GLS89SQ1T923-I-CD401
    GREENLIANT(绿芯)
GLS89SQ1T923-I-CD401 数据手册
GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 Features  Industry Standard ATA Host Interface – SATA 1.5Gb/s, 3Gb/s and 6Gb/s – SATA Revision 3.2 – ATA/ATAPI-8 compliant – Supports 48-bit address feature set – Native Command Queuing (NCQ) up to 32 commands  Performance – Sequential data read: Up to 550 MB/s – Sequential data write: Up to 520 MB/s  Reliability – Mean Time Between Failures (MTBF): 1.5 million hours  Data Protection – End-to-end data path protection – Supports TCG OPAL – Crypto Erase (cryptographic key reset) – Secure erase / Data sanitization)  Supports TRIM and SMART Commands  20-Byte Serial Number – Factory pre-programmed unique ID  Built-in ECC – Uses advanced LDPC bit error detection and correction optimized for 3D NAND  Industrial 3D TLC NAND Flash  Endurance – Program/Erase (P/E) cycles: 3K  Operating Temperature Range – Industrial: -40°C to 85°C (measured using 128KB transfer size)  Power Management – 5V power supply – Host initialized power management (HIPM) – Device initialized power management (DIPM)  Power Consumption – Active mode: 3.84TB: < 4,000mW 1.92TB: < 3,200mW 960GB: < 3,100mW 480GB: < 2,900mW 240GB: < 2,200mW – Idle mode: < 1,600mW  DRAM for Enhanced Performance (as reported by SMART)  2.5-inch Form Factor – 100mm x 69.85mm x 7.00mm  All Devices are RoHS Compliant Product Description The GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temperature SATA 2.5” ArmourDrive™ PX Series (referred to as 2.5” ArmourDrive” in this factsheet) are high-performance, high-reliability solid state drives. They combine 240, 480 or 960 GBytes, or 1.92 or 3.84 TBytes of NAND flash memory with DRAM and an advanced Serial ATA (SATA) controller in a standard 2.5-inch form factor housing. The SATA SSD controller with built-in advanced NAND management firmware communicates with the host through the standard SATA protocol. It does not require any additional or proprietary software such as the Flash File System (FFS) and Memory Technology Driver (MTD). The firmware effectively optimizes the use of NAND flash memory’s program/erase (P/E) cycles and minimizes write amplification. 2.5” ArmourDrive’s advanced NAND management technology improves endurance, enhances data security and helps prevent data corruption during unexpected power failure events. This innovative technology combines robust NAND controller hardware error correction capabilities with advanced wear-leveling algorithms and bad block management to improve data reliability and significantly extend the life of the product. 2.5” ArmourDrive is ideal for applications that require hot-swappable and reliable data storage. 2.5” SATA solid state storage technology is widely used in servers, laptops, network-attached storage, industrial computers, navigation systems, test and measurement instrumentation, multi-function printers, security and surveillance equipment, digital signage and networking systems. These removable solid state drives (SSDs) surpass traditional hard disk drives (HDDs) in their security, reliability, ruggedness and low power consumption. These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 1 03/31/2023 S71473-01 GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 1.0 GENERAL DESCRIPTION Each 2.5” ArmourDrive integrates a SATA SSD controller with NAND flash multi-chip packages and DRAM in a standard 2.5-inch form factor housing. Refer to Figure 2-1 for the 2.5” ArmourDrive block diagram. 1.1 Optimized 2.5” ArmourDrive 1.1.5 The heart of 2.5” ArmourDrive is the SATA SSD controller, which translates standard SATA signals into flash media data and control signals. The following components contribute to 2.5” ArmourDrive’s operation. 1.1.1 Power Interrupt Data Protection is a mechanism to help prevent data corruption during unexpected power failure events. Enhanced data integrity is supported by the controller’s advanced firmware during abnormal power loss. The controller proactively optimizes the amount and stay time of the “in-flight” data residing in the cache. To ensure there is no data loss risk caused by power cycling, the controller sends an acknowledgement to the host only when the incoming data is fully committed to the NAND flash. Microcontroller Unit (MCU) The MCU translates SATA commands into data and control signals required for flash media operation. 1.1.2 Internal Direct Memory Access (DMA) 2.5” ArmourDrive uses internal DMA allowing instant data transfer from/to buffer to/from flash media. This implementation eliminates microcontroller overhead associated with the traditional, firmware-based approach, thereby increasing the data transfer rate. 1.1.3 Power Interrupt Data Protection 1.1.6 Error Checking and Correction (ECC) The ECC technology uses advanced algorithms to detect and correct errors, ensuring data integrity and extending the SSD lifespan. Power Management Unit (PMU) 1.1.7 Multi-tasking Interface The PMU controls the power consumption of 2.5” ArmourDrive. The PMU dramatically reduces the power consumption of 2.5” ArmourDrive by putting the part of the circuitry that is not in operation into sleep mode. The multi-tasking interface enables concurrent Read, Program and Erase operations to multiple NAND flash media. The Flash File System handles inadvertent power interrupts and has auto-recovery capability to ensure 2.5” ArmourDrive firmware integrity. For regular power management, the host must send an IDLE_IMMEDIATE command and wait for command ready before powering down 2.5” ArmourDrive. 