Product Series Code
GDO
Brand
GOTREND
File Version
GDO-V3R0
Editor
Teddy
Established Date
2009.08.04
Description
Ferrite Core With Plastic Base
Inductor
Latest Edit Date
2013.02.23
Pages
Page : 2
Features & Application:
Product Structure
DIP
SMD
* High-Current SMT Drum Choke for PWM circuit
Unshield
Shield
* Fit for power line & signal line circuit
* To help you go pass the CE/FCC standard.
2005 RoHS Compliant - SGS Certified Result
* Mobile Device / Handheld Device / LowProfile Device / Panel...
鉛
Pb
75%
Go through real SMT IR-Reflow....
Solder Temp.: 230± 5 o C
Time: 90 Sec. Cycles: x 1
10
Elec. no variation
Appearance
no deformation
ok
10
Elec. no variation
Appearance
no deformation
ok
10
Elec. no variation
Appearance
no deformation
ok
Preheat:120 ~ 150 o C (6 sec)
Solder:H63A(eutectic solder)
Solder Temp.: 260 ± 5 o C
Flux: Rosin
Dip time: 10± 1 seconds
10
Elec. no variation
Appearance
no deformation
ok
10
Elec. no variation
Appearance
no deformation
ok
ITEM
TEST CONDITIONS
Actual Size ...
2
Dimension
本體相關呎吋
Thermal Shock
(Temperature Cycle)
溫度循環試驗
3
Humidity Resistance
耐濕試驗
4
HighTemperature
耐熱試驗
5
Low Temperature
耐寒試驗
Temperature and
Humidity Cycle
溫/濕度循環試驗
1
6
7
Vibration
振動性試驗
8
Dipping Verification
吃錫性試驗
9
IR Reflow Soldering
焊錫性試驗
10
Soldering Heat
Resistance
耐熱 焊性試驗
11
Bending Strength
折斷力試驗
1
2
3
25± 2 o C
55± 2 o C
25± 2 o C
Sample
Qty/pcs
Time
95~100%RH
95~96%RH
95~100%RH
3.0Hr
9.5Hr
9.5Hr
10
R 0.5
P
Chip
>3KG
A
12
Flexure Strength
彎曲試驗
10
Elec. no variation
Appearance
no deformation
ok
10
After solder between copper plate and
terminals
of coil, push in two directions of X,Y with
2.0kg
must no crack
ok
1.6
2 0
2
4 5
13
Terminal Strength
推/ 拉力試驗
4 5
X
Y
14
High-Voltage
高壓電擊試驗
100 V DC between core & winding
10
Elec. no variation
Appearance
no deformation
ok
15
reliability test
負載電氣試驗
Elec loading & spec test...
base on Spec for approval
10
Elec. no variation
Appearance
no deformation
ok
GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908
http://www.gotrend.com.tw E.mail: service@gotrend.com.tw
Page: 5
Product Series Code
GDO
Brand
GOTREND
File Version
GDO-V3R0
Editor
Teddy
Established Date
2009.08.04
Description
Inductor
Latest Edit Date
2013.02.23
Pages
Page : 6
TAPE DIMENSION: mm
End the Tape : Min. 30 cm Blank Tape
4.0+/-0.1
2.0+/-0.05
T+/-0.05
680
Direction
Start the Tape : Min. 30cm Blank Tape
1.75+/-0.1
PEEL STRENGTH OF COVER TAPE
W+/-0.2
STRENGTH : 10~100 g
B0+/-0.1
F+/-0.05
P+/-0.1
SIZE/mm
0402
0802
0804
0810
1306
W
16.00
24.00
24.00
24.00
32.00
P
8.00
12.00
12.00
12.00
20.00
Reel Dimensions: mm
A0+/-0.1
AO
4.80
9.65
9.65
9.50
15.80
CARRIER
VELOCITY : 300mm/min.
K0+/-0.1
ANGLE
BO
7.20
13.80
13.80
13.80
19.20
o
: 165~180 FROM THE TAPE ADHESIVE FACE
KO
3.30
3.50
6.50
11.80
8.50
T
0.35
0.35
0.35
0.50(+/-0.01)
0.35
F
11.50
11.50
11.50
11.50
11.50
C [Max]
[ Reel Color 7"=White , 13"=Dark Blue ]
+/-0.75
QC OK
MFD :XXXXX-XXXXX
PN :XXX XXXXXX
QTY :XXXXX
Note :XXXXXXXX
A
B+/-0.5
Cucstomer Label:
PN:
BarCode:
PO:
Descriptin:
...........etc. Request
Labeled on Reel
D+/-0.2
SIZE / mm
0402
0802
0804
0810
1306
A
178/330
330
330
330
330
B
50
50
50
50
50
C
22.4
26.4
26.4
26.4
30.4
D
18
22
22
22
26
REEL SIZE
7” / 13”
13”
13”
13”
13”
BOX Package ( Reel 7" ) : Unit: cm
BOX Package ( Reel 13" ) : Unit: cm
0402 - 5 Reel in
0402-2 Reel in
0802/0804/0810/1306-1 Reel in
5 Inner Small Box in
QTY/REEL
0.7K / 2.5K
1.0K
1.0K
0.35K
0.25K
4 2
19
19
34
25
4.5
36
34
Inner Small Box
Inner Mediu Box
Inner Small Box
36
Outer Large Box
Page: 6
很抱歉,暂时无法提供与“GDO0402P-1R0M”相匹配的价格&库存,您可以联系我们找货
