GLS36VF1601G-70-4I-EKE
    GREENLIANT(绿芯)
    TSOP
GLS36VF1601G-70-4I-EKE 数据手册
16 Mbit (x8/x16) Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet GLS36VF1601E / 1602E16Mb (x8/x16) Concurrent SuperFlash FEATURES: • Organized as 1M x16 or 2M x8 • Dual Bank Architecture for Concurrent Read/Write Operation – 16 Mbit Bottom Sector Protection - GLS36VF1601G: 4 Mbit + 12 Mbit – 16 Mbit Top Sector Protection - GLS36VF1602G: 12 Mbit + 4 Mbit • Single 2.7-3.6V for Read and Write Operations • Superior Reliability – Endurance: 100,000 cycles (typical) – Greater than 100 years Data Retention • Low Power Consumption: – Active Current: 6 mA typical – Standby Current: 4 µA typical – Auto Low Power Mode: 4 µA typical • Hardware Sector Protection/WP# Input Pin – Protects the 4 outermost sectors (8 KWord) in the smaller bank by driving WP# low and unprotects by driving WP# high • Hardware Reset Pin (RST#) – Resets the internal state machine to reading array data • Byte# Pin – Selects 8-bit or 16-bit mode • Sector-Erase Capability – Uniform 2 KWord sectors • Chip-Erase Capability • Block-Erase Capability – Uniform 32 KWord blocks • Erase-Suspend / Erase-Resume Capabilities • Security ID Feature – Greenliant: 128 bits – User: 256 Byte • Fast Read Access Time – 70 ns • Latched Address and Data • Fast Erase and Program (typical): – Sector-Erase Time: 18 ms – Block-Erase Time: 18 ms – Chip-Erase Time: 35 ms – Program Time: 7 µs • Automatic Write Timing – Internal VPP Generation • End-of-Write Detection – Toggle Bit – Data# Polling – Ready/Busy# pin • CMOS I/O Compatibility • Conforms to Common Flash Memory Interface (CFI) • JEDEC Standards – Flash EEPROM Pinouts and command sets • Packages Available – 48-ball TFBGA (6mm x 8mm) – 48-lead TSOP (12mm x 20mm) – 56-ball LFBGA (8mm x 10mm) • All non-Pb (lead-free) devices are RoHS compliant PRODUCT DESCRIPTION The GLS36VF1601G and GLS36VF1602G are 1M x16 or 2M x8 CMOS Concurrent Read/Write Flash Memory manufactured with high performance SuperFlash memory technology. The split-gate cell design and thick oxide tunneling injector attain better reliability and manufacturability compared with alternate approaches. The devices write (Program or Erase) with a 2.7-3.6V power supply and conform to JEDEC standard pinouts for x8/x16 memories. Featuring high performance Program, the GLS36VF160xG provide a typical Program time of 7 µsec and use Toggle Bit, Data# Polling, or RY/BY# to detect the completion of the Program or Erase operation. To protect against inadvertent write, the devices have on-chip hardware and Soft- ©2010 Greenliant Systems, Ltd. ware Data Protection schemes. Designed, manufactured, and tested for a wide spectrum of applications, these devices are offered with a guaranteed endurance of 10,000 cycles. Data retention is rated at greater than 100 years. These devices are suited for applications that require convenient and economical updating of program, configuration, or data memory. For all system applications, the GLS36VF160xG significantly improve performance and reliability, while lowering power consumption. These devices inherently use less energy during Erase and Program than alternative flash technologies, because the total energy consumed is a function of the applied voltage, current, and time of application. For any given voltage range, www.greenliant.com S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet the SuperFlash technology uses less current to program and has a shorter erase time; therefore, the total energy consumed during any Erase or Program operation is less than alternative flash technologies. TABLE 1: Concurrent Read/Write State SuperFlash technology provides fixed Erase and Program times, independent of the number of Erase/Program cycles that have occurred. Therefore the system software or hardware does not have to be modified or de-rated as is necessary with alternative flash technologies, whose Erase and Program times increase with accumulated Erase/Program cycles. Bank 2 Read No Operation Write Note: For the purposes of this table, write means to perform Blockor Sector-Erase or Program operations as applicable to the appropriate bank. The Read operation of the GLS36VF160xG is controlled by CE# and OE#, both of which have to be low for the system to obtain data from the outputs. CE# is used for device selection. When CE# is high, the chip is deselected and only standby power