GSSR2-104P-4R7N
GSSR2-104P-4R7N
    GOTREND(高创)
    IND_10X10MM_SM
    功率电感 SMD,10x10x3.8mm
GSSR2-104P-4R7N 数据手册
Product Series Code GSSR2 Brand GOTREND File Version GSSR2-V5R0 Editor Teddy Established Date 2009.08.27 Description SMD Power Choke Latest Edit Date 2016.12.05 Pages Page : 2 Product Structure ▼ Features & Application: * Shielding for good in EMI and LowProfile for large current ▼ DIP SMD Unshield Shield * Fit for power line & signal line circuit * To help you go pass the CE/FCC standard. 2005 RoHS Compliant - SGS Certified Result * Mobil Device / Handheld Device / LowProfile Device / Panel... 鉛 Pb 75% Go through real SMT IR-Reflow.... Solder Temp.: 230± 5 o C Time: 90 Sec. Cycles: x 1 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok Preheat:120 ~ 150 o C (6 sec) Solder:H63A(eutectic solder) Solder Temp.: 260 ± 5 o C Flux: Rosin Dip time: 10± 1 seconds 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok 10 Elec. no variation Appearance no deformation ok 10 After solder between copper plate and terminals of coil, push in two directions of X,Y with 2.0kg must no crack ok ITEM TEST CONDITIONS Actual Size ... 2 Dimension 本體相關呎吋 Thermal Shock (Temperature Cycle) 溫度循環試驗 3 Humidity Resistance 耐濕試驗 4 HighTemperature 耐熱試驗 5 Low Temperature 耐寒試驗 Temperature and Humidity Cycle 溫/濕度循環試驗 1 6 7 Vibration 振動性試驗 8 Dipping Verification 吃錫性試驗 9 IR Reflow Soldering 焊錫性試驗 10 Soldering Heat Resistance 耐熱 焊性試驗 11 Bending Strength 折斷力試驗 1 2 3 25± 2 o C 55± 2 o C 25± 2 o C Sample Qty/pcs Time 95~100%RH 95~96%RH 95~100%RH 3.0Hr 9.5Hr 9.5Hr 10 R 0.5 P Chip A 11 Flexure Strength 彎曲試驗 1.6 2 0 2 4 5 12 Terminal Strength 推/ 拉力試驗 4 5 X Y 13 High-Voltage 高壓電擊試驗 100 V DC between core & winding 10 Elec. no variation Appearance no deformation ok 14 ORT:on going reliability test 負載電氣試驗 Elec loading & spec test... base on Spec for approval 10 Elec. no variation Appearance no deformation ok GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page 4 Product Series Code GSSR2 Brand GOTREND File Version GSSR2-V5R0 Editor Teddy Established Date 2009.08.27 Description SMD Power Choke Latest Edit Date 2016.12.05 Pages Page : 5 TAPE DIMENSION: mm End the Tape : Min. 30 cm Blank Tape 4.0+/-0.1 2.0+/-0.05 T+/-0.05 Direction Start the Tape : Min. 30cm Blank Tape 1.75+/-0.1 PEEL STRENGTH OF COVER TAPE W+/-0.2 STRENGTH : 10~100 g B0+/-0.1 F+/-0.05 P+/-0.1 SIZE/mm 104 W 24.00 P 16.00 A0+/-0.1 AO 10.70 CARRIER VELOCITY : 300mm/min. K0+/-0.1 o ANGLE BO 10.70 : 165~180 FROM THE TAPE ADHESIVE FACE KO 4.10 Reel Dimensions: mm T 0.35 F 11.50 C [Max] +/-0.75 QC OK MFD :XXXXX-XXXXX PN :XXX XXXXXX QTY :XXXXX Note :XXXXXXXX A B+/-0.5 Cucstomer Label: PN: BarCode: PO: Descriptin: ...........etc. Request Labeled on Reel D+/-0.2 SIZE / mm 104 A 330 B 100 C 28.9 D 24.5 REEL SIZE 13” QTY/REEL 0.8K BOX Package: Unit: cm 1 Reel in 5 Inner Small Box in 340 330 330 38 Inner Small Box 340 220 Outter Large Box GOTREND Technology Co., Ltd. TEL:886-2-82271808 FAX:886-2-82271908 http://www.gotrend.com.tw E.mail: service@gotrend.com.tw Page 5
GSSR2-104P-4R7N 价格&库存
很抱歉,暂时无法提供与“GSSR2-104P-4R7N”相匹配的价格&库存,您可以联系我们找货
