GPSR-AP0320-3R3MS
GPSR-AP0320-3R3MS
    SGTE(感通)
    3.3UH ±20%
GPSR-AP0320-3R3MS 数据手册
CUSTOMER CUSTOMER’S P/N DESCRIPTION SMD Power Inductor SGTE PART NO. GPSR-AP0320-3R3MS SAMPLE NO. S18032301 REVISION NO. A0 DATE 2018/3/23 SPECIFICATION FOR APPROVAL FULLY APPROVED REVISE APPROVED 深圳感通科技有限公司 (大陸工廠) GANTONG TECHNOLOGY (SHENZHEN) CO., LTD. 深圳市平湖街道平湖村萬福路26號 No.26 Wan fu Road, Ping hu Village. Ping hu town, Shenzhen City. Tel: 0755-28457600 Fax: 0755-28452952 感通科技有限公司 (台灣辦事處) 臺北縣汐止市新台5路一段77號10樓之7 10F~7, N0.77, Sec.1, Hsin Tai 5 Road, Shi-chi City,Taipei. Tel: 886-2-8698-2341 Fax:886-2-8698-2342 納美科技股份有限公司 (香港辦事處) LAPEE TECHNOLOGY LIMITED 香港九龍尖沙嘴加連威老道嘉蘭圍5-11號利時商業大廈17樓1713室 Room 1713 17/F, Rise Commercial Bldg5-11 Granville Cri cuit, Granville Rd, TSim Sha Tsui., Kln Tel: 852-25301111 Fax: 852-25371111 http://www.sgte.cn SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018/3/23 Gan Tong Part NO. Sample NO. Revision No. GPSR-AP0320-3R3MS S18032301 Pages A0 5 Version Change history Before the change After the change Release date A0 NEW ─ ─ 2018/3/23 DRAWN BY CHECKED BY APPROVED BY SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018/3/23 Gan Tong Part NO. Sample NO. GPSR-AP0320-3R3MS S18032301 Revision No. A0 Page 1-5 External Dimensions Unit (mm) Connection A 3.6±0.15 B 3.2±0.15 C 2.0 Max D ≤0.2 E 1.2±0.3 F 0.6±0.3 G 4.0 REF H 1.0 REF I 1.2 REF Recommended Land Pattern ELECTRICAL REQUIREMENTS: PARAMETER SPECIFICATION CONDITION TEST INSTRUMENTS L 3.3± 20% uH 100KHz/1V DCR 170max mΩ @ 25℃ I-sat 2.0 A mps ≧65%L0A ■A4284A+A42841A Irms 1.5 A mps ΔT ≦40℃ ■Chroma /11300+3302+1320+1320S ■LCR Agilent4284A / Chroma 11300 ■CH16502 IMPEDANCE METER LCR METER ‧ I rms: Current that causes a 40℃ temperature rise from 25℃ ambient. ‧ I sat: DC current at which the inductance drops 35% from it’s value without current. ‧ All test Data is referenced to 25℃ ambient. ‧ Operating Temperature Range: -25℃ to +125℃. SPECIFICATION Customers Part Number Item Name SMD Power Inductor Sample NO. S18032301 Gan Tong Part NO. GPSR-AP0320-3R3MS Date 2018/3/23 Revision No. A0 Page 2-5 Electrical Characteristic : PARAMETER L DCR I-sat Irms UNIT uH mΩ A mps A mps SPECIFICATION 3.3± 20% 170max 2.0 1.5 CONDITION 100KHz/1V @ 25℃ ≧65%L0A ΔT ≦40℃ 1 3.32 134.0 2 3.29 135.2 3 3.20 135.2 4 3.15 134.2 5 3.22 135.2 75.0% 30℃ 6 7 8 9 10 MEAN 3.24 134.8 R 0.17 1.20 External Dimensions: A B C D E F 3.6±0.15 3.2±0.15 2.0 Max ≤0.2 1.2±0.3 0.6±0.3 1 3.60 3.20 1.79 0.05 1.19 0.60 2 3.54 3.21 1.87 0.02 1.16 0.65 3 3.64 3.20 1.79 0.03 1.18 0.66 4 3.60 3.18 1.85 0.06 1.20 0.61 5 3.62 3.20 1.87 0.06 1.18 0.62 MEAN 3.60 3.20 1.83 0.04 1.18 0.63 R 0.10 0.03 0.08 0.04 0.04 0.06 NO 6 7 8 9 10 Inductance measured at 100KHz/1Vrms.. Electrical specifications at 25±5℃. Humidity 60±10% SPECIFICATION Customers Part Number Item Name SMD Power Inductor Sample NO. S18032301 Gan Tong Part NO. GPSR-AP0320-3R3MS Date 2018/3/23 Revision No. A0 