GPSR0750-330MS
GPSR0750-330MS
    SGTE(感通)
    SMD,7.2x6.6mm
    33UH ±20%
GPSR0750-330MS 数据手册
CUSTOMER CUSTOMER’S P/N DESCRIPTION SGTE PART NO. SMD POWER INDUCTOR GPSR0750-330MS SAMPLE NO. S10062205 REVISION NO. A DATE 22-Jun-10 SPECIFICATION FOR APPROVAL FULLY APPROVED REVISE APPROVED 深圳感通科技有限公司 (大陸工廠) GANTONG TECHNOLOGY (SHENZHEN) CO., LTD. 深圳市平湖街道平湖村萬福路 26 號 No.26 Wan fu Road, Ping hu Village. Ping hu town, Shenzhen City. Tel: 0755-28457600 Fax: 0755-28452952 感通科技有限公司 (台灣辦事處) 臺北縣汐止市新台 5 路一段 77 號 10 樓之 7 10F~7, N0.77, Sec.1, Hsin Tai 5 Road, Shi-chi City,Taipei. Tel: 886-2-8698-2341 Fax:886-2-8698-2342 納美科技股份有限公司 (香港辦事處) LAPEE TECHNOLOGY LIMITED 香港九龍尖沙嘴加連威老道嘉蘭圍 5-11 號利時商業大廈 17 樓 1713 室 Room 1713 17/F, Rise Commercial Bldg5-11 Granville Cri cuit, Granville Rd, TSim Sha Tsui., Kln Tel: 852-25301111 Fax: 852-25371111 http://www.szgte.com SPECIFICATION INDEX COVER PAGE ▓ SHAPE & DIMENSION…………………….………...........1-8 ▓ ELECTRICAL CHARACTERISTICS AND EXTERNAL TEST REPORT…….……………………………………….2-8 ▓ ELECTRICAL CHARACTERISTICS……………………..3-8 ▓ ELECTRICAL CHARACTERISTICS……………………..4-8 ▓ ELECTRICAL CHARACTERISTICS……………………..5-8 ▓ PACKING FOR SPECIFICATION…………………………6-8 ▓ GENERAL CHARACTERISTICS………………………….7-8 ▓ THE CONDITION OF REFLOW…………………………..8-8 APPROVED BY CHECKED BY DRAWING BY Jesse Gary Lily 6/22 6/22 6/22 SPECIFICATION Customers Part Number Item Name Date Power Inductor 22-Jun-10 Gan Tong Part NO. Sample NO. Page GPSR0750-330MS S10062205 1-8 External Dimensions Unit (mm) 330 A 7.2±0.3 B 6.6±0.3 C 5.0 MAX D ≤0.15 E 3.0±0.3 F 1.6±0.3 G 8.4 REF H 3.7 REF I 3.5 REF Coating:uncolored Connection Recommended Land Pattern Electrical Specification Measurement Item Unit Tolerance Specification 33uH ±20% DCR uH (±20%) mΩ I rms Amps 2A L Test Frequency 100KHz/1V 237mΩ(Max) Test Instrument LCR Meter Agilent/4284A or Chroma /11300 Chroma /16502 100KHz/1V LCR Meter Agilent/4284A+42841A or Chroma /11300+3302+1320+1320S 4A 100KHz/1V ‧I rms: Current that causes a 40℃ temperature rise from 25℃ ambient. I sat Amps ‧I sat: DC current at which the inductance drops 35% from it’s value without current. ‧All test Data is referenced to 25℃ ambient. ‧Operating Temperature Range: -25℃ to +125℃ TEST REPORT Customers Part Number Item Name Date Power Inductor 22-Jun-10 Gan Tong Part NO. Sample NO. Revision No. Page GPSR0750-330MS S10062205 A 2-8 Electrical Characteristic Item L0A Specification 33uH DCR 237mΩ Tolerance ±20% Max 1 33.59 197.47 2 33.23 196.25 3 33.61 196.11 4 33.57 195.96 5 35.64 199.27 6 32.47 197.79 7 33.18 197.86 8 34.67 197.85 9 31.81 197.78 10 35.39 197.13 X 33.72 197.35 σ 1.15 0.97 I rms I sat 2Amps △T≦40℃ 4Amps L≧65% 11.5℃ 77.8% External Dimensions Item A B C Specification 7.2 6.6 5.0 Tolerance ±0.3 ±0.3 MAX 1 7.32 6.76 2 7.35 3 E F 3.0 1.6 ≤0.15 ±0.3 ±0.3 3.89 0.10 3.05 1.47 6.73 3.78 0.05 2.98 1.67 7.31 6.77 3.81 0.08 3.01 1.58 4 7.36 6.75 3.92 0.09 3.03 1.45 5 7.34 6.72 3.86 0.07 2.99 1.54 6 7.30 6.74 3.79 0.11 3.04 1.63 7 7.33 6.75 3.87 0.06 3.00 1.56 8 7.38 6.73 3.83 0.09 3.07 1.73 9 7.35 6.74 3.90 0.07 3.05 1.61 10 7.37 6.71 3.88 0.08 3.01 