is consumed. OE# is the output control and is used to gate data from the output pins. The data bus is in a high impedance state when either CE# or OE# is high. Refer to Figure 9, the Read cycle timing diagram, for further details. To meet high-density, surface-mount requirements, the GLS36VF1601G and GLS36VF1602G devices are offered in 48-ball TFBGA, 48-lead TSOP, and 56-ball LFBGA packages. See Figures 6, 7, and 8 for pin assignments. Device Operation Program Operation Memory operation functions are initiated using standard microprocessor write sequences. A command is written by asserting WE# low while keeping CE# low. The address bus is latched on the falling edge of WE# or CE#, whichever occurs last. The data bus is latched on the rising edge of WE# or CE#, whichever occurs first. These devices are programmed on a word-by-word or byte-by-byte basis depending on the state of the BYTE# pin. Before programming, ensure that the sector which is being programmed is fully erased. The Program operation is accomplished in three steps: 1. Initiate Software Data Protection using the threebyte load sequence. Auto Low Power Mode These devices also have the Auto Lower Power mode which puts them in a near-standby mode within 500 ns after data has been accessed with a valid Read operation. This reduces the typical IDD active Read current to 4 µA. While CE# is low, the devices exit Auto Low Power mode with any address transition or control signal transition used to initiate another Read cycle, with no access time penalty. 2. Load address and data. During the Program operation, the addresses are latched on the falling edge of either CE# or WE#, whichever occurs last. The data is latched on the rising edge of either CE# or WE#, whichever occurs first. 3. Initiate the internal Program operation after the rising edge of the fourth WE# or CE#, whichever occurs first. The Program operation, once initiated, will be completed typically within 7 µs. Concurrent Read/Write Operation The dual bank architecture of these devices allows the Concurrent Read/Write operation whereby the user can read from one bank while programming or erasing in the other bank. For example, reading system code in one bank while updating data in the other bank. See Table 1 below for more information. See Figures 10 and 11 for WE# and CE# controlled Program operation timing diagrams and Figure 25 for flowcharts. During the Program operation, the only valid reads are Data# Polling and Toggle Bit. During the internal Program operation, the host is free to perform additional tasks. Any commands issued during an internal Program operation are ignored. TABLE 1: Concurrent Read/Write State Bank 1 Bank 2 Read No Operation Read Write Write Read Write No Operation ©2010 Greenliant Systems, Ltd. Bank 1 No Operation 2 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Sector-Erase/Block-Erase Operation Erase-Suspend/Erase-Resume Operations The Sector- or Block- Erase operation allows the system to erase the device on a sector-by-sector (or block-by-block) basis. The GLS36VF160xG offer both Sector-Erase and Block-Erase operations. The Erase-Suspend operation temporarily suspends a Sector- or Block-Erase operation thus allowing data to be read or programmed into any sector or block that is not engaged in an Erase operation. The operation is executed by issuing a one-byte command sequence with Erase-Suspend command (B0H). The device automatically enters read mode no more than 10 µs after the Erase-Suspend command had been issued. (TES maximum latency equals 10 µs.) Valid data can be read from any sector or block that is not suspended from an Erase operation. Reading at address location within erase-suspended sectors/blocks will output DQ2 toggling and DQ6 at ‘1’. While in EraseSuspend mode, a Program operation is allowed except for the sector or block selected for Erase-Suspend. The sector architecture is based on a uniform sector size of 2 KWord. The Sector-Erase operation is initiated by executing a six-byte command sequence with a Sector-Erase command (50H) and sector address (SA) in the last bus cycle. The Block-Erase mode is based on a uniform block size of 32 KWord. Block-Erase is initiated by executing a six-byte command sequence with Block-Erase command (30H) and block address (BA) in the last bus cycle. The sector or block address is latched on the falling edge of the sixth WE# pulse, while