GZT80-BLACK
GZT80-BLACK
    RELPOL
    RELPOL - GZT80-BLACK - Relay Socket, DIN Rail, Plug, 8 Pins, 12 A, 230 V, REPOL 8-Pin RM85
GZT80-BLACK 数据手册
RM85 miniature relays RM85-...-01 ❶ • Cadmium - free contacts • Height 15,7 mm • 5000 V / 10 mm reinforced insulation • For PCB and plug-in sockets • Accessories: sockets and modules • AC and DC coils • Available special versions: with transparent cover ❶; with the increased dielectric strength of the contact clearance ❷ • Compliance with standard PN-EN 60335-1 • Recognitions, certifications, directives: RoHS, Contact data Number and type of contacts Contact material Rated / max. switching voltage Min. switching voltage Rated load (capacity) Min. switching current Max. inrush current Rated current Max. breaking capacity Min. breaking capacity Contact resistance Max. operating frequency • at rated load • no load AC AC1 AC15 AC3 DC1 DC13 AC1 AC1 Coil data Rated voltage Must release voltage Operating range of supply voltage Rated power consumption 50/60 Hz AC DC Insulation according to PN-EN 60664-1 AC DC Insulation rated voltage Rated surge voltage Overvoltage category Insulation pollution degree Dielectric strength • between coil and contacts • contact clearance Contact - coil distance • clearance • creepage General data Operating / release time (typical values) Electrical life (number of cycles) • resistive AC1 • cosφ • DC L/R=40 ms Mechanical life (cycles) Dimensions (L x W x H) / Weight Ambient temperature Cover protection category Environmental protection Shock resistance Vibration resistance Solder bath temperature Soldering time • storage • operating 1 CO, 1 NO ❷ AgNi, AgNi/Au hard gold plating, AgSnO2 250 V / 440 V 5 V AgNi, 5 V AgNi/Au hard gold plating, 10 V AgSnO2 16 A / 250 V AC 3 A / 120 V 1,5 A / 240 V (B300) 750 W (single-phase motor) 16 A / 24 V DC (see Fig. 3) 0,22 A / 120 V 0,1 A / 250 V (R300) 5 mA AgNi, 2 mA AgNi/Au hard gold plating, 10 mA AgSnO2 30 A AgSnO2 16 A 4 000 VA 0,3 W AgNi, 0,05 W AgNi/Au hard gold plating, 1 W AgSnO2 ≤ 100 mΩ 600 cycles/hour 72 000 cycles/hour 12 ... 240 V 3 ... 110 V AC: ≥ 0,15 Un DC: ≥ 0,1 Un see Tables 1, 2 and Fig. 4, 5 0,75 VA 0,4 ... 0,48 W 400 V AC 4 000 V 1,2 / 50 µs III 3 5 000 V AC type of insulation: reinforced 1 000 V AC type of clearance: micro-disconnection 2 000 V AC contact 1 NO, type of clearance: full-disconnection ❷ ≥ 10 mm ≥ 10 mm 7 ms / 3 ms > 0,7 x 105 16 A, 250 V AC > 104 20 A, 250 V AC, 85 °C (RM85-3021-25-1...) see Fig. 2 > 105 0,15 A, 220 V DC > 3 x 107 29 x 12,7 x 15,7 mm / 14 g -40...+85 oC AC: -40...+70 oC DC: -40...+85 oC -20...+70 oC ❶ IP 40 ❶ or IP 67 PN-EN 60529 RTII ❶ or RTIII PN-EN 116000-3 30 g 10 g 10...150 Hz max. 270 oC max. 5 s The data in bold type relate to the standard versions of the relays. ❶ Relate to the special versions - relays with transparent cover, only available with IP 40 and RTII, operating temperature -20...