FBGA package - 14.0 mm x 24.0 mm x 1.95 mm, 145-ball, 1.0 mm ball pitch, FZJE • All Devices are RoHS Compliant * measured using 128 KByte transfer size • Power Management - 3.3V and 1.2Vpower supply - Host SATA interface power management - Immediate disabling of unused circuitry without host intervention 2) • Power Specifications - Active mode: 750mW typical (GLS85LS1008P) 560mW typical (GLS85LS1004P) 450mW typical (GLS85LS1002P) - Idle / Standby mode: 210mW typical - Sleep mode: 70mW typical 1) 2) Current product revision supports SATA Revision 1.x with host transfer rate of up to 1.5 Gb/s (i.e. SATA 1.5Gb/s). For management of the Sleep Mode, refer to “SATA NANDrive Application Design Guide.” Product Description The GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ devices (referred to as “SATA NANDrive” in this factsheet) are fully integrated solid state drives. They combine an advanced Greenliant NAND controller and 2, 4 or 8 GByte of NAND flash in a multi-chip package. These products are ideal for embedded and portable applications that require smaller form-factor and more reliable data storage. The integrated NAND flash controller with built-in advanced NAND management firmware communicates with the host through the standard SATA protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). SATA NANDrive is pre-programmed with a 10-Byte unique serial ID and has the option of programming an additional 10-Byte serial ID for even greater system security. SATA-interface solid state mass storage technology is widely used in portable and industrial computers, settop boxes, multi-functional printers, point-of-sales terminals, video and audio recorders, medical instruments and car infotainment systems. SATA NANDrive’s advanced NAND management technology enhances data reliability and security, improves endurance and accurately estimates the remaining life of the NAND flash devices. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to significantly extend the life of the product. SATA NANDrive is a single device, solid state drive (SSD) that provides the functionality and compatibility of a complete SATA hard disk drive (HDD) in a 14 mm x 24 mm BGA package for easy, space saving mounting to a system motherboard. These products surpass traditional storage in their small size, security, reliability, ruggedness and low power consumption. These specifications are subject to change without notice. © 2018 Greenliant SATA NANDrive devices are offered in a 145-ball BGA, 1 mm ball pitch package. 1 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 1.0 GENERAL DESCRIPTION Each SATA NANDrive contains an integrated SATA NAND flash memory controller and up to eight discrete NAND flash die in a BGA package. Refer to Figure 2-1 for the SATA NANDrive block diagram. 1.1 1.1.4 Optimized SATA NANDrive The embedded flash file system is an integral part of SATA NANDrive. It contains MCU firmware that performs the following tasks: The heart of SATA NANDrive is the SATA NAND flash memory controller which translates standard SATA signals into flash media data and control signals. The following components contribute to SATA NANDrive’s operation. 1.1.1 1. Translates host side signals into flash media writes and reads 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures 4. Manages system security for the selected protection zones Microcontroller Unit (MCU) The MCU translates SATA commands into data and control signals required for flash media operation. 1.1.2 Internal Direct Memory Access (DMA) SATA NANDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmware-based approach, thereby increasing the data transfer rate. 1.1.3 Embedded Flash File System 1.1.5 E rror C orrec tion C ode (E C C ) High performance is achieved through optimized hardware error detection and correction. Power Management Unit (PMU) 1.1.6 Serial Communication Interface (SCI) The PMU controls the power consumption of SATA NANDrive. The PMU dramatically reduces the power consumption of SATA NANDrive by putting the part of 3) the circuitry that is not in operation into sleep mode. The Serial Communication Interface (SCI) is designed for error reporting. During the product development stage, it is recommended to provide the SCI port on the PCB to aid in design validation. The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure SATA NANDrive firmware integrity. For regular power management, the host must send a STANDBY_IMMEDIATE (E0h), IDLE_IMMEDIATE (E1h), STANDBY (E2h) or IDLE (E3h) command and wait for command ready before powering down SATA NANDrive. 1.1.7 3) Multi-tas king Interfac e The multi-tasking interface enables fast, sequential write performance by allowing concurrent Read, Program and Erase operations to multiple flash media. 1.2 SMT Reflow Consideration The SATA NANDrive family utilizes standard NAND flash for data storage. Because the high temperature in a surface-mount soldering reflow process may alter the content on NAND flash, it is recommended to program SATA NANDrive after the reflow process. For management of the Sleep Mode, refer to “SATA NANDrive Application Design Guide.” 1.3 Advanced NAND Management SATA NANDrive’s integrated controller uses advanced wear-leveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. These specifications are subject to change without notice. © 2018 Greenliant 2 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 2.0 FUNCTIONAL BLOCKS SATA NANDrive NAND Controller SATA ll HOST I/F MCU SRAM Buffer SATA I/F 3.0/1.5 Gbps Memory Channel I/F Embedded Flash File System ECC NAND NAND NAND NAND NAND Chips Chips Chips Chips Flash Memory Channel I/F Internal DMA PMU Flash Media I/F NAND I/F SCI ECC Figure 2-1: SATA NANDrive Block Diagram These specifications are subject to change without notice. © 2018 Greenliant 3 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 PR ODUC T OR DE R ING INF OR MAT ION 3.0 GLS 85 LS 1 0xxP - S - I - FZJE - NDxxx XX XX X XXXX - X - X - XXXX - XXXXX 4) Ordering Code NDxxx or TTxxx = NANDrive revision Exxxx = Evaluation Board revision Environmental Attribute E = non-Pb solder (RoHS Compliant) Package Modifier