GLS93SP032G3-I-BZ802
    GREENLIANT(绿芯)
GLS93SP032G3-I-BZ802 数据手册
GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 Features • Industry Standard Interface – SD Specification Version 6.10 compliant – Supports secure digital (SD) and serial peripheral interface (SPI) protocols • Performance – Class 10 Speed performance rating (based on SD 6.10 Specification) – Bus speed mode (using 4 parallel data lines)* SDR12: 1.8V signaling (up to 25 MHz) up to 12.5MB/sec SDR25: 1.8V signaling (up to 50 MHz) up to 25MB/sec SDR50: 1.8V signaling (up to 100 MHz) up to 50MB/sec SDR104: 1.8V signaling (up to 208 MHz) up to 104MB/sec DDR50: 1.8V signaling (up to 50 MHz, sampled on both clock edges) up to 50MB/sec • Reliability – Mean Time Between Failures (MTBF): More than 3 million hours • Data Protection – Content Protection for Recordable Media (CPRM) support (optional) – Password protection (optional) • Built-in ECC – Uses advanced bit error detection and correction optimized for 3D NAND • SSD Lifespan Monitoring – Enables SMART command-based alerts indicating the remaining useful product life and device information • NAND Configuration – 3 bits per cell (3D TLC NAND) • Endurance – 3K P/E cycles • Operating Temperature Range – Industrial: -40°C to 85°C • SD and microSD Card Form Factors – SD card: 32 x 24 x 2.1 mm – microSD card: 15 x 11 x 1.0 mm • Capacity – High Capacity SD / microSD Card (SDHC / microSDHC): 32GB – Extended Capacity SD Card / microSD Card (SDXC / SDXC): 64GB, 128GB, 256GB • All Devices are RoHS Compliant *timing in 1.8V signaling differs from that of 3.3V signaling – Sequential data read / write: Up to 95 MB/s / Up to 30 MB/s** **measured using 128 KByte transfer size • Power Management – 3.3V power supply – 2.7V ~ 3.6V operating voltage range with 2 Type signaling (1.8V and 3.3V) • Power Consumption – Active mode: < 400 mA – Standby mode: < 1 mA • ESD Protection – +4KV/-4KV (contact pads) Product Description The GLS93SP032G3 / 064G3 / 128G3 / 256G3 (SD form factor) and GLS93MP032G3 / 064G3 / 128G3 / 256G3 (microSD form factor) Industrial Temperature SD / microSD ArmourDrive™ PX Series (referred to as “SD/microSD ArmourDrive” in this factsheet) are high-performance, low-power flash memory cards. They combine 32, 64, 128 or 256 GBytes of NAND flash memory with an advanced NAND controller in standard SD and microSD card form factors. The NAND flash controller with built-in advanced NAND management firmware communicates with the host through the standard SD / SPI protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). The firmware effectively optimizes the use of NAND flash memory’s program/erase (P/E) cycles and minimizes write amplification. SD/microSD ArmourDrive is ideal for applications that require hot-swappable, small form factor data storage with high shock-resistance. SD/microSD cards are widely used in transportation systems, industrial automation, vending and gaming machines, medical computing, professional video and photo cameras, set-top boxes and point-of-sales (POS) equipment. These industrial removable memory cards surpass consumer memory cards in their security, reliability and ruggedness. SD/microSD ArmourDrive’s advanced NAND management technology improves endurance, enhances data security and helps prevent data loss during unexpected power loss events. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to improve data reliability and significantly extend the life of the product. These specifications are subject to change without notice. © 2019 Greenliant 1 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 1.0 GENERAL DESCRIPTION Each SD/microSD ArmourDrive integrates a NAND flash memory controller with NAND flash in a multi-chip package. Refer to Figure 2-1 for the SD/microSD ArmourDrive block diagram. 1.1 1.1.5 Optimized SD/microSD ArmourDrive The ECC technology uses advanced algorithms to detect and correct errors, ensuring data integrity and extending the SSD lifespan. The heart of SD/microSD ArmourDrive is the NAND flash memory controller, which translates standard SD / SPI signals into flash media data and control signals. The following components contribute to SD/microSD ArmourDrive’s operation. 