GPDA1010-2R2M01
GPDA1010-2R2M01
    SGTE(感通)
    插件
    2.2UH ±20%
GPDA1010-2R2M01 数据手册
CUSTOMER CUSTOMER’S P/N DESCRIPTION SGTE PART NO. POWER INDUCTOR GPDA1010-2R2M01 SAMPLE NO.: S11090902 REVISION NO. A DATE 9-Sep-11 SPECIFICATION FOR APPROVAL FULLY APPROVED REVISE APPROVED 深圳感通科技有限公司 (大陸工廠) GANTONG TECHNOLOGY (SHENZHEN) CO., LTD. 深圳市平湖街道平湖村萬福路 26 號 No.26 Wan fu Road, Ping hu Village. Ping hu town, Shenzhen City. Tel: 0755-28457600 Fax: 0755-28452952 感通科技有限公司 (台灣辦事處) 臺北縣汐止市新台 5 路一段 77 號 10 樓之 7 10F~7, N0.77, Sec.1, Hsin Tai 5 Road, Shi-chi City,Taipei. Tel: 886-2-8698-2341 Fax:886-2-8698-2342 納美科技股份有限公司 (香港辦事處) LAPEE TECHNOLOGY LIMITED 香港九龍尖沙嘴加連威老道嘉蘭圍 5-11 號利時商業大廈 17 樓 1713 室 Room 1713 17/F, Rise Commercial Bldg5-11 Granville Cri cuit, Granville Rd, TSim Sha Tsui., Kln Tel: 852-25301111 Fax: 852-25371111 http://www.sgte.cn SPECIFICATION INDEX COVER PAGE ▓ SHAPE & DIMENSION…………………….………...........1-8 ▓ ELECTRICAL CHARACTERISTICS AND EXTERNAL TEST REPORT…….……………………………………….2-8 ▓ ELECTRICAL CHARACTERISTICS……………………..3-8 ▓ ELECTRICAL CHARACTERISTICS……………………..4-8 ▓ ELECTRICAL CHARACTERISTICS……………………..5-8 ▓ PACKING FOR SPECIFICATION…………………………6-8 ▓ GENERAL CHARACTERISTICS………………………….7-8 ▓ THE CONDITION OF REFLOW…………………………..8-8 APPROVED BY CHECKED BY DRAWING BY Jesse Tony you 9/9 9/9 9/9 SPECIFICATION Customers Part Number Item Name Date Power Inductor 9-Sep-11 Gan Tong Part NO. Sample NO. Page GPDA1010-2R2M01 S11090902 1-8 External Dimensions Unit (mm) B 2R2 E F Mark A C B D A 10.0± 0.5 (mm) B 10.0± 0.5 (mm) C 10.0Max (mm) D 1.0± 0.1 (mm) E 3.4± 0.5 (mm) F 7.5± 0.5 (mm) G 7.5± 0.5(mm) H 1.2 (ref) Coating: Black Connection Recommended Land Pattern Electrical Specification Measurement Item L Unit Tolerance Specification Test Frequency 2.2uH ±20% 6.0mΩ(Max) 100KHz/1V DCR uH (±20%) mΩ I rms Amps 20A 100KHz/1V Test Instrument LCR Meter Agilent/4284A or Chroma /11300 Chroma /16502 LCR Meter Agilent/4284A+42841A or Chroma /11300+3302+1320+1320S 32A 100KHz/1V ‧I rms: Current that causes a 40℃ temperature rise from 25℃ ambient. ‧I sat: DC current at which the inductance drops 35% from it’s value without current. ‧All test Data is referenced to 25℃ ambient. ‧Operating Temperature Range: -25℃ to +125℃ I sat Amps TEST REPORT Customers Part Number Item Name Date Power Inductor 9-Sep-11 Gan Tong Part NO. Sample NO. Revision No. Page GPDA1010-2R2M01 S11090902 A 2-8 Electrical Characteristic Item L0A Specification 2.2uH DCR 6.0mΩ Tolerance ±20% Max 1 2.11 3.45 2 2.01 3.42 3 1.92 3.34 4 2.20 3.36 5 2.25 3.38 6 2.15 3.40 7 2.15 3.48 8 2.22 3.41 9 2.03 3.37 10 2.14 3.50 X 2.12 3.41 σ 0.10 0.05 I rms I sat 20Amps △T≦40℃ 32Amps L≧65% 17.1℃ 82.0% External Dimensions Item A B C D E F Specification 10.0 10.0 10.0 1.0 3.4 7.5 Tolerance ± 0.5 (mm) ± 0.5 (mm) Max (mm) ± 0.1 (mm) ± 0.5 (mm) ± 0.5 (mm) 1 10.17 10.19 8.61 0.95 3.42 7.48 2 10.11 10.12 8.63 0.95 3.42 7.51 3 10.15 10.10 8.49 0.95 3.38 7.44 4 10.14 10.16 8.46 0.95 3.40 7.48 5 10.10 10.11 8.59 0.96 3.39 7.35 6 10.13 10.14 8.60 0.95 3.41 7.53 