GL6-P4212
GL6-P4212
    SICK
    SENSOR RETROREFLECTIVE 5MM PNP
GL6-P4212 数据手册
Product data sheet GL6-P4212 G6 MINIATURE PHOTOELECTRIC SENSORS GL6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. GL6-P4212 1062110 Included in delivery: P250 (1), BEF-W100-A (1) Other models and accessories www.sick.com/G6 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Functional principle Photoelectric retro-reflective sensor Functional principle detail Dual lens Sensing range max. ≤ 6 m 1) Sensing range ≤ 5 m 1) Polarisation filters Yes Emitted beam Light source PinPoint LED 2) Type of light Visible red light Light spot size (distance) Ø 8 mm (350 mm) Key LED figures Wave length 650 nm Adjustment 1) 2) Potentiometer, 270°  Reflector PL80A.  Average service life: 100,000 h at TU = +25 °C. Safety-related parameters MTTFD 1,705 years DCavg 0 % 2 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GL6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS Electrical data Supply voltage UB 10 V DC ... 30 V DC 1) Ripple ± 10 % 2) Power consumption 30 mA 3) Protection class III Digital output Type PNP Signal voltage PNP HIGH/LOW VS - (≤ 3 V) / approx. 0 V Output current Imax. ≤ 100 mA 4) Response time 24 V, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected. Mechanical data Housing Rectangular Dimensions (W x H x D) 12 mm x 31.5 mm x 21 mm Connection Male connector M8, 4-pin Material Housing Plastic, ABS/PC Front screen Plastic, PMMA Weight 20 g Items supplied Reflector P250, Stainless steel mounting bracket (1.4301/304) BEF-W100-A Ambient data Enclosure rating IP67 Ambient operating temperature –25 °C ... +55 °C 1) Ambient temperature, storage –40 °C ... +70 °C UL File No. NRKH.E348498 & NRKH7.E348498 1)  Temperature stability following adjustment +/-10 °C. Classifications ECl@ss 5.0 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice 27270902 PHOTOELECTRIC SENSORS | SICK 3 GL6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 5.1.4 27270902 ECl@ss 6.0 27270902 ECl@ss 6.2 27270902 ECl@ss 7.0 27270902 ECl@ss 8.0 27270902 ECl@ss 8.1 27270902 ECl@ss 9.0 27270902 ECl@ss 10.0 27270902 ECl@ss 11.0 27270902 ETIM 5.0 EC002717 ETIM 6.0 EC002717 ETIM 7.0 EC002717 ETIM 8.0 EC002717 UNSPSC 16.0901 39121528 Connection type Connection diagram Cd-066 BN 1 WH 2 BU 3 BK 4 4 + (L+) not connected - (M) Q PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GL6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS Characteristic curve GL6 Operating reserve 100 1 10 4 3 5 2 Operatingrange 1 Sensing range max. typ. 1 2 (3.28) (6.56) 3 4 (9.84) (13.12) 5 6 (16.4) (19.69) Distance in m (feet) ①  Reflector PL80A ②  Reflector PL40A ③  Reflector P250 ④  Reflector PL20A ⑤  Reflective tape REF-IRF-56 Light spot size GL6, GL6G Ø 80 mm Ø 130 mm Sensor Ø 8 mm Ø 25 mm 0.35 1.0 3.0 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice 5.0 Distance [m] PHOTOELECTRIC SENSORS | SICK 5 GL6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F Sensing range diagram H I J K L M N O P Q R S T Adjustments GL6, GL6G 1 0.03 0.07 2 3 0.03 0.07 4 5 0.03 0.07 2.2 0.2 0.25 1.6 1.8 5.0 6.0 3.8 4.3 0.03 0.07 3.5 4.0 2.5 2 4 6 8 (6.56) (13.12) (19.69) (26.25) 0 Distance in m (feet) Sensing range Sensing range max. ①  Reflector PL80A ②  Reflector PL40A ③  Reflector P250 ④  Reflector PL20A ⑤  Reflective tape REF-IRF-56 Adjustment possibility 5 4 + – 7 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑦  Sensitivity control: potentiometer 4 9.7 (0.38) 3 (0.12) 5 6 31.5 (1.24) 11.4 25.4 (1.00) 3 28.5 (1.12) 3 L D (0.45) 9.7 7.6 0.5 (0.02) (0.38) 1 2 21 (0.83) (0.30) 0.5 (0.02) Dimensional drawing (Dimensions in mm (inch)) 18.3 12 (0.72) (0.47) ①  Optical axis, receiver ②  Optical axis, sender ③  Mounting holes M3 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑥  Light/ dark rotary switch: L = light switching, D = dark switching 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GL6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS Recommended accessories Other models and accessories www.sick.com/G6 Brief description Type Part no. BEF-WN-G6 2062909 BEF-WN-REFX 2064574 YF8U14050VA3XLEAX 2095889 STE-0804-G 6037323 P250 5304812 Mounting brackets and plates Stainless steel (1.4301) Universal mounting bracket for reflectors, steel, zinc coated Plug connectors and cables Head A: female connector, M8, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M8, 4-pin, straight Head B: Cable: unshielded Reflectors Rectangular, screw connection, 51 mm x 61 mm, PMMA/ABS, Screw-on, 2 hole mounting 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
GL6-P4212 价格&库存
很抱歉,暂时无法提供与“GL6-P4212”相匹配的价格&库存,您可以联系我们找货
GL6-P4212
  • 1+1060.745841+136.93340
  • 5+979.163475+126.40180