1.1.1 1.1.6 1.2 Power Management Unit (PMU) The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure SD/microSD ArmourDrive firmware integrity. Embedded Flash File System 1.2.1 The embedded flash file system is an integral part of SD/microSD ArmourDrive. It contains MCU firmware that performs the following tasks: SMART Support Industrial SD/microSD ArmourDrive memory cards use Self-Monitoring, Analysis and Reporting Technology (SMART) for automatic monitoring and reporting of the device’s health and remaining usage life. With SMART support for advanced notifications, preventive actions can be taken by the host to minimize any irreversible data loss and ensure data integrity. 1. Translates host side signals into flash media writes and reads 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures 1.1.4 Advanced NAND Management SD/microSD ArmourDrive’s controller uses advanced wear-leveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed across all available blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. The PMU controls the power consumption of SD/microSD ArmourDrive. The PMU dramatically reduces the power consumption of SD/microSD ArmourDrive by putting the part of the circuitry that is not in operation into sleep mode. 1.1.3 Multi-tasking Interface The multi-tasking interface enables concurrent Read, Program and Erase operations to multiple NAND flash media. Microcontroller Unit (MCU) The MCU translates SD/SPI commands into data and control signals required for flash media operation. 1.1.2 Error Correction Code (ECC) Power Interrupt Data Protection Power Interrupt Data Protection is a mechanism to help prevent data loss during unexpected power failure events. Enhanced data integrity is supported by the controller’s advanced firmware during abnormal power loss. These specifications are subject to change without notice. © 2019 Greenliant 2 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 2.0 FUNCTIONAL BLOCKS Figure 2-1: SD / microSD ArmourDrive Block Diagram These specifications are subject to change without notice. © 2019 Greenliant 3 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 3.0 APPENDIX 3.1 Product Ordering Information GLS 93 xP XX XX xxx G3 - I - BZ8xx XXX XX - X - XXXXX Ordering Code BZ8xx = SD / microSD ArmourDrive Revision Operating Temperature I = Industrial: -40°C to +85°C NAND Configuration 3 = 3 bits per cell GByte Designator G = GByte Capacity 032 = 32 GByte 064 = 64 GByte 128 = 128 GByte 256 = 256 GByte Product Generation P = Generation Form Factor S = SD M = microSD Product Family 93 = SD / micro SD ArmourDrive These specifications are subject to change without notice. © 2019 Greenliant 4 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: SD ArmourDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 32GB Industrial (-40°C to 85°C) GLS93SP032G3-I-BZ802 SD card 64GB Industrial (-40°C to 85°C) GLS93SP064G3-I-BZ802 SD card 128GB Industrial (-40°C to 85°C) GLS93SP128G3-I-BZ802 SD card 256GB Industrial (-40°C to 85°C) GLS93SP256G3-I-BZ802 SD card Table 3-2: microSD ArmourDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 32GB Industrial (-40°C to 85°C) GLS93MP032G3-I-BZ800 microSD card 64GB Industrial (-40°C to 85°C) GLS93MP064G3-I-BZ800 microSD card 128GB Industrial (-40°C to 85°C) GLS93MP128G3-I-BZ800 microSD card 256GB Industrial (-40°C to 85°C) GLS93MP256G3-I-BZ800 microSD card These specifications are subject to change without notice. © 2019 Greenliant 5 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 3.2 Product Diagrams SIDE VIEW TOP VIEW BOTTOM VIEW Note: All dimensions are in millimeters, unless otherwise specified. Figure 3-1: SD ArmourDrive Dimensions These specifications are subject to change without notice. © 2019 Greenliant 6 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 SIDE VIEW Note: TOP VIEW BOTTOM VIEW All dimensions are in millimeters, unless otherwise specified. Figure 3-2: microSD ArmourDrive Dimensions These specifications are subject to change without notice. © 2019 Greenliant 7 10/18/2019 S71477-01 GLS93SPxxxG3 / GLS93MPxxxG3 Industrial Temp SD / microSD ArmourDrive™ PX Series Factsheet 01.000 October 2019 Revision History Revision 01.000 Description Date October 18, 2019 Initial release as Factsheet © 2019 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and ArmourDrive is a trademark of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2019 Greenliant 8 10/18/2019 S71477-01
GLS93SP032G3-I-BZ802 价格&库存
很抱歉,暂时无法提供与“GLS93SP032G3-I-BZ802”相匹配的价格&库存,您可以联系我们找货
    库存:375