the command (50H or 30H) is latched on the rising edge of the sixth WE# pulse. The internal Erase operation begins after the sixth WE# pulse. To resume a suspended Sector-Erase or Block-Erase operation, the system must issue an Erase-Resume command. The operation is executed by issuing a one-byte command sequence with Erase Resume command (30H) at any address in the one-byte sequence. Any commands issued during the Sector- or Block-Erase operation are ignored except Erase-Suspend and EraseResume. See Figures 15 and 16 for timing waveforms. Write Operation Status Detection To optimize the system Write cycle time, the GLS36VF160xG provide two software means to detect the completion of a Write (Program or Erase) cycle The software detection includes two status bits: Data# Polling (DQ7) and Toggle Bit (DQ6). The End-of-Write detection mode is enabled after the rising edge of WE#, which initiates the internal Program or Erase operation. Chip-Erase Operation The GLS36VF1601G and GLS36VF1602G provide a Chip-Erase operation, which erases the entire memory array to the ‘1’ state. This operation is useful when the entire device must be quickly erased. The Chip-Erase operation is initiated by executing a sixbyte command sequence with Chip-Erase command (10H) at address 555H in the last byte sequence. The Erase operation begins with the rising edge of the sixth WE# or CE#, whichever occurs first. During the Erase operation, the only valid Read is Toggle Bit or Data# Polling. Any commands issued during the Chip-Erase operation are ignored. See Table 6 for the command sequence, Figure 14 for timing diagram, and Figure 29 for the flowchart. When WP# is low, any attempt to Chip-Erase will be ignored. ©2010 Greenliant Systems, Ltd. The actual completion of the nonvolatile write is asynchronous with the system. Therefore, Data# Polling or Toggle Bit maybe be read concurrent with the completion of the write cycle. If this occurs, the system may possibly get an incorrect result from the status detection process. For example, valid data may appear to conflict with either DQ7 or DQ6. To prevent false results, upon detection of failures, the software routine should loop to read the accessed location an additional two times. If both reads are valid, then the device has completed the Write cycle, otherwise the failure is valid. 3 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Ready/Busy# (RY/BY#) Toggle Bits (DQ6 and DQ2) The GLS36VF160xG include a Ready/Busy# (RY/BY#) output signal. RY/BY# is an open drain output pin that indicates whether an Erase or Program operation is in progress. Since RY/BY# is an open drain output, it allows several devices to be tied in parallel to VDD via an external pull-up resistor. After the rising edge of the final WE# pulse in the command sequence, the RY/BY# status is valid. During the internal Program or Erase operation, any consecutive attempts to read DQ6 will produce alternating ‘1’s and ‘0’s, i.e., toggling between ‘1’ and ‘0’. When the internal Program or Erase operation is completed, the DQ6 bit will stop toggling, and the device is then ready for the next operation. For Sector-, Block-, or Chip-Erase, the toggle bit (DQ6) is valid after the rising edge of sixth WE# (or CE#) pulse. DQ6 will be set to ‘1’ if a Read operation is attempted on an Erase-Suspended Sector or Block. If Program operation is initiated in a sector/block not selected in Erase-Suspend mode, DQ6 will toggle. When RY/BY# is actively pulled low, it indicates that an Erase or Program operation is in progress. When RY/BY# is high (Ready), the devices may be read or left in standby mode. An additional Toggle Bit is available on DQ2, which can be used in conjunction with DQ6 to check whether a particular sector or block is being actively erased or erase-suspended. Table 2 shows detailed bit status information. The Toggle Bit (DQ2) is valid after the rising edge of the last WE# (or CE#) pulse of Write operation. See Figure 13 for Toggle Bit timing diagram and Figure 26 for a flowchart. Byte/Word (BYTE#) The device includes a BYTE# pin to control whether the device data I/O pins operate x8 or x16. If the BYTE# pin is at logic “1” (VIH) the device is in x16 data configuration: all data I/0 pins DQ0-DQ15 are active and controlled by CE# and OE#. If the BYTE# pin is at logic ‘0’, the device is in x8 data configuration -- only data I/O pins DQ0-DQ7 are