7 10.11 10.16 8.69 0.95 3.40 7.54 8 10.09 10.13 8.49 0.95 3.42 7.46 9 10.10 10.12 8.61 0.97 3.39 7.52 10 10.14 10.14 8.56 0.95 3.40 7.44 X 10.12 10.14 8.57 0.95 3.40 7.48 σ 0.02 0.03 0.07 0.01 0.01 0.05 Inductance measured at 100KHz/1Vrms. Electrical specifications at 25℃. Humidity 60±10% ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 9-Sep-11 Gan Tong Part NO. Sample NO. Page GPDA1010-2R2M01 S11090902 3-8 Inductance VS DC current IDC L %L0A 0A 2.05 100.0% 4A 2.05 100.0% 8A 2.02 98.5% 12A 1.97 96.1% 16A 1.91 93.2% 20A 1.86 90.7% 24A 1.79 87.3% 28A 1.73 84.4% 32A 1.68 82.0% 36A 1.62 79.0% 40A 1.57 76.6% CONDITTON:100KHz/1Vrms ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 9-Sep-11 Gan Tong Part NO. Sample NO. Page GPDA1010-2R2M01 S11090902 4-8 DC current VS Temperature Time L(μН) T(℃) △T(℃) 0H 1.94 33.5 0.5H 1.93 47.5 14.0 1H 1.90 50.6 17.1 2H 1.90 50.6 17.1 3H 1.90 50.6 17.1 4H 1.90 50.6 17.1 5H 1.90 50.6 17.1 CONDITTON: Load 20A 50.6℃ 33.5℃ ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 9-Sep-11 Gan Tong Part NO. Sample NO. Page GPDA1010-2R2M01 S11090902 5-8 Inductance VS Frequency FREQ. L(μН) 1KHZ 2.00 10KHZ 2.10 100KHZ 2.09 500KHZ 2.08 800KHZ 2.06 1000KHZ 2.09 PACKING FOR SPECIFICATION Customers Part Number Item Name Date Power Inductor 9-Sep-11 Gan Tong Part NO. Sample NO. Page GPDA1010-2R2M01 S11090901 6-8 PET Size : 215*148 *16(C)mm Quantity : 110PCS/PET Small box Size : 238*156*165 mm Quantity : 10PET/Small box 1Small box/1100PCS Big box Size : 328*251*175 mm Quantity : 2 Small box/Big box 1 Big box/2200PCS GENERAL CHARACTERISTICS Gan Tong Part NO.: GPDA1010-2R2M01 Item PAGE : Performance 7-8 Test Condition Mechanical Performance Test More than 90% of terminal electrode should be covered with solder. After fluxing, component shall be dipped in a melted solder bath at 260±5℃ for 10 seconds Solder ability Test Solder Heat Resistance Components should have not evidence of electrical and mechanical damage. Inductance: within±20% of initial value. Preheat:150℃ 60 seconds Solder: (SnCu0.7) Solder Temperature:260±5℃ Flux: Rosin. Dip time:10±0.5 seconds Temperature:- 40℃±5℃Time: 500±12 Hours Recovery: 4to24hrs of recovery under the standard Low temperature storage test condition after the removal from test chamber. Temperature: 85℃±5℃ Time: 500±2 Hours Recovery: 4to24hrs of recovery under the standard High temperature storage test condition after the removal from test chamber. 1. Appearance: No damage. 2. Inductance: within±20% of initial value. 3.No disconnection or short Thermal Shock Test -40±5℃ for 30 Minutes. +85±5℃ for 30 Minutes. Total: 10 Cycles circuit. (Temperature cycle) Humidity load life test Temperature: 40±5℃ Humidity.: 90-95% Time: 500±12 Hours Load: Allowed DC current Recovery: 4to24hrs of recovery under the standard condition after the removal from test chamber. THE CONDITION OF REFLOW Gan Tong Part NO. : GPDA1010-2R2M01 Wave Soldering Hand soldering PAGE : 8-8
GPDA1010-2R2M01 价格&库存
很抱歉,暂时无法提供与“GPDA1010-2R2M01”相匹配的价格&库存,您可以联系我们找货
