GPDC1010-470M01
GPDC1010-470M01
    SGTE(感通)
    插件,D10xL10mm
    47UH ±20%
GPDC1010-470M01 数据手册
CUSTOMER CUSTOMER’S P/N DESCRIPTION POWER INDUCTOR SGTE PART NO. GPDC1010-470M01 SAMPLE NO.: S10052702 REVISION NO. A DATE 27-May-10 SPECIFICATION FOR APPROVAL FULLY APPROVED REVISE APPROVED 深圳感通科技有限公司 (大陸工廠) GANTONG TECHNOLOGY (SHENZHEN) CO., LTD. 深圳市平湖街道平湖村萬福路 26 號 No.26 Wan fu Road, Ping hu Village. Ping hu town, Shenzhen City. Tel: 0755-28457600 Fax: 0755-28452952 感通科技有限公司 (台灣辦事處) 臺北縣汐止市新台 5 路一段 77 號 10 樓之 7 10F~7, N0.77, Sec.1, Hsin Tai 5 Road, Shi-chi City,Taipei. Tel: 886-2-8698-2341 Fax:886-2-8698-2342 納美科技股份有限公司 (香港辦事處) LAPEE TECHNOLOGY LIMITED 香港九龍尖沙嘴加連威老道嘉蘭圍 5-11 號利時商業大廈 17 樓 1713 室 Room 1713 17/F, Rise Commercial Bldg5-11 Granville Cri cuit, Granville Rd, TSim Sha Tsui., Kln Tel: 852-25301111 Fax: 852-25371111 http://www.szgte.com SPECIFICATION INDEX COVER PAGE ▓ SHAPE & DIMENSION…………………….………...........1-8 ▓ ELECTRICAL CHARACTERISTICS AND EXTERNAL TEST REPORT…….……………………………………….2-8 ▓ ELECTRICAL CHARACTERISTICS……………………..3-8 ▓ ELECTRICAL CHARACTERISTICS……………………..4-8 ▓ ELECTRICAL CHARACTERISTICS……………………..5-8 ▓ PACKING FOR SPECIFICATION…………………………6-8 ▓ GENERAL CHARACTERISTICS………………………….7-8 ▓ THE CONDITION OF REFLOW…………………………..8-8 APPROVED BY CHECKED BY DRAWING BY Jesse Gary Lily 5/27 5/27 5/27 SPECIFICATION Customers Part Number Item Name Date Power Inductor 27-May-10 Gan Tong Part NO. Sample NO. Page GPDC1010-470M01 S10052702 1-8 External Dimensions Unit (mm) C 470 E B A D F A 10.0± 0.5 (mm) B 10.0± 0.5 (mm) C 14.0Max (mm) D 0.55± 0.1 (mm) E 3.4± 0.5 (mm) F 6.0± 0.5 (mm) G 6.0± 0.5(mm) H 0.95 (ref) Coating:Black Connection Recommended Land Pattern H G Electrical Specification Measurement Item L Unit Tolerance Specification Test Frequency Test Instrument 47uH ±20% 100KHz/1V 79mΩ(Max) LCR Meter Agilent/4284A or Chroma /11300 DCR uH (±20%) mΩ I rms Amps 4A LCR Meter Agilent/4284A+42841A 100KHz/1V Chroma /16502 or Chroma /11300+3302+1320+1320S 7A 100KHz/1V ‧I rms: Current that causes a 40℃ temperature rise from 25℃ ambient. ‧I sat: DC current at which the inductance drops 35% from it’s value without current. ‧All test Data is referenced to 25℃ ambient. ‧Operating Temperature Range: -25℃ to +125℃ I sat Amps TEST REPORT Customers Part Number Item Name Date Power Inductor 27-May-10 Gan Tong Part NO. Sample NO. Revision No. Page GPDC1010-470M01 S10052702 A 2-8 Electrical Characteristic Item L0A Specification 47 uH DCR 79mΩ Tolerance ±20% Max 1 44.47 60.59 2 43.73 60.61 3 45.16 60.47 4 44.78 60.49 5 46.19 60.52 6 45.16 60.57 7 43.47 60.53 8 44.86 60.60 9 44.35 60.56 10 45.10 60.58 X 44.73 60.55 σ 0.74 0.05 I rms I sat 4Amps △T≦40℃ 7Amps L≧65% 24.5℃ 81.4% External Dimensions Item A B C D E F Specification 10.0 10.0 14.0 0.55 3.4 6.0 Tolerance ± 0.5 (mm) ± 0.5 (mm) Max (mm) ± 0.1 (mm) ± 0.5 (mm) ± 0.5 (mm) 1 10.11 10.06 12.38 0.54 3.58 6.19 2 10.06 10.07 12.65 0.56 3.49 6.10 3 10.13 10.10 12.37 0.55 3.53 6.09 4 10.10 10.12 12.20 0.54 3.67 6.27 5 10.09 10.10 12.32 0.57 3.60 6.30 6 10.07 10.06 12.30 0.58 