active and controlled by CE# and OE#. The remaining data pins DQ8DQ14 are at Hi-Z, while pin DQ15 is used as the address input A-1 for the Least Significant Bit of the address bus. TABLE 2: Write Operation Status Status Data# Polling (DQ7) EraseSuspend Mode When the GLS36VF160xG are in an internal Program operation, any attempt to read DQ7 will produce the complement of true data. Once the Program operation is completed, DQ7 will produce valid data. During internal Erase operation, any attempt to read DQ7 will produce a ‘0’. Once the internal Erase operation is completed, DQ7 will produce a ‘1’. The Data# Polling is valid after the rising edge of fourth WE# (or CE#) pulse for Program operation. For Sector-, Block-, or Chip-Erase, the Data# Polling is valid after the rising edge of sixth WE# (or CE#) pulse. See Figure 12 for Data# Polling (DQ7) timing diagram and Figure 26 for a flowchart. ©2010 Greenliant Systems, Ltd. DQ7 DQ6 DQ2 RY/BY# DQ7# Toggle No Toggle 0 Standard Erase 0 Toggle Toggle 0 Read From Erase Suspended Sector/Block 1 1 Toggle 1 Read From Non-Erase Suspended Sector/Block Data Data Data 1 Program DQ7# Toggle N/A Normal Standard Operation Program 0 T2.1 1342 Note: DQ7, DQ6, and DQ2 require a valid address when reading status information. The address must be in the bank where the operation is in progress in order to read the operation status. If the address is pointing to a different bank (not busy), the device will output array data. 4 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Data Protection These devices are shipped with the Software Data Protection permanently enabled. See Table 6 for the specific software command codes. The GLS36VF160xG provide both hardware and software features to protect nonvolatile data from inadvertent writes. All Program operations require the inclusion of the threebyte sequence. The three-byte load sequence is used to initiate the Program operation, providing optimal protection from inadvertent Write operations. SDP for Erase operations is similar to Program, but a six-byte load sequence is required for Erase operations. Hardware Data Protection Noise/Glitch Protection: A WE# or CE# pulse of less than 5 ns will not initiate a Write cycle. VDD Power Up/Down Detection: The Write operation is inhibited when VDD is less than 1.5V. Write Inhibit Mode: Forcing OE# low, CE# high, or WE# high will inhibit the Write operation. This prevents inadvertent writes during power-up or power-down. During SDP command sequence, invalid commands will abort the device to read mode within TRC. The contents of DQ15-DQ8 can be VIL or VIH, but no other value, during any SDP command sequence. Hardware Block Protection Common Flash Memory Interface (CFI) The GLS36VF1601G and GLS36VF1602G provide hardware block protection which protects the outermost 8 KWord in the smaller bank. The block is protected when WP# is held low. See Figures 2, 3, 4, and 5 for Block-Protection location. These devices contain Common Flash Memory Interface (CFI) information that describes the characteristics of the device. In order to enter the CFI Query mode, the system must write a three-byte sequence, using the CFI Query command, to address BKx555H in the last byte sequence. The system can also use the one-byte sequence with address BKx55H and Data Bus 98H to enter this mode. See Figure 18 for CFI Entry and Read timing diagram. Once the device enters the CFI Query mode, the system can read CFI data at the addresses given in Tables 7 through 9. Block protection is disabled by driving WP# high. This allows data to be erased or programmed into the protected sectors. WP# must be held high prior to issuing the Write command and remain stable until after the entire Write operation has completed. If WP# is left floating, it is internally held high via a pull-up resistor, and the Boot Block is unprotected, enabling Program and Erase operations on that block. The system must write the CFI Exit command to return to Read mode from the CFI Query mode. Hardware Reset (RST#) Security ID The RST# pin provides a hardware method of resetting the devices to read array data. When the RST# pin is held low for at least TRP, any in-progress operation will terminate and return to Read mode (see). When no internal Program/ Erase operation is in progress, a minimum period of TRHR is required after RST# is driven high before a valid Read can take place. See