电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
GTC1005P-18NJ
GTC1005P-18NJ
    GOTREND(高创)
    固定电感器
GTC1005P-18NJ 数据手册
Product Series Code GTC Brand GOTREND File Version GTC-V3R4 Editor Teddy Established Date 2009.05.22 Description Multilayer Ceramic High-Frequency Inductor Latest Edit Date 2017.07.11 Pages Page : 2 Features & Application: * High Frequency SRF up to 10GHz Product Structure ▼ ▼ DIP SMD Unshield Shield * Fit for 2.4GHz / 5GHz....etc. RF circuit * To help you go pass the CE/FCC standard. 2005 RoHS Compliant - SGS Certified Result * Mobile Device / Handheld Device / LowProfile Device / Panel... 鉛 Pb 17000 >17000 >17000 8000 6000 6000 8600 6500 6300 5400 4600 4500 3800 3700 3200 2900 2100 2100 2000 1600 1500 1200 1100 1050 1050 850 750 700 650 550 450 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.12 0.14 0.16 0.18 0.22 0.24 0.26 0.28 0.32 0.35 0.40 0.45 0.55 0.60 0.70 0.75 0.85 0.85 1.00 1.20 2.30 2.40 2.70 3.00 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 250 Page: 4 Part No. GTC2012P-1N0S GTC2012P-1N2S GTC2012P-1N5S GTC2012P-1N8S GTC2012P-2N2S GTC2012P-2N7S GTC2012P-3N3 GTC2012P-3N9 GTC2012P-4N7 GTC2012P-5N6 GTC2012P-6N8 GTC2012P-8N2 GTC2012P-10N GTC2012P-12N GTC2012P-15N GTC2012P-18N GTC2012P-22N GTC2012P-27N GTC2012P-33N GTC2012P-39N GTC2012P-47N GTC2012P-56N GTC2012P-68N GTC2012P-82N GTC2012P-R10 GTC2012P-R12 GTC2012P-R15 GTC2012P-R18 GTC2012P-R22 GTC2012P-R27 GTC2012P-R33 GTC2012P-R39 GTC2012P-R47 GTC2012P-R56 GTC2012P-R68 Product Series Code GTC Brand GOTREND File Version GTC-V3R4 Editor Teddy Established Date 2009.05.22 Description Multilayer Ceramic High-Frequency Inductor Latest Edit Date 2017.07.11 Pages Page : 5 L - Value (nH) @100MHz 0.25V 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10.0 12.0 15.0 18.0 22.0 27.0 33.0 39.0 47.0 56.0 68.0 82.0 100.0 120.0 150.0 180.0 220.0 270.0 330.0 390.0 470.0 560.0 680.0 Q Typcial @ Tolerance of L.value Q @100MHz (Min.) 100MHz +/-0.3nH +/-0.3nH +/-0.3nH +/-0.3nH +/-0.3nH +/-0.3nH S/K S/K S/K S/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K J/K 10 10 10 10 10 12 12 12 12 12 15 15 15 15 15 15 15 15 15 18 18 18 18 18 18 13 @50MHz 13 @50MHz 13 @50MHz 12 @50MHz 12 @50MHz 12 @50MHz 10 @50MHz 10 @50MHz 10 @50MHz 10 @50MHz 12 12 13 13 13 13 15 15 15 15 15 15 16 16 17 17 17 18 19 21 21 21 21 22 23 22 22 23 20 20 22 17 17 17 17 800MHz S.R.F (MHz) Ref. DCR (ohm) Max. IDC (mA) Max. 38 38 40 45 48 40 56 54 50 53 51 53 45 48 48 43 47 38 35 40 38 31 28 25 25 25 24 23 22 22 20 20 20 20 20 >6000 >6000 >6000 >6000 >6000 >6000 >6000 5600 5500 4700 3900 3200 3100 2800 2400 2100 2000 1800 1700 1400 1200 1000 900 900 700 600 500 430 400 340 320 270 250 230 180 0.10 0.10 0.10 0.10 0.10 0.12 0.13 0.15 0.20 0.23 0.25 0.28 0.30 0.35 0.40 0.45 0.50 0.55 0.60 0.65 0.70 0.75 0.80 0.85 0.90 0.95 1.00 1.10 1.20 1.30 1.50 1.60 1.80 2.50 3.00 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 GOTREND Technology Co., Ltd. TEL : 886-2-82271808 FAX : 886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page: 5 Product Series Code GTC Brand GOTREND File Version GTC-V3R4 Editor Teddy Established Date 2009.05.22 Description Multilayer Ceramic High-Frequency Inductor Latest Edit Date 2017.07.11 Pages Page : 6 Reliability Test Result : NO 1 ITEM Thermal Shock (Temperature Cycle) 溫度循環試 2 Humidity Resistance 耐濕試 3 