Page 3-5 INDUCTANCE (uH) / TEMPERATURE RISE(°C) VS DC BIAS (Amps) IDC L(uH) 0.0 A 3.32 0.5 A L/L0A (%) T(℃) △T(℃) #N/A 20.0 #N/A 3.12 #N/A 26.0 #N/A 1.0 A 2.85 #N/A 35.0 #N/A 1.5 A 2.64 #N/A 50.0 #N/A 2.0 A 2.49 #N/A 68.0 #N/A (7)MARKING: NR60 SPECIFICATION Item Name SMD Power Inductor Sample NO. S18032301 Customers Part Number Gan Tong Part NO. GPSR-AP0320-3R3MS Date 2018/3/23 Revision No. A0 Page 4-5 PACKAGING A0 B0 K0 T P W 3.3 3.7 2.1 0.3 8 12 Unit mm (7)MARKING: NR60 Packaging Quantity Inner Carton Reel size Quantity/ReelInside the box size 1000pcs 195*195*105mm ¢178 Storage Quter Carton Quantity 1000pcs Carton size 405*405*125mm Unit: mm Quantity 24000pcs Transportation 1. Products should be handled with care to avoid damage or 1. Temperature and humidity conditions: Less than 40℃ and 70% RH. contamination from perspiration and skin oils. 2. Recommended products should be used within 6 months 2. The use of tweezers or vacuum pick up is strongly form the time of delivery. recommended for individual components. 3. The packaging material should be kept where no chlorine3. Bulk handling should ensure that abrasion and mechanical or sulfur exists in the air. shock are minimized. SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018/3/23 Gan Tong Part NO. Sample NO. GPSR-AP0320-3R3MS S18032301 A0 5-5 Revision No. Page SOLDRING CONDITIONS Figure 1. Re-flow Soldering Figure 2. Wave Soldering Soldering Iron: temperature 350℃±10℃ , dwell time shall be less than 3 sec. Reliability and Testing Conditions/Sureface Mount Type Power Inductors Item Specification Solderbility More than 90% of the terminal electrode should be covered with solder. Solder Heat Resistance Inductance within ±20% of initial value and appearance shall not break. Heat resistance Cold resistance Thermal shock Conditions Inductance within ±20% of initial value. After 500±12 hours in 145±5℃ and 2 hour drying No disconnection or short circuit. under normal condition. Appearance shall not break. Inductance within ±20% of initial value. After 500±12 hours in -40±2℃ and 2 hour drying No disconnection or short circuit. under normal condition. Appearance shall not break. After 10 cycles of following condition. Inductance within ±20% of initial value. No disconnection or short circuit. Appearance shall not break. Step Temperature (℃) 1 -40±2 Times (min.) 30 2 Room Temperature Within 3 3 145±5 30 4 Room Temperature Within 3 Inductance within ±20% of initial value. After 500±12 hours in 40±2℃ and 90 to 95% Humidity Resistance No disconnection or short circuit. humidity , and 2 hour drying under normal condition. Appearance shall not break. ﹡Vibration Test Inductance within ±20% of initial value and appearance shall not break. After vibration for 1hour, In each of three orientations at sweep vibration (10~55~10Hz) with 1.52mm P-P Amplitudes.
GPSR-AP0320-3R3MS 价格&库存
很抱歉,暂时无法提供与“GPSR-AP0320-3R3MS”相匹配的价格&库存,您可以联系我们找货
