GPSR0855-680MS
GPSR0855-680MS
    SGTE(感通)
    SMD,7.8x7.2mm
GPSR0855-680MS 数据手册
CUSTOMER CUSTOMER’S P/N DESCRIPTION SMD Power Inductor SGTE PART NO. GPSR-RP0855-680MS01 SAMPLE NO. S18100701 REVISION NO. ADATE 2018-10-7 SPECIFICATION FOR APPROVAL FULLY APPROVEDREVISE APPROVED 深圳感通科技有限公司 (大陸工廠) GANTONG TECHNOLOGY (SHENZHEN) CO., LTD. 深圳市平湖街道平湖村萬福路26號 No.26 Wan fu Road, Ping hu Village. Ping hu town, Shenzhen City. Tel: 0755-28457600 Fax: 0755-28452952 感通科技有限公司 (台灣辦事處) 臺北縣汐止市新台5路一段77號10樓之7 10F~7, N0.77, Sec.1, Hsin Tai 5 Road, Shi-chi City,Taipei. Tel: 886-2-8698-2341 Fax:886-2-8698-2342 納美科技股份有限公司 (香港辦事處) LAPEE TECHNOLOGY LIMITED 香港九龍尖沙嘴加連威老道嘉蘭圍5-11號利時商業大廈17樓1713室 Room 1713 17/F, Rise Commercial Bldg5-11 Granville Cri cuit, Granville Rd, TSim Sha Tsui., Kln Tel: 852-25301111 Fax: 852-25371111 http://www.szgte.com SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018-10-7 Gan Tong Part NO. Sample NO. GPSR-RP0855-680MS01 S18100701 Version Change history A NEW DRAWN BY Revision No. Pages Before the change After the change ─ CHECKED BY ─ A 5 Release date 2018-10-7 APPROVED BY SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018-10-7 Gan Tong Part NO. Sample NO. GPSR-RP0855-680MS01 S18100701 Revision No. Page A 1-5 MECHANICAL & DIMENSIONS (UNIT: mm) CIRCUIT A 7.8± 0.5 B 7.2± 0.5 C 5.99 MAX D ≤0.15 E 3.0± 0.3 F 1.6± 0.3 F S ELECTRICAL REQUIREMENTS: PARAMETER SPECIFICATION CONDITION L 68± 20% uH 100KHz/1V DCR 260max mΩ @ 25℃ I-sat Irms 3.0 2.4 A mps A mps ≧65%L0A ΔT ≦40℃ TEST INSTRUMENTS ■LCR Agilent4284A / Chroma 11300 ■CH16502 IMPEDANCE METER ■A4284A+A42841A LCR METER ■Chroma /11300+3302+1320+1320S ‧I rms: Current that causes a 40℃ temperature rise from 25℃ ambient. ‧I sat: DC current at which the inductance drops 35% from it’s value without current. ‧All test Data is referenced to 25℃ ambient. ‧Operating Temperature Range: -25℃ to +125℃. SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018-10-7 Gan Tong Part NO. Sample NO. Revision No. A0 GPSR-RP0855-680MS01 S18100701 Page 2-5 Electrical Characteristic : PARAMETER L DCR I-sat Irms UNIT uH mΩ A mps A mps SPECIFICATION 68± 20% 260Max 3.0 2.4 CONDITION 100KHz/1V @ 25℃ ≧65%L0A ΔT ≦40℃ 1 65.70 198.0 2 64.30 199.0 3 64.03 201.0 4 64.80 197.0 5 65.55 198.0 71.80% 33.6℃ MEAN 64.88 198.60 R 1.67 4.00 6 10 External Dimensions: A B C D E F 7.8± 0.5 7.2± 0.5 5.99 MAX ≤0.15 3.0± 0.3 1.6± 0.3 1 8.05 7.25 5.55 0.07 2.97 1.63 2 8.11 7.24 5.52 0.09 2.99 1.62 3 8.08 7.25 5.54 0.08 2.99 1.60 4 8.07 7.26 5.56 0.08 3.00 1.61 5 8.06 7.25 5.57 0.08 3.01 1.58 MEAN 8.07 7.25 5.55 0.08 2.99 1.61 R 0.06 0.02 0.05 0.02 0.04 0.05 NO 6 Inductance measured at 100KHz/1Vrms.. Electrical specifications at 25±5℃. Humidity 60±10% SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018-10-7 Gan Tong Part NO. Sample NO. Revision No. GPSR-RP0855-680MS01 S18100701 Page A 4-5 .1 /- 0 4±0.1 T ABC ABC ABC ABC ABC P W +0 B0 1 .5 1.75 PACKAGING K0 A0 A0 B0 K0 T P W Unit 7.7 ±0.1 8.2 ±0.1 6.1 ±0.1 0.4 ±0.05 12 ±0.1 16 ±0.3 mm B ox A ll ti-s tatic bag 37 35 0 REEL C /N O 335 (7)MARKING: NR60 Packaging Quantity Inner Carton Quter Carton Reel size Quantity/Reel Inside the box size Quantity Carton size Quantity ¢330 800pcs 350*335*37 800pcs 365*345*290 4800pcs Storage Transportation 1. Temperature and humidity conditions: Less than 40℃ 1. Products should be handled with care to avoid damage or and 70% RH. 2. Recommended products should be used within 6 months form the time of delivery. 