+70 °C. See ”Ordering codes”. ❷ Relate to the special versions - relays with one normally open contact 1 NO, with increased contact gap - dielectric strength 2000 V AC, only available with DC coils. See ”Ordering codes”. www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl 19.04.2016 RM85 1 RM85 miniature relays Pinout (solder side view) Dimensions 1 CO 5 15,2 2,5 12,7 2,5 7,5 12,7 5 5 15,2 5 2,5 29 15,7 3,9 8 × Ø 1,3 2,5 1 NO 20,2 2,5 3,9 2,5 15,7 5 6 × Ø 1,3 Connection diagrams (pin side view) 2,5 Connection of GZ... sockets Clamp bridge Cu wire min. 1,5 mm2 1 CO Terminal (pin) [mm] 1 NO A1(1); A2(2) 22(3); 21(4); 24(5); 12(6); 11(7); 14(8) Ø 0,6 0,5 x 0,9 Drilling hole: • for relays Ø 1,3 + 0,1 mm • for sockets Ø 1,5 + 0,1 mm 19.04.2016 RM85 terminals are doubled for each contact. Both terminals are to be used while connecting to load. Note: Loads above 12 A (GZT80, GZM80) or 10 A (GZS80, GZF80, GZMB80) require bridging pairs of terminals: 11 with 21, 12 with 22, 14 with 24. Loads up to 12 A or 10 A do not require bridging of common terminals (such bridges may be fixed, however). 2 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl RM85 miniature relays AC1 N - electrical life at AC1 DC1 19.04.2016 In = 16 A 3 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl RM85 miniature relays Mounting Relays RM85 ❸ are designed for: • direct PCB mounting • screw terminals plug-in sockets GZT80 ❹ ❺ and GZM80 ❹ ❺ with clip GZT80-0040 or GZM80-0041; sockets GZS80 ❹ ❺ with clip GZS-0040 or GZM80-0041; sockets GZF80 ❹ with clip GZM80-0041, 35 mm rail mount acc. to PN-EN 60715 or on panel mounting with one M3 screw • spring terminals plug-in sockets GZMB80 ❹ ❻ with clip GZMB80-0040 or GZM80-0041, 35 mm rail mount acc. to PN-EN 60715. Signalling / protecting modules type M... ❼ are available with sockets (see page 10) • plug-in sockets for PCB mounting EC 50 with clip MP16-2, MH16-2; plug-in sockets PW80 with clip MH16-2; plug-in sockets GD50 with clip MP16-2, GD-0016, MH16-2. ❸ Relate to the special versions - relays with transparent cover: the distance of min. 5 mm between the mounting relays. ❹ Loads above 12 A (GZT80, GZM80) or 10 A (GZS80, GZF80, GZMB80) require bridging pairs of terminals: 11 with 21, 12 with 22, 14 with 24 - see page 2. ❺ Plug-in sockets GZT80, GZM80, GZS80 may be linked with inter­­con­nection strip type ZGGZ80 (see page 11). ❻ For sockets GZMB80 - see page 7 (wire connection). ❼ For sockets GZF80 not applicable modules type M... Coil data - DC voltage version Coil code Table 1 Rated voltage V DC Coil resistance at 20 °C Ω Acceptable resistance Coil operating range V DC min. (at 20 °C) max. (at 20 °C) 1003 3 22 ± 10% 2,1 7,6 1005 5 60 ± 10% 3,5 12,7 1006 6 90 ± 10% 4,2 15,3 1009 9 200 ± 10% 6,3 22,9 1012 12 360 ± 10% 8,4 30,6 1018 18 710 ± 10% 12,6 45,9 1024 24 1 440 ± 10% 16,8 61,2 1036 36 3 140 ± 10% 25,2 91,8 1048 48 5 700 ± 10% 33,6 122,4 1060 60 7 500 ± 10% 42,0 153,0 1110 110 25 200 ± 10% 77,0 280,0 The data in bold type relate to the standard versions of the relays. Coil data - AC 50/60 Hz voltage version Coil code Rated voltage V AC Table 2 Coil resistance at 20 °C Ω Acceptable resistance Coil operating range V AC 50 Hz min. (at 20 °C) max. (at 20 °C) 5012 12 100 ± 10% 9,6 13,2 5024 24 400 ± 10% 19,2 28,8 5048 48 1 550 ± 10% 38,4 57,6 5060 60 2 600 ± 10% 48,0 72,0 5110 110 8 900 ± 10% 88,0 132,0 5115 115 9 600 ± 10% 92,0 138,0 5120 120 10 200 ± 10% 96,0 144,0 5220 220 35 500 ± 10% 176,0 264,0 5230 230 38 500 ± 10% 184,0 276,0 5240 240 42 500 ± 15% 192,0 288,0 19.04.2016 The data in bold type relate to the standard versions of the relays. 