GSE6-P4112
GSE6-P4112
    SICK
    SICK - GSE6-P4112 - Photoelectric Sensor, G6 Series, Through Beam, 15 m, PNP, 10 to 30 Vdc
GSE6-P4112 数据手册
Online data sheet GSE6-P4112 G6 PHOTOELECTRIC SENSORS GSE6-P4112 | G6 PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. GSE6-P4112 1052450 Other models and accessories www.sick.com/G6 Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Sensor/detection principle Through-beam photoelectric sensor Dimensions (W x H x D) 12 mm x 31.5 mm x 21 mm Housing design (light emission) Rectangular Sensing range max. 0 m ... 15 m Sensing range 0 m ... 10 m Type of light Visible red light Light source PinPoint LED 1) Light spot size (distance) Ø 375 mm (12 m) Wave length 650 nm Adjustment None 1)  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ± 10 % 2) Power consumption ≤ 30 mA 3) Output type PNP 1) 2) 3) 4) 5) 6) 7) 8) 9)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Without load.  At Uv > 24 V, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected. 10)  Temperature stability following adjustment +/-10 °C. 2 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2017-07-27 18:43:07 Subject to change without notice GSE6-P4112 | G6 PHOTOELECTRIC SENSORS Switching mode Light/dark switching Switching mode selector Selectable via light/dark selector Signal voltage PNP HIGH/LOW VS - (≤ 3 V) / approx. 0 V Output current Imax. ≤ 100 mA 4) Response time 24 V, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected. 10)  Temperature stability following adjustment +/-10 °C. Classifications ECl@ss 5.0 27270901 ECl@ss 5.1.4 27270901 ECl@ss 6.0 27270901 ECl@ss 6.2 27270901 ECl@ss 7.0 27270901 ECl@ss 8.0 27270901 ECl@ss 8.1 27270901 ECl@ss 9.0 27270901 ETIM 5.0 EC002716 ETIM 6.0 EC002716 UNSPSC 16.0901 39121528 2017-07-27 18:43:07 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 GSE6-P4112 | G6 PHOTOELECTRIC SENSORS A B C D E F Adjustments possible No adjustment possibility 5 4 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam Connection diagram Cd-057 2 1 brn 1 H I J K L M N O P Q R S T wht 2 blu 3 blk 4 + (L+) not connected brn 1 wht 2 blu 3 - (M) not connected blk 4 + (L+) not connected - (M) Q ①  Sender ②  Receiver Characteristic curve GSE6 Function reserve 1,000 100 10 Operating range 1 4 mm 4,000 8,000 12,000 16,000 (inch) (157.48) (314.96) (472.44) (629.92) PHOTOELECTRIC SENSORS | SICK Online data sheet | 2017-07-27 18:43:07 Subject to change without notice GSE6-P4112 | G6 PHOTOELECTRIC SENSORS Light spot size GSE6 Ø 7.5 mm Ø 130 mm Ø 480 mm Sensor Ø 310 mm Ø 250 mm 4 0 8 10 15 Distance [m] Sensing range diagram GSE6 0 10.0 0(m) 4.0 15.0 8.0 Sensing range 16.0 12.0 Sensing range max. 21 (0.83) 0.5 (0.02) 28.5 (1.12) 3 (0.12) 9.7 6 31.5 (1.24) 11.4 3 5 L D (0.45) 25.4 (1.00) (0.30) 9.7 4 3 (0.38) 1 2 7.6 0.5 (0.02) Dimensional drawing (Dimensions in mm (inch)) (0.38) 18.3 12 (0.72) (0.47) ①  Optical axis, receiver ②  Optical axis, sender ③  Mounting holes M3 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑥  Light/ dark rotary switch: L = light switching, D = dark switching Recommended accessories Other models and accessories www.sick.com/G6 Brief description Type Part no. BEF-KHS-ISG6 2075080 Universal bar clamp systems Clamp bar to fix G6 sensors on rods of 10 mm, clamp-on design up to 4 mm wall thickness, aluminum (clamp bar), stainless steel (bracket), clamp bar for 10 mm rod mounting and clamp function, mounting bracket, mounting hardware 2017-07-27 18:43:07 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 GSE6-P4112 | G6 PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Brief description Type Part no. BEF-SG-G6 2069044 BEF-WN-G6 2062909 Head A: female connector, M8, 4-pin, straight Head B: cable Cable: PVC, unshielded, 2 m DOL-0804-G02M 6009870 Head A: female connector, M8, 4-pin, straight Head B: cable Cable: PVC, unshielded, 5 m DOL-0804-G05M 6009872 Head A: female connector, M8, 4-pin, angled Head B: cable Cable: PVC, unshielded, 2 m DOL-0804-W02M 6009871 Head A: female connector, M8, 4-pin, angled Head B: cable Cable: PVC, unshielded, 5 m DOL-0804-W05M 6009873 Head A: female connector, M8, 4-pin, straight Head B: Cable: unshielded DOS-0804-G 6009974 Head A: female connector, M8, 4-pin, angled Head B: Cable: unshielded DOS-0804-W 6009975 Head A: male connector, M8, 4-pin, straight Head B: Cable: unshielded STE-0804-G 6037323 BEF-SLIT MASK-G6 2075254 Device protection (mechanical) Stainless steel 1.4301 (SVS 304), 3 mm thick protective sleeve for G6, stainless steel 1.4301, mounting hardware included Mounting brackets and plates Plug connectors and cables Masks Slit mask, vertical slots, slot width: 1.0 mm, 2 pieces, black, Aluminum, Slit mask (2 pieces) 6 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2017-07-27 18:43:07 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
GSE6-P4112 价格&库存
很抱歉,暂时无法提供与“GSE6-P4112”相匹配的价格&库存,您可以联系我们找货
