GLS86FA008G1-BN004
GLS86FA008G1-BN004
    GREENLIANT(绿芯)
    mSATA
GLS86FA008G1-BN004 数据手册
GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 Features • Expanded Data Protection - Added data security through user-selectable protection zones • Integrated Voltage Detector - Detects supply voltage fluctuations and generates reset during power-up and powerdown to prevent inadvertent writes • Supports SMART Commands • Supports TRIM Commands • 20-Byte Serial Number - Factory pre-programmed 10-Byte unique ID - User-programmable 10-Byte ID • Robust Built-in ECC • NAND Configuration - 1 bit per cell (SLC) • Temperature Range - Industrial: -40°C to 85°C • JEDEC standard MO-300 mSATA form factor 29.85 mm x 50.80 mm x 4.8 mm • All Devices are RoHS Compliant • Industry Standard mini-Serial ATA (miniSATA or mSATA) Host Interface 1) - SATA 1.5 Gb/s or SATA 3.0 Gb/s - ATA/ATAPI-8 compliant - Supports 48-bit address feature set • Performance - Sequential data read Up to 120 MByte/sec* - Sequential data write Up to 80 MByte/sec* * measured using 128 KByte transfer size • Power Management - 3.3V power supply - Host SATA interface power management - Immediate disabling of unused circuitry without host intervention 2) • Power Specifications - Active mode: 1070mW typical (GLS86FA032G1) 820mW typical (GLS86FA016G1) 810mW typical (GLS86FA008G1) - Idle/Standby mode: as low as 380mW typical - Sleep mode: as low as 110mW typical 1) 2) Current product revision supports SATA Revision 1.x with host transfer rate of up to 1.5 Gb/s (i.e. SATA 1.5 Gb/s). SATA 3.0 Gb/s refers to SATA Revision 2.x and will be supported by our planned future product revisions. For management of the Sleep Mode, please refer to “SATA NANDrive Application Design Guide.” Product Description The GLS86FA008G1 / 016G1 / 1032G1 Industrial Grade miniSATA (mSATA) ArmourDrive™ solid state drive modules (referred to as “mSATA ArmourDrive” in this fact sheet) are high-reliability, fully integrated solid state drives. They combine an 8, 16 or 32 GByte SATA NANDrive™ and power interrupt data protection circuit on a printed circuit board (PCB) module. These products are ideal for portable applications that require removable form factor and more reliable data storage. The integrated NAND flash controller with built-in advanced NAND management firmware communicates with the host through the standard SATA protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). mSATA ArmourDrive is pre-programmed with a 10Byte unique serial ID and has the option of programming an additional 10-Byte serial ID for even greater system security. SATA-interface solid state mass storage technology is widely used in portable and industrial computers, settop boxes, test and measurement instrumentation, multi-functional printers, video and audio recorders, network servers and car infotainment systems. mSATA ArmourDrive’s advanced NAND management technology enhances data reliability and security, improves endurance and accurately estimates the remaining life of the NAND flash devices. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to significantly extend the life of the product. mSATA ArmourDrive is a removable solid state drive (SSD) that provides the functionality and compatibility of a complete SATA hard disk drive (HDD) in a 29.85 mm x 50.80 mm form factor. These products surpass traditional storage in their small size, security, reliability, ruggedness and low power consumption. These specifications are subject to change without notice. © 2018 Greenliant mSATA ArmourDrive is offered in a standard JEDEC 52-pin PCB module form factor. 1 04/16/2018 S71446-01 GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 1.0 GENERAL DESCRIPTION Each mSATA ArmourDrive module contains a NANDrive multi-chip package, which integrates a SATA NAND flash memory controller with up to eight discrete NAND flash die. Refer to Figure 2-1 for the mSATA ArmourDrive block diagram. 1.1 1.1.5 Optimized mSATA ArmourDrive Dedicated power failure detection and backup power circuitry are built in to prevent data integrity issues due to sudden power interruptions. The heart of mSATA ArmourDrive is the SATA NAND flash memory controller which translates standard SATA signals into flash media data and control signals. The following components contribute to mSATA ArmourDrive’s operation. 1.1.1 1.1.6 1.1.7 1.1.8 Power Management Unit (PMU) 1.2 Advanced NAND Management mSATA ArmourDrive’s integrated controller uses advanced wear-leveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure mSATA ArmourDrive firmware integrity. For regular power management, the host must send an IDLE_IMMEDIATE command and wait for command ready before powering down mSATA ArmourDrive. 