4 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl RM85 miniature relays Ordering codes Cover protection category Type Contact material R M 8 5 — Number and type of contacts Connection mode — Coil code — Cover Special version — Contact material 20 - AgNi 23 - AgNi/Au hard gold plating 30 - AgSnO2 see Tables 1, 2 page 4 Number and type of contacts 11 - 1 CO 21 - 1 NO Cover protection category 2 - in cover, IP 40 version 3 - in cover, IP 67 waterproof version Connection mode 5 - for PCB and sockets Cover without marks - standard cover (no transparent, white colour) 01 - transparent cover (special version, without signs recognitions) ❶ Special version without marks - basic version, dielectric strength of contact clearance 1000 V AC (51) - contact 1 NO, increased contact gap - dielectric strength 2000 V AC ❷ ❶ 01: special version - relay with transparent cover, only available with IP 40 and RTII, operating temperature -20...+70 °C ❷ (51): special version - relay with one normally open contact 1 NO, with increased contact gap - dielectric strength 2000 V AC, only available with DC coil Examples of ordering code: RM85-3011-25-5024 RM85-2011-25-1012-01 19.04.2016 RM85-2321-35-1024 (51) relay RM85, for PCB and sockets, one changeover contact, contact material AgSnO2, coil voltage 24 V AC 50/60 Hz, in standard cover (no transparent, white colour) IP 40 relay RM85, for PCB and sockets, one changeover contact, contact material AgNi, coil voltage 12 V DC, with transparent cover (special version, without signs recognitions) IP 40 relay RM85, special version with increased contact gap, for PCB and sockets, one normally open contact, contact material AgNi/Au hard gold plating, coil voltage 24 V DC, in standard cover (no transparent, white colour) IP 67 5 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl Plug-in sockets and accessories COM NO 67 61-0,2 42,5 15,6-0,2 RM87P 35,2 RM85 inrush RM87L RM85 105 °C sensitive 29,8 75,3±0,15 80-0,2 RM85 Ø 3,2 RM84 19,8 COIL 7 24 20 Screw terminals Max. tightening moment for the terminal: 0,7 Nm 35 mm rail mount acc. to PN-EN 60715 or on panel mounting 80 x 15,6 x 61(67) mm ❷ Two poles, 5 mm pinout 12 A, 300 V AC NC 5 5 For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive Dimensions Connection diagrams ❸ GZT80 GZT80-0040 GZT80-0035 Module type M... 7,5 Accessories ❶ Dimensions COM NO NC 67 61-0,2 42,5 15,9-0,2 32,1 78,1 81,6-0,2 RM87P 35,3 RM85 inrush RM87L RM85 105 °C sensitive Ø 3,2 RM85 5 5 RM84 21,5 COIL 7 24 20 Screw terminals Max. tightening moment for the terminal: 0,7 Nm 35 mm rail mount acc. to PN-EN 60715 or on panel mounting 81,6 x 15,9 x 61(67) mm ❷ Two poles, 5 mm pinout 12 A, 300 V AC GZM80-0041 Connection diagrams ❸ GZM80 For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive ZGGZ80 42,5 GZT80-0040 GZT80-0035 Module type M... 7,5 Accessories ❶ Dimensions COM NO COIL NC RM84 RM85 RM85 inrush RM87L RM85 105 °C sensitive GZS-0040 Accessories ❶ TR ZGGZ80 RM87P Module type M... GZM80-0041 ❶ Mounting and sub-assemblies of accessories in the socket - see page 8. Signalling / protecting modules type M... - see page 10. ❷ In the bracket the height of socket with retainer / retractor clip is shown. ❸ For RM85..., RMP85: loads above 12 A (GZT80, GZM80) or 10 A (GZS80, GZF80, GZMB80) require bridging pairs of terminals: 11 with 21, 12 with 22, 14 with 24 - see catalog ”Relays” and www.relpol.com.pl www.relpol.com.pl 19.04.2016 Screw terminals Max. tightening moment for the terminal: 0,5 Nm 35 mm rail mount acc. to PN-EN 60715 or on panel mounting 76,8 x 15,8 x 42,5(57,1) mm ❷ Two poles, 5 mm pinout 10 A, 300 V AC GZM80-0041 