GLS89SP001T3-I-BZ400
    GREENLIANT(绿芯)
GLS89SP001T3-I-BZ400 数据手册
GLS89SP032G3/064G3/128G3/256G3/512G3/001T3 Industrial Temp 2.5” SATA ArmourDrive™ PX Series Factsheet 01.002 July 2019 Features  Industry Standard 2.5” SATA Host Interface – SATA 1.5Gb/s, 3Gb/s and 6Gb/s – SATA Revision 3.2 – ATA/ATAPI-8 compliant – Supports 48-bit address feature set  Performance – Sequential data read: Up to 550 MB/s* – Sequential data write: Up to 500 MB/s*  Reliability – Mean Time Between Failures (MTBF): More than 2 million hours  Data Protection – Secure Erase (data sanitization)  Integrated Current Detector – Protects from inrush current and generates reset during power-up and power-down to prevent inadvertent writes  Native Command Queuing (NCQ) – Up to 32 commands  Supports SMART and TRIM Commands  20-Byte Serial Number – Factory pre-programmed unique ID  Built-in ECC – Uses advanced LDPC bit error detection and correction optimized for 3D NAND  NAND Configuration – 3 bits per cell (3D TLC)  Endurance – 3K P/E cycles (typical)  Operating Temperature Range – Industrial: -40°C to 85°C  2.5-inch Form Factor – 100mm x 69.85mm x 7.00mm  All Devices are RoHS Compliant * measured using 128 KByte transfer size  Power Management – 5V power supply – Host initialized power management (HIPM) – Device initialized power management (DIPM)  Power Specifications – Active mode: 1TB: 1680mW (typical) 512GB: 1670mW (typical) 256GB: 1450mW (typical) 128GB: 1350mW (typical) 64GB: 1230mW (typical) 32GB: 1100mW (typical) – Idle mode: < 325mW (typical) – Slumber mode: < 16mW (typical) – DevSleep mode (optional): < 5mW (typical) Product Description The GLS89SP032G3 / 064G3 / 128G3 / 256G3 / 512G3 / 001T3 Industrial Temperature SATA 2.5” ArmourDrive™ PX Series (referred to as 2.5” ArmourDrive” in this factsheet) are high-performance, high-reliability solid state drives. They combine 32, 64, 128, 256 or 512 GBytes, or 1 TByte of NAND flash memory with an advanced Serial ATA (SATA) controller in a standard 2.5-inch form factor housing. The SATA SSD controller with built-in advanced NAND management firmware communicates with the host through the standard SATA protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). The firmware effectively optimizes the use of NAND flash memory’s program/erase (P/E) cycles and minimizes write amplification. 2.5” ArmourDrive is ideal for applications that require hot-swappable and reliable data storage. 2.5” SATA solid state storage technology is widely used in servers, laptops, network-attached storage, industrial computers, navigation systems, test and measurement instrumentation, multi-function printers, security and surveillance equipment, digital signage and networking systems. These removable solid state drives (SSDs) surpass traditional hard disk drives (HDDs) in their security, reliability, ruggedness and low power consumption. These specifications are subject to change without notice. © 2019 Greenliant GLS FS0019 Rev. 00 2.5” ArmourDrive’s advanced NAND management technology improves endurance, enhances data security and helps prevent data loss during unexpected power failure events. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to improve data reliability and significantly extend the life of the product. 1 07/08/2019 S71465-01 GLS89SP032G3/064G3/128G3/256G3/512G3/001T3 Industrial Temp 2.5” SATA ArmourDrive™ PX Series 1.0 GENERAL DESCRIPTION 1.1 Optimized 2.5” ArmourDrive Factsheet 01.002 July 2019 Each 2.5” ArmourDrive integrates a SATA SSD controller with up to four NAND flash multi-chip packages in a standard 2.5-inch form factor housing. Refer to Figure 2-1 for the 2.5” ArmourDrive block diagram. 1.1.5 Power Interrupt Data Protection Power Interrupt Data Protection is a mechanism to help prevent data loss during unexpected power failure events. Enhanced data integrity is supported by the controller’s advanced firmware during abnormal power loss. The controller proactively optimizes the amount and stay time of the “in-flight” data residing in the cache. To ensure there is no data loss risk caused by power cycling, the controller sends an acknowledgement to the host only when the incoming data is fully committed to the NAND flash. The heart of 2.5” ArmourDrive is the SATA SSD controller, which translates standard SATA signals into flash media data and control signals. The following components contribute to 2.5” ArmourDrive’s operation. 