1.1.4 Multi-tasking Interface The multi-tasking interface enables concurrent Read, Program and Erase operations to multiple NAND flash media. The PMU controls the power consumption of mSATA ArmourDrive. The PMU dramatically reduces the power consumption of mSATA ArmourDrive by putting the part of the circuitry that is not in operation into 3) sleep mode. 3) Serial Communication Interface (SCI) The Serial Communication Interface (SCI) is designed for error reporting. During the product development stage, it is recommended to provide the SCI port on the PCB to aid in design validation. Internal Direct Memory Access (DMA) mSATA ArmourDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmwarebased approach, thereby increasing the data transfer rate. 1.1.3 Error Correction Code (ECC) High performance is achieved through optimized hardware error detection and correction. Microcontroller Unit (MCU) The MCU translates SATA commands into data and control signals required for flash media operation. 1.1.2 Power Interrupt Data Protection For management of the Sleep Mode, please refer to “SATA NANDrive Application Design Guide.” Embedded Flash File System The embedded flash file system is an integral part of mSATA ArmourDrive. It contains MCU firmware that performs the following tasks: 1. Translates host side signals into flash media writes and reads 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures 4. Manages system security for the selected protection zones These specifications are subject to change without notice. © 2018 Greenliant 2 04/16/2018 S71446-01 GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 2.0 FUNCTIONAL BLOCKS ArmourDrive NAND Controller MCU mSATA HOST I/F SRAM Buffer Memory Channel I/F SATA I/F Flash Media I/F NAND I/F NAND NAND NAND NAND NAND Chips Chips Chips Flash Chips ECC Internal DMA PMU SCI Power Interrupt Data Protection Circuitry Figure 2-1: mSATA ArmourDrive Block Diagram These specifications are subject to change without notice. © 2018 Greenliant 3 04/16/2018 S71446-01 GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 3.0 APPENDIX 3.1 Product Ordering Information GLS 86 FA XX XX xxx G1 - BNxxx XXX XX - XXXXX 4) Ordering Code BNxxx = AmourDrive revision NAND Configuration 1 = 1 bit per cell (SLC) GByte or TByte Designator G = GByte Capacity 008 = 8 GByte 016 = 16 GByte 032 = 32 GByte Product Generation A = First generation Form Factor F = Full length (mSATA) Product Series 86 = mSATA ArmourDrive 4) Note that the top side marking on the package typically does not include ordering codes (e.g. BNxxx), unless it is a special custom specification (C-SPEC) required by the end-customer to be marked on the device. Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: mSATA ArmourDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number 8GB Industrial (-40°C to 85°C) 16GB Industrial (-40°C to 85°C) 32GB Industrial (-40°C to 85°C) Form Factor GLS86FA008G1-BN001 JEDEC MO-300 (full length) GLS86FA008G1-BN004* JEDEC MO-300 (full length) GLS86FA016G1-BN001 JEDEC MO-300 (full length) GLS86FA016G1-BN004* JEDEC MO-300 (full length) GLS86FA032G1-BN001 JEDEC MO-300 (full length) GLS86FA032G1-BN004* JEDEC MO-300 (full length) * BN004 products include enhanced support for TRIM command and power management in Windows environments. These specifications are subject to change without notice. © 2018 Greenliant 4 04/16/2018 S71446-01 GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 3.2 Board Diagrams TOP VIEW SIDE VIEW BOTTOM VIEW Note: All dimensions are in millimeters, unless otherwise specified. Tolerances on all dimensions are ± 0.15 mm, unless otherwise specified. Figure 3-1: mSATA ArmourDrive Dimensions These specifications are subject to change without notice. © 2018 Greenliant 5 04/16/2018 S71446-01 GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 TOP VIEW BOTTOM VIEW Note: All dimensions are in millimeters, unless otherwise specified. Tolerances on all dimensions are ± 0.15 mm, unless otherwise specified. Figure 3-2: mSATA ArmourDrive Connector These specifications are subject to change without notice. © 2018 Greenliant 6 04/16/2018 S71446-01 GLS86FA008G1 / 016G1 / 032G1 Industrial Grade mSATA ArmourDrive™ Fact Sheet 02.000 April 2018 3.3 Revision History Table 3-2: Revision History Revision Description 01.000 Initial release as Fact Sheet for GLS86FA008G1 / 016G1 / 032G1 01.100 Updated Power Specifications 01.101 Fixed typos on first page 02.000 Added ordering code BN004 Date July 18, 2013 October 04, 2013 December 10, 2013 April 16, 2018 © 2018 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and ArmourDrive and NANDrive are trademarks of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2018 Greenliant 7 04/16/2018 S71446-01
GLS86FA008G1-BN004 价格&库存
很抱歉,暂时无法提供与“GLS86FA008G1-BN004”相匹配的价格&库存,您可以联系我们找货