Connection diagrams ❸ GZS80 For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive ZGGZ80 24 Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl 6 Plug-in sockets and accessories Dimensions Connection diagrams ❸ GZF80 NO 36,5 21,8 15,5 6,8 3,5 18,5 COIL RM87P 13,3 27 67,2 RM85 inrush RM87L RM85 105 °C sensitive 35,4 RM85 RMP85 Ø 3,5 RM84 RMP84 38 NC 5 5 Screw terminals Max. tightening moment for the terminal: 0,5 Nm 35 mm rail mount acc. to PN-EN 60715 or on panel mounting 67,2 x 15,5 x 36,5 mm Two poles, 5 mm pinout 10 A, 250 V AC COM 20 For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive, RMP84, RMP85 10,5 23,2 26,7 Accessories ❶ GZM80-0041 GZM80-0025 Dimensions Connection diagrams ❸ GZMB80 78 COM ❹ NO 69 45,2 36 16 30,2 COIL RM84 RMP84 RM85 RMP85 RM85 inrush RM87L RM85 105 °C sensitive RM87P 97 Spring terminals Max. cross section of the cables: 1 x 0,2...1,5 mm2 (1 x 24...16 AWG) Length of the cable deinsulation: 9...11 mm NC 5,1 For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive, RMP84, RMP85 6 25,9 20,3 5,1 35 mm rail mount acc. to PN-EN 60715 97 x 16 x 45,2(69 /78 ❹) mm ❷ Two poles, 5 mm pinout 10 A, 300 V AC 7,6 27 The drawings present the sequence of operations in course of inserting wires to the spring terminal, and the recommended screwdriver to be used for opening of case springs, comply with the DIN 5264 FORM „A”. TR GZMB80-0040 GZMB80-0025 Accessories ❶ ❹ GZM80-0041 Module type M... GZM80-0025 Wire connection 19.04.2016 ❶ Mounting and sub-assemblies of accessories in the socket - see page 8. Signalling / protecting modules type M... - see page 10. ❷ In the bracket the height of socket with retainer / retractor clip is shown. ❸ For RM85..., RMP85: loads above 12 A (GZT80, GZM80) or 10 A (GZS80, GZF80, GZMB80) require bridging pairs of terminals: 11 with 21, 12 with 22, 14 with 24 - see catalog ”Relays” and www.relpol.com.pl ❹ Height of set: 69 mm (GZMB80-0040) or 78 mm (GZMB80-0025). 7 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl Plug-in sockets and accessories Mounting and sub-assemblies of the relay and accessories in the socket Retainer / retractor clip Electromagnetic relay Signalling / protecting module type M... Removing the relay from the socket with a retrainer / retractor clip Description plate PRECAUTIONS: 1. Ensure that the parameters of the product described in its specification provide a safety margin for the appropriate operation of the device or system and never use the product in circumstances which exceed the parameters of the product. 2. Never touch any live parts of the device. 3. Ensure that the product has been connected correctly. An incorrect connection may cause malfunction, excessive heating or risk of fire. 4. In case of any risk of any serious material loss or death or injuries of humans or animals, the devices or systems shall be designed so to equip them with double safety system to guarantee their reliable operation. 