GSBS74P-100M
GSBS74P-100M
    GOTREND(高创)
    SMD,7.4x7.4mm
    10UH ±20%
GSBS74P-100M 数据手册
Product Series Code GSBS Brand GOTREND File Version GSBS-V3R9 Editor Teddy Established Date 2009.06.10 Description SMD Drum Choke with Shielding Latest Edit Date 2017.07.27 Pages Page : 2 Product Structure ▼ Features & Application: * Drum Choke with Shielding for good in EMI performance. ▼ DIP SMD Unshield Shield * Fit for power line & signal line circuit * To help you go pass the CE/FCC standard. 2005 RoHS Compliant - SGS Certified Result * Mobile Device / Handheld Device / LowProfile Device / Panel... 鉛 Pb 75% Go through real SMT IR-Reflow.... Solder Temp.: 230± 5 o C Time: 90 Sec. Cycles: x 1 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok Preheat:120 ~ 150 o C (6 sec) Solder:H63A(eutectic solder) Solder Temp.: 260 ± 5 o C Flux: Rosin Dip time: 10± 1 seconds 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok 10 After solder between copper plate and terminals of coil, push in two directions of X,Y with 2.0kg must no crack ok ITEM TEST CONDITIONS Actual Size ... 2 Dimension 本體相關呎吋 Thermal Shock (Temperature Cycle) 溫度循環試驗 3 Humidity Resistance 耐濕試驗 4 HighTemperature 耐熱試驗 5 Low Temperature 耐寒試驗 Temperature and Humidity Cycle 溫/濕度循環試驗 1 6 7 Vibration 振動性試驗 8 Dipping Verification 吃錫性試驗 9 IR Reflow Soldering 焊錫性試驗 10 Soldering Heat Resistance 耐熱 焊性試驗 11 Bending Strength 折斷力試驗 1 2 3 25± 2 o C 55± 2 o C 25± 2 o C Sample Qty/pcs Time 95~100%RH 95~96%RH 95~100%RH 3.0Hr 9.5Hr 9.5Hr 10 R 0.5 P Chip A 12 Flexure Strength 彎曲試驗 1.6 2 0 2 4 5 13 Terminal Strength 推/ 拉力試驗 4 5 X Y 14 High-Voltage 高壓電擊試驗 100 V DC between core & winding 10 Elec. no variation Appearance no deformation ok 15 ORT:on going reliability test 負載電氣試驗 Elec loading & spec test... base on Spec for approval 10 Elec. no variation Appearance no deformation ok GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page :6 Product Series Code GSBS Brand GOTREND File Version GSBS-V3R9 Editor Teddy Established Date 2009.06.10 Description SMD Drum Choke with Shielding Latest Edit Date 2017.07.27 Pages Page : 7 TAPE DIMENSION: mm End the Tape : Min. 30 cm Blank Tape 4.0+/-0.1 2.0+/-0.05 T+/-0.05 330 Direction Start the Tape : Min. 30cm Blank Tape 1.75+/-0.1 PEEL STRENGTH OF COVER TAPE W+/-0.2 STRENGTH : 10~100 g B0+/-0.1 F+/-0.05 P+/-0.1 SIZE/mm 63 73 74 104 126 127 128 W 12.00 16.00 16.00 24.50 16.00 16.00 16.00 P 12.00 12.00 12.00 16.00 16.00 16.00 16.00 Reel Dimensions: mm A0+/-0.1 K0+/-0.1 AO 6.20 7.50 7.50 11.00 13.05 13.05 13.05 CARRIER VELOCITY : 300mm/min. ANGLE BO 6.20 7.50 7.50 11.00 13.05 13.05 13.05 o : 165~180 FROM THE TAPE ADHESIVE FACE KO 3.25 3.20 4.30 4.30 6.20 7.20 8.20 T 0.35 0.35 0.35 0.40 0.40 0.40 0.40 F 5.50 7.50 7.50 11.50 7.50 7.50 7.50 C [Max] [ Reel Color 7"=White , 13"=Dark Blue ] +/-0.75 QC OK MFD :XXXXX-XXXXX PN :XXX XXXXXX QTY :XXXXX Note :XXXXXXXX A B+/-0.5 Cucstomer Label: PN: BarCode: PO: Descriptin: ...........etc. Request Labeled on Reel D+/-0.2 SIZE / mm 63 73 74 104 126 127 128 A 330 330 330 330 330 330 330 B 100 100 100 100 100 100 100 BOX Package: Unit: cm 73/74 2 Reel in -104 34 C 14 22 22 30 30 30 30 D 12.5 16.5 16.5 24.5 24.5 24.5 24.5 REEL SIZE 13” 13” 13” 13” 13” 13” 13” QTY/REEL 1.50K 1.00K 1.00K 0.75K 0.50K 0.50K 0.50K 5 Inner Small Box in 1 Reel in 25 4.5 36 34 36 Inner Small Box GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Outter Large Box Page :7
GSBS74P-100M 价格&库存
很抱歉,暂时无法提供与“GSBS74P-100M”相匹配的价格&库存,您可以联系我们找货
