GSTC104P-1R5MN
GSTC104P-1R5MN
    GOTREND(高创)
    IND_11.5X10.3MM_SM
    1.5UH ±20%
GSTC104P-1R5MN 数据手册
Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 2 Features & Application : * High performance (Isat) realized by metal dust core. * Low profile : 4.5mm x 4.3mm x 2.0mm * Low loss realized with low DCR * Capable of corresponing high frequency (1MHz) 100% lead (Pb) free meet RoHS standard DC/DC converter for CPU in Notebook PC Product Structure ▼ ▼ DIP SMD Unshield Shield 2005 RoHS Compliant - SGS Certified Result 鉛 Pb = 1R0 : 3.0 mm +/-0.5 GSTC135P TYPE " D " Dimension : L < 2R2 : 4.0 mm +/-0.5 ; L >= 2R2 : 3.0 mm +/-0.5 * Wayne kerr 3260B/G LCR Meter * Wayne kerr 3265B Bias Current Source Standard Atmospheric Conditions : Ambient Temp : 20 +/- 15oC Relative Humidity : 65 +/- 20% If there may be any doubt on the result, measurement shall be made within the following limits : Ambient Temp : 25 +/- 5oC Relative Humidity : 75 +/- 10% Marking and Date Code : Marking The inductor is marked with a 3-digit code Example : 4.7uH 4R7 Date Code (1) Year Ex : 2005 = 5 X XX (1) (2) (2) Weekly Serial number : 01 ~ 52 Taping No. Serial number : 000~ZZZ Marking Direction : 1R0 GSTC042 GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw 1R0 XXX XXX GSTC053 GSTC06X 1R0 XXX XXX Test Equipment : GSTC104 GSTC133 GSTC135 Page: 2 2.0 2.5 2.5 3.5 3.5 4.1 5.0 5.0 Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 3 Operatiing & Storage Condition : Recommend IR Reflow Curve : o OPERATING TEMP : -55 ~ +125 C Temp [ oC ] STORAGE TEMP : -25 ~ +35oC STORAGE LIFE TIME : 12 MONTH @25oC , RH 70% Lead Free Solder : A = 217 oC Time : C = 40 ~ 60 Sec. B = 245 +/- 5 o C B A Soldering 180 160 Attention & Caution : Please avoid following matters : * Splashing water or salt water * Toxic Gas (Hydrogen sulfide, Sulfurous acid, Chlorine, Ammonia) * Vibrations or shocks which exced the specified condition * Dew condenses * Please be careful for the stress to this product by board flexure or C 100 60 ~ 90 Sec. 50 something after the mounting. Notice : Iron Soldering , Solder < 30 Watt , Direct touch the terminal x 3 Sec. Max. @ 350 o C Electrical Characteristics : Part No. GSTC252012PA-R33MS GSTC252012PA-R47MS GSTC252012PA-1R0MS GSTC252012PA-2R2MS GSTC252012PB-R22MS GSTC252012PB-R33MS GSTC252012PB-R47MS GSTC252012PB-R50MS GSTC252012PB-1R0MS GSTC252012PB-1R5MS GSTC252012PB-2R2MS GSTC252012PB-3R3MS Inductance L(uH) +/- 20% 0.33 0.47 1.00 2.20 0.22 0.33 0.47 0.50 1.00 1.50 2.20 3.30 RDC (m Ohm) [ Typ. ] / [ Max. ] 14.0 / 17.0 20.0 / 25.0 43.0 / 53.0 84.0 / 98.0 8.0 / 10.0 14.0 / 17.0 23.0 / 28.0 25.0 / 30.0 45.0 / 55.0 58.0 / 70.0 86.0 / 105.0 120.0 / 144.0 Irms (Amp) Typ. Isat (Amp) Typ. 5.60 4.50 3.10 2.30 7.30 5.50 4.50 4.30 3.10 2.70 2.30 1.75 *Test Condition@1MHz,1.0Vrms, 25oC Ambient * Isat: Saturated Current measured at the point of L drop approximately 30% [ S TYPE ] * Irms: Rated Current Loading when temperature rise approximately 40oC * The parts final operating temperature (Ambient+The parts temperature rise) should not exceed 125oC if under worst case of conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part Part temperature should be verified in the end application. * All test data is referenced to 25o C Ambient. GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw 4.30 3.80 2.80 1.80 7.00 5.80 5.00 4.80 3.80 2.90 2.50 2.00 operating temperature. Page: 3 Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 4 Electrical Characteristics : Part No. GSTC042 P-R10MN GSTC042 P-R22MN GSTC042 P-R47MN GSTC042 P-1R0MN GSTC042 P-R10MS GSTC042 P-R22MS GSTC042 P-R47MS GSTC042 P-1R0MS GSTC042 P-1R5MS GSTC042 P-2R2MS GSTC042 P-3R3MS GSTC053 P-R68MN GSTC053 P-1R0MN GSTC053 P-1R2MN GSTC053 P-1R5MN GSTC053 P-2R2MN GSTC053 P-3R3MN GSTC053 P-R56MS GSTC053 P-4R7MS GSTC061 P-R10MS GSTC061 P-R33MS GSTC061 P-R47MS GSTC061 P-R68MS GSTC061 P-1R0MS GSTC061 P-2R0MS GSTC061 P-2R2MS GSTC061 P-3R3MS GSTC061 P-4R7MS GSTC063 P-1R5MS GSTC063 P-2R2MS GSTC063 P-4R7MS GSTC063 P-8R2MS GSTC063 P-100MS GSTC063 P-R10MN GSTC063 P-R20MN GSTC063 P-R22MN GSTC063 P-R25MN GSTC063 P-R33MN GSTC063 P-R47MN GSTC063 P-R56MN GSTC063 P-R68MN GSTC063 P-R82MN GSTC063 P-R90MN GSTC063 P-1R0MN GSTC063 P-1R2MN GSTC063 P-1R5MN GSTC063 P-2R2MN GSTC063 P-2R5MN GSTC063 P-3R3MN GSTC063 P-4R7MN GSTC063 P-6R8MN Inductance L(uH) +/- 20% 0.10 0.22 0.47 1.00 0.10 0.22 0.47 1.00 1.50 2.20 3.30 0.68 1.00 1.20 1.50 2.20 3.30 0.56 4.70 0.10 0.33 0.47 0.68 1.00 2.00 2.20 3.30 4.70 1.50 2.20 4.70 8.20 10.00 0.10 0.20 0.22 0.25 0.33 0.47 0.56 0.68 0.82 0.90 1.00 1.20 1.50 2.20 2.50 3.30 4.70 6.80 RDC (m Ohm) [ Typ. ] / [ Max. ] 4.50 / 5.00 7.30 / 8.00 14.00 /15.50 32.00 / 36.00 3.50 / 4.00 6.00 / 6.60 12.50 /14.00 24.00 / 27.00 38.00 / 46.00 52.00 / 58.00 74.00 / 87.00 11.0 / 12.00 13.0 / 14.00 15.0 / 16.00 20.0 / 25.00 29.0 / 35.00 32.0 / 38.00 8.20 / 9.50 50.0 / 60.00 2.00 / 2.50 5.20 / 6.80 7.30 / 8.40 10.80 / 12.70 14.50 / 17.00 28.00 / 32.00 31.00 / 35.00 56.00 / 60.00 68.00 / 70.00 10.80 / 12.00 18.00 / 20.00 32.50 / 35.00 54.00 / 60.00 62.00 / 68.00 1.50 / 1.70 2.40 / 3.00 2.50 / 2.80 3.00 / 3.50 3.50 / 3.90 4.00 / 4.20 4.70 / 5.00 5.00 / 5.50 6.70 / 8.00 9.00 / 10.00 9.00 / 10.00 10.00 / 12.00 14.00 / 15.00 18.00 / 20.00 20.00 / 22.00 28.00 / 30.00 37.00 / 40.00 54.00 / 60.00 Irms (Amp) Typ. Isat (Amp) Typ. 11.0 9.0 6.0 3.8 12.0 9.0 7.0 4.5 4.0 3.0 2.5 8.5 7.0 6.5 6.0 5.5 5.0 11.0 3.0 18.0 12.0 11.0 9.0 7.0 6.0 6.0 3.5 3.5 9.0 8.0 5.5 4.5 4.0 32.5 24.0 23.0 21.0 20.0 17.5 16.5 15.5 13.0 11.0 11.0 10.0 9.0 8.0 7.0 6.0 5.5 4.5 *Test Condition@100KHz,1.0Vrms, 25oC Ambient * Isat: Saturated Current measured at the point of L drop approximately 20% [ N / F TYPE ] Saturated Current measured at the point of L drop approximately 30% [ S TYPE ] * Irms: Rated Current Loading when temperature rise approximately 40oC * The parts final operating temperature (Ambient+The parts temperature rise) should not exceed 125oC if under worst case of conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part Part temperature should be verified in the end application. * All test data is referenced to 25o C Ambient. GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw 30.0 17.0 11.5 8.5 22.0 12.5 9.5 