Figures 22 and 21 for more information. The GLS36VF160xG offer a 136-word Security ID space. The Secure ID space is divided into two segments — one 128-bit, factory-programmed, segment and one 256-Byte, user programmed segment. The first segment is programmed and locked at Greenliant and contains a 128 bit Unique ID which uniquely identifies the device. The user segment is left un-programmed for the customer to program as desired. The interrupted Erase or Program operation must be re-initiated after the device resumes normal operation mode to ensure data integrity. The user segment of the Security ID can be programmed using the Security ID Program command. End-of-Write status is checked by reading the toggle bits. Data# Polling is not used for Security ID End-of-Write detection. Software Data Protection (SDP) The GLS36VF160xG devices implement the JEDEC approved Software Data Protection (SDP) scheme for all data alteration operations, such as Program and Erase. ©2010 Greenliant Systems, Ltd. Once the programming is complete, lock the Sec ID by issuing the User Sec ID Program Lock-Out command. Locking the Sec ID disables any corruption of this space. Note that regardless of whether or not the Sec ID is locked, the Sec ID segments can not be erased. 5 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet The Secure ID space can be queried by executing a threebyte command sequence with Query Sec ID command (88H) at address 555H in the last byte sequence. See Figure 20 for timing diagram. To exit this mode, the Exit Sec ID command should be executed. Refer to Table 6 for more details. TABLE 3: Product Identification Manufacturer’s ID Address Data BK0000H 00BFH BK0001H 7343H BK0001H 7344H Device ID GLS36VF1601G GLS36VF1602G Product Identification T3.0 1342 Note: BK = Bank Address (A19-A18) The Product Identification mode identifies the devices as GLS36VF1601G or GLS36VF1602G and the manufacturer as Greenliant. For details, see Table 3 for software operation, Figure 17 for the Software ID Entry and Read timing diagram, and Figure 27 for the Software ID Entry command sequence flowchart. Product Identification Mode Exit/CFI Mode Exit In order to return to the standard Read mode, the Software Product Identification mode must be exited. The exit is accomplished by issuing the Software ID Exit command sequence, which returns the device to the Read mode. This command may also be used to reset the device to the Read mode after any inadvertent transient condition that causes the device to behave abnormally. Please note that the Software ID Exit/CFI Exit command is ignored during an internal Program or Erase operation. See Table 6 for the software command code, Figure 19 for timing waveform and Figure 28 for a flowchart. The addresses A19 and A18 indicate a bank address. When the addressed bank is switched to Product Identification mode, it is possible to read another address from the same bank without issuing a new Software ID Entry command. Address Buffers Memory Address SuperFlash Memory 12 Mbit Bank BYTE# SuperFlash Memory 4 Mbit Bank (8 KWord Sector Protection) RST# CE# WP# Control Logic I/O Buffers WE# DQ15/A-1 - DQ0 OE# RY/BY# 1342 B01.0 FIGURE 1: Functional Block Diagram ©2010 Greenliant Systems, Ltd. 6 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Bottom Sector Protection; 32 KWord Blocks; 2 KWord Sectors Block 31 Block 30 Block 29 Block 28 Block 27 Block 26 Block 25 Block 24 Block 23 Block 22 Block 21 Block 20 Block 19 Bank 2 Block 18 Block 17 Block 16 Block 15 Block 14 Block 13 Block 12 Block 11 Block 10 Block 9 Block 8 Block 7 Block 6 Block 5 Block 4 Block 3 Block 2 Bank 1 8 KWord Sector Protection (4-2 KWord Sectors) FFFFFH F8000H F7FFFH F0000H EFFFFH E8000H E7FFFH E0000H DFFFFH D8000H D7FFFH D0000H CFFFFH C8000H C7FFFH C0000H BFFFFH B8000H B7FFFH B0000H AFFFFH A8000H A7FFFH A0000H 9FFFFH 98000H 97FFFH 90000H 8FFFFH 88000H 87FFFH 80000H 7FFFFH 78000H 77FFFH 70000H 6FFFFH 68000H 67FFFH 60000H 5FFFFH 58000H 57FFFH 50000H 4FFFFH 48000H 47FFFH 40000H 3FFFFH 38000H 37FFFH 30000H 2FFFFH 28000H 27FFFH 20000H 1FFFFH 18000H 17FFFH 10000H 0FFFFH 08000H 07FFFH 02000H 01FFFH 00000H Block 1 Block 0 1342 F01.0 Note: The address input range in x16 mode (BYTE#=VIH) is A19- FIGURE 2: GLS36VF1601G, 1M x16 Concurrent SuperFlash Dual-Bank Memory Organization ©2010 Greenliant Systems, Ltd. 7 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Bottom