HighTemperature 耐熱試 4 Low Temperature 耐寒試 Temperature and Humidity Cycle 溫/濕度循環試 5 6 Vibration 振動性試 7 IR Reflow Soldering 焊錫性試 8 Soldering Heat Resistance 耐熱 焊性試 9 Bending Strength 折斷力試 TEST CONDITIONS REMARKS Temperature:-40 o C/ +125 o C kept stabilized for 30 minutes each Inductance value shall be within ± 10% of the initial value. Q-factor shall be within ± 30% of the initial value. Impedance shall be within ± 20% of the initial value. DCR value shall be within ± 20% of the initial value. Cycle: 100 Cycles Humidity: 90%~ 95% RH Temperature: 40± 2 o C Test Time: 1000± 12 Hours Temperature: 85± 2 o C Humidity: 20% Testing Time: 1000± 12 Hours Temperature: -40 ± 2 o C Time: 1000± 12 Hours Step 1 2 3 Temp 25± 2 o C 55± 2 o C 25± 2 o C ■NO.1~4 Measurement:After placing for 24 hours (min.) ■NO.2~3 Applied current(spec): Rated current(maximum value) Humidity Time 3.0Hr 9.5Hr 9.5Hr 95~100%RH 95~96%RH 95~100%RH Frequency: 10Hz~55Hz Amplitude: 1.5mm Direction: X,Y,Z Time: 2 Hours each Solder: H63A(eutectic solder) Solder Temp.: 230± 5 o C Time: 6 minutes Cycles: x 1 Impedance(inductance) shall be within ± 20% of the initial value. DCR value shall be within ± 20% of the initial value. Preheat:120 ~ 150 o C (60 sec) Solder:H63A(eutectic solder) Solder Temp.: 260 ± 5 o C Flux: Rosin Dip time: 10± 1 seconds The chip must have no cracks.More than 75% of the terminal electrode must be covered with solder. The terminal electrode and the ferrite must not be damaged by the forces applied on the test conditions. 10 R 0.5 P Chip 1005: ≧ 2.5 kg 1608: ≧ 3.0 kg 2012: ≧ 3.5 kg A 10 ■NO.5 Cycle: 5 cycles Flexure Strength 彎曲試 No mechanical damage shall be noticed even when the board is bent 2 mm 20 1.6 2 45 11 Terminal Strength 拉力試 45 w The terminal electrode and the ferrite must not be damaged by the forces applied on the test conditions. 1005: ≧ 1.0 kg GOTREND Technology Co., Ltd. TEL : 886-2-82271808 FAX : 886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw 1608: ≧ 1.5 kg 2012: ≧ 2.0 kg Page: 6 Product Series Code GTC Brand GOTREND File Version GTC-V3R4 Editor Teddy Established Date 2009.05.22 Description Multilayer Ceramic High-Frequency Inductor Latest Edit Date 2017.07.11 Pages Page : 7 TAPE DIMENSION: mm End the Tape : Min. 30 cm Blank Tape 4.0+/-0.1 2.0+/-0.05 T+/-0.05 Direction Start the Tape : Min. 30cm Blank Tape 1.75+/-0.1 PEEL STRENGTH OF COVER TAPE W+/-0.2 STRENGTH : 10~100 g B0+/-0.1 F+/-0.05 P+/-0.1 SIZE/mm 1005 1608 2012 W 8.00 8.00 8.00 P 2.00 4.00 4.00 Reel Dimensions: mm A0+/-0.1 ANGLE K0+/-0.1 AO 0.60 1.00 1.60 CARRIER VELOCITY : 300mm/min. BO 1.15 1.90 2.25 o : 165~180 FROM THE TAPE ADHESIVE FACE KO 0.70 1.05 1.15 T 0.35 0.35 0.35 F 3.50 3.50 3.50 C [Max] [ Reel Color 7"=White , 13"=Dark Blue ] +/-0.75 QC OK MFD :XXXXX-XXXXX PN :XXX XXXXXX QTY :XXXXX Note :XXXXXXXX A B+/-0.5 Cucstomer Label: PN: BarCode: PO: Descriptin: ...........etc. Request Labeled on Reel D+/-0.2 SIZE / mm 1005 1608 2012 A 178 178 178 BOX Package:cm 5 Reel in B 60 60 60 C 12 12 12 D 1.5 1.5 1.5 REEL SIZE 7” 7” 7” QTY/REEL 10K 4K 4K 5 Inner Small Box in 21 22 21.5 20 42 21 8 Inner Small Box 40 Inner Medium Box 41 Outter Large Box GOTREND Technology Co., Ltd. TEL : 886-2-82271808 FAX : 886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page: 7
GTC1005P-18NJ 价格&库存
很抱歉,暂时无法提供与“GTC1005P-18NJ”相匹配的价格&库存,您可以联系我们找货