7.0 6.0 5.0 4.0 14.0 11.0 11.0 10.0 9.0 7.0 10.0 5.0 45.0 22.0 18.0 17.0 14.0 13.0 13.0 10.0 5.0 11.5 10.0 6.5 6.0 5.5 60.0 41.0 40.0 39.0 30.0 26.0 25.5 25.0 24.0 22.0 22.0 20.0 18.0 14.0 14.0 13.5 10.0 8.0 operating temperature. Page: 4 Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 5 Electrical Characteristics : Part No. GSTC104 P-R15MN GSTC104 P-R19MN GSTC104 P-R36MN GSTC104 P-R22MN GSTC104 P-R39MN GSTC104 P-R41MN GSTC104 P-R45MN GSTC104 P-R47MN GSTC104 P-R56MN GSTC104 P-R68MN GSTC104 P-R88MN GSTC104 P-1R0MN GSTC104 P-1R5MN GSTC104 P-2R2MN GSTC104 P-4R7MN GSTC104 P-3R3MS GSTC133 P-R22MF GSTC133 P-R33MF GSTC133 P-R39MF GSTC133 P-R47MF GSTC133 P-R56MF GSTC133 P-R62MF GSTC133 P-R68MF GSTC133 P-1R0MF GSTC133 P-1R5MF GSTC133 P-2R2MF GSTC133 P-3R3MF GSTC133 P-4R7MF GSTC135 P-R15MF GSTC135 P-R36MF GSTC135 P-R47MF GSTC135 P-R50MF GSTC135 P-R56MF GSTC135 P-R62MF GSTC135 P-R68MF GSTC135 P-R82MF GSTC135 P-1R0MF GSTC135 P-1R2MF GSTC135 P-1R5MF GSTC135 P-2R2MF GSTC135 P-3R3MF GSTC135 P-4R7MF GSTC135 P-6R3MF GSTC135 P-6R8MF Inductance L(uH) +/- 20% 0.15 0.19 0.36 0.22 0.39 0.41 0.45 0.47 0.56 0.68 0.88 1.00 1.50 2.20 4.70 3.30 0.22 0.33 0.39 0.47 0.56 0.62 0.68 1.00 1.50 2.20 3.30 4.70 0.15 0.36 0.47 0.50 0.56 0.62 0.68 0.82 1.00 1.20 1.50 2.20 3.30 4.70 6.30 6.80 RDC (m ohm) [ Typ ] / [ Max ] 0.50 / 0.65 0.70 / 0.80 1.05 / 1.20 0.90 / 1.00 1.10/1.30 1.10 / 1.30 1.10 / 1.30 1.60 / 1.80 1.60 / 1.80 2.40 / 2.70 2.70 / 3.00 3.00 / 3.30 3.80 / 4.20 6.70 / 7.00 15.00 / 16.50 10.80 / 11.80 1.10 / 1.30 1.30 / 1.50 1.10 / 1.30 1.70 / 2.00 1.80 / 2.20 1.80 / 2.20 2.30 / 2.50 3.30 / 3.50 5.10 / 5.50 7.20 / 8.0 10.0 / 12.0 16.0 / 18.0 0.55 / 0.70 0.77 / 1.10 1.10 / 1.30 1.20 / 1.50 1.20 / 1.50 1.50 / 1.70 1.50 / 1.70 1.80 / 2.10 2.10 / 2.50 2.60 / 3.00 3.40 / 4.10 4.60 / 5.50 7.70 / 9.20 12.8 / 15.0 15.4 / 18.5 15.4 / 18.5 Irms (Amp) Typ. Isat (Amp) Typ. 40.0 38.0 30.0 35.0 30.0 30.0 29.0 26.0 25.0 22.0 20.0 18.0 16.0 12.0 9.5 10.0 38.0 36.5 38.0 32.0 29.0 29.0 28.0 24.0 19.0 16.0 12.0 9.0 45.0 41.0 38.0 36.0 36.0 34.0 34.0 31.0 29.0 25.0 23.0 20.0 15.0 12.0 11.0 11.0 75.0 60.0 60.0 60.0 60.0 60.0 45.0 40.0 40.0 39.0 38.0 36.0 33.0 27.0 17.0 16.0 65.0 62.0 65.0 55.0 51.0 51.0 49.0 40.0 35.0 29.0 27.0 22.0 110.0 75.0 65.0 55.0 55.0 54.0 54.0 53.0 50.0 49.0 48.0 32.0 32.0 27.0 21.0 21.0 *Test Condition@100KHz,1.0Vrms, 25oC Ambient * Isat : Saturated Current measured at the point of L drop approximately 20% [ N / F TYPE ] Saturated Current measured at the point of L drop approximately 30% [ S TYPE ] * Irms : Rated Current Loading when temperature rise approximately 40oC * The parts final operating temperature (Ambient+The parts temperature rise) should not exceed 125oC if under worst case of operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. * All test data is referenced to 25o C Ambient. GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page: 5 Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 6 Care note : Care note for Use : (1) Storage Condition : Temperature 25 to 350C, Humidity 45 to 85% RH (2) Use Temperature : a. Minimum Temperature : -550C Ambient