Sector Protection; 64 KByte Blocks; 4 KByte Sectors Block 31 Block 30 Block 29 Block 28 Block 27 Block 26 Block 25 Block 24 Block 23 Block 22 Block 21 Block 20 Block 19 Block 18 Bank 2 Block 17 Block 16 Block 15 Block 14 Block 13 Block 12 Block 11 Block 10 Block 9 Block 8 Block 7 Block 6 Block 5 Block 4 Block 3 Block 2 Bank 1 16 KByte Sector Protection (4-4 KByte Sectors) 1FFFFFH 1F0000H 1EFFFFH 1E0000H 1DFFFFH 1D0000H 1CFFFFH 1C0000H 1BFFFFH 1B0000H 1AFFFFH 1A0000H 19FFFFH 190000H 18FFFFH 180000H 17FFFFH 170000H 16FFFFH 160000H 15FFFFH 150000H 14FFFFH 140000H 13FFFFH 130000H 12FFFFH 120000H 11FFFFH 110000H 10FFFFH 100000H 0FFFFFH 0F0000H 0EFFFFH 0E0000H 0DFFFFH 0D0000H 0CFFFFH 0C0000H 0BFFFFH 0B0000H 0AFFFFH 0A0000H 09FFFFH 090000H 08FFFFH 080000H 07FFFFH 070000H 06FFFFH 060000H 05FFFFH 050000H 04FFFFH 040000H 03FFFFH 030000H 02FFFFH 020000H 01FFFFH 010000H 00FFFFH 004000H 003FFFH 000000H Block 1 Block 0 1342 F02.0 Note: The address input range in x8 mode (BYTE#=VIL) FIGURE 3: GLS36VF1601G, 2M x8 Concurrent SuperFlash Dual-Bank Memory Organization ©2010 Greenliant Systems, Ltd. 8 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Top Block Protection; 32 KWord Blocks; 2 KWord Sectors 8 KWord Block Protection (4 - 2 KWord Sectors) Block 31 Block 30 Block 29 Block 28 Block 27 Bank 2 Block 26 Block 25 Block 24 Block 23 Block 22 Block 21 Block 20 Block 19 Block 18 Block 17 Block 16 Block 15 Block 14 Block 13 Block 12 Block 11 Bank 1 FFFFFH FE000H FDFFFH F8000H F7FFFH F0000H EFFFFH E8000H E7FFFH E0000H DFFFFH D8000H D7FFFH D0000H CFFFFH C8000H C7FFFH C0000H BFFFFH B8000H B7FFFH B0000H AFFFFH A8000H A7FFFH A0000H 9FFFFH 98000H 97FFFH 90000H 8FFFFH 88000H 87FFFH 80000H 7FFFFH 78000H 77FFFH 70000H 6FFFFH 68000H 67FFFH 60000H 5FFFFH 58000H 57FFFH 50000H 4FFFFH 48000H 47FFFH 40000H 3FFFFH 38000H 37FFFH 30000H 2FFFFH 28000H 27FFFH 20000H 1FFFFH 18000H 17FFFH 10000H 0FFFFH 08000H 07FFFH 00000H Block 10 Block 9 Block 8 Block 7 Block 6 Block 5 Block 4 Block 3 Block 2 Block 1 Block 0 1342 F03.0 Note: The address input range in x16 mode (BYTE#=VIH) is FIGURE 4: GLS36VF1602G, 1M x16 Concurrent SuperFlash Dual-Bank Memory Organization ©2010 Greenliant Systems, Ltd. 9 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Top Block Protection; 64 KByte Blocks; 4 KByte Sectors 16 KByte Block Protection (4 - 4 KByte Sectors) Block 31 Block 30 Block 29 Block 28 Block 27 Bank 2 Block 26 Block 25 Block 24 Block 23 Block 22 Block 21 Block 20 Block 19 Block 18 Block 17 Block 16 Block 15 Block 14 Block 13 Block 12 Bank 1 1FFFFFH 1FC000H 1FBFFFH 1F0000H 1EFFFFH 1E0000H 1DFFFFH 1D0000H 1CFFFFH 1C0000H 1BFFFFH 1B0000H 1AFFFFH 1A0000H 19FFFFH 190000H 18FFFFH 180000H 17FFFFH 170000H 16FFFFH 160000H 15FFFFH 150000H 14FFFFH 140000H 13FFFFH 130000H 12FFFFH 120000H 11FFFFH 110000H 10FFFFH 100000H 0FFFFFH 0F0000H 0EFFFFH 0E0000H 0DFFFFH 0D0000H 0CFFFFH 0C0000H 0BFFFFH 0B0000H 0AFFFFH 0A0000H 09FFFFH 090000H 08FFFFH 080000H 07FFFFH 070000H 06FFFFH 060000H 05FFFFH 050000H 04FFFFH 040000H 03FFFFH 030000H 02FFFFH 020000H 01FFFFH 010000H 00FFFFH 000000H Block 11 Block 10 Block 9 Block 8 Block 7 Block 6 Block 5 Block 4 Block 3 Block 2 Block 1 Block 0 Note: The address input range in x8 mode (BYTE#=VIL) is 1342 F04.0 FIGURE 5: GLS36VF1602G, 2M x8 Concurrent SuperFlash Dual-Bank Memory Organization ©2010 Greenliant Systems, Ltd. 10 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet TOP VIEW (balls facing down) 6 5 A13 A12 A14 A15 A16 BYTE# A9 A8 NOTE* VSS A10 A11 DQ7 DQ14 DQ13 DQ6 WE# RST# NC A19 DQ5 DQ12 VDD DQ4 RY/BY# WP# A18 NC DQ2 DQ10 DQ11 DQ3 3 1342 48-tfbga P1.0 4 2 1 DQ0 DQ8 DQ9 DQ1 A7 A17 A6 A5 A3 A4 A2 A1 A0 A B C D E CE# OE# VSS F G H Note* = DQ15/A-1 FIGURE 6: Pin Assignments for 48-ball TFBGA (6mm x 8mm) A15 A14 A13 A12 A11 A10 A9 A8 A19 NC WE# RST# NC WP# RY/BY# A18 A17 A7 A6 A5 A4 A3 A2 A1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Standard Pinout Top View Die Up 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 A16 BYTE# VSS DQ15/A-1 DQ7 DQ14 DQ6 DQ13 DQ5 DQ12 DQ4 VDD DQ11 DQ3 DQ10 DQ2 DQ9 DQ1 DQ8 DQ0 OE# VSS CE# A0 1342 48-tsop P02.0 FIGURE 7: Pin Assignments for 48-lead TSOP (12mm x 20mm) ©2010 Greenliant Systems, Ltd. 11 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet TOP VIEW (balls facing down) 8 7 6 5 4 A15 NC NC A16 BYTE# VSS A11 A12 A13 A14 NC DQ15/A-1 DQ7 DQ14 A8 A19 A9 A10 DQ6 DQ13 DQ12 DQ5 WE# NC NC DQ4 WP# RST# RY/BY# NC NC DQ3 