GSOT12C
GSOT12C
    KUU(永裕泰)
    SOT-23
    单向ESD 12V截止 峰值浪涌电流:12A@8/20US
GSOT12C 数据手册
GSOTxxC Features z SOT-23 Package z 2 Unidirectional Transil functions z Peak Power Dissipation 300W @8 x 20 us Pulse z Low Leakage z Fast Response Time < 1 ns z Protects I/O Port z ESD Protection to IEC 61000-4-2 Level 4,15KV(Air), 8KV(Contanct) z 16KV Human Body Model ESD Requirements z RoHS Compliant in Lead-Free Versions SOT-23 1.BASE 2.EMITTER 3.COLLECTOR Applications z Computers z Printers z Communication Systems Absolute Maximum Ratings Symbol Parameter Value Units PPP Peak Pulse Power (tp = 8/20μs) 300 W TL Maximum lead temperature for soldering during 10s 260 °C Tstg Storage Temperature Range -55 to +15 °C Top Operating Temperature Range -40 to +125 °C Tj Maximum junction temperature 150 °C Electrostatic discharge VPP MIL STD 883C -Method 3015-6 25 IEC61000-4-2 air discharge 16 IEC61000-4-2 contact discharge 9 Electrical Characteristics Symbol Parameter VRM Stand-off voltage VBR Breakdown voltage VCL Clamping voltage IRM Leakage current IPP Peak pulse current αT Voltage temperature coefficient VF Forward voltage drop C Capacitance Rd Dynamic resistance 1/3 kv GSOTxxC Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Maximum Minimum Maximum Maximum Leakage Breakdown Clamping Pulse Peak Current Voltage Voltage Current @ VRM 1mA VRM IRM VBR V µA V V Rated Stand-off Part Numbers Marking Maximum Capacitance Voltage 1A 1) 5A 1) tp=8/20us 0v, 1MHz IPPM C V A pF VCL GSOT04C 04C 4.0 3.0 5.0 8.5 10.5 17 300 GSOT05C 05C 5.0 1.0 6.0 9.8 12.5 17 220 GSOT08C 08C 8.0 1.0 8.5 13.4 15.0 15 190 GSOT12C 12C 12.0 1.0 13.3 19.0 28.0 12 150 GSOT15C 15C 15.0 1.0 16.7 24.0 35.0 10 140 GSOT24C 24C 24.0 1.0 26.7 43.0 60.0 5 83 GSOT36C 36C 36.0 1.0 40 60.0 75.0 2 80 1).8/20 waveform used. (see fig2.) Typical Characteristics Fig1. Peak Pulse Power VS Pulse Time Fig2. Pulse Waveform Wa Fig3.Power Derating 2/3 GSOTxxC PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-23 3/3
GSOT12C
1. 物料型号:GSOTxxC系列,包括GSOT04C、GSOT05C、GSOT08C、GSOT12C、GSOT15C、GSOT24C和GSOT36C。
2. 器件简介:这些器件采用SOT-23封装,具有单向瞬态电压抑制功能,能够保护I/O端口,具有低漏电流和快速响应时间。
3. 引脚分配:1.BASE 2.EMITTER 3.COLLECTOR。
4. 参数特性: - 峰值脉冲功率:300W @8 x 20 us脉冲。 - 最大焊接温度:260°C,持续10秒。 - 存储温度范围:-55°C至+150°C。 - 工作温度范围:-40°C至+125°C。 - 最大结温:150°C。 - 静电放电保护:符合IEC 61000-4-2标准,空气放电25kV,接触放电16kV。
5. 功能详解:器件具有保护I/O端口免受静电放电损害的功能,符合人体模型ESD要求。
6. 应用信息:适用于计算机、打印机和通信系统。
7. 封装信息:塑料表面贴装封装,3个引脚,具体尺寸在文档中有详细描述。
GSOT12C 价格&库存
很抱歉,暂时无法提供与“GSOT12C”相匹配的价格&库存,您可以联系我们找货
GSOT12C
  • 20+0.21525
  • 200+0.16859
  • 600+0.14267
  • 3000+0.12302
  • 9000+0.10952
  • 21000+0.10228
库存:2720