temperature of power choke coil. b. Maximum Temperature : +1250C The value of temperature including ambient of the transformer and temperature rise of power choke coil. c. There is not a problem from -550C ~ +1250C in a reliability test. d. However, this is not meant a temperature grade guarantee of UL. (3) Model : When this power choke coil was used in a similar or new product to the original one, sometimes it might be unable to satisfy the specifications due to difference of condition of usage. (4) Drop : If the power choke coil suffered mechanical stress such as drop, characteristics may become poor ( due to damage on coil bobbin, etc. ). Never use such stressed power choke coil. Care note for Safety : (1) Provision to Abnormal Condition : This power choke coil itself does not have any protective function in abnormal condition such as overload, short-circuit and open-circuit conditions, etc. Therefore, it shall be confirmed as the end product that there is no risk of smoking, fire, dielectric withstand voltage, insulation resistance, etc. in abnormal conditions to provide protective devices and /or protection circuit in the end product. (2) Temperature Rise : Temperature rise of power choke coil depends on the installation condition on end products. It shall be confirmed on the actual end product that temperature rise of power choke coil is in the limit of specified temperature class. (3) Dielectric Strength : Dielectric withstanding test with higher voltage than specific value will damage insulating material and shorten its life. (4) Water : This power choke coil must not be used in wet condition by water, coffee or any liquid because insulation strength becomes very low on the condition. (5) Potting : If this power choke coil is potted in some compound, coating material of magnet wire might be occasionally damaged. Please ask us if you intend to pot this power choke coil. (6) Detergent : Please consult our company once in case of this because the confirmation of reliability etc. is needed when the washing medicine is used for the power choke coil. GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page: 6 NO 1 2 3 4 5 6 Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 7 ITEM Dimension 本體相關呎吋 Thermal Shock (Temperature Cycle) 溫度循環試驗 Humidity Resistance 耐濕試驗 HighTemperature 耐熱試驗 Sample Qty/pcs TEST CONDITIONS Actual Size ... 10 o o Temperature : -40 C~+125 C kept stabilized for 30 minutes each Cycle : 100 Cycle ( Power off ) Humidity: 90%~ 95% RH Temperature: 40± 2 o C Test Time: 96± 2 Hours Temperature: 85± 2 o C Testing Time: 96± 2 Hours Temperature: -40 ± 2 C Time: 96± 2 Hours Step Temp Humidity Vibration 振動性試驗 Frequency: 10Hz~50Hz Amplitude: 1.5mm Direction: X,Y,Z Time: 2 Hours each Go through real SMT IR-Reflow.... The profile like our suggest profile. Preheat : 160 ± 10 o C ( 90 sec. ) Peak : 245 ± 5 o C Peak Time : 50 Sec. / up 217 o C Preheat:160 ± 10 o C (90 sec) Solder:Sn/Ag/Cu(Pb Free) Solder Temp.: 260 ± 5 o C Time: 3± 1 seconds Solder Temp. 350 ± 5 o C Flux : Rosin Time : 3± 1 seconds 25± 2 o C 55± 2 o C 25± 2 o C 90~95%RH 