ZJ = 145-ball positions Package Type F = FBGA Operation Temperature I = Industrial: -40°C to +85°C NAND Configuration S = 1 bit per cell Generation / Product Configuration P = First generation Capacity 002 = 2 GByte 004 = 4 GByte 008 = 8 GByte MByte or GByte Designator 0 = MByte 1 = GByte Interface S = SATA Voltage L = 3.3V Product Series 85 = NANDrive 4) Note that the top side marking on the package typically does not include ordering codes (e.g. NDxxx), unless it is a special C-SPEC (custom specification) which is required by the end-customer to be marked on the device. These specifications are subject to change without notice. © 2018 Greenliant 4 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: SATA NANDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number Package 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-FZJE FZJE, 14x24x1.95mm 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-FZJE-ND104 FZJE, 14x24x1.95mm 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-FZJE-TT095* FZJE, 14x24x1.95mm 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-FZJE FZJE, 14x24x1.95mm 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-FZJE-ND104 FZJE, 14x24x1.95mm 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-FZJE-TT095* FZJE, 14x24x1.95mm 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-FZJE FZJE, 14x24x1.95mm 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-FZJE-ND101 FZJE, 14x24x1.95mm 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-FZJE-ND104 FZJE, 14x24x1.95mm 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-FZJE-TT095* FZJE, 14x24x1.95mm * TT095 products include enhanced support for TRIM command and power management in Windows environments. Table 3-2: SATA NANDrive Evaluation Board Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1S-K Module with SATA connector 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1S-ED104 Module with SATA connector 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1S-ET095 Module with SATA connector 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1S-K Module with SATA connector 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1S-ED104 Module with SATA connector 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1S-ET095 Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-K Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-ED101 Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-ED104 Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-ET095 Module with SATA connector Capacity Operating Temperature Part Number Form Factor 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1S-K Module with SATA connector 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1S-ED104 Module with SATA connector 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1S-ET095 Module with SATA connector 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1S-K Module with SATA connector 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1S-ED104 Module with SATA connector 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1S-ET095 Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-K Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-ED101 Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-ED104 Module with SATA connector 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1S-ET095 Module with SATA connector Table 3-3: SATA NANDrive miniSATA Evaluation Board Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1MS-K These specifications are subject to change without notice. © 2018 Greenliant 5 JEDEC MO-300 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ 2GB Industrial (-40°C to 85°C) GLS85LS1002P-S-I-1MS-ED104 Factsheet 04.100 July 2018 JEDEC MO-300 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1MS-K JEDEC MO-300 4GB Industrial (-40°C to 85°C) GLS85LS1004P-S-I-1MS-ED104 JEDEC MO-300 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1MS-K JEDEC MO-300 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1MS-ED101 JEDEC MO-300 8GB Industrial (-40°C to 85°C) GLS85LS1008P-S-I-1MS-ED104 JEDEC MO-300 These specifications are subject to change without notice. © 2018 Greenliant 6 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 3.1 Package Diagram TOP VIEW 11 10 9 8 7 14.0 +/- 0.1 6 5 4 3 2 1 A B C D E F G H J K L M N P R T U V W Y AA AB AC 24.0 ±0.1 A1 CORNER BOTTOM VIEW 0.5 +/- 0.05 (145x) 14.0 3.0 1 1.0 2 3 4 5 6 8.0 7 8 9 10 11 1.0 A B C D E F G H J K L M N P R T U V W Y AA AB AC SIDE VIEW 1mm DETAIL Note: All linear dimensions are in millimeters. Untoleranced dimensions are nominal target values. Coplanarity: 0.15 mm. Ball opening size is 0.40 mm (± 0.05 mm). 0.40 ±0.05 1.80 ± 0.15 0.15 SEATING PLANE Figure 3-1: SATA NANDrive 145-Ball, Ball Grid Array (BGA) Greenliant Package Code: FZJ These specifications are subject to change without notice. © 2018 Greenliant 7 07/10/2018 S71432-F GLS85LS1002P / 1004P / 1008P Industrial Grade SATA NANDrive™ Factsheet 04.100 July 2018 Revision History Revision 01.000 01.001 01.002 02.000 02.100 02.101 02.200 03.000 03.001 04.000 04.100 Description Initial release of Fact Sheet for GLS85LS1002P/1004P/1008P Updated Table 3-1 Corrected typo in Table 3-1 Added part numbers GLS85LS1016P/1032P and updated Section 1.2 Separated part numbers GLS85LS1016P/1032P to document S71445-F Updated Table 3-1 and Section 4.0 Removed Table 3-1 Updated Power Specifications Added information for part number GLS85LS1008P-S-I-FZJE-ND104 Added information for part numbers GLS85LS1002P-S-I-FZJE-ND104 and GLS85LS1004P-S-I-FZJE-ND104 Updated Section 1.1.3 Added GLS85LS1002P/1004P/1008P part numbers with the TT095 suffix Added Evaluation Board part numbers with the ET095 suffix Date October 17, 2011 December 22, 2011 March 12, 2012 April 9, 2012 January 18, 2013 April 17, 2013 November 21, 2013 February 25, 2014 May 09, 2014 October 19, 2016 July 10, 2018 © 2018 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and NANDrive is a trademark of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2018 Greenliant 8 07/10/2018 S71432-F
GLS85LS1004P-S-I-FZJE-TT095 价格&库存
很抱歉,暂时无法提供与“GLS85LS1004P-S-I-FZJE-TT095”相匹配的价格&库存,您可以联系我们找货