1.53 X 7.34 6.74 3.85 0.08 3.02 1.58 σ 0.02 0.02 0.05 0.02 0.03 0.08 Inductance measured at 100KHz/1Vrms. Electrical specifications at 25℃. Humidity 60±10% D ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 22-Jun-10 Gan Tong Part NO. Sample NO. Page GPSR0750-330MS S10062205 3-8 Inductance VS DC current IDC L %L0A 0A 33.21 100.0% 0.5A 32.75 98.6% 1.0A 32.05 96.5% 1.5A 31.21 94.0% 2.0A 30.18 90.9% 2.5A 29.14 87.7% 3.0A 27.95 84.2% 3.5A 26.99 81.3% 4.0A 25.85 77.8% 4.5A 24.90 75.0% CONDITTON:100KHz/1.0Vrms ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 22-Jun-10 Gan Tong Part NO. Sample NO. Page GPSR0750-330MS S10062205 4-8 DC current VS Temperature Time L(μН) T(℃) △T(℃) 0H 29.84 32.2 0.5H 29.82 43.2 11.0 1H 29.81 43.4 11.2 2H 29.80 43.5 11.3 3H 29.79 43.6 11.4 4H 29.78 43.7 11.5 5H 29.78 43.7 11.5 CONDITTON: Load 2A 43.7℃ 32.2℃ ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 22-Jun-10 Gan Tong Part NO. Sample NO. Page GPSR0750-330MS S10062205 5-8 Inductance VS Frequency FREQ. L(μН) 1KHZ 34.21 10KHZ 34.15 100KHZ 33.87 500KHZ 33.45 800KHZ 33.48 1000KHZ 33.67 PACKING FOR SPECIFICATION Customers Part Number Item Name Date Power Inductor 22-Jun-10 Gan Tong Part NO. Sample NO. Page GPSR0750-330MS S10062205 6-8 Packaging Information: TYPE A(mm) B(mm) C(mm) D(mm) 13´´*16mm 16.0±0.5 100±2 13.5±0.5 330 TYPE A B C W P GPSR0750 1000 16 330 16 12 GENGRAL CHARACTERISTICS Gan Tong Part NO. GPSR0750-330MS .STORAGE TEMPERATURE: 25℃~30℃ HUMIDITY 45~85% RH 2.OPERATING TEMPERATURE -30℃~+125℃(CONTAIN HEATING COIL) PAGE : 7-8 RANGE : 3.EXTERNAL APPEARANCE : NO EXTERNAL DEFECTS CAN BE FOUND IN THE VISUAL INSPECTION. 4. TERMINAL STRENGTH NO TERMINAL DETACHMENT SHOULD BE FOUND WHEN THE DEVICE IS PUSHED IN TWO : DIRECTIONS OF X AND Y WITH THE FORCE OF 10.0N FOR 10±2 SECONDS AFTER SOLDERING BETWEEN COPPER PLATE AND THE TERMINALS.(REFER TO FIGURE AT RIGHT) 5.HEAT ENDURANCE TEST : REFER TO Recommended Soldering Temperature Graph.(AT PAGE 2). 6.INSULATING RESISTANCE : THE INSULATION RESISTANCE SHOULD BE OVER 100MΩ WHEN D.C.100V IS APPLIED TO THE WINDING –CORE. MEANWHILE NO STRUCTURE AND ELECTRIC DEFECTS SHOULD BE FOUND FOR 1 MINUTE. 7. TEMPERATURE FEATURE: INDUCTANCE COEFFICIENT IS (0~2000)x10-6(-25~+85℃) 8. HUMIDITY TEST INDUCTANCE DEVIATION IS WITHIN ±5.0% AND NO STRUCTURE AND ELECTRIC DEFECTS CAN BE : FOUND AFTER 96 HOURS TEST UNDER THE CONDITIONOF RELATIVE HUMIDITY OF 90~95% AND TEMPERATURE OF 40±2℃. AND 1 HOUR STORAGE UNDER ROOM AMBIENT CONDITIONS AFTER THE DEVICE IS WIPED WITH DRY CLOTH. 9. VIBRATION TEST : INDUCTANCE DEVIATION IS WITHIN ±5.0% AFTER 1 HOUR SWEEPING VIBRATION IN EACH THREE DIRECTIONS. NAMELY, FREQUENCY IS 10~55~10Hz ANDTHE AMPLITUDE OF 1MINUTE CYCLE IS 1.5mm PP. 10.SHOCK TEST : INDUCTANCE DEVIATION IS WITHIN ±5.0% AFTER THE TEST WITH GOM-BLOCK SHOCK TESTING MACHINE,ONCE IN EACH OF THE THREE PERPENDICULAR AXIS DIRECTIONS. THE SHOCK ACCELERATION IS 981m/s2. THE CONDITION OF REFLOW Gan Tong Part NO. : GPSR0750-330MS Wave Soldering Hand soldering PAGE : 8-8
GPSR0750-330MS 价格&库存
很抱歉,暂时无法提供与“GPSR0750-330MS”相匹配的价格&库存,您可以联系我们找货