3.65 6.24 7 10.06 10.08 12.64 0.54 3.59 6.17 8 10.09 10.08 12.58 0.56 3.57 6.18 9 10.07 10.07 12.55 0.54 3.62 6.15 10 10.06 10.06 12.16 0.55 3.68 6.21 X 10.08 10.08 12.42 0.55 3.60 6.21 σ 0.02 0.02 0.17 0.01 0.06 0.06 Inductance measured at 100KHz/1Vrms. Electrical specifications at 25℃. Humidity 60±10% ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 27-May-10 Gan Tong Part NO. Sample NO. Page GPDC1010-470M01 S10052702 3-8 Inductance VS DC current IDC L %L0A 0A 44.46 100.0% 1A 44.13 99.3% 2A 42.98 96.7% 3A 41.51 93.4% 4A 40.52 91.1% 5A 39.85 89.6% 6A 38.04 85.6% 7A 36.18 81.4% 8A 33.53 75.4% CONDITTON:100KHZ/1.0Vrms ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 27-May-10 Gan Tong Part NO. Sample NO. Page GPDC1010-470M01 S10052702 4-8 DC current VS Temperature Time L(μН) T(℃) △T(℃) 0h 39.42 29.2 0.5h 39.23 42.5 13.3 1h 39.20 53.2 24.0 2h 39.19 53.4 24.2 3h 39.18 53.5 24.3 4h 39.17 53.6 24.4 5h 39.17 53.7 24.5 CONDITTON: Load 4A 53.7℃ 29.2℃ ELECTRICAL CHARACTERISTICS Customers Part Number Item Name Date Power Inductor 27-May-10 Gan Tong Part NO. Sample NO. Page GPDC1010-470M01 S10052702 5-8 Inductance VS Frequency FREQ. L(μН) 1KHZ 45.14 10KHZ 45.11 100KHZ 44.47 500KHZ 44.46 800KHZ 45.41 1000KHZ 46.41 PACKING FOR SPECIFICATION Customers Part Number Item Name Date Power Inductor 27-May-10 Gan Tong Part NO. Sample NO. Page GPDC1010-470M01 S10052702 6-8 PET Size : 175*159*19mm Quantity : 130PCS/PET Small box Size : 324*178*114 mm Quantity : 10PET/Small box 1Small box/650PCS Big box Size : 386*338*132 mm Quantity : 2 Small box/Big box 1 Big box/1300PCS GENERAL CHARACTERISTICS Gan Tong Part NO.: GPDC1010-470M01 Item PAGE : Performance 7-8 Test Condition Mechanical Performance Test More than 90% of terminal electrode should be covered with solder. After fluxing, component shall be dipped in a melted solder bath at 260±5℃ for 10 seconds Solder ability Test Solder Heat Resistance Components should have not evidence of electrical and mechanical damage. Inductance: within±20% of initial value. Preheat:150℃ 60 seconds Solder: (SnCu0.7) Solder Temperature:260±5℃ Flux: Rosin. Dip time:10±0.5 seconds Temperature:- 40℃±5℃Time: 500±12 Hours Recovery: 4to24hrs of recovery under the standard Low temperature storage test condition after the removal from test chamber. Temperature: 85℃±5℃ Time: 500±2 Hours Recovery: 4to24hrs of recovery under the standard High temperature storage test condition after the removal from test chamber. 1. Appearance: No damage. 2. Inductance: within±20% of initial value. 3.No disconnection or short Thermal Shock Test -40±5℃ for 30 Minutes. +85±5℃ for 30 Minutes. Total: 10 Cycles circuit. (Temperature cycle) Humidity load life test Temperature: 40±5℃ Humidity.: 90-95% Time: 500±12 Hours Load: Allowed DC current Recovery: 4to24hrs of recovery under the standard condition after the removal from test chamber. THE CONDITION OF REFLOW Gan Tong Part NO. : GPDC1010-470M01 Wave Soldering Hand soldering PAGE : 8-8
GPDC1010-470M01 价格&库存
很抱歉,暂时无法提供与“GPDC1010-470M01”相匹配的价格&库存,您可以联系我们找货