3. The packaging material should be kept where no chlorine or sulfur exists in the air. contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018-10-7 Gan Tong Part NO. Sample NO. GPSR-RP0855-680MS01 S18100701 Revision No. A0 Page INDUCTANCE (uH) / TEMPERATURE RISE(°C) VS DC BIAS (Amps) IDC L(uH) L/L0A (%) T(℃) △T(℃) 0.0 A 64.8 100.00% 26.6 0.0 1.0 A 63.38 97.81% 32.1 5.5 1.2 A 61.71 95.23% 36.6 10.0 1.5 A 59.51 91.84% 42.5 15.9 1.8 A 57.09 88.10% 47.2 20.6 2.0 A 54.55 84.18% 52.6 26.0 2.4 A 52.57 81.13% 60.2 33.6 2.7 A 50.24 77.53% 79.3 52.7 3.0 A 47.98 74.04% 108.7 82.1 CONDITION: 100KHz , 1.0Vrms 3-5 SPECIFICATION Customers Part Number Item Name Date SMD Power Inductor 2018-10-7 Gan Tong Part NO. Sample NO. GPSR-RP0855-680MS01 S18100701 Revision No. A Page 5-5 SOLDRING CONDITIONS Figure 1. Re-flow Soldering Figure 2. Hand Soldering Max time at max Peak 260℃ max temp 10S max 255 Preheating Soldering cooling 26 Max Ramp Up Rate=3℃/sec. Max Ramp Down Rate=6℃/sec. 217 200℃ 150 23 60~90sec. 15 60~120sec. 25 Time 25℃ to Peak =8 min OVER 2min Within 10sec Gradual Cooling Reliability and Testing Conditions/Sureface Mount Type Power Inductors Item Specification Conditions Preheating Solderbility More than 90% of the terminal electrode should be covered with solder. dipping 23 15 60S 4±1S Preheating Solder Heat Resistance Inductance within ±20% of initial value and appearance shall not break. Cold resistance Thermal shock Humidity Resistance ﹡Vibration Test Inductance within ±20% of initial value. No disconnection or short circuit. Appearance shall ±20% not break. Inductance within of initial value. No disconnection or short circuit. Appearance shall not break. Inductance within ±20% of initial value. No disconnection or short circuit. Appearance shall not break. Inductance within ±20% of initial value. No disconnection or short circuit. Appearance shall not break. dipping cooling 26 23 60S Heat resistance cooling 10S After 500±12 hours in 145±5℃ and 2 hour drying under normal condition. After 500±12 hours in -40±2℃ and 2 hour drying under normal condition. After 10 cycles of following condition. Step Temperature (℃) 1 -40±2 Times (min.) 30 2 Room Temperature Within 3 3 145±5 30 4 Room Temperature Within 3 After 500±12 hours in 40±2℃ and 90 to 95% humidity , and 2 hour drying under normal condition. Inductance within ±20% of initial value and After vibration for 1hour, In each of three orientations at sweep vibration appearance shall not break. (10~55~10Hz) with 1.52mm P-P
GPSR0855-680MS 价格&库存
很抱歉,暂时无法提供与“GPSR0855-680MS”相匹配的价格&库存,您可以联系我们找货
