DOS-2312-G
DOS-2312-G
    SICK
DOS-2312-G 数据手册
DOS-2312-G Product data sheet DOS-2312-G A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. DOS-2312-G 6027538 Other models and accessories www.sick.com/ Detailed technical data Technical specifications Accessory group Plug connectors and cables Accessory family Field-attachable connectors Connection type head A Female connector, M23, 12-pin, straight Connection type Solder connection Locking plug connector Quick screw connection Connector material Zinc die-cast, nickel-plated Connector color Nickel-plated Locking nut material Zinc die-cast, nickel-plated Shielding Shielded Permitted cable diameter 5.5 mm ... 10.5 mm Reference voltage ≤ 160 V Current loading 7 A Signal type HIPERFACE®, SSI, Incremental Enclosure rating IP66/ IP67 Description Head A: female connector, M23, 12-pin, straight, shielded, for cable diameter 5.5 mm ... 10.5 mm Head B: Operating temperature: –20 °C ... +130 °C Ambient operating temperature Head –20 °C ... +130 °C 2 | SICK Product data sheet | 2022-07-30 07:26:40 Subject to change without notice DOS-2312-G Dimensional drawing (Dimensions in mm (inch)) ①  Blue ②  White ③  Yellow ④  Gray ⑤  Green ⑥  Pink ⑦  Black ⑧  Red ⑨  Orange ⑩  Brown ⑪  Purple ⑫  Orange/black 2022-07-30 07:26:40 | Product data sheet  Subject to change without notice | SICK 3 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
DOS-2312-G 价格&库存
很抱歉,暂时无法提供与“DOS-2312-G”相匹配的价格&库存,您可以联系我们找货
DOS-2312-G
    • 1+262.436061+33.66270
    • 5+243.936045+31.28970
    库存:31
