GTE6-P4211
GTE6-P4211
    SICK
    SICK - GTE6-P4211 - Photo Sensor, 300 mm, PNP, Proximity Diffuse, 10 to 30 VDC, M8 Connector, G6 Ser...
GTE6-P4211 数据手册
Product data sheet GTE6-P4211 G6 MINIATURE PHOTOELECTRIC SENSORS GTE6-P4211 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. GTE6-P4211 1050710 Other models and accessories www.sick.com/G6 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Functional principle Photoelectric proximity sensor Functional principle detail Energetic Sensing range max. ≤ 300 mm 1) Sensing range ≤ 250 mm Polarisation filters No Emitted beam Light source PinPoint LED 2) Type of light Visible red light Light spot size (distance) Ø 7 mm (90 mm) Key LED figures Wave length 650 nm Adjustment 1) 2) Mechanical spindle, 5 turns  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Safety-related parameters MTTFD 1,879 years DCavg 0 % 2 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GTE6-P4211 | G6 MINIATURE PHOTOELECTRIC SENSORS Electrical data Supply voltage UB 10 V DC ... 30 V DC 1) Ripple ± 10 % 2) Power consumption 30 mA 3) Protection class III Digital output Type PNP Signal voltage PNP HIGH/LOW VS - (≤ 3 V) / approx. 0 V Output current Imax. ≤ 100 mA 4) Response time 24 V, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected. Mechanical data Housing Rectangular Dimensions (W x H x D) 12 mm x 31.5 mm x 21 mm Connection Male connector M8, 4-pin Material Housing Plastic, ABS/PC Front screen Plastic, PMMA Weight 20 g Ambient data Enclosure rating IP67 Ambient operating temperature –25 °C ... +55 °C 1) Ambient temperature, storage –40 °C ... +70 °C UL File No. NRKH.E348498 & NRKH7.E348498 1)  Temperature stability following adjustment +/-10 °C. Classifications ECl@ss 5.0 27270903 ECl@ss 5.1.4 27270903 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 GTE6-P4211 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 6.0 27270903 ECl@ss 6.2 27270903 ECl@ss 7.0 27270903 ECl@ss 8.0 27270903 ECl@ss 8.1 27270903 ECl@ss 9.0 27270903 ECl@ss 10.0 27270904 ECl@ss 11.0 27270904 ETIM 5.0 EC001821 ETIM 6.0 EC001821 ETIM 7.0 EC002719 ETIM 8.0 EC002719 UNSPSC 16.0901 39121528 Connection type Connection diagram Cd-066 BN 1 WH 2 BU 3 BK 4 4 + (L+) not connected - (M) Q PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GTE6-P4211 | G6 MINIATURE PHOTOELECTRIC SENSORS Characteristic curve GTE6 Operating reserve 100 10 1 2 1 0 mm 50 (inch) (1.9) 100 150 200 250 300 (3.9) (5.9) (7.9) (9.8) (11.8) ①  Sensing range on white, 90% remission ②  Sensing range on gray, 18 % remission Light spot size GTE6 Ø 5.0 mm Ø 5.5 mm Ø 7.5 mm Sensor Ø 7.5 mm 150 0 200 300 Distance [mm] Sensing range diagram GTE6 1 2 10 15 30 35 0(mm) 300 120 140 100 Sensing range 250 200 300 Sensing range max. ①  Object with 90% remission (based on standard white DIN 5033) ②  Sensing range on gray, 18 % remission 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 GTE6-P4211 | G6 MINIATURE PHOTOELECTRIC SENSORS Adjustments Adjustment possibility 5 4 + – 7 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑦  Sensitivity control: potentiometer Dimensional drawing (Dimensions in mm (inch)) 4 3 (0.12) 9.7 5 6 31.5 (1.24) 11.4 25.4 (1.00) 3 28.5 (1.12) 3 L D (0.45) 9.7 7.6 0.5 (0.02) (0.38) H I J K L M N O P Q R S T 1 2 21 (0.83) (0.30) 0.5 (0.02) A B C D E F (0.38) 18.3 12 (0.72) (0.47) ①  Optical axis, receiver ②  Optical axis, sender ③  Mounting holes M3 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑥  Light/ dark rotary switch: L = light switching, D = dark switching Recommended accessories Other models and accessories www.sick.com/G6 Brief description Type Part no. BEF-WN-G6 2062909 YF8U14050VA3XLEAX 2095889 STE-0804-G 6037323 Mounting brackets and plates Stainless steel (1.4301) Plug connectors and cables Head A: female connector, M8, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M8, 4-pin, straight Head B: Cable: unshielded 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
GTE6-P4211 价格&库存
很抱歉,暂时无法提供与“GTE6-P4211”相匹配的价格&库存,您可以联系我们找货
GTE6-P4211
  • 1+680.67964
库存:97