VDD DQ11 NC NC A18 A17 DQ1 DQ9 DQ10 DQ2 A7 A6 A5 A4 VSS OE# DQ0 A3 A2 A1 A0 CE# NC B C D E F 2 DQ8 1 A G 1342 56-lfbga P1.0 3 H FIGURE 8: Pin Assignments for 56-lead LFBGA (8mm x 10mm) TABLE 4: Pin Description Symbol Name A19-A0 Address Inputs Functions To provide memory addresses. During Sector-Erase and Hardware Sector Protection, A19-A11 address lines will select the sector. During Block-Erase A19-A15 address lines will select the block. DQ14-DQ0 Data Input/Output To output data during Read cycles and receive input data during Write cycles Data is internally latched during a Write cycle. The outputs are in tri-state when OE# or CE# is high. DQ15/A-1 DQ15 is used as data I/O pin when in x16 mode (BYTE# = “1”) A-1 is used as the LSB address pin when in x8 mode (BYTE# = “0”) Data Input/Output and LBS Address CE# Chip Enable To activate the device when CE# is low. OE# Output Enable To gate the data output buffers WE# Write Enable To control the Write operations RST# Hardware Reset To reset and return the device to Read mode RY/BY# Ready/Busy# To output the status of a Program or Erase operation RY/BY# is a open drain output, so a 10K - 100K pull-up resistor is required to allow RY/BY# to transition high indicating the device is ready to read. WP# Write Protect To protect and unprotect top or bottom 8 KWord (4 outermost sectors) from Erase or Program operation. BYTE# Word/Byte Configuration To select 8-bit or 16-bit mode. VDD Power Supply VSS Ground NC No Connection To provide 2.7-3.6V power supply voltage Unconnected pins T4.0 1342 ©2010 Greenliant Systems, Ltd. 12 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet TABLE 5: Operation Modes Selection DQ15-DQ8 Mode1 CE# OE# WE# DQ7-DQ0 BYTE# = VIH BYTE# = VIL Address Read VIL VIL VIH DOUT DOUT DQ14-DQ8 = High Z AIN Program VIL VIH VIL DIN DIN DQ15 = A-1 AIN Erase VIL VIH VIL X2 X High Z Sector or Block address, 555H for Chip-Erase VIHC X X High Z High Z High Z X X VIL X High Z / DOUT High Z / DOUT High Z X X X VIH High Z / DOUT High Z / DOUT High Z X VIL VIL VIH Manufacturer’s ID (BFH) Manufacturer’s ID (00H) High Z See Table 6 Device ID3 Device ID3 High Z Standby Write Inhibit Product Identification Software Mode T5.2 1342 1. RST# = VIH for all described operation modes 2. X can be VIL or VIH, but no other value. 3. Device ID = GLS36VF1601G = 7343H, GLS36VF1602G = 7344H ©2010 Greenliant Systems, Ltd. 13 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet TABLE 6: Software Command Sequence Command Sequence 1st Bus Write Cycle Addr1 Data2 2nd Bus Write Cycle Addr1 Data2 3rd Bus Write Cycle Addr1 4th Bus Write Cycle Data2 Addr1 Data2 Data AAH Program 555H AAH 2AAH 55H 555H A0H WA3 Sector-Erase 555H AAH 2AAH 55H 555H 80H 555H 5th Bus Write Cycle 6th Bus Write Cycle Addr1 Data2 Addr1 Data2 2AAH 55H SAX4 50H 4 30H 10H Block-Erase 555H AAH 2AAH 55H 555H 80H 555H AAH 2AAH 55H BAX Chip-Erase 555H AAH 2AAH 55H 555H 80H 555H AAH 2AAH 55H 555H Erase-Suspend XXXXH B0H Erase-Resume XXXXH 30H Query Sec ID5 555H AAH 2AAH 55H 555H 88H User Security ID Program 555H AAH 2AAH 55H 555H A5H SIWA6 Data User Security ID Program Lock-out7 555H AAH 2AAH 55H 555H 85H XXH 0000H Software ID Entry8 555H AAH 2AAH 55H BKX9 555H 90H CFI Query Entry 555H AAH 2AAH 55H BKX9 555H 98H CFI Query Entry BKX9 55H 98H Software ID Exit/ CFI Exit/ Sec ID Exit10,11 555H AAH 2AAH 55H 555H F0H Software ID Exit/ CFI Exit/ Sec ID Exit10,11 XXH F0H T6.0 1342 1. Address format A10-A0 (Hex), Addresses A19-A11 can be VIL or VIH, but no other value, for the command sequence when in x16 mode. When in x8 mode, Addresses A19-A12, Address A-1 and DQ14-DQ8 can be VIL or VIH, but no other value, for the command sequence. 2. DQ15-DQ8 can be VIL or VIH, but no other value, for the command sequence 3. WA = Program word/byte address 4. SAX for Sector-Erase; uses A19-A11 address lines BAX for Block-Erase; uses A19-A15 address lines 5. For GLS36VF1601G, Greenliant ID is read with A3 = 0 (Address range = 00000H to 00007H), User ID is read with A3 = 1 (Address range = = 00008H to 00087H). Lock Status is read with A7-A0 = 000FFH. Unlocked: DQ3 = 1 / Locked: DQ3 = 0. For GLS36VF1602G, Greenliant ID is read with A3 = 0 (Address range = C0000H to C0007H), User ID is read with A3 = 1 (Address range = = C0008H to C0087H). Lock Status is read with A7-A0 = C00FFH. Unlocked: DQ3 = 1 / Locked: DQ3 = 0. 