GRTB18S-N241Z
GRTB18S-N241Z
    SICK
    SICK - GRTB18S-N241Z - Photoelectric Sensor, GR18S Series, Background Suppression, 300 mm, NPN, 10 t...
GRTB18S-N241Z 数据手册
Online data sheet GRTB18S-N241Z GR18S PHOTOELECTRIC SENSORS GRTB18S-N241Z | GR18S PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. GRTB18S-N241Z 1076109 Other models and accessories www.sick.com/GR18S Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Sensor/detection principle Photoelectric proximity sensor, Background suppression Housing design (light emission) Cylindrical, straight, fully flush Thread diameter (housing) M18 x 1 Optical axis Axial, fully flush Sensing range max. 3 mm ... 300 mm 1) Sensing range 20 mm ... 150 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 7 mm (100 mm) Wave length 650 nm Adjustment Potentiometer, 270° 1) 2)  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ± 5 Vpp 2) Power consumption ≤ 30 mA 1) 2) 3) 4) 5) 6) 7) 8) 9) 2  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  At Uv > 24 V or ambient temperature > 49 °C, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected.  At Uv
GRTB18S-N241Z 价格&库存
很抱歉,暂时无法提供与“GRTB18S-N241Z”相匹配的价格&库存,您可以联系我们找货
