GLS85LS1008G-S-I-LBJE-ND124
    GREENLIANT(绿芯)
GLS85LS1008G-S-I-LBJE-ND124 数据手册
GLS85LS1xxxG / GLS85LS1xxxQ Industrial Grade SATA NANDrive™ EX Series Factsheet 02.000 November 2020 Features • Expanded Data Protection – Added data security through user-selectable protection zones – Secure Erase (data sanitization) • 20-Byte Serial Number – Factory pre-programmed 10-Byte unique ID – User-programmable 10-Byte ID • Supports SMART and TRIM Commands • Robust Built-in ECC • Thermal Throttling • NAND Configuration – 1 bit per cell (SLC) – Designed with Greenliant’s advanced EnduroSLC™ Technology • High Endurance – GLS85LS1xxxG: 50K P/E cycles – GLS85LS1xxxQ: 100K P/E cycles • Operating Temperature Range – Industrial: -40°C to 85°C • BGA package – 14.0 mm x 24.0 mm x 1.40 mm, 145-ball, 1.0 mm ball pitch, LBJE (LFBGA) – 14.0 mm x 24.0 mm x 1.55 mm, 145-ball, 1.0 mm ball pitch, LFJE (LBGA) • All Devices are RoHS Compliant • Industry Standard Serial ATA (SATA) Host Interface – SATA 1.5Gb/s, 3Gb/s and 6Gb/s – SATA Revision 3.2 – ATA/ATAPI-8 compliant – Supports 48-bit address feature set – Native Command Queuing (NCQ) up to 32 commands • Performance – Sequential data read: Up to 470 MByte/sec – Sequential data write: Up to 340 MByte/sec (measured using 128 KByte transfer size tested in VDBench on Linux) • Power Management – 3.3V and 1.0V power supply • Power Consumption – Active mode: 128GB: Up to 2180mW 64GB: Up to 1800mW 32GB: Up to 1980mW 16GB: Up to 1540mW 8GB: Up to 1200mW 4GB: Up to 1200mW – Idle / Standby mode:
GLS85LS1008G-S-I-LBJE-ND124 价格&库存
很抱歉,暂时无法提供与“GLS85LS1008G-S-I-LBJE-ND124”相匹配的价格&库存,您可以联系我们找货