6. SIWA = User Security ID Program word/byte address For GLS36VF1601G, valid Word-Addresses for User Sec ID are from 00008H to 00087H. For GLS36VF1602G, valid Word-Addresses for User Sec ID are from C0008H to C0087H. All 4 cycles of User Security ID Program and Program Lock-out must be completed before going back to Read-Array mode. 7. The User Security ID Program Lock-out command must be executed in x16 mode (BYTE#=VIH). 8. The device does not remain in Software Product Identification mode if powered down. 9. A19 and A18 = BKX (Bank Address): address of the bank that is switched to Software ID/CFI Mode With A17-A1 = 0;Greenliant Manufacturer’s ID = 00BFH, is read with A0 = 0 GLS36VF1601G Device ID = 7343H, is read with A0 = 1 GLS36VF1602G Device ID = 7344H, is read with A0 = 1 10. Both Software ID Exit operations are equivalent ©2010 Greenliant Systems, Ltd. 14 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet 11. If users never lock after programming, User Sec ID can be programmed over the previously unprogrammed bits (data=1) using the User Sec ID mode again (the programmed “0” bits cannot be reversed to “1”). For GLS36VF1601G, valid Word-Addresses for User Sec ID are from 00008H to 00087H. For GLS36VF1602G, valid Word-Addresses for User Sec ID are from C0008H to C0087H. TABLE 7: CFI Query Identification String1 Address x16 Mode 10H 11H 12H 13H 14H 15H 16H 17H 18H 19H 1AH Address x8 Mode 20H 22H 24H 26H 28H 2AH 2CH 2EH 30H 32H 34H Data2 0051H 0052H 0059H 0002H 0000H 0000H 0000H 0000H 0000H 0000H 0000H Description Query Unique ASCII string “QRY” Primary OEM command set Address for Primary Extended Table Alternate OEM command set (00H = none exists) Address for Alternate OEM extended Table (00H = none exits) T7.0 1342 1. Refer to CFI publication 100 for more details. 2. In x8 mode, only the lower byte of data is output. TABLE 8: System Interface Information Address x16 Mode Address x8 Mode Data1 Description 1BH 36H 0027H VDD Min (Program/Erase) 1CH 38H 0036H VDD Max (Program/Erase) DQ7-DQ4: Volts, DQ3-DQ0: 100 millivolts DQ7-DQ4: Volts, DQ3-DQ0: 100 millivolts 1DH 3AH 0000H VPP min (00H = no VPP pin) 1EH 3CH 0000H VPP max (00H = no VPP pin) 1FH 3EH 0004H Typical time out for Program 2N µs (24 = 16 µs) 20H 40H 0000H Typical time out for min size buffer program 2N µs (00H = not supported) 21H 42H 0004H Typical time out for individual Sector/Block-Erase 2N ms (24 = 16 ms) 22H 44H 0006H Typical time out for Chip-Erase 2N ms (26 = 64 ms) 23H 46H 0001H Maximum time out for Program 2N times typical (21 x 24 = 32 µs) 24H 48H 0000H Maximum time out for buffer program 2N times typical 25H 4AH 0001H Maximum time out for individual Sector-/Block-Erase 2N times typical (21 x 24 = 32 ms) 26H 4CH 0001H Maximum time out for Chip-Erase 2N times typical (21 x 26 = 128 ms) T8.0 1342 1. In x8 mode, only the lower byte of data is output. ©2010 Greenliant Systems, Ltd. 15 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet TABLE 9: Device Geometry Information Address x16 Mode 27H 28H 29H 2AH 2BH 2CH 2DH 2EH 2FH 30H 31H 32H 33H 34H Address x8 Mode 4EH 50H 52H 54H 56H 58H 5AH 5CH 5EH 60H 62H 64H 66H 68H Data1 0015H 0002H 0000H 0000H 0000H 0002H 00FFH 0001H 0010H 0000H 001FH 0000H 0000H 0001H Description Device size = 2N Bytes (15H = 21; 221 = 2 MByte) Flash Device Interface description; 0002H = x8/x16 asynchronous interface Maximum number of bytes in multi-byte write = 2N (00H = not supported) Number of Erase Sector/Block sizes supported by device Sector Information (y + 1 = Number of sectors; z x 256B = sector size) y = 511 + 1 = 512 sectors (01FFH = 512) z = 16 x 256 Bytes = 4 KByte/sector (0010H = 16) Block Information (y + 1 = Number of blocks; z x 256B = block size) y = 31 + 1 = 32 blocks (001FH = 31) z = 256 x 256 Bytes = 64 KByte/block (0100H = 256) T9.1 1342 1. In x8 mode, only the lower byte of data is output. ©2010 Greenliant Systems, Ltd. 16 S71342-03-000 05/10 16 Mbit Concurrent SuperFlash GLS36VF1601G / GLS36VF1602G Data Sheet Absolute Maximum Stress Ratings (Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability.) Temperature Under Bias . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -55°C to +125°C Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -65°C to +150°C D. C. Voltage on Any Pin to Ground Potential . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to VDD+0.5V Transient Voltage (
GLS36VF1601G-70-4I-EKE 价格&库存
很抱歉,暂时无法提供与“GLS36VF1601G-70-4I-EKE”相匹配的价格&库存,您可以联系我们找货