2.5” ArmourDrive’s controller uses advanced wearleveling algorithms to substantially increase the longevity of NAND flash media. Wear caused by data writes is evenly distributed in all or select blocks in the device that prevents “hot spots” in locations that are programmed and erased extensively. This effective wear-leveling technique results in optimized device endurance, enhanced data retention and higher reliability required by long-life applications. 1.1.4 1.2 Embedded Flash File System The embedded flash file system is an integral part of 2.5” ArmourDrive. It is integrated in the controller’s firmware that performs the following tasks: 1.3 1. Manages and optimizes the data access of flash media 2. Provides flash media wear leveling to spread the flash writes across all memory address space to increase the longevity of flash media 3. Keeps track of data file structures These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 Advanced NAND Management Advanced Data Security Advanced data security measures include end-to-end data path protection, data sanitization (Secure Erase) and cryptographic erase (Crypto Erase) support. Secure Erase is an effective method to quickly wipe all data from a SATA-based SSD using the SATA protocol. Cryptographic erase resets the cryptographic key of an OPAL-activated SSD making all encrypted user data useless. 2.5” ArmourDrive’s controller supports industry standard AES-256 encryption to protect sensitive user data. 2 03/31/2023 S71473-01 GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 2.0 FUNCTIONAL BLOCKS Figure 2-1: SATA 2.5” ArmourDrive Block Diagram These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 3 03/31/2023 S71473-01 GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 3.0 APPENDIX 3.1 Product Ordering Information GLS 89 SQ XX XX xxx x3 - I - CD4xx XXX XX - X - XXXXX Ordering Code CD4xx = SATA 2.5” AmourDrive Revision with encryption and on-board DRAM Operating Temperature I = Industrial: -40°C to +85°C NAND Configuration 3 = 3 bits per cell GByte or TByte Designator G = GByte Note: TByte Designator included in Capacity Capacity 240 = 240 GByte 480 = 480 GByte 960 = 960 GByte 1T92 = 1.92 TByte 3T84 = 3.84 TByte Product Generation Q = Generation Form Factor S = 2.5” Product Family 89 = SATA 2.5” ArmourDrive These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 4 03/31/2023 S71473-01 GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 Valid Combinations Valid product combinations are those that are in the mass production or will be in the mass production. Consult your Greenliant sales representative to confirm availability of the valid combinations and to determine availability of new product combinations. Table 3-1: SATA 2.5” ArmourDrive Product Valid Ordering Numbers Capacity Operating Temperature Part Number GLS89SQ240G3-I-CD401 240GB Industrial (-40°C to 85°C) GLS89SQ240G3-I-CD405 GLS89SQ480G3-I-CD401 480GB Industrial (-40°C to 85°C) GLS89SQ480G3-I-CD405 GLS89SQ960G3-I-CD401 960GB Industrial (-40°C to 85°C) GLS89SQ960G3-I-CD405 GLS89SQ1T923-I-CD401 1.92TB Industrial (-40°C to 85°C) GLS89SQ1T923-I-CD405 3.84TB Industrial (-40°C to 85°C) GLS89SQ3T843-I-CD401 These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 5 Form Factor 2.5-inch 2.5-inch 2.5-inch 2.5-inch 2.5-inch 03/31/2023 S71473-01 GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 3.2 Mechanical Diagrams Note: All linear dimensions are in millimeters. Figure 3-1: SATA 2.5” ArmourDrive Dimensions These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 6 03/31/2023 S71473-01 GLS89SQ240G3 / 480G3 / 960G3 / 1T923 / 3T843 Industrial Temp SATA 2.5” ArmourDrive™ PX Series Factsheet 02.000 March 2023 Revision History Revision 01.000 Initial Release as Factsheet Description Date December 6, 2019 02.000 Added CD405 part numbers March 31, 2023 © 2023 Greenliant. All rights reserved. Greenliant and the Greenliant logo are registered trademarks, and ArmourDrive is a trademark of Greenliant. All other trademarks and registered trademarks are the property of their respective owners. Specifications are subject to change without notice. Memory sizes denote raw storage capacity; actual usable capacity may be less. Greenliant makes no warranty for the use of its products other than those expressly contained in the Greenliant Terms and Conditions of Sale. www.greenliant.com These specifications are subject to change without notice. © 2023 Greenliant GLS FS0019 Rev. 01 7 03/31/2023 S71473-01
GLS89SQ1T923-I-CD401 价格&库存
很抱歉,暂时无法提供与“GLS89SQ1T923-I-CD401”相匹配的价格&库存,您可以联系我们找货
