GP8401-TC50-EW
GP8401-TC50-EW
    GUESTGOOD(客益)
    ESOP-10_4.9X3.9MM-EP
    PWM信号转模拟信号
GP8401-TC50-EW 数据手册
P-1 特性  GP8401将2路0%-100%占空比的PWM信号输入,线性转换成0-5V或者0-10V的两路模拟电压输 出。  输入信号范围0%-100%  输入PWM信号的频率范围: 50Hz to 50KHz(小于50Hz请联系先积)  输入PWM信号高电平:2.7V-5.5V  输出电压误差:< 0.5% (两点校准可得0.1 %)  输出电压线性度误差:0.1% TPY  输出短路保护,输出脚与地短路时芯片进入保护模式停止输出。  电源电压:9V - 36V  功耗:0.5V VCC@12V 最小 典型 最大 单位 9 12 36 V 3 5 mA VCC @12V 空载 SEL接地 0 5 V SEL接V5V 0 10 V *1:V5V上外挂负载后可能会轻微影响芯片精度。 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.5 20 % mA FN1601-46.1 — Data Sheet GP8401 PAC (PWM to Analog Converter) Dual 0%-100% PWM to 0-5V/0-10V P-6 7. 订购须知 GP 8 4 01 - X- X - X X 产品类型 8:PAC 9:APC 温度范围 W:-40°C-85°C 封装 E:ESOP10 系列号 温度系数 TC50:50PPM/℃ TC25:25PPM/℃ PWM频率范围 F50: >50Hz 温度系数 精度 封装 工作温度 订购码 50PPM/℃ 0.5% ESOP10 -40℃-85℃ GP8401-TC50-EW CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-46.1 — Data Sheet GP8401 PAC (PWM to Analog Converter) Dual 0%-100% PWM to 0-5V/0-10V 8. 封装信息 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-46.1 — Data Sheet P-7 GP8401 PAC (PWM to Analog Converter) Dual 0%-100% PWM to 0-5V/0-10V
GP8401-TC50-EW 价格&库存
很抱歉,暂时无法提供与“GP8401-TC50-EW”相匹配的价格&库存,您可以联系我们找货