95~96%RH 90~95%RH ok 10 Elec. no variation Appearance no deformation ok 10 Time 3.0Hr 5.0Hr 3.0Hr ok 10 o 1 2 3 Meet Spec Result Elec. no variation Appearance no deformation 10 Low Temperature 耐寒試驗 Temperature and Humidity Cycle 溫/濕度循環試驗 Specification 10 Elec. no variation Appearance no deformation Elec. no variation Appearance Elec. no variation Appearance no deformation ok ok ok Cycle: 20 Cycles 7 8 9 10 11 Solderability 焊錫性試驗 Soldering Heat Resistance 耐熱 焊性試驗 Iron Solder Heat Resistance 手焊耐熱試驗 Bending Strength 折斷力試驗 10 x 10 10 10 10 10 Elec. no variation Appearance no deformation Elec. no variation Appearance no deformation Elec. no variation Appearance no deformation Elec. no variation Appearance no deformation ok ok ok ok Elec. no variation Appearance no deformation R : 0.5 10 ok Force : 1Kg / min. 12 Flexure Strength 彎曲試驗 Elec. no variation Appearance no deformation Unit : mm 10 x 20 1.2 2.0 4.5 10 ok 4.5 Solder cream 0.15 mm 13 Must no crack and damage Terminal Strength 推/ 拉力試驗 X Mount on PCB Solder Cream 0.15 mm Push 10N force to X , Y direction 10 ok Y 14 High-Voltage 高壓電擊試驗 100 V DC Between core & winding 15 ORT:on going reliability test 負載電氣試驗 Temperature. : 25 ± 3 o C Load : Allowed DC Current Test Time : 96 ± 2 Hr 10 10 GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Elec. no variation Appearance no deformation There should be no evidence of short or open circle ok ok Page: 7 Product Series Code GSTC Brand GOTREND File Version GSTC-V6R5 Editor Teddy Established Date 2009.09.01 Description High Current Inductor Latest Edit Date 2016.06.28 Pages Page : 8 TAPE DIMENSION: mm End the Tape : Min. 30 cm Blank Tape 4.0+/-0.1 2.0+/-0.05 T+/-0.05 Direction Start the Tape : Min. 30cm Blank Tape 1.75+/-0.1 PEEL STRENGTH OF COVER TAPE W+/-0.2 STRENGTH : 10~100 g B0+/-0.1 F+/-0.05 P+/-0.1 SIZE/mm 252012 042 053 061 063 104 133 135 W 8.00 12.00 16.00 16.00 16.00 24.00 24.00 24.00 A0+/-0.1 P 4.00 8.00 12.00 12.00 12.00 16.00 16.00 16.00 Reel Dimensions: mm K0+/-0.1 AO 2.27 4.20 5.20 7.00 7.00 10.60 13.50 13.50 CARRIER VELOCITY : 300mm/min. o ANGLE BO 2.74 4.50 5.50 7.50 7.50 12.00 14.20 14.20 : 165~180 FROM THE TAPE ADHESIVE FACE KO 1.40 2.50 3.75 2.55 3.60 4.50 3.85 5.20 T 0.23 0.30 0.30 0.30 0.30 0.35 0.35 0.35 F 3.50 5.50 7.50 7.50 7.50 11.50 11.50 11.50 C [Max] [ Reel Color 7"=White , 13"=Dark Blue ] +/-0.75 QC OK MFD :XXXXX-XXXXX PN :XXX XXXXXX QTY :XXXXX Note :XXXXXXXX A B+/-0.5 Cucstomer Label: PN: BarCode: PO: Descriptin: ...........etc. Request Labeled on Reel D+/-0.2 SIZE / mm 252012 042 053 061 063 104 133 135 A 180 330 330 330 330 330 330 330 B 60 100 100 100 100 100 100 100 C 12 21 21 21 21 28 28 28 BOX Package: Unit: cm D 9 16.5 16.5 16.5 16.5 25 25 25 REEL SIZE 7” 13” 13” 13” 13” 13” 13” 13” QTY/REEL 3000 PCS 2000 PCS 1000 PCS 1000 PCS 1000 PCS 500 PCS 500 PCS 500 PCS 3 Inner Small Box in 4 Reel in 36 34 36 34 7.5 Inner Small Box Size Box ALL SIZE 25 Outter Large Box Reels in Small Box 2 GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Small Box in Large Box 5 Page: 8
GSTC104P-1R5MN 价格&库存
很抱歉,暂时无法提供与“GSTC104P-1R5MN”相匹配的价格&库存,您可以联系我们找货