19.04.2016 Screw terminals plug-in socket 8 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl Plug-in sockets and accessories EC 50 Pinout Dimensions For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive, RM83, RMP84, RMP85 For PCB 31,3 x 12,7 x 9 mm Two poles, 5 mm pinout 8 A, 300 V AC Accessories PW80 MP25-2 MH25-2 MP16-2 MH16-2 Pinout Dimensions For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive, RM83 For PCB 34,6 x 12,9 x 6,6 mm Two poles, 5 mm pinout 8 A, 250 V AC Accessories GD50 MH16-2 MH25-2 Pinout Dimensions For RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L, RM87L sensitive, RM87P, RM87P sensitive, RM83, RMP84, RMP85 For PCB 31,5 x 13 x 9 mm Two poles, 5 mm pinout 8 A, 300 V AC MH25-2 MP16-2 MH16-2 GD-0016 19.04.2016 Accessories MP25-2 9 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl Signalling / protecting modules type M... For sockets type: GZT80, GZM80, GZS80, GZMB80, GZT92, GZM92, GZS92, ES 32, GZT2, GZM2, GZMB2, GZT3, GZM3, GZT4, GZM4, GZMB4 Modules type M... are parallely connected with relay coil. Polarity P: -A1/+A2. Polarity N: +A1/-A2. Modules type M... Layout Voltage Type of module ❶ ❷ Module D (polarization P) 6/230 V DC M21P Module D (polarization N) 6/230 V DC M21N Module LD (polarization P) 6/24 V DC 24/60 V DC 110/230 V DC M31R, M31G M32R, M32G M33R, M33G Module LD (polarization N) 6/24 V DC 24/60 V DC 110/230 V DC M41R, M41G M42R, M42G M43R, M43G Module RC 6/24 V AC/DC 24/60 V AC/DC 110/240 V AC/DC M51 M52 M53 Module L 6/24 V AC/DC 24/60 V AC/DC 110/240 V AC/DC M61R, M61G M62R, M62G M63R, M63G Module LV 6/24 V AC/DC 24/60 V AC/DC 110/240 V AC/DC M91R, M91G M92R, M92G M93R, M93G Module V It limits overvoltage on AC coils. No indication. 6/24 V AC 110/130 V AC 220/240 V AC M71 M72 M73 Module R 110/240 V AC M103 It limits overvoltage on DC coils. It limits overvoltage on DC coils. It limits overvoltage on DC coils. Coil energizing indication. It limits overvoltage on DC coils. Coil energizing indication. It protects against EMC disturbance. It limits overvoltage. Coil energizing indication. It limits overvoltage on AC and DC coils. Coil energizing indication. It limits harmful voltage on AC coils induced in long lines which causes unwanted making of the relay. ❶ M...R - LED red, M...G - LED green ❷ When ordering modules indicate their color: gray or black. MODULE type M... LED red – M...R 19.04.2016 LED green – M...G 10 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl Interconnection strips ZGGZ80 PI85-...-MS-... (RM85 + GZM80) ZGGZ80 ZGGZ80 for: Plug-in sockets Relays for plug-in sockets Interface relays ❸ GZT80 GZM80 GZS80 GZT92 GZM92 GZS92 ES 32 RM84, RM85, RM85 inrush, RM85 105 °C sensitive, RM87L ❹, RM87P ❹, RM87N ❹ PI84-...-TS-... (RM84 + GZT80) PI84-...-MS-... (RM84 + GZM80) PI85-...-TS-... (RM85 + GZT80) (RM85 inrush + GZT80) PI85-...-MS-... (RM85 + GZM80) RM96 1 CO ❸ Interface relay PI84 (PI85) is offered as a set: plug-in socket GZT80 or GZM80 + miniature relay RM84 (RM85) + signalling / protecting module type M... + retainer / retractor clip GZT80-0040 + description plate GZT80-0035. ❹ Also versions RM87. sensitive Interconnection strip ZGGZ80 • designed for the co-operation with plug-in sockets of miniature relays and with interface relays PI84 and PI85, which are equipped with screw terminals; sockets and relays are mounted on 35 mm rail mount acc. to PN-EN 60715, • bridges common input signals (coil terminals A1 or A2) or output signals - see photo at the top, • maximum permissible current is 10 A / 250 V AC, • colours of strips: ZGGZ80-1 grey, ZGGZ80-2 black. 19.04.2016 • possibility of connection of 8 sockets or relays, 11 www.relpol.com.pl Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl
GZT80-BLACK 价格&库存
很抱歉,暂时无法提供与“GZT80-BLACK”相匹配的价格&库存,您可以联系我们找货
GZT80-BLACK
    • 1+63.32655
    库存:679