1.1.1 Microcontroller Unit (MCU) The MCU translates SATA commands into data and control signals required for flash media operation. 1.1.2 Internal Direct Memory Access (DMA) 1.1.6 Error Correction Code (ECC) 2.5” ArmourDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmware-based approach, thereby increasing the data transfer rate. The ECC technology uses advanced Low Density Parity Check (LDPC) algorithms to detect and correct errors, ensuring data integrity and extending the SSD lifespan. 1.1.7 Multi-tasking Interface 1.1.3 Power Management Unit (PMU) The multi-tasking interface enables concurrent Read, Program and Erase operations to multiple NAND flash media. The PMU controls the power consumption of 2.5” ArmourDrive. The PMU dramatically reduces the power consumption of 2.5” ArmourDrive by putting the part of the circuitry that is not in operation into sleep mode. 1.2 The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure 2.5” ArmourDrive firmware integrity. For regular power management, the host must send an IDLE_IMMEDIATE command and wait for command ready before powering down 2.5” ArmourDrive. Advanced NAND Management 2.5” ArmourDrive’s controller uses advanced wearleveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. 1.1.4 Embedded Flash File System The embedded flash file system is an integral part of 2.5” ArmourDrive. It contains MCU firmware that performs the following tasks: 1. Translates host side signals into flash media writes and reads 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures These specifications are subject to change without notice. © 2019 Greenliant GLS FS0019 Rev. 00 2 07/08/2019 S71465-01 GLS89SP032G3/064G3/128G3/256G3/512G3/001T3 Industrial Temp 2.5” SATA ArmourDrive™ PX Series Factsheet 01.002 July 2019 2.0 FUNCTIONAL BLOCKS Figure 2-1: SATA 2.5” ArmourDrive Block Diagram These specifications are subject to change without notice. © 2019 Greenliant GLS FS0019 Rev. 00 3 07/08/2019 S71465-01 GLS89SP032G3/064G3/128G3/256G3/512G3/001T3 Industrial Temp 2.5” SATA ArmourDrive™ PX Series 3.0 3.1 Factsheet 01.002 July 2019 APPENDIX Product Ordering Information GLS 89 SP XX XX xxx G3 - I - BZ4xx XXX XX - X - XXXXX Ordering Code BZ4xx = SATA AmourDrive Revision Operating Temperature I = Industrial: -40°C to +85°C NAND Configuration 3 = 3 bits per cell GByte or TByte Designator G = GByte T = TByte Capacity 032 = 32 GByte 064 = 64 GByte 128 = 128 GByte 256 = 256 GByte 512 = 512 GByte 001 = 1 TByte Product Generation P = Generation Form Factor S = 2.5” Product Family 89 = SATA 2.5” ArmourDrive Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: SATA 2.5” ArmourDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number Form Factor 32GB Industrial (-40°C to 85°C) GLS89SP032G3-I-BZ400 2.5-inch 128GB Industrial (-40°C to 85°C) GLS89SP128G3-I-BZ400 2.5-inch Industrial (-40°C to 85°C) GLS89SP512G3-I-BZ400 2.5-inch 64GB 256GB 512GB 1TB Industrial (-40°C to 85°C) Industrial (-40°C to 85°C) Industrial (-40°C to 85°C) These specifications are subject to change without notice. © 2019 Greenliant GLS FS0019 Rev. 00 GLS89SP064G3-I-BZ400 GLS89SP256G3-I-BZ400 GLS89SP001T3-I-BZ400 4 2.5-inch 2.5-inch 2.5-inch 07/08/2019 S71465-01 GLS89SP032G3/064G3/128G3/256G3/512G3/001T3 Industrial Temp 2.5” SATA ArmourDrive™ PX Series 3.2 Factsheet 01.002 July 2019 Mechanical Diagrams Note: All linear dimensions are in millimeters. Figure 3-1: SATA 2.5” ArmourDrive Dimensions These specifications are subject to change without notice. © 2019 Greenliant GLS FS0019 Rev. 00 5 07/08/2019 S71465-01 GLS89SP032G3/064G3/128G3/256G3/512G3/001T3 Industrial Temp 2.5” SATA ArmourDrive™ PX Series Revision History Revision 01.000 01.001 01.002 Initial Release as Factsheet Factsheet 01.002 July 2019 Description Updated Features descriptions on page 1 Date January 31, 2019 June 5, 2019 Updated Features descriptions on page 1 July 8, 2019 © 2019 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and ArmourDrive is a trademark of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2019 Greenliant GLS FS0019 Rev. 00 6 07/08/2019 S71465-01
GLS89SP001T3-I-BZ400 价格&库存
很抱歉,暂时无法提供与“GLS89SP001T3-I-BZ400”相匹配的价格&库存,您可以联系我们找货
