GRL18S-P2431
GRL18S-P2431
    SICK
    SICK - GRL18S-P2431 - Photoelectric Sensor, GR18S Series, Retro Reflective, Dual Lens, 7.2 mm, PNP, ...
GRL18S-P2431 数据手册
Online data sheet GRL18S-P2431 GR18S PHOTOELECTRIC SENSORS GRL18S-P2431 | GR18S PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. GRL18S-P2431 1069586 Other models and accessories www.sick.com/GR18S Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Sensor/detection principle Photoelectric retro-reflective sensor, Dual lens Housing design (light emission) Cylindrical, straight Thread diameter (housing) M18 x 1 Optical axis Axial Sensing range max. 0.03 m ... 7.2 m 1) Sensing range 0.06 m ... 6 m 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 175 mm (7 m) Wave length 650 nm Adjustment None 1) 2)  Reflector PL80A.  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ± 5 Vpp 2) Power consumption ≤ 30 mA 1) 2) 3) 4) 5) 6) 7) 8) 9) 2  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  At Uv > 24 V or ambient temperature > 49 °C, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected.  At Uv
GRL18S-P2431 价格&库存
很抱歉,暂时无法提供与“GRL18S-P2431”相匹配的价格&库存,您可以联系我们找货
GRL18S-P2431
  • 1+607.06422
  • 5